I found the following errors when I run Linux 08_05_00_08 SDK in evm board:
1. Line 255: [ 0.610825] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
Line 256: [ 0.617118] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
2. Line 280: [ 0.759948] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
Line 281: [ 0.766311] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
3. Line 318: [ 2.121257] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
Line 319: [ 2.131144] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
Line 320: [ 2.137904] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
Line 321: [ 2.146780] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
Line 322: [ 2.156940] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
Line 323: [ 2.163699] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
So I have a few questions about this phenomenon:
1. Why do logs No.1 and No.2 fail ?
2. Why is ringacc's driver initialized three times?
U-Boot SPL 2021.01-g7996ed51f1 (Apr 18 2023 - 12:14:49 +0000) ti_sci system-controller@44083000: Message not acknowledgedSYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') SPL initial stack usage: 13472 bytes Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty NOTICE: BL31: Built : 10:59:07, Apr 18 2023 I/TC: I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Apr 18 11:00:42 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-g7996ed51f1 (Apr 18 2023 - 11:01:50 +0000) ti_sci system-controller@44083000: Message not acknowledgedSYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') Trying to boot from MMC2 U-Boot 2021.01-g7996ed51f1 (Apr 18 2023 - 11:01:50 +0000) SoC: J721S2 SR1.0 GP Model: Texas Instruments J721S2 EVM ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 Board: rev DRAM: 16 GiB Flash: 0 Bytes MMC: mmc@4f80000: 0, mmc@4fb0000: 1 Loading Environment from MMC... OK In: serial@2880000 Out: serial@2880000 Err: serial@2880000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Unidentified board claims in eeprom header Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 0 bytes read in 0 ms Loaded env from uEnv.txt Importing environment from mmc1 ... 18608640 bytes read in 398 ms (44.6 MiB/s) 80207 bytes read in 8 ms (9.6 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee9000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.153-g90c3a58fd2 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Apr 18 12:13:05 UTC 2023 [ 0.000000] Machine model: Texas Instruments J721S2 EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a9bfffff] [ 0.000000] node 0: [mem 0x00000000a9c00000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x0000000bffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff] [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] cma: Reserved 512 MiB at 0x00000000dfc00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128766 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=4992af39-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000dbc00000-0x00000000dfc00000] (64MB) [ 0.000000] Memory: 15664208K/16777208K available (10880K kernel code, 1148K rwdata, 4212K rodata, 1792K init, 432K bss, 588712K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008365] Console: colour dummy device 80x25 [ 0.012930] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023601] pid_max: default: 32768 minimum: 301 [ 0.028361] LSM: Security Framework initializing [ 0.033171] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.040985] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.050032] rcu: Hierarchical SRCU implementation. [ 0.055099] Platform MSI: msi-controller@1820000 domain created [ 0.061304] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070602] EFI services will not be available. [ 0.075342] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088423] Detected PIPT I-cache on CPU1 [ 0.088449] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088462] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.088503] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088558] smp: Brought up 1 node, 2 CPUs [ 0.117905] SMP: Total of 2 processors activated. [ 0.122710] CPU features: detected: 32-bit EL0 Support [ 0.127965] CPU features: detected: CRC32 instructions [ 0.142422] CPU: All CPU(s) started at EL2 [ 0.146626] alternatives: patching kernel code [ 0.151689] devtmpfs: initialized [ 0.159094] KASLR disabled due to lack of seed [ 0.163748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.173713] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.185889] pinctrl core: initialized pinctrl subsystem [ 0.191567] DMI not present or invalid. [ 0.195823] NET: Registered protocol family 16 [ 0.201160] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.208826] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.217351] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.225771] thermal_sys: Registered thermal governor 'step_wise' [ 0.225774] thermal_sys: Registered thermal governor 'power_allocator' [ 0.232368] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.246021] ASID allocator initialised with 65536 entries [ 0.266883] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.273741] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.280587] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.287433] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.294909] cryptd: max_cpu_qlen set to 1000 [ 0.301041] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected [ 0.310144] vsys_3v3: supplied by evm_12v0 [ 0.314536] vsys_5v0: supplied by evm_12v0 [ 0.319275] iommu: Default domain type: Translated [ 0.324476] SCSI subsystem initialized [ 0.328596] mc: Linux media interface: v0.10 [ 0.332979] videodev: Linux video capture interface: v2.00 [ 0.338614] pps_core: LinuxPPS API ver. 