Other Parts Discussed in Thread: DRA821
I am using meta-ti(zeus branch) in my own Yocto distro. I am aiming to build images for DRA821U device. Is j7-evm.conf appropriate for DRA821U?
Raxesh
Hi Raxesh,
For DRA821, please use j7200-evm.conf
Karthik
Raxesh,
Ok, I missed that.
DRA821U did not exist at the time of zeus and it was only added in dunfell timeframe. Therefore you have to migrate to dunfell or you can backport it yourself. But note that there are dependencies that you will have to take care of.
Recommendation will be start on dunfell.
regards
Karthik
Noted. I did generate a build with MACHINE=j7-evm, would it not work for DRA821U because the conf has J7200 listed?
Raxesh,
This is not a tested configuration. I don't know if this will work or not.
You can try it and if it doesn't work please use the recommendation above.
Karthik
