TDA4VM: Main CAN cannot find device under Linux
Part Number: TDA4VM
Hi team,
main_can0 is being used and the device tree configuration is as follows:
In k3-j721e-main.dtsi,
	main_mcan0: can@2701000 {
		compatible = "bosch,m_can";
		reg = <0x00 0x02701000 0x00 0x200>,
		      <0x00 0x02708000 0x00 0x8000>;
		reg-names = "m_can", "message_ram";
		power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 156 0>, <&k3_clks 156 1>;
		clock-names = "hclk", "cclk";
		interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>,
			     <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>;
		interrupt-names = "int0", "int1";
		bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>;
In k3-j721e-sk.dts,
	main_mcan0_pins_default: main-mcan0-pins-default {
		pinctrl-single,pins = <
			J721E_IOPAD(0x208, PIN_INPUT, 0) /* (W5) MCAN0_RX */
			J721E_IOPAD(0x20c, PIN_OUTPUT, 0) /* (W6) MCAN0_TX */
	main_mcan0_gpio_pins_default: main-mcan0-gpio-pins-default {
			J721E_IOPAD(0x108, PIN_INPUT, 7) /* (AD27) PRG0_PRU1_GPO2.GPIO0_65 */
		transceiver2: can-phy1 {
		compatible = "ti,tcan1042";
		#phy-cells = <0>;
		max-bitrate = <5000000>;
		pinctrl-names = "default";
		pinctrl-0 = <&main_mcan0_gpio_pins_default>;
		standby-gpios = <&main_gpio0 65 GPIO_ACTIVE_HIGH>;
However, after the system starts up, by checking the command dmesg | grep can
[   32.432940] m_can_platform 40528000.can: m_can device registered (irq=19, version=32),
It's found only MCU_CAN0 registration was to be successful, none of the other main_can registration was successful.
Could you help look into this case? Thanks.
Cherry
  • Cherry,
    Can you share the complete boot logs? Do you see the main domain CAN failing or it never gets probed? Can you check if the node is disabled in any of the dts files?
    Keerthy
  • Hi Keerthy,
    This is the complete BOOT LOG. Customer didn’t see any CAN information related to the main domain reported an error. These nodes are also not disabled in the DTS file, and the DTS configuration is the same as the DTS configuration in the original question.
    U-Boot 2021.01 (May 31 2023 - 23:00:10 +0800)
    SoC:   J721E SR1.1 GP
    Model: Texas Instruments K3 J721E SoC
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed 1
    Board: J721EX-PM1-SOM rev E2
    DRAM:  4 GiB
    Flash: 0 Bytes
    MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
    env_driver_lookup..success..loc=5...Loading Environment from11 MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    cdns,sierra serdes@5000000: PHY not found 0x7364 vs 0x0
    Sierra init failed:-22
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    i2c_write: error waiting for data ACK (status=0x116)
    pca953x gpio@22: Error reading output register
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    483 bytes read in 29 ms (15.6 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 30 ms (0 Bytes/s)
    Already setup.
    pca953x gpio@20: Error reading output register
    GPIO: 'gpio@22_17' not found
    Command 'gpio' failed: Error -121
    GPIO: 'gpio@22_16' not found
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
    572728 bytes read in 58 ms (9.4 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 572728 bytes: Success!
    302028 bytes read in 46 ms (6.3 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success!
    Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
    Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
    1325844 bytes read in 89 ms (14.2 MiB/s)
    Load Remote Processor 6 with data@addr=0x82000000 1325844 bytes: Success!
    Load Remote Processor 7 with data@addr=0x82000000 1325844 bytes: Success!
    12849160 bytes read in 570 ms (21.5 MiB/s)
    Load Remote Processor 8 with data@addr=0x82000000 12849160 bytes: Success!
    18106880 bytes read in 752 ms (23 MiB/s)
    99767 bytes read in 35 ms (2.7 MiB/s)
    10670 bytes read in 31 ms (335.9 KiB/s)
       Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version11 5.10.153-g90c3a58fd2 (root@ubuntu) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Jul 12 23:54:13 CST 2023
    [    0.000000] Machine model: Texas Instruments J721E SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
    [    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 400 MiB at 0x00000000e7000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s50648 r8192 d31272 u90112
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.2.78:/home/fanhua/ti-processor-sdk-rtos-j721e-evm-08_05_00_11/targetfs, ip=192.168.2.58
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB)
    [    0.000000] Memory: 1812088K/4194304K available (10560K kernel code, 1170K rwdata, 3976K rodata, 1856K init, 442K bss, 1972616K reserved, 409600K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008a7030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000008] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.009180] Console: colour dummy device 80x25
    [    0.013812] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.024553] pid_max: default: 32768 minimum: 301
    [    0.029444] LSM: Security Framework initializing
    [    0.034316] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.041969] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.052686] rcu: Hierarchical SRCU implementation.
    [    0.058120] Platform MSI: msi-controller@1820000 domain created
    [    0.064693] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.074254] EFI services will not be available.
    [    0.079222] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.093184] Detected PIPT I-cache on CPU1
    [    0.093244] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.093266] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
    [    0.093332] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.093494] smp: Brought up 1 node, 2 CPUs
    [    0.123025] SMP: Total of 2 processors activated.
    [    0.127870] CPU features: detected: 32-bit EL0 Support
    [    0.133190] CPU features: detected: CRC32 instructions
    [    0.166148] CPU: All CPU(s) started at EL2
    [    0.170396] alternatives: patching kernel code
    [    0.176188] devtmpfs: initialized
    [    0.200035] KASLR disabled due to lack of seed
    [    0.204917] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.214944] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.239558] pinctrl core: initialized pinctrl subsystem
    [    0.245809] DMI not present or invalid.
    [    0.250942] NET: Registered protocol family 16
    [    0.258002] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.265562] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.274032] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.282903] thermal_sys: Registered thermal governor 'step_wise'
    [    0.282914] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.290463] cpuidle: using governor menu
    [    0.301616] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.308672] ASID allocator initialised with 65536 entries
    [    0.394940] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.401857] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.408766] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.415661] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.424822] cryptd: max_cpu_qlen set to 1000
    [    0.434260] ACPI: Interpreter disabled.