1 registered [ 0.343685] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.353023] PTP clock support registered [ 0.357043] EDAC MC: Ver: 3.0.0 [ 0.360859] FPGA manager framework [ 0.364372] Advanced Linux Sound Architecture Driver Initialized. [ 0.371014] clocksource: Switched to clocksource arch_sys_counter [ 0.377350] VFS: Disk quotas dquot_6.6.0 [ 0.381387] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.391044] NET: Registered protocol family 2 [ 0.396307] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.407383] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.416302] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.424988] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) [ 0.433029] TCP: Hash tables configured (established 131072 bind 65536) [ 0.439969] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.447087] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.454742] NET: Registered protocol family 1 [ 0.459548] RPC: Registered named UNIX socket transport module. [ 0.465607] RPC: Registered udp transport module. [ 0.470410] RPC: Registered tcp transport module. [ 0.475213] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.481798] PCI: CLS 0 bytes, default 64 [ 0.486194] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.496735] Initialise system trusted keyrings [ 0.501375] workingset: timestamp_bits=46 max_order=22 bucket_order=0 [ 0.509531] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.515830] NFS: Registering the id_resolver key type [ 0.521024] Key type id_resolver registered [ 0.525295] Key type id_legacy registered [ 0.529419] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.536267] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.543919] 9p: Installing v9fs 9p2000 file system support [ 0.569359] Key type asymmetric registered [ 0.573547] Asymmetric key parser 'x509' registered [ 0.578548] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.586107] io scheduler mq-deadline registered [ 0.590733] io scheduler kyber registered [ 0.596273] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.602391] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.610825] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.617118] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.625129] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.638067] brd: module loaded [ 0.644634] loop: module loaded [ 0.648461] megasas: 07.714.04.00-rc1 [ 0.654255] tun: Universal TUN/TAP device driver, 1.6 [ 0.659759] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.666170] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.672243] sky2: driver version 1.30 [ 0.676610] VFIO - User Level meta-driver version: 0.3 [ 0.682429] i2c /dev entries driver [ 0.686848] sdhci: Secure Digital Host Controller Interface driver [ 0.693175] sdhci: Copyright(c) Pierre Ossman [ 0.697907] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.704259] ledtrig-cpu: registered to indicate activity on CPUs [ 0.710611] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.717992] optee: probing for conduit method. [ 0.722561] optee: revision 3.19 (afacf356) [ 0.722708] optee: dynamic shared memory is enabled [ 0.732187] optee: initialized driver [ 0.737268] NET: Registered protocol family 17 [ 0.741896] 9pnet: Installing 9P2000 support [ 0.746302] Key type dns_resolver registered [ 0.750761] Loading compiled-in X.509 certificates [ 0.759948] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.766311] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.775398] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') [ 0.813079] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz [ 0.819272] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz [ 0.825367] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz [ 0.831893] pca953x 3-0021: supply vcc not found, using dummy regulator [ 0.838725] pca953x 3-0021: using no AI [ 0.863573] pca953x 3-0020: supply vcc not found, using dummy regulator [ 0.870389] pca953x 3-0020: using no AI [ 0.875094] pca953x 3-0022: supply vcc not found, using dummy regulator [ 0.881897] pca953x 3-0022: using AI [ 0.886218] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.892787] pca953x 4-0020: supply vcc not found, using dummy regulator [ 0.899617] pca953x 4-0020: using no AI [ 0.927349] omap_i2c 2040000.i2c: bus 4 rev0.12 at 400 kHz [ 0.933696] pca953x 5-0020: supply vcc not found, using dummy regulator [ 0.940550] pca953x 5-0020: using no AI [ 0.967356] omap_i2c 2050000.i2c: bus 5 rev0.12 at 400 kHz [ 0.973781] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created [ 0.982337] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created [ 0.991673] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created [ 1.000278] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created [ 1.011711] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 1.019390] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 1.027672] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 1.035949] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.046349] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00 [ 2.052769] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.058376] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff]) [ 2.068067] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff] [ 2.075121] pci 0000:00:00.0: [104c:b013] type 01 class 0x060400 [ 2.081354] pci 0000:00:00.0: supports D1 [ 2.085448] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.092751] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.102214] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.108985] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.114304] pcieport 0000:00:00.0: PME: Signaling with IRQ 58 [ 2.121257] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272 [ 2.131144] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 2.137904] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 2.146780] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259 [ 2.156940] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 2.163699] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 2.171384] omap8250 40a00000.serial: failed to get alias [ 2.177489] printk: console [ttyS2] disabled [ 2.181889] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 27, base_baud = 3000000) is a 8250 [ 2.190633] printk: console [ttyS2] enabled [ 2.190633] printk: console [ttyS2] enabled [ 2.199070] printk: bootconsole [ns16550a0] disabled [ 2.199070] printk: bootconsole [ns16550a0] disabled [ 2.215086] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.259014] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.267618] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.275918] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 2.288775] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.295982] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.302266] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 2.312464] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0 [ 2.422162] mmc0: CQHCI version 5.10 [ 2.426154] gpio-mux mux-controller0: 2-way mux-controller registered [ 2.433056] gpio-mux mux-controller1: 2-way mux-controller registered [ 2.443086] vdd_mmc1: supplied by vsys_3v3 [ 2.448813] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 2.455642] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 2.462456] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 2.469267] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 2.470115] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 2.483751] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 2.493780] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16) [ 2.506959] spi-nor spi7.0: s28hs512t (65536 Kbytes) [ 2.511957] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 2.518558] Creating 7 MTD partitions on "47040000.spi.0": [ 2.524035] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 2.530085] 0x000000080000-0x000000280000 : "ospi.tispl" [ 2.535830] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 2.541642] 0x000000680000-0x0000006c0000 : "ospi.env" [ 2.547214] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 2.553380] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 2.559213] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 2.572626] spi-nor spi8.0: mt25qu512a (65536 Kbytes) [ 2.577966] mmc0: Command Queue Engine enabled [ 2.582652] mmc0: new HS400 MMC card at address 0001 [ 2.588188] mmc1: CQHCI version 5.10 [ 2.588468] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present! [ 2.591927] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 2.599099] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present! [ 2.603881] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 2.611340] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present! [ 2.616803] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 2.624425] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present! [ 2.629997] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0) [ 2.649599] ALSA device list: [ 2.652576] No soundcards found. [ 2.655024] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 2.664466] Waiting for root device PARTUUID=4992af39-02... [ 2.710190] mmc1: new ultra high speed DDR50 SDXC card at address 59b4 [ 2.717089] mmcblk1: mmc1:59b4 EC1S5 59.7 GiB [ 2.722805] mmcblk1: p1 p2 [ 3.012738] EXT4-fs (mmcblk1p2): recovery complete [ 3.018381] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.026499] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.033688] devtmpfs: mounted [ 3.037326] Freeing unused kernel memory: 1792K [ 3.041974] Run /sbin/init as init process [ 3.207647] systemd[1]: System time before build time, advancing clock. [ 3.257159] NET: Registered protocol family 10 [ 3.262190] Segment Routing with IPv6 [ 3.279209] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.300983] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 3.335580] systemd[1]: Set hostname to <j721s2-evm>. [ 3.494223] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock ? /run/docker.sock; please update the unit file accordingly. [ 3.556388] random: systemd: uninitialized urandom read (16 bytes read) [ 3.563136] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 3.575464] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 3.585575] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 3.607109] random: systemd: uninitialized urandom read (16 bytes read) [ 3.614509] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 3.635101] random: systemd: uninitialized urandom read (16 bytes read) [ 3.642371] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 3.663236] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password �ts to Console Directory Watch. [ 3.687168] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R�uests to Wall Directory Watch. [ 3.711146] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 3.727085] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 3.747073] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 3.763075] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 3.783805] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 3.807131] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 3.829305] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.851251] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 3.883903] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 3.892322] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.915389] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 3.931423] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 