Dear TI,
I have omapl138 evaluation board, I want to perform complex vector multiplication in DSP core (C6748), but in the dsp lib, I find the real vector multiplication. I program a function that performs complex vector multiplication, it seems very slow. Could you tell me how to perfom complex vector multiplication fastly and efficiently? Thank you very much.
Yuehai Zhou
Hi Yuehai,
In the link below, we may find the performance of few DSPLIB and MATH LIB functions for OMAPL138/C6748. https://www.ti.com/microcontrollers-mcus-processors/processors/digital-signal-processors/core-benchmarks/core-benchmarks.html
Please do check for your required function. Let me also check.... mean while.
The below doc has the list of DSPLIB functions for C674x.
Shankari G
Hi Yuehai,
I see dsp lib supporting "DSPF_sp_dotp_cplx". Is this something you can use for your need?
Also, please note that you can speed up the implementation which you had done in "C" with the help of "intrinsic" which can help the compilers to schedule the code in best possible ways to get an optimal implementation.
Here is the link for the Optimizing Compiler guide
https://www.ti.com/lit/ug/sprui04b/sprui04b.pdf
Also, it may be better to consider to keep the buffers in internal memory and have Cache enabled to speed up the execution time.
Thanks.