    [    0.439000] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.448688] vsys_3v3: supplied by vusb-main5v0
    [    0.455155] iommu: Default domain type: Translated
    [    0.460673] SCSI subsystem initialized
    [    0.465589] mc: Linux media interface: v0.10
    [    0.470031] videodev: Linux video capture interface: v2.00
    [    0.475727] pps_core: LinuxPPS API ver. 1 registered
    [    0.480837] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.490235] PTP clock support registered
    [    0.494350] EDAC MC: Ver: 3.0.0
    [    0.499812] FPGA manager framework
    [    0.504898] clocksource: Switched to clocksource arch_sys_counter
    [    0.511485] VFS: Disk quotas dquot_6.6.0
    [    0.515637] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.522976] pnp: PnP ACPI: disabled
    [    0.538002] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.544462] NET: Registered protocol family 2
    [    0.549502] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.561633] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.570563] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.579219] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    0.587764] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.594697] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.601796] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.609487] NET: Registered protocol family 1
    [    0.614758] RPC: Registered named UNIX socket transport module.
    [    0.620930] RPC: Registered udp transport module.
    [    0.625812] RPC: Registered tcp transport module.
    [    0.630655] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.637286] PCI: CLS 0 bytes, default 64
    [    0.642441] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.658306] Initialise system trusted keyrings
    [    0.663182] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.676716] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.683540] NFS: Registering the id_resolver key type
    [    0.688833] Key type id_resolver registered
    [    0.693148] Key type id_legacy registered
    [    0.697394] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.704287] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.712122] 9p: Installing v9fs 9p2000 file system support
    [    0.814052] Key type asymmetric registered
    [    0.818291] Asymmetric key parser 'x509' registered
    [    0.823362] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.830965] io scheduler mq-deadline registered
    [    0.835626] io scheduler kyber registered
    [    0.847910] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.854841] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.872643] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.879084] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.885812] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.892313] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.900642] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.907158] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.915450] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.921969] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.930268] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.936669] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.945049] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.951452] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.967526] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.981763] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.990734] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.998264] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    1.008078] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    1.028728] brd: module loaded
    [    1.042407] loop: module loaded
    [    1.047424] megasas: 07.714.04.00-rc1
    [    1.059980] tun: Universal TUN/TAP device driver, 1.6
    [    1.065454] vcan: Virtual CAN interface driver
    [    1.070045] vxcan: Virtual CAN Tunnel driver
    [    1.074438] slcan: serial line CAN interface driver
    [    1.079467] slcan: 10 dynamic interface channels.
    [    1.084305] CAN device driver interface
    [    1.088493] cc770: CAN netdevice driver
    [    1.092440] cc770_isa: insufficient parameters supplied
    [    1.101759] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    1.108203] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.114341] sky2: driver version 1.30
    [    1.120675] VFIO - User Level meta-driver version: 0.3
    [    1.127416] i2c /dev entries driver
    [    1.135235] sdhci: Secure Digital Host Controller Interface driver
    [    1.141600] sdhci: Copyright(c) Pierre Ossman
    [    1.147025] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.155263] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.165855] optee: probing for conduit method.
    [    1.170476] optee: revision 3.19 (afacf356)
    [    1.170896] optee: dynamic shared memory is enabled
    [    1.181107] optee: initialized driver
    [    1.187898] NET: Registered protocol family 17
    [    1.192527] can: controller area network core
    [    1.197120] NET: Registered protocol family 29
    [    1.201693] can: raw protocol
    [    1.204741] can: broadcast manager protocol
    [    1.209051] can: netlink gateway - max_hops=1
    [    1.213669] can: SAE J1939
    [    1.216448] can: isotp protocol
    [    1.219894] 9pnet: Installing 9P2000 support
    [    1.224392] Key type dns_resolver registered
    [    1.229368] Loading compiled-in X.509 certificates
    [    1.256320] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.263071] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.282240] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    1.421081] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.428194] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.435211] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.443150] lm75 3-0048: supply vs not found, using dummy regulator
    [    1.473669] hwmon hwmon0: temp1_input not attached to any thermal zone
    [    1.480408] lm75 3-0048: hwmon0: sensor 'tmp100'
    [    1.485268] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.492382] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
    [    1.520993] pca954x 5-0070: probe failed
    [    1.525155] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.532273] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
    [    1.541265] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.551505] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.560605] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.570860] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.584605] wiz bus@100000:wiz@5000000: wiz_get_lane_phy_types: Reading "reg" from "phy" failed: -22
    [    1.594131] wiz: probe of bus@100000:wiz@5000000 failed with error -22
    [    1.602511] wiz bus@100000:wiz@5010000: wiz_get_lane_phy_types: Reading "reg" from "phy" failed: -22
    [    1.612024] wiz: probe of bus@100000:wiz@5010000 failed with error -22
    [    1.638901] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.648860] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.655682] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.669972] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.680177] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.686981] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.695907] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    1.706748] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 27, base_baud = 3000000) is a 8250
    [    1.715575] printk: console [ttyS2] enabled
    [    1.724062] printk: bootconsole [ns16550a0] disabled
    [    1.735971] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 28, base_baud = 3000000) is a 8250
    [    1.746258] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 29, base_baud = 3000000) is a 8250
    [    1.773113] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.816944] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.826560] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.835022] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.847964] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.855199] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.862152] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.874585] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [    1.920927] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.928520] davinci_mdio c000f00.mdio: no live phy, scanning all
    [    1.963781] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
    [    1.971688] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
    [    1.979530] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
    [    1.987368] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
    [    1.995206] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
    [    2.003043] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
    [    2.010881] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
    [    2.018728] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
    [    2.026566] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
    [    2.034403] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
    [    2.042250] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
    [    2.050175] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
    [    2.058105] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
    [    2.066029] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
    [    2.073957] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
    [    2.081910] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
    [    2.089856] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
    [    2.097783] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
    [    2.105705] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
    [    2.113628] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
    [    2.121551] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
    [    2.129474] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
    [    2.137396] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
    [    2.145337] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
    [    2.153262] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
    [    2.161185] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
    [    2.169107] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
    [    2.177030] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
    [    2.184952] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
    [    2.192898] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
    [    2.200948] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
    [    2.208947] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
    [    2.217122] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
    [    2.229872] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
    [    2.246795] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    2.358426] sdhci_am654_probe:4f80000.mmc....
    [    2.359475] sdhci_am654_init:655 4f80000.mmc. enter	....
    [    2.364072] sdhci_am654_probe:4fb0000.mmc....
    [    2.364103] mmc0: CQHCI version 5.10
    [    2.378097] sdhci_am654_init:655 4fb0000.mmc. enter	....
    [    2.378132] DYW regulator_dev_lookup:1797. error supply=vmmc...
    [    2.383489] DYW regulator_dev_lookup:1797. error supply=vqmmc...
    [    2.389598] sdhci_am654_probe:916 4fb0000.mmc. error  ....
    [    2.399545] pinctrl-single 11c000.pinctrl: pin PIN102 already requested by 2150000.spi; cannot claim for 600000.gpio
    [    2.405123] sdhci_am654_probe:938 error out	....
    [    2.415563] pinctrl-single 11c000.pinctrl: pin-102 (600000.gpio) status -22
    [    2.415580] pinctrl-single 11c000.pinctrl: could not request pin 102 (PIN102) from group rpi-header-gpio0-pins-default  on device pinctrl-single
    [    2.420217] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.427148] davinci_gpio 600000.gpio: Error applying setting, reverse things back
    [    2.427177] davinci_gpio: probe of 600000.gpio failed with error -22
    [    2.440690] sdhci_am654_probe:925 normal out	....
    [    2.464997] vdd_mmc1: supplied by vsys_3v3
    [    2.475676] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    2.483048] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    2.490407] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    2.497763] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    2.505064] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    2.525811] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    2.542886] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    2.550466] mmc0: Command Queue Engine enabled
    [    2.556051] mmc0: new HS200 MMC card at address 0001
    [    2.561953] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.566887] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    2.573178] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    2.579374] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (238:0)
    [    2.588377]  mmcblk0: p1 p2
    [    2.609240] m_can_platform 40528000.can: m_can device registered (irq=19, version=32)
    [    2.622099] sdhci_am654_probe:4fb0000.mmc....
    [    2.622821] sdhci_am654_init:655 4fb0000.mmc. enter	....
    [    2.627721] mmc1: CQHCI version 5.10
    [    2.640723] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    2.648097] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    3.693939] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    3.701506] sdhci_am654_probe:925 normal out	....
    [    3.708832] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0
    [    3.719019] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    3.735531] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    3.745037] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    3.775969] mmc1: new ultra high speed DDR50 SDHC card at address b36d
    [    3.783456] mmcblk1: mmc1:b36d SDABC 29.3 GiB
    [    3.789822]  mmcblk1: p1 p2
    [   10.906166] TI DP83867 46000f00.mdio:00: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
    [   10.917732] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
    [   10.948922] IP-Config: Guessing netmask 255.255.255.0
    [   10.954001] IP-Config: Complete:
    [   10.957253]      device=eth0, hwaddr=34:08:e1:5e:9c:b7, ipaddr=192.168.2.58, mask=255.255.255.0, gw=255.255.255.255
    [   10.967689]      host=192.168.2.58, domain=, nis-domain=(none)
    [   10.973578]      bootserver=255.255.255.255, rootserver=192.168.2.78, rootpath=
    [   11.015566] VFS: Mounted root (nfs filesystem) on device 0:20.
    [   11.029483] devtmpfs: mounted
    [   11.034423] Freeing unused kernel memory: 1856K
    [   11.053114] Run /sbin/init as init process
    [   11.782701] systemd[1]: System time before build time, advancing clock.
    [   11.944812] NET: Registered protocol family 10
    [   11.951688] Segment Routing with IPv6
    [   12.010069] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [   12.032473] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [   12.075534] systemd[1]: Set hostname to <tda4vm-sk>.
    [   13.025516] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
    [   13.245055] random: systemd: uninitialized urandom read (16 bytes read)
    [   13.251950] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [   13.264323] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [   13.278710] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [   13.301142] random: systemd: uninitialized urandom read (16 bytes read)
    [   13.310530] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [   13.333132] random: systemd: uninitialized urandom read (16 bytes read)
    [   13.342234] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [   13.365565] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [   13.389463] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [   13.413340] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [   13.429180] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [   13.449139] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [   13.465163] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [   13.483839] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [   13.505190] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [   13.534730] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [   13.557569] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [   13.615374] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [   13.623596] systemd[1]: systemd-journald-dev-log.socket: Socket service systemd-journald.service not loaded, refusing.
    [   13.634333] systemd[1]: Failed to listen on Journal Socket (/dev/log).
    [FAILED] Failed to listen on Journal Socket (/dev/log).
    See 'systemctl status systemd-journald-dev-log.socket' for details.
    [   13.677140] systemd[1]: systemd-journald.socket: Socket service systemd-journald.service not loaded, refusing.
    [   13.687208] systemd[1]: Failed to listen on Journal Socket.
    [FAILED] Failed to listen on Journal Socket.
    See 'systemctl status systemd-journald.socket' for details.
    [   13.726743] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [   13.750917] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [   13.773637] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [   13.801003] systemd[1]: Mounting Huge Pages File System...
    [   13.803643] systemd[200]: dev-hugepages.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   13.840616] systemd[1]: Mounting POSIX Message Queue File System...
    [   13.844265] systemd[201]: dev-mqueue.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   13.880353] systemd[1]: Mounting Kernel Debug File System...
    [   13.883100] systemd[202]: sys-kernel-debug.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   13.917589] systemd[1]: Mounting Temporary Directory (/tmp)...
    [   13.920332] systemd[203]: tmp.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   13.953349] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [   13.955838] systemd[204]: kmod-static-nodes.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
             Starting Create list of st…odes for the current kernel...
    [   13.995986] systemd[1]: Starting Start psplash boot splash screen...
    [   13.998390] systemd[205]: psplash-start.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.068606] systemd[1]: Starting RPC Bind...
    [   14.070817] systemd[206]: rpcbind.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.094641] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [   14.123394] systemd[1]: Starting Load Kernel Modules...
    [   14.125729] systemd[207]: systemd-modules-load.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.166622] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems systemd[208]: systemd-remount-fs.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [0m...
    [   14.215032] systemd[1]: Starting udev Coldplug all Devices...
    [   14.216014] systemd[209]: systemd-udev-trigger.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.256139] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [   14.278172] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [   14.300379] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File Sy[   14.309187] cryptodev: loading out-of-tree module taints kernel.
    stem.
    [   14.321263] cryptodev: disagrees about version of symbol crypto_skcipher_encrypt
    [   14.329072] cryptodev: Unknown symbol crypto_skcipher_encrypt (err -22)
    [   14.337509] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [   14.352658] cryptodev: disagrees about version of symbol fd_install
    [   14.364111] systemd[1]: Mounted Temporary Directory (/tmp).
    [   14.369399] cryptodev: Unknown symbol fd_install (err -22)
    [  OK  ] Mounted Temporary Directory (/tmp) cryptodev: disagrees about version of symbol crypto_skcipher_setkey
    [0m.
    [   14.391483] cryptodev: Unknown symbol crypto_skcipher_setkey (err -22)
    [   14.399007] cryptodev: disagrees about version of symbol crypto_skcipher_decrypt
    [   14.406764] cryptodev: Unknown symbol crypto_skcipher_decrypt (err -22)
    [   14.413694] cryptodev: disagrees about version of symbol __close_fd
    [   14.420166] cryptodev: Unknown symbol __close_fd (err -22)
    [   14.425917] cryptodev: disagrees about version of symbol crypto_alloc_skcipher
    [   14.429044] systemd[1]: Started Create list of static device nodes for the current kernel.
    [   14.433158] cryptodev: Unknown symbol crypto_alloc_skcipher (err -22)
    [  OK  ] Started Create list of sta… nodes[   14.449147] systemd-modules-load[207]: Failed to insert module 'cryptodev': Invalid argument
    [   14.471200] systemd-modules-load[207]: Inserted module 'rpmsg_kdrv_switch'
    [   14.481237] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
    [   14.491521] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
    [   14.503066] systemd[1]: Failed to start Start psplash boot splash screen.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [   14.545136] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [   14.569122] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
    [   14.580498] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
    [   14.591108] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
    [   14.603233] systemd[1]: Failed to start Load Kernel Modules.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [   14.645850] systemd[1]: Started Remount Root and Kernel File Systems.
    [  OK  ] Started Remount Root and Kernel File Systems.
    [   14.674430] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
    [   14.674843] systemd[214]: systemd-udev-trigger.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.683822] random: systemd: uninitialized urandom read (16 bytes read)
    [   14.709503] systemd[1]: Mounting Kernel Configuration File System...
    [   14.719607] systemd[215]: sys-kernel-config.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.752719] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [   14.761458] random: systemd: uninitialized urandom read (16 bytes read)
    [   14.775221] systemd[1]: Starting Flush Journal to Persistent Storage...
    [   14.785658] systemd[216]: systemd-journal-flush.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.813470] random: systemd: uninitialized urandom read (16 bytes read)
    [   14.830835] systemd[1]: Starting Apply Kernel Variables...
    [   14.832445] systemd[217]: systemd-sysctl.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.865913] systemd[1]: Condition check resulted in Create System Users being skipped.
    [   14.884979] systemd[1]: Starting Create Static Device Nodes in /dev...
    [   14.896543] systemd[218]: systemd-tmpfiles-setup-dev.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   14.928959] random: crng init done
    [   14.932371] random: 24 urandom warning(s) missed due to ratelimiting
    [   14.939614] systemd[1]: Mounted Kernel Configuration File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [   14.971490] systemd-sysctl[217]: Couldn't write '1' to 'net/ipv4/tcp_syncookies', ignoring: No such file or directory
    [   14.983479] systemd[1]: systemd-journal-flush.service: Main process exited, code=exited, status=1/FAILURE
    [   14.995025] systemd[1]: systemd-journal-flush.service: Failed with result 'exit-code'.
    [   15.013296] systemd[1]: Failed to start Flush Journal to Persistent Storage.
    [FAILED] Failed to start Flush Journal to Persistent Storage.
    See 'systemctl status systemd-journal-flush.service' for details.
    [   15.062720] systemd[1]: Started Apply Kernel Variables.
    [  OK  ] Started Apply Kernel Variables.
    [   15.112242] systemd[1]: Started Create Static Device Nodes in /dev.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [   15.137843] systemd[1]: Reached target Local File Systems (Pre).
    [  OK  ] Reached target Local File Systems (Pre).
    [   15.170975] systemd[1]: Mounting /media/ram...
             Mounting /media/ram...[   15.179920] systemd[220]: media-ram.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   15.212026] systemd[1]: Mounting /var/volatile...
    [   15.213927] systemd[221]: var-volatile.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   15.255876] systemd[1]: Starting udev Kernel Device Manager...
    [   15.265657] systemd[222]: systemd-udevd.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   15.293264] systemd[1]: Mounted /media/ram.
    [  OK  ] Mounted /media/ram.
    [   15.314383] systemd[1]: Mounted /var/volatile.
    [  OK  ] Mounted /var/volatile.
    [   15.334842] systemd[1]: Condition check resulted in Bind mount volatile /var/cache being skipped.
    [   15.346486] systemd[1]: Condition check resulted in Bind mount volatile /var/lib being skipped.
    [   15.370992] systemd[1]: Starting Load/Save Random Seed...
    [   15.385617] systemd[223]: systemd-random-seed.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   15.401886] systemd[1]: Condition check resulted in Bind mount volatile /var/spool being skipped.
    [   15.424054] systemd[1]: Condition check resulted in Bind mount volatile /srv being skipped.
    [   15.435115] systemd[1]: Reached target Local File Systems.
    [  OK  ] Reached target Local File Systems.
    [   15.462145] systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
    [   15.474677] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    [   15.502144] systemd[1]: Starting Create Volatile Files and Directories...
    [   15.516584] systemd[224]: systemd-tmpfiles-setup.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   15.556120] systemd[1]: Started Load/Save Random Seed.
    [  OK  ] Started Load/Save Random Seed.
    [   15.591829] systemd-tmpfiles[224]: [/usr/lib/tmpfiles.d/legacy.conf:13] Duplicate line for path "/run/lock", ignoring.
    [   15.596114] systemd[1]: Started udev Coldplug all Devices.
    [  OK  ] Started udev Coldplug all Devices.
    [   15.632579] systemd[1]: Starting udev Wait for Complete Device Initialization...
    [   15.635006] systemd[225]: systemd-udev-settle.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   15.853211] systemd[1]: Started udev Kernel Device Manager.
    [  OK  ] Started udev Kernel Device Manager.
    [   15.922443] systemd[1]: Started Create Volatile Files and Directories.
    [  OK  ] Started Create Volatile Files and Directories.
    [   15.955257] systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
    [   15.986069] systemd[1]: Starting Network Time Synchronization...
    [   16.014438] systemd[1]: Condition check resulted in Update is Completed being skipped.
    [   16.037649] systemd[1]: Starting Update UTMP about System Boot/Shutdown...
             Starting Update UTMP about System Boot/Shutdow[   16.053678] systemd[243]: systemd-update-utmp.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    n...
    [   16.144140] systemd[1]: Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [   16.431339] systemd[1]: Started Network Time Synchronization.
    [  OK  ] Started Network Time Synchronization.
    [   16.458245] systemd[1]: Reached target System Time Set.
    [  OK  ] Reached target System Time Set.
    [   16.481212] systemd[1]: Reached target System Time Synchronized.
    [  OK  ] Reached target System Time Synchronized.
    [   16.737964] systemd-udevd[234]: bus@100000: Process '/sbin/modprobe of:NbusT(null)Csimple-bus' failed with exit code 1.
    [   16.877715] systemd-udevd[238]: Fixed MDIO bus.0: Process '/sbin/modprobe platform:Fixed MDIO bus' failed with exit code 1.
    [   16.966563] systemd-udevd[239]: 2120000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   16.980240] systemd-udevd[229]: 2000000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   17.013670] systemd-udevd[228]: 2110000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   17.027493] systemd-udevd[233]: 2130000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   17.049711] systemd-udevd[241]: 2030000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   17.066313] systemd-udevd[235]: 2160000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   17.107543] systemd-udevd[236]: 2010000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   17.120129] systemd-udevd[232]: 2050000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   17.145761] systemd-udevd[240]: 2100000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   17.157201] systemd-udevd[234]: 11c000.pinctrl: Process '/sbin/modprobe of:NpinctrlT(null)Cpinctrl-single' failed with exit code 1.
    [   17.158477] systemd-udevd[231]: 100000.scm-conf: Process '/sbin/modprobe of:Nscm-confT(null)Cti,j721e-system-controllerCsysconCsimple-mfd' failed with exit code 1.
    [   17.177676] systemd-udevd[227]: 2150000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   17.245940] systemd-udevd[229]: 104140.clock-controller: Process '/sbin/modprobe of:Nclock-controllerT(null)Cti,am654-ehrpwm-tbclkCsyscon' failed with exit code 1.
    [   17.273511] systemd-udevd[226]: 100000.scm-conf:mux-controller@4000: Process '/sbin/modprobe of:Nmux-controllerT(null)Cmmio-mux' failed with exit code 1.
    [   17.346077] DYW ads8688_probe:497 enter ....
    [   17.346133] DYW ads8688_probe:526 . ok ....
    [   17.375832] systemd-udevd[237]: 2840000.serial: Process '/sbin/modprobe of:NserialT(null)Cti,j721e-uartCti,am654-uart' failed with exit code 1.
    [   17.428258] systemd-udevd[239]: spi0.0: Process '/sbin/modprobe spi:spidev' failed with exit code 1.
    [   17.438847] DYW ads8688_probe:534 . normal ....
    [   17.438860] ads8688_reset data-0={0x85,0x0,0x0,0x0}
    [   17.469757] systemd-udevd[228]: spi5.0: Process '/sbin/modprobe spi:spidev' failed with exit code 1.
    [   17.514547] systemd-udevd[240]: 2810000.serial: Process '/sbin/modprobe of:NserialT(null)Cti,j721e-uartCti,am654-uart' failed with exit code 1.
    [   17.532646] systemd-udevd[234]: 104080.mux: Process '/sbin/modprobe of:NmuxT(null)Cmmio-mux' failed with exit code 1.
    [   17.577388] DYW ads8688_probe:555 . normal ....
    [   17.593247] systemd-udevd[231]: 3-0048: Process '/sbin/modprobe of:Ni2c-tmp100T(null)Cti,tmp100' failed with exit code 1.
    [   17.604661] ads8688_prog_write data-0={0x0,0xb,0x5,0x0}
    [   17.614719] systemd-udevd[238]: 104044.phy: Process '/sbin/modprobe of:NphyT(null)Cti,j721e-cpsw9g-phy-gmii-sel' failed with exit code 1.
    [   17.625621] systemd-udevd[232]: 5-0070: Process '/sbin/modprobe of:Ni2c-switchT(null)Cnxp,pca9543' failed with exit code 1.
    [   17.653274] systemd-udevd[230]: spi6.0: Process '/sbin/modprobe spi:spidev' failed with exit code 1.
    [   17.670274] systemd-udevd[241]: 2800000.serial: Process '/sbin/modprobe of:NserialT(null)Cti,j721e-uartCti,am654-uart' failed with exit code 1.
    [   17.686568] ads8688_prog_write data-0={0x0,0xd,0x5,0x0}
    [   17.693382] ads8688_prog_write data-0={0x0,0xf,0x5,0x0}
    [   17.708414] ads8688_prog_write data-0={0x0,0x11,0x5,0x0}
    [   17.831242] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [   17.850446] ads8688_AUTO_Mode data-0={0xc0,0x0,0x0,0x0}
    [   17.923753] DYW ads8688_probe:571 . normal .ret=0...
    [   17.926269] DYW ads8688_probe:497 enter ....
    [   17.929175] systemd-udevd[236]: 4a00000.dss: Process '/sbin/modprobe of:NdssT(null)Cti,j721e-dss' failed with exit code 1.
    [   17.932022] DYW ads8688_probe:526 . ok ....
    [   17.947546] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [   17.959657] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [   17.963163] DYW ads8688_probe:534 . normal ....
    [   17.967865] ads8688_reset data-0={0x85,0x0,0x0,0x0}
    [   17.971276] systemd-udevd[232]: 4f80000.mmc: Process '/sbin/modprobe of:NmmcT(null)Cti,j721e-sdhci-8bit' failed with exit code 1.
    [   17.978952] remoteproc remoteproc0: 4d80800000.dsp is available
    [   18.005860] DYW ads8688_probe:555 . normal ....
    [   18.008255] ads8688_prog_write data-0={0x0,0xb,0x5,0x0}
    [   18.108802] systemd-udevd[230]: 4e20000000.gpu: Process '/sbin/modprobe of:NgpuT(null)Cti,j721e-pvrCimg,pvr-ge8430' failed with exit code 1.
    [   18.135028] systemd-udevd[241]: 4fb0000.mmc: Process '/sbin/modprobe of:NmmcT(null)Cti,j721e-sdhci-4bit' failed with exit code 1.
    [   18.155723] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [   18.170487] ads8688_prog_write data-0={0x0,0xd,0x5,0x0}
    [   18.174724] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [   18.183530] ads8688_prog_write data-0={0x0,0xf,0x5,0x0}
    [   18.184644] img_enc 4200000.video-encoder: encoder registered as /dev/video0
    [   18.204125] ads8688_prog_write data-0={0x0,0x11,0x5,0x0}
    [   18.220014] systemd-udevd[239]: 601000.gpio: Process '/sbin/modprobe of:NgpioT(null)Cti,j721e-gpioCti,keystone-gpio' failed with exit code 1.
    [   18.221017] ads8688_AUTO_Mode data-0={0xc0,0x0,0x0,0x0}
    [   18.238142] DYW ads8688_probe:571 . normal .ret=0...
    [   18.254252]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [   18.278706] img_dec 4300000.video-decoder: fw_get_filesystem_firmware  P __getname success
    [   18.297199] img_dec 4300000.video-decoder: loading /lib/firmware/updates/5.10.153-g90c3a58fd2/pvdec_full_bin.fw failed for no such file or directory rcd=-2.
    [   18.299941] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   18.320287] img_dec 4300000.video-decoder: loading /lib/firmware/updates/pvdec_full_bin.fw failed for no such file or directory rcd=-2.
    [   18.323047]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [   18.338714] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [   18.348265] img_dec 4300000.video-decoder: loading /lib/firmware/5.10.153-g90c3a58fd2/pvdec_full_bin.fw failed for no such file or directory rcd=-2.
    [   18.362926] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [   18.390655] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [   18.421390] img_dec 4300000.video-decoder: fw_get_filesystem_firmware kernel_read_file_from_path_initns /lib/firmware/pvdec_full_bin.fw sucess rc=247469
    [   18.459353] img_dec 4300000.video-decoder: decoder registered as /dev/video1
    [   18.529034] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [   18.566106] systemd-udevd[236]: 600000.gpio: Process '/sbin/modprobe of:NgpioT(null)Cti,j721e-gpioCti,keystone-gpio' failed with exit code 1.
    [   18.615011] systemd-udevd[232]: mmc0:0001: Process '/sbin/modprobe mmc:block' failed with exit code 1.
    [   18.631413] systemd-udevd[234]: mmc1:b36d: Process '/sbin/modprobe mmc:block' failed with exit code 1.
    [   18.644740] systemd-udevd[230]: a000000.dp-bridge: Process '/sbin/modprobe of:Ndp-bridgeT(null)Cti,j721e-mhdp8546' failed with exit code 1.
    [   18.707220] remoteproc remoteproc1: 4d81800000.dsp is available
    [   18.713767] systemd-udevd[241]: 70000000.sram: Process '/sbin/modprobe of:NsramT(null)Cmmio-sram' failed with exit code 1.
    [   18.727335] systemd-udevd[233]: bus@100000:bus@28380000: Process '/sbin/modprobe of:NbusT(null)Csimple-bus' failed with exit code 1.
    [   18.749925] systemd-udevd[238]: bus@100000:main-navss: Process '/sbin/modprobe of:Nmain-navssT(null)Csimple-mfd' failed with exit code 1.
    [   18.787719] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [   18.803741] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   18.815928] systemd-udevd[227]: bus@100000:interrupt-controller0: Process '/sbin/modprobe of:Ninterrupt-controller0T(null)Cti,sci-intr' failed with exit code 1.
    [   18.860469] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [   18.911083] platform 41000000.r5f: configured R5F for IPC-only mode
    [   18.917683] systemd-udevd[232]: bus@100000:wiz@5000000: Process '/sbin/modprobe of:NwizT(null)Cti,j721e-wiz-16g' failed with exit code 1.
    [   18.935268] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   18.977268]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [   18.989758] remoteproc remoteproc2: 41000000.r5f is available
    [   19.091361] remoteproc remoteproc2: attaching to 41000000.r5f
    [   19.113889] systemd-udevd[231]: 40300000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   19.153666] systemd-udevd[230]: bus@100000:wiz@5010000: Process '/sbin/modprobe of:NwizT(null)Cti,j721e-wiz-16g' failed with exit code 1.
    [   19.161161] systemd-udevd[241]: 40310000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   19.261669] systemd-udevd[227]: 40b00000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   19.268374] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   19.274916] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [   19.281171]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [   19.294271] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
    [   19.302330] systemd-udevd[233]: 40320000.spi: Process '/sbin/modprobe of:NspiT(null)Cti,am654-mcspiCti,omap4-mcspi' failed with exit code 1.
    [   19.314058] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   19.316391] systemd-udevd[232]: 40a00000.serial: Process '/sbin/modprobe of:NserialT(null)Cti,j721e-uartCti,am654-uart' failed with exit code 1.
    [   19.341706] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [   19.365957]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   19.389334] systemd-udevd[232]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
    [   19.413721] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [   19.421247] remoteproc remoteproc3: 64800000.dsp is available
    [   19.432736] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   19.439098]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [   19.444083] systemd-udevd[237]: 40b10000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   19.457765] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
    [   19.465658] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [   19.476147] remoteproc remoteproc3: attaching to 64800000.dsp
    [   19.482524] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [   19.518553] remoteproc remoteproc3: unsupported resource 65538
    [   19.525038] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [   19.531715]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [   19.542256] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   19.544338] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [   19.548576]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   19.566577] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
    [   19.571343] systemd-udevd[230]: 40f00000.syscon: Process '/sbin/modprobe of:NsysconT(null)CsysconCsimple-mfd' failed with exit code 1.
    [   19.605327] platform 5c00000.r5f: configured R5F for IPC-only mode
    [   19.721830] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   19.737708] systemd-udevd[239]: 42110000.gpio: Process '/sbin/modprobe of:NgpioT(null)Cti,j721e-gpioCti,keystone-gpio' failed with exit code 1.
    [   19.781240] systemd-udevd[237]: 4301c000.pinctrl: Process '/sbin/modprobe of:NpinctrlT(null)Cpinctrl-single' failed with exit code 1.
    [   19.787883] systemd-udevd[227]: 43000014.chipid: Process '/sbin/modprobe of:NchipidT(null)Cti,am654-chipid' failed with exit code 1.
    [   19.795437] remoteproc remoteproc4: 5c00000.r5f is available
    [   19.810563] systemd-udevd[241]: 42040000.temperature-sensor: Process '/sbin/modprobe of:Ntemperature-sensorT(null)Cti,j721e-vtm' failed with exit code 1.
    [   19.811394] remoteproc remoteproc4: attaching to 5c00000.r5f
    [   19.830896] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [   19.837769]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   19.851680] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   19.864841]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   19.866567] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [   19.871607] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
    [   19.917571] systemd-udevd[238]: 41c00000.sram: Process '/sbin/modprobe of:NsramT(null)Cmmio-sram' failed with exit code 1.
    [   19.960247] platform 5d00000.r5f: configured R5F for IPC-only mode
    [   19.967414] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   19.973830] systemd-udevd[233]: 42120000.i2c: Process '/sbin/modprobe of:Ni2cT(null)Cti,j721e-i2cCti,omap4-i2c' failed with exit code 1.
    [   20.023415] systemd-udevd[238]: 40f04040.phy: Process '/sbin/modprobe of:NphyT(null)Cti,am654-phy-gmii-sel' failed with exit code 1.
    [   20.025342] systemd-udevd[231]: 44083000.dmsc: Process '/sbin/modprobe of:NdmscT(null)Cti,k2g-sci' failed with exit code 1.
    [   20.063994] remoteproc remoteproc5: 5d00000.r5f is available
    [   20.074427] remoteproc remoteproc5: attaching to 5d00000.r5f
    [   20.193225] systemd-udevd[227]: 46000000.ethernet: Process '/sbin/modprobe of:NethernetT(null)Cti,j721e-cpsw-nuss' failed with exit code 1.
    [   20.223078] systemd-udevd[237]: 47000000.fss: Process '/sbin/modprobe of:NfssT(null)Csimple-bus' failed with exit code 1.
    [   20.237355] systemd-udevd[228]: bus@100000:bus@28380000:mcu-navss: Process '/sbin/modprobe of:Nmcu-navssT(null)Csimple-mfd' failed with exit code 1.
    [   20.251611] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [   20.268011] systemd-udevd[230]: bus@100000:bus@28380000:interrupt-controller2: Process '/sbin/modprobe of:Ninterrupt-controller2T(null)Cti,sci-intr' failed with exit code 1.
    [   20.398323]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   20.414110] systemd-udevd[229]: 44083000.dmsc:clocks: Process '/sbin/modprobe of:NclocksT(null)Cti,k2g-sci-clk' failed with exit code 1.
    [   20.437143] systemd-udevd[231]: 31010000.pat: Process '/sbin/modprobe of:NpatT(null)Cti,j721e-pat' failed with exit code 1.
    [   20.438323] systemd-udevd[240]: 44083000.dmsc:reset-controller: Process '/sbin/modprobe of:Nreset-controllerT(null)Cti,sci-reset' failed with exit code 1.
    [   20.466946] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   20.476092]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   20.481674] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   20.490347] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
    [   20.491933] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   20.525320] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [   20.534309] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [   20.543685] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   20.545703] systemd-udevd[237]: Using default interface naming scheme 'v243'.
    [   20.550325] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [   20.604978] systemd-udevd[237]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
    [   20.611095] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [   20.633115] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [   20.665880] systemd-udevd[233]: 30e00000.spinlock: Process '/sbin/modprobe of:NspinlockT(null)Cti,am654-hwspinlock' failed with exit code 1.
    [   20.678792] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [   20.686130] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [   20.697232] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   20.713169] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [   20.729145] systemd-udevd[241]: 44083000.dmsc:power-controller: Process '/sbin/modprobe of:Npower-controllerT(null)Cti,sci-pm-domain' failed with exit code 1.
    [   20.733285] systemd-udevd[238]: 31011000.pat: Process '/sbin/modprobe of:NpatT(null)Cti,j721e-pat' failed with exit code 1.
    [   20.771655] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   20.804648] systemd-udevd[232]: 31012000.pat: Process '/sbin/modprobe of:NpatT(null)Cti,j721e-pat' failed with exit code 1.
    [   20.831552] systemd-udevd[227]: 46000f00.mdio: Process '/sbin/modprobe of:NmdioT(null)Cti,cpsw-mdioCti,davinci_mdio' failed with exit code 1.
    [   20.870038] remoteproc remoteproc6: 5e00000.r5f is available
    [   20.881473] remoteproc remoteproc6: fw_get_filesystem_firmware   __getname success
    [   20.893292] remoteproc remoteproc6: loading /lib/firmware/updates/5.10.153-g90c3a58fd2/j7-main-r5f1_0-fw failed for no such file or directory rcd=-2.