3.955342] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 3.975238] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.997608] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.017575] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.041613] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.062310] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 4.081799] systemd[1]: Starting Create list of static device nodes for the current kernel... Starting Create list of st�odes for the current kernel... [ 4.109513] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 4.134421] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 4.147282] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 4.159713] systemd[1]: Starting Journal Service... Starting Journal Service... [ 4.182969] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 4.201762] systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.208709] cryptodev: loading out-of-tree module taints kernel. Starting Remount Root and Kernel File Systems EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [0m... [ 4.219199] cryptodev: driver 1.10 loaded. [ 4.237665] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 4.262315] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 4.283562] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta� nodes for the current kernel. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star�progress communication helper. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 4.516312] systemd-journald[162]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ 4.631747] random: systemd: uninitialized urandom read (16 bytes read) [ OK ] Reached target Local File Systems (Pre). [ 4.655163] random: systemd: uninitialized urandom read (16 bytes read) Mounting /media/ram... [ 4.665658] random: systemd-journal: uninitialized urandom read (16 bytes read) Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. [ OK ] Started udev Kernel Device Manager. Starting udev Wait for Complete Device Initialization... Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchron[ 5.063947] random: crng init done ized. [ 5.076813] random: 66 urandom warning(s) missed due to ratelimiting [ OK ] Started Load/Save Random Seed.[ 5.088733] CAN device driver interface [ 5.271629] [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* failed to find dsi host [ 5.315499] [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* failed to find dsi host [ 5.376311] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a6000000 [ 5.425561] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode [ 5.432659] remoteproc remoteproc0: 64800000.dsp is available [ 5.439958] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a7000000 [ 5.522298] PVR_K: 200: Read BVNC 36.53.104.796 from HW device registers [ 5.564137] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode [ 5.599626] PVR_K: 200: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 5.611276] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 1 [ 5.696065] remoteproc remoteproc1: 65800000.dsp is available [ 5.703500] remoteproc remoteproc0: powering up 64800000.dsp [ 5.709222] remoteproc remoteproc0: Booting fw image j721s2-c71_0-fw, size 10488944 [ 5.721061] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 5.733071] remoteproc remoteproc0: unsupported resource 65538 [ 5.739638] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa6e00000 [ 5.750805] remoteproc0#vdev0buffer: assigned reserved memory node c71-dma-memory@a6000000 [ 5.762619] virtio_rpmsg_bus virtio0: rpmsg host is online [ 5.770222] remoteproc0#v�uffer: registered virtio0 (type 7) [ 5.777989] remoteproc remoteproc0: remote processor 64800000.dsp is now up [ 5.786822] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 5.795671] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 5.808250] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0 [ 5.819099] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes [ 5.840710] platform 41000000.r5f: configured R5F for IPC-only mode [ 5.852465] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 5.861571] remoteproc remoteproc2: 41000000.r5f is available [ 5.870175] remoteproc remoteproc2: attaching to 41000000.r5f [ 5.876238] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 5.883820] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000 [ 5.892703] virtio_rpmsg_bus virtio1: rpmsg host is online [ 5.907067] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 5.916220] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 5.930609] remoteproc2#vdev0buffer: registered virtio1 (type 7) [ 5.957911] remoteproc remoteproc2: remote processor 41000000.r5f is now attached [ 5.991596] platform 5c00000.r5f: configured R5F for remoteproc mode [ 6.014464] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000 [ 6.032264] remoteproc remoteproc3: 5c00000.r5f is available [ 6.046085] platform 5d00000.r5f: configured R5F for remoteproc mode [ 6.063407] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000 [ 6.083829] remoteproc remoteproc1: powering up 65800000.dsp [ 6.089713] remoteproc remoteproc3: powering up 5c00000.r5f [ 6.095351] remoteproc remoteproc3: Booting fw image j721s2-main-r5f0_0-fw, size 110796 [ 6.098605] remoteproc remoteproc4: 5d00000.r5f is available [ 6.103436] remoteproc remoteproc1: Booting fw image j721s2-c71_1-fw, size 10488944 [ 6.118328] remoteproc remoteproc1: unsupported resource 65538 [ 6.125055] remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@af����j��[ 6.133705] k3-dsp-rproc 65800000.dsp: booting DSP core using boot addr = 0xa7e00000 [ 6.141861] virtio_rpmsg_bus virtio2: rpmsg host is online [ 6.147510] remoteproc3#vdev0buffer: registered virtio2 (type 7) [ 6.154072] remoteproc1#vdev0buffer: assigned reserved memory node c71-dma-memory@a7000000 [ 6.165015] remoteproc remoteproc3: remote processor 5c00000.r5f is now up [ 6.172338] virtio_rpmsg_bus virtio3: rpmsg host is online [ 6.178057] remoteproc1#vdev0buffer: registered virtio3 (type 7) [ 6.184203] remoteproc remoteproc1: remote processor 65800000.dsp is now up [ 6.192715] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 6.200937] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 6.208707] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd [ 6.217581] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe [ 6.231557] remoteproc remoteproc4: powering up 5d00000.r5f [ 6.237215] remoteproc remoteproc4: Booting fw image j721s2-main-r5f0_1-fw, size 110796 [ 6.250115] platform 5e00000.r5f: configured R5F for remoteproc mode [ 6.257282] remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@ab00000 [ 6.269358] virtio_rpmsg_bus virtio4: rpmsg host is online [ 6.274924] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 6.281069] remoteproc remoteproc4: remote processor 5d00000.r5f is now up [ 6.288437] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd [ 6.296689] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe [ 6.323247] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000 [ 6.337463] m_can_platform 26a1000.can: m_can device registered (irq=41, version=32) [ 6.349219] remoteproc remoteproc5: 5e00000.r5f is available [ 6.358154] m_can_platform 40528000.can: m_can device registered (irq=19, version=32) [ 6.374035] m_can_platform 40568000.can: m_can device registered (irq=21, version=32) [ 6.389122] m_can_platform 2731000.can: m_can device registered (irq=37, version=32) [ 6.403370] m_can_platform 2751000.can: m_can device registered (irq=39, version=32) [ 6.418609] platform 5f00000.r5f: configured R5F for remoteproc mode [ 6.425274] remoteproc remoteproc5: powering up 5e00000.r5f [ 6.431112] remoteproc remoteproc5: Booting fw image j721s2-main-r5f1_0-fw, size 110796 [ 6.446312] remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@ahL��0 [ 6.456494] virtio_rpmsg_bus virtio5: rpmsg host is online [ 6.466439] remoteproc5#vdev0buffer: registered virtio5 (type 7) [ 6.469328] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd [ 6.472577] remoteproc remoteproc5: remote processor 5e00000.r5f is now up [ 6.489817] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe [ 6.503394] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000 [ 6.552481] remoteproc remoteproc6: 5f00000.r5f is available [ 6.566569] remoteproc remoteproc6: powering up 5f00000.r5f [ 6.572337] remoteproc remoteproc6: Booting fw image j721s2-main-r5f1_1-fw, size 110796 [ 6.584089] remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a�����j��[ 6.592790] virtio_rpmsg_bus virtio6: rpmsg host is online [ 6.602459] remoteproc6#vdev0buffer: registered virtio6 (type 7) [ 6.608613] remoteproc remoteproc6: remote processor 5f00000.r5f is now up [ 6.617743] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd [ 6.625396] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe [ 7.466145] usbcore: registered new interface driver usbfs [ 7.476116] usbcore: registered new interface driver hub [ 7.483310] usbcore: registered new device driver usb [ 7.498981] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22 [ 7.517503] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22 [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Started udev Wait for Complete Device Initialization. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API. [ OK ] Listening on dropbear.socket. Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting rc.pvr.service... Starting Login Service... [ OK ] Started TEE Supplicant. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Started File System Check on /dev/mmcblk1p1. [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Started Telephony service. [ OK ] Reached target Network (Pre). Mounting /run/media/mmcblk1p1... Starting Network Service... [ 8.350392] Bluetooth: Core ver 2.22 [ 8.357053] NET: Registered protocol family 31 [ 8.366314] Bluetooth: HCI device and connection manager initialized [ 8.383052] Bluetooth: HCI socket layer initialized [ 8.388082] Bluetooth: L2CAP socket layer initialized [ 8.393156] Bluetooth: SCO socket layer initialized [ OK ] Mounted /run/media/mmcblk1p1. [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 8.571060] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0 [ OK ] Started Login Service. [ 8.620478] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ OK ] Listening on Load/Save RF �itch S[ 8.690782] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) tatus /dev/rfkill Watch. [ 8.751066] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Ma�ent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Avahi mDNS/DNS-SD Stack. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started rc.pvr.service. Starting weston.service... [ OK ] Started Simple Network Man�ement Protocol (SNMP) Daemon.. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav-dev gstreamer1.0-libav gzip less libasm1 libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libidn2-0 libidn2-dev libmpc3 libmpfr6 libreadline-dev libreadline8 libunistring-dev libunistring2 m4-dev m4 make nettle-dev nettle parted python3-rfc3987 python3-strict-rfc3339 tar which zeromq If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ OK ] Started weston.service. Starting telnetd.service... [ OK ] Started telnetd.service. [ 12.506581] PVR_K: 1049: RGX Firmware image 'rgx.fw.36.53.104.796' loaded [ 12.535254] PVR_K: 1049: Shader binary image 'rgx.sh.36.53.104.796' loaded [ 13.884913] PVR_K:(Error): 67: RGXSafetyEventHandler: Safety Watchdog Trigger ! [358] _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project j721s2-evm ttyS2 Arago 2021.09 j721s2-evm ttyS2 j721s2-evm login:
