TDA4VM: TDA4VM: Which boot mode should I set to run keywriter
Part Number: TDA4VM
Hi TI expert,
I try to run keywriter on my TDA4VM88TRxx SOC(prime), but can't find any log in MCU uart when powerup.
Instead, in UART mode, I can see hex strings in MCU uart and 2minutes later,  keywriter log will output.
02000000011a00006a376573000000000000000048534653010101000101010002a6010000000000aa1f8e3095042e5c71ac40ede5b4e8c85fa87e03305ae0ea4f47933e89f4164aeb5a12ae13778f49de0622c1a578e6e747981d8c44a130f89a336a887a7955eead0bc40b000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000cc5a0a74c1e69d3c3a4b606d1fda6f8d6c5b5a7a41b0337f83edb49e20ba88f4CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCOTP Keywriter Version: 02.00.00.00 (Jul 20 2022 - 18:21:21)
OTP Keywriter ver: 21.5.2--v2021.05b (Terrific Lla
So, why there is no any log in SD card mode, but UART mode is OK?
  • Hi Henry,
    Kerywritter is not dependent on the boot mode. As long as correct boot mode is selected in the boot pins, it should just work fine.. So can you please check boot pins?
    Brijesh
  • Hi Brijesh,
    Thanks for your reply.
    The boot pins should be OK, since we change SOC to another XJ721E6BALF, our board bootup normally from SD card mode.
     Any other suggestions?
  • Hi  Brijesh,
    Get a patch about uart changes from TI guys and now MCU uart log is OK in sdcard mode.
    Now we have only one issue.
    From MCU and M3 log,it seems flash efuse successfully. but actually MPK not burned by parse UART mode log.
    Any suggestion?
  • Update some logs based on SDK8.0 and keywriter SR1.1 package
    R5 uart log:
    OTP Keywriter Version: 02.00.00.00 (Jul 21 2022 - 13:37:44)
    OTP_VppEn
    test_pmic_i2c_lld_intf_setup(): 493: PMIC_MAIN_INST I2C Setup...
    test_pmic_i2c_lld_intf_setup(): 533: done...
    I2C1: Passed for address 0x48 !!!
    [DEBUG] OTP_VppEn:(88), slave addr =0x4c
    Key programming sequence initialted
    Taking OTP certificate from 0x41c73004
    Debug response: 0x0
    Key programming sequence completed
    M3 log:
    0x400002
            0x800004
                    0x4003005
                             0x4401552
                                      0x40000B
                                              0x800004
                                                      0x4003005
                                                               0x4401552
        0x40000D
        0x800004
        0x20800000
        0x20800001
        0x400002
        0x800004
        0x4003005
        0x4401552
        0x409031
        0x800004
        # Decrypting extensions..
              MPK Options:  0x0
                               MEK Options:  0x0
                                                MPK Opt P1:  0x0
        MPK Opt P2:  0x0
        MEK Opt   :  0x0
        * SMPKH Part 1 BCH code: a0d92479
        * SMPKH Part 2 BCH code: a0ac26ca
        * SMPK Hash (part-1,2):
              d254fe362f9f46acc2a214adb470c597524df15764dea5543d1b0d535acc1e7c00
        df3707914b9dd61608a3f63552babe2bfcb8897fd68466d7cf7a799c7a761b3500
        * SMEK BCH code: 003342db
        * SMEK Hash: fafdabd515cec9ab6fd84164427430150876a3298e90e00ee7a68d10e1a53b958f1c0e03fcc253e5ec0b362fbdca50e74a083d723a442ff930d36aae5a8df511
        EXT OTP extension disabled
        MSV extension disabled
                  KEY CNT extension disabled
                                            KEY REV extension disabled
        SWREV extension disabled
        FW CFG REV extension disabled
        * KEYWR VERSION:  0x20000
        # Programming Keys..
        * MSV:
      [u32] bch + msv:  0x0
        * SWREV:
        [u32] SWREV-SYSFW:  0x1
        [u32] SWREV-SBL  :  0x1
                        * FW CFG REV:
                                      [u32] SWREV-FW-CFG-REV:  0x1
        SWREV SEC BCFG extension disabled
        * EXT OTP:
        * BMPKH, BMEK:
        BMPKH extension disabled
                                BMEK extension disabled
                                                       * SMPKH, SMEK:
        Programmed 11/11 rows successfully
        Programmed 2/2 rows successfully
        * KEYCNT:
        [u32] keycnt:  0x0
        [u32] keycnt:  0x0
        * KEYREV:
        [u32] keyrev:  0x0
                                                    [u32] keyrev:  0x0
    R5 log in UART mode
    ====== parsed log =======
    SoC ID Header Info:
    ('NumBlocks            :', [2])
    SoC ID Public ROM Info:
    ('SubBlockId           :', 1)
    ('SubBlockSize         :', 26)
    ('DeviceName           :', 'j7es\x00\x00\x00\x00\x00\x00\x00')
    ('DeviceType :', 'HSFS')
    ('DMSC ROM Version     :', [0, 1, 1, 1])
    ('R5 ROM Version       :', [0, 1, 1, 1])
    SoC ID Secure ROM Info:
    ('Sec SubBlockId       :', 2)
    ('Sec SubBlockSize     :', 166)
    ('Sec Prime            :', 1)
    ('Sec Key Revision     :', 0)
    ('Sec Key Count        :', 0)
    ('Sec TI MPK Hash      :', 'aa1f8e3095042e5c71ac40ede5b4e8c85fa87e03305ae0ea4f47933e89f4164aeb5a12ae13778f49de0622c1a578e6e747981d8c44a130f89a336a887a7955ee')
    ('Sec Cust MPK Hash    :', 'ad0bc40b000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000')
    ('Sec Unique ID :', 'cc5a0a74c1e69d3c3a4b606d1fda6f8d6c5b5a7a41b0337f83edb49e20ba88f4')
    The log still shows HSFS i.e HS-Field Securable. So what you have tried burning? Have you programmed the key revision and key version?
    So in SD boot mode you copied the keywriter binary as tiboot3.bin and copied to Boot partition of your SD card?
    - Keerthy
  • My detailed steps are as follows:
    1. Download keywriter_patch.tar.gz from www.ti.com/.../08.00.00.12, decompress and replace the keywriter file in pdk_jacinto_08_00_00_37/packages/ti/boot folder
    2. Download the OTP Keywriter add-on package, replace pdk_jacinto_08_00_00_37/packages/ti/boot/keywriter/tifs_bin/j721e/ti-fs-keywriter.bin, and copy ti_fek_public.pem file to pdk_jacinto_08_00_00_37/packages/ti/boot/keywriter/scripts
    3. Generate Key
    $ cd pdk_jacinto_08_00_00_37/ti/boot/keywriter/scripts
    $ ./gen_keywr_cert.sh -g
    4. Generate the corresponding X509 certification file
    $ ./gen_keywr_cert.sh -s keys/smpk.pem --smek keys/smek.key -t ti_fek_public.pem -a keys/aes256.key
    PS:
    We notice that 'plain_key_rev' and 'plain_key_cnt' will be set to 1 by gen_keywr_cert.sh, so don't modify
    templates/config_template.txt.
    5. Make some changes
    5.1 Enable uart in keywriter, Get this patch from our TI local support.
    5.2 Change PMIC related code in keywriter to enable VPP_CORE and VPP_MCU according to our customer board.
    Besides, no other changes.
    6. Generate Keywriter image
    $ cd pdk_jacinto_08_00_00_37/ti/build
    $ make keywriter_img -j8
    7. Flashing the keys to eFuses
    7.1 $ cp pdk_jacinto_08_00_00_37/ti/boot/keywriter/binary/keywriter_img_j721e_release.tiimage /media/xxx/boot/tiboot3.bin
    7.2 Connect MCU UART and M3 UART to PC, set bootmode to SDcard
    7.3 Power up customer board and get the uart logs
    We also try to burn efuse on SDK8.2 and using external power supply to VPP_CORE and VPP_MCU. We got the same flash log and
    burned efuse failed too according to MCU UART log in UART boot mode.
    Can you share the patch that you are using to enable the VPP voltage? Also could you please verify if the voltage is indeed 1.8V?
    - Keerthy
  • Subject: [PATCH] Enable VPP_ power supply
     ti/boot/keywriter/build/keywriter.mk          |   1 +
     ti/boot/keywriter/soc/j721e/keywriter_utils.c | 129 +++++++++---------
     ti/boot/keywriter/soc/j721e/keywriter_utils.h |   1 +
     ti/boot/keywriter/soc/j721e/pmic_example.c    |  14 +-
     ti/drv/pmic/src/pmic_core_priv.h              |   2 +-
     5 files changed, 78 insertions(+), 69 deletions(-)
    diff --git a/ti/boot/keywriter/build/keywriter.mk b/ti/boot/keywriter/build/keywriter.mk
    index 78c19f5..83cc801 100644
    --- a/ti/boot/keywriter/build/keywriter.mk
    +++ b/ti/boot/keywriter/build/keywriter.mk
    @@ -15,6 +15,7 @@ INCDIR                      += $(PDK_INSTALL_PATH)/ti/board/src/$(BOARD)/include
     INCDIR                      += $(PDK_INSTALL_PATH)/ti/csl
     INCDIR                      += $(KEYWRITER_APP_DIR)/boardcfgs/$(SOC)
     INCDIR                      += $(PDK_INSTALL_PATH)/ti/drv/pmic
    +INCDIR                      += $(PDK_INSTALL_PATH)/ti/drv/pmic/src
     INCDIR                      += $(PDK_INSTALL_PATH)/ti/drv/pmic/include
     INCDIR                      += $(PDK_INSTALL_PATH)/ti/drv/pmic/test/common
     INCDIR                      += $(PDK_INSTALL_PATH)/ti/drv/pmic/test/power_test
    diff --git a/ti/boot/keywriter/soc/j721e/keywriter_utils.c b/ti/boot/keywriter/soc/j721e/keywriter_utils.c
    index 22c72d6..87dc2ba 100644
    --- a/ti/boot/keywriter/soc/j721e/keywriter_utils.c
    +++ b/ti/boot/keywriter/soc/j721e/keywriter_utils.c
    @@ -43,80 +43,83 @@
     static void keywr_leo_pmicb_set_params(Pmic_CoreCfg_t* pmicConfigData)
         /* Fill parameters to pmicConfigData */
    -    pmicConfigData->pmicDeviceType       = PMIC_DEV_LEO_TPS6594X;
    -    pmicConfigData->validParams         |= PMIC_CFG_DEVICE_TYPE_VALID_SHIFT;
    +    pmicConfigData->pmicDeviceType = PMIC_DEV_LEO_TPS6594X;
    +    pmicConfigData->validParams |= PMIC_CFG_DEVICE_TYPE_VALID_SHIFT;
    -    pmicConfigData->commMode             = PMIC_INTF_SINGLE_I2C;
    -    pmicConfigData->validParams         |= PMIC_CFG_COMM_MODE_VALID_SHIFT;
    +    pmicConfigData->commMode = PMIC_INTF_DUAL_I2C;
    +    pmicConfigData->validParams |= PMIC_CFG_COMM_MODE_VALID_SHIFT;
    -    pmicConfigData->slaveAddr            = J721E_LEO_PMICB_SLAVE_ADDR;
    -    pmicConfigData->validParams         |= PMIC_CFG_SLAVEADDR_VALID_SHIFT;
    +    pmicConfigData->slaveAddr = J721E_LEO_PMICA_SLAVE_ADDR;
    +    pmicConfigData->validParams |= PMIC_CFG_SLAVEADDR_VALID_SHIFT;
    -    pmicConfigData->qaSlaveAddr          = J721E_LEO_PMICB_WDG_SLAVE_ADDR;
    -    pmicConfigData->validParams         |= PMIC_CFG_QASLAVEADDR_VALID_SHIFT;
    +    pmicConfigData->qaSlaveAddr = J721E_LEO_PMICB_WDG_SLAVE_ADDR;
    +    pmicConfigData->validParams |= PMIC_CFG_QASLAVEADDR_VALID_SHIFT;
    -    pmicConfigData->pFnPmicCommIoRead    = test_pmic_regRead;
    -    pmicConfigData->validParams         |= PMIC_CFG_COMM_IO_RD_VALID_SHIFT;
    +    pmicConfigData->pFnPmicCommIoRead = test_pmic_regRead;
    +    pmicConfigData->validParams |= PMIC_CFG_COMM_IO_RD_VALID_SHIFT;
    -    pmicConfigData->pFnPmicCommIoWrite   = test_pmic_regWrite;
    -    pmicConfigData->validParams         |= PMIC_CFG_COMM_IO_WR_VALID_SHIFT;
    +    pmicConfigData->pFnPmicCommIoWrite = test_pmic_regWrite;
    +    pmicConfigData->validParams |= PMIC_CFG_COMM_IO_WR_VALID_SHIFT;
    -    pmicConfigData->pFnPmicCritSecStart  = test_pmic_criticalSectionStartFn;
    -    pmicConfigData->validParams         |= PMIC_CFG_CRITSEC_START_VALID_SHIFT;
    +    pmicConfigData->pFnPmicCritSecStart = test_pmic_criticalSectionStartFn;
    +    pmicConfigData->validParams |= PMIC_CFG_CRITSEC_START_VALID_SHIFT;
    -    pmicConfigData->pFnPmicCritSecStop   = test_pmic_criticalSectionStopFn;
    -    pmicConfigData->validParams         |= PMIC_CFG_CRITSEC_STOP_VALID_SHIFT;
    +    pmicConfigData->pFnPmicCritSecStop = test_pmic_criticalSectionStopFn;
    +    pmicConfigData->validParams |= PMIC_CFG_CRITSEC_STOP_VALID_SHIFT;
     void OTP_VppEn(void)
    -	uint16_t pmic_device_info;
    -	uint16_t pwrRsrc;
    -	int32_t status, pmicStatus;
    -	Pmic_CoreHandle_t *pPmicCoreHandle  = NULL;
    -    Pmic_CoreCfg_t pmicb_cfg            = {0U};
    -	Pmic_PowerResourceCfg_t powerCfg_rd =
    +    uint8_t pwrRsrc;
    +    int32_t status, pmicStatus;
    +    Pmic_CoreHandle_t *pPmicCoreHandle = NULL;
    +    Pmic_CoreCfg_t pmicb_cfg = {0U};
    +    UART_printf("OTP_VppEn\n");
    +    keywr_leo_pmicb_set_params(&pmicb_cfg);
    +    status = test_pmic_appInit(&pPmicCoreHandle, &pmicb_cfg);
    +    pPmicCoreHandle->slaveAddr = J721E_LEO_PMICB_SLAVE_ADDR;   // PMCIB GPIO9
    +    if (PMIC_ST_SUCCESS == status)
    -        PMIC_CFG_REGULATOR_VMON_VOLTAGE_SET_VALID_SHIFT,
    -    Pmic_PowerResourceCfg_t pPowerCfg   =
    +        /*  PMIC_B GPIO9 set to output */
    +        pmicStatus = Pmic_commIntf_recvByte(pPmicCoreHandle, 0x39, &pwrRsrc);
    +        if (pmicStatus == PMIC_ST_SUCCESS)
    +            if (pwrRsrc != 0x01)
    +                pmicStatus = Pmic_commIntf_sendByte(pPmicCoreHandle, 0x39, 0x01);
    +                if (PMIC_ST_SUCCESS != pmicStatus)
    +                    UART_printf("Pmic_commIntf_sendByte addr: 0x39 ret: %d\n", pmicStatus);
    +        else
    +            UART_printf("Pmic_commIntf_recvByte addr: 0x39 ret: %d\n", pmicStatus);
    +        pmicStatus = Pmic_commIntf_recvByte(pPmicCoreHandle, 0x3E, &pwrRsrc);
    +            pwrRsrc |= 0x01;
    +            pmicStatus = Pmic_commIntf_sendByte(pPmicCoreHandle, 0x3E, pwrRsrc);
    +                UART_printf("Pmic_commIntf_sendByte addr: 0x3E ret: %d\n", pmicStatus);
    +        else
    +            UART_printf("Pmic_commIntf_recvByte addr: 0x3E ret: %d\n", pmicStatus);
    +    if ((pPmicCoreHandle != NULL) && (PMIC_ST_SUCCESS == status))
    -	UART_printf("OTP_VppEn\n");
    -	pmic_device_info = J721E_LEO_PMICB_DEVICE;
    -	(void)pmic_device_info;
    -	keywr_leo_pmicb_set_params(&pmicb_cfg);
    -	status = test_pmic_appInit(&pPmicCoreHandle, &pmicb_cfg);
    -	if(PMIC_ST_SUCCESS == status){
    -		/*  Set Power Resource as LDO3 */
    -	   	pwrRsrc = PMIC_TPS6594X_REGULATOR_LDO3;
    -		pmicStatus = Pmic_powerGetPwrResourceCfg(pPmicCoreHandle,
    -                                                 pwrRsrc,
    -                                                 &powerCfg_rd);
    -        if(PMIC_ST_SUCCESS != pmicStatus){
    -			UART_printf("Pmic_powerGetPwrResourceCfg ret: %d\n", pmicStatus);
    -        pPowerCfg.voltage_mV = KEYWRITER_VPP_VOLT_mV;
    -		UART_printf("volate_mV: %u\n", pPowerCfg.voltage_mV);
    -        pmicStatus = Pmic_powerSetPwrResourceCfg(pPmicCoreHandle,
    -                                                 pwrRsrc,
    -                                                 pPowerCfg);
    -			UART_printf("Pmic_powerSetPwrResourceCfg ret: %d\n", pmicStatus);
    -	if((pPmicCoreHandle != NULL) && (PMIC_ST_SUCCESS == status)){
    -		test_pmic_appDeInit(pPmicCoreHandle);
    +        test_pmic_appDeInit(pPmicCoreHandle);
    diff --git a/ti/boot/keywriter/soc/j721e/keywriter_utils.h b/ti/boot/keywriter/soc/j721e/keywriter_utils.h
    index bb181dd..9976d9c 100644
    --- a/ti/boot/keywriter/soc/j721e/keywriter_utils.h
    +++ b/ti/boot/keywriter/soc/j721e/keywriter_utils.h
    @@ -42,6 +42,7 @@
     #include <pmic.h>
     #include <pmic_ut_power.h>
    +#include <pmic_io_priv.h>
     #define KEYWRITER_VPP_VOLT_mV 1800U
    diff --git a/ti/boot/keywriter/soc/j721e/pmic_example.c b/ti/boot/keywriter/soc/j721e/pmic_example.c
    index 7df7d9f..2a321e9 100644
    --- a/ti/boot/keywriter/soc/j721e/pmic_example.c
    +++ b/ti/boot/keywriter/soc/j721e/pmic_example.c
    @@ -1205,7 +1205,7 @@ int32_t test_pmic_appInit(Pmic_CoreHandle_t **pmicCoreHandle,
         /* For DUAL I2C Instance */
         else if(PMIC_INTF_DUAL_I2C == pmicConfigData->commMode)
    -        uint64_t delta = 0;
    +        //uint64_t delta = 0;
             /* Get PMIC valid Main I2C Instance */
             pmicStatus = test_pmic_i2c_lld_intf_setup(pmicConfigData,
                                                       PMIC_MAIN_INST);
    @@ -1216,11 +1216,13 @@ int32_t test_pmic_appInit(Pmic_CoreHandle_t **pmicCoreHandle,
                 pmicConfigData->instType = PMIC_MAIN_INST;
                 if(true == enableBenchMark)
    +#if 0
                     uint64_t t1 = 0;
                     t1 = print_timeTakenInUsecs(0U, NULL);
    +#endif
                     /* Get PMIC core Handle for Main Instance */
                     pmicStatus = Pmic_init(pmicConfigData, pmicHandle);
    -                delta = print_timeTakenInUsecs(t1, NULL);
    +                //delta = print_timeTakenInUsecs(t1, NULL);
                 else
    @@ -1250,7 +1252,7 @@ int32_t test_pmic_appInit(Pmic_CoreHandle_t **pmicCoreHandle,
             if(PMIC_ST_SUCCESS == pmicStatus)
    -            pmicStatus = Pmic_intrClr(pmicHandle);
    +            //pmicStatus = Pmic_intrClr(pmicHandle);
    @@ -1267,11 +1269,12 @@ int32_t test_pmic_appInit(Pmic_CoreHandle_t **pmicCoreHandle,
    +#if 0
                 /* Get PMIC valid QA I2C Instance */
    -            pmicStatus = test_pmic_i2c_lld_intf_setup(pmicConfigData,
    -                                                      PMIC_QA_INST);
    +            //pmicStatus = test_pmic_i2c_lld_intf_setup(pmicConfigData,
    +            //                                          PMIC_QA_INST);
    @@ -1303,6 +1306,7 @@ int32_t test_pmic_appInit(Pmic_CoreHandle_t **pmicCoreHandle,
                 /* Probe connected PMIC device on given i2c Instance */
                 test_pmic_i2c_devices(pmicHandle, PMIC_QA_INST);
    +#endif
         /* For SPI Instance */
         else if(PMIC_INTF_SPI  == pmicConfigData->commMode)
    diff --git a/ti/drv/pmic/src/pmic_core_priv.h b/ti/drv/pmic/src/pmic_core_priv.h
    index d823e9d..4c812df 100644
    --- a/ti/drv/pmic/src/pmic_core_priv.h
    +++ b/ti/drv/pmic/src/pmic_core_priv.h
    @@ -60,7 +60,7 @@ extern "C" {
     #define PMIC_DEV_REV_REGADDR                (0x01U)
     #define PMIC_WDG_LONGWIN_CFG_REGADDR        (0x405U)
     /* On J7 1.0 EVM, PMIC_LEO_DEV_REV_ID is 0x08 */
    -#define PMIC_LEO_DEV_REV_ID                 (0x08U)
    +#define PMIC_LEO_DEV_REV_ID                 (0x82U)
     /* On J7 2.0 EVM, PMIC_LEO_DEV_REV_ID will be 0x03 */
     /* #define PMIC_LEO_DEV_REV_ID              (0x03U) */
    2.37.1
    We measured it by multimeter and voltage is 1.8V
  • Hi Henry,
    TI TDA4VM board has 2 options for VPP. One is via PMIC GPIO & the other is an always on source of 1.8V. So in your EVM are you using
    the PMIC GPIO or the always on source?
    Can you confirm that?
    - Keerthy
  • Our customer board use PMIC GPIO.
    We also try to use external power supply.
    our circut design for VPP power is as below. And as Henry said, we also tried to use external power supply and it still didn't work till now.
    VPP power.pdf
  • Hi Henry,
    Can you try this patch:
    From 9566e3a8858001e0815e33f5610af24f3948c896 Mon Sep 17 00:00:00 2001
    Date: Tue, 28 Jun 2022 10:18:00 +0530
    Subject: [PATCH] packages/ti/boot/keywriter/soc/j721e/keywriter_utils.c:
     Enable GPIO9 of LEO PMICB for VPP
    Signed-off-by: Keerthy <j-keerthy@ti.com>
     .../keywriter/soc/j721e/keywriter_utils.c     | 23 +++++--------------
     1 file changed, 6 insertions(+), 17 deletions(-)
    diff --git a/packages/ti/boot/keywriter/soc/j721e/keywriter_utils.c b/packages/ti/boot/keywriter/soc/j721e/keywriter_utils.c
    index e9a54ef..1fe9d7e 100644
    --- a/packages/ti/boot/keywriter/soc/j721e/keywriter_utils.c
    +++ b/packages/ti/boot/keywriter/soc/j721e/keywriter_utils.c
    @@ -92,28 +92,16 @@ void OTP_VppEn(void)
    -                                                 pwrRsrc,
    -                                                 &powerCfg_rd);
    +        /* Here is where we need to set GPIO9 of LEO PMICB */
    +        pmicStatus = Pmic_gpioSetValue(pPmicCoreHandle, 9, PMIC_GPIO_HIGH);
    +            UART_printf("Pmic_gpioSetValue ret: %d\n", pmicStatus);
    -                                                 pwrRsrc,
    -                                                 pPowerCfg);
    -        if (PMIC_ST_SUCCESS != pmicStatus)
    +        else
    +            UART_printf("Pmic_gpioSetValue ret: %d Works!!!\n", pmicStatus);
    @@ -121,4 +109,5 @@ void OTP_VppEn(void)
    2.17.1
    This will make sure GPIO9 from GPIO is toggled correctly when VPP is needed.
    - Keerthy
  • https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/08_01_00_11/exports/docs/pdk_jacinto_08_01_00_33/docs/userguide/jacinto/modules/keywriter.html
    You used this command line, which does not include keycnt & keyrev (or write protect commands)
    M3 logs show keycnt & keyrev not programmed
    You should use this instead:
    ./gen_keywr_cert.sh -s keys/smpk.pem -s-wp --smek keys/smek.key --smek-wp -t ti_fek_public.pem -a keys/aes256.key --keycnt 1 --keyrev 1
    These parameters a) write protect the key values and b) sets keycnt & keyrev which converts device to HS-SE.
    If you do not write keycnt & keyrev, then device remains in HS-FS state.
     You can recover devices previously progammed with VPP set properly by writing just keycnt & keyrev:
    ./gen_keywr_cert.sh -t ti_fek_public.pem -a keys/aes256.key --keycnt 1 --keyrev 1
    I will enter a follow-up post showing how you can program TI dummy keys
  • Thanks a lot. I try it and it works now
  • That is good news
    See below for how to retrieve TI Dummy Keys and program
    • Get TI Dummy Keys from SDK
    • Use unique DK key filenames since keys smpk.pem and smek.key have been created in earlier steps
      • cd <PDK-INSTALL-PATH>
      • # Copy the customer dummy private key (SMPK private key, PEM format)
      • cp build/makerules/k3_dev_mpk.pem boot/keywriter/scripts/keys/smpk_dk.pem
      • # Copy the customer dummy encryption key (SMEK, converted to binary file)
      • xxd -p -r build/makerules/k3_dev_mek.txt > boot/keywriter/scripts/keys/smek_dk.key
    • Generate single pass Key data with TI Dummy Key
      • ./gen_keywr_cert.sh -s keys/smpk_dk.pem -s-wp --smek keys/smek_dk.key --smek-wp -t ti_fek_public.pem -a keys/aes256.key --keycnt 1 --keyrev 1
    • Run Keywriter