    [   20.909039] platform 5f00000.r5f: configured R5F for remoteproc mode
    [   20.912219] remoteproc remoteproc6: loading /lib/firmware/updates/j7-main-r5f1_0-fw failed for no such file or directory rcd=-2.
    [   20.930705] remoteproc remoteproc6: loading /lib/firmware/5.10.153-g90c3a58fd2/j7-main-r5f1_0-fw failed for no such file or directory rcd=-2.
    [   20.936309] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [   20.973794] remoteproc remoteproc6: fw_get_filesystem_firmware kernel_read_file_from_path_initns /lib/firmware/j7-main-r5f1_0-fw sucess rc=187288
    [   20.997015] remoteproc remoteproc6: powering up 5e00000.r5f
    [   21.002709] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 187288
    [   21.011562] remoteproc remoteproc7: 5f00000.r5f is available
    [   21.017498] remoteproc remoteproc7: fw_get_filesystem_firmware   __getname success
    [   21.028286] remoteproc remoteproc7: loading /lib/firmware/updates/5.10.153-g90c3a58fd2/j7-main-r5f1_1-fw failed for no such file or directory rcd=-2.
    [   21.042015]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   21.042278] remoteproc remoteproc7: loading /lib/firmware/updates/j7-main-r5f1_1-fw failed for no such file or directory rcd=-2.
    [   21.057687] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   21.064807] remoteproc remoteproc7: loading /lib/firmware/5.10.153-g90c3a58fd2/j7-main-r5f1_1-fw failed for no such file or directory rcd=-2.
    [   21.080060]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   21.092994] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
    [   21.108365] systemd-udevd[232]: 285c0000.dma-controller: Process '/sbin/modprobe of:Ndma-controllerT(null)Cti,j721e-navss-mcu-udmap' failed with exit code 1.
    [   21.122734] systemd-udevd[230]: 2b800000.ringacc: Process '/sbin/modprobe of:NringaccT(null)Cti,am654-navss-ringacc' failed with exit code 1.
    [   21.128388] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [   21.146262] remoteproc remoteproc7: fw_get_filesystem_firmware kernel_read_file_from_path_initns /lib/firmware/j7-main-r5f1_1-fw sucess rc=187288
    [   21.160513] remoteproc remoteproc7: powering up 5f00000.r5f
    [   21.167288] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 187288
    [   21.188310]  remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [   21.199841] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   21.209092]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   21.216292] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
    [   21.274702] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [   21.346505] systemd-udevd[233]: 31014000.pat: Process '/sbin/modprobe of:NpatT(null)Cti,j721e-pat' failed with exit code 1.
    [   21.367545] systemd-udevd[240]: 31013000.pat: Process '/sbin/modprobe of:NpatT(null)Cti,j721e-pat' failed with exit code 1.
    [   21.385299] systemd-udevd[227]: 310d0000.cpts: Process '/sbin/modprobe of:NcptsT(null)Cti,j721e-cpts' failed with exit code 1.
    [   21.495048] systemd-udevd[238]: 46000f00.mdio:00: Process '/sbin/modprobe of:Nethernet-phyT(null)' failed with exit code 1.
    [   21.699222] systemd-udevd[232]: 31f84000.mailbox: Process '/sbin/modprobe of:NmailboxT(null)Cti,am654-mailbox' failed with exit code 1.
    [   21.741145] systemd-udevd[237]: 31f80000.mailbox: Process '/sbin/modprobe of:NmailboxT(null)Cti,am654-mailbox' failed with exit code 1.
    [   21.741190] systemd-udevd[240]: 32c00000.mailbox: Process '/sbin/modprobe of:NmailboxT(null)Cti,am654-secure-proxy' failed with exit code 1.
    [*     ] A start job is running for udev Wai…vice Initialization (8s / 3min 2s)
    [   21.773139] systemd-udevd[230]: 31f81000.mailbox: Process '/sbin/modprobe of:NmailboxT(null)Cti,am654-mailbox' failed with exit code 1.
    [   21.787665] systemd-udevd[239]: 33d00000.interrupt-controller: Process '/sbin/modprobe of:Ninterrupt-controllerT(null)Cti,sci-inta' failed with exit code 1.
    [   21.832472] systemd-udevd[235]: 31150000.dma-controller: Process '/sbin/modprobe of:Ndma-controllerT(null)Cti,j721e-navss-main-udmap' failed with exit code 1.
    [   21.851853] systemd-udevd[227]: 3c000000.ringacc: Process '/sbin/modprobe of:NringaccT(null)Cti,am654-navss-ringacc' failed with exit code 1.
    [   21.872488] systemd-udevd[226]: 31f82000.mailbox: Process '/sbin/modprobe of:NmailboxT(null)Cti,am654-mailbox' failed with exit code 1.
    [   21.908726] systemd-udevd[238]: 31f83000.mailbox: Process '/sbin/modprobe of:NmailboxT(null)Cti,am654-mailbox' failed with exit code 1.
    [   21.909929] systemd-udevd[237]: bus@100000:wiz@5020000: Process '/sbin/modprobe of:NwizT(null)Cti,j721e-wiz-16g' failed with exit code 1.
    [   21.924105] systemd-udevd[233]: 36600000.iommu: Process '/sbin/modprobe of:NiommuT(null)Carm,smmu-v3' failed with exit code 1.
    [   22.042854] systemd-udevd[230]: bus@100000:wiz@5030000: Process '/sbin/modprobe of:NwizT(null)Cti,j721e-wiz-16g' failed with exit code 1.
    [***   ] A start job is running for udev Wai…vice Initialization (9s / 3min 2s)
    [   22.944211] systemd-udevd[231]: firmware:optee: Process '/sbin/modprobe of:NopteeT(null)Clinaro,optee-tz' failed with exit code 1.
    [   22.975745] systemd-udevd[226]: firmware:psci: Process '/sbin/modprobe of:NpsciT(null)Carm,psci-1.0' failed with exit code 1.
    [   23.007699] systemd-udevd[234]: 5020000.serdes: Process '/sbin/modprobe of:NserdesT(null)Cti,sierra-phy-t0' failed with exit code 1.
    [   23.085257] systemd-udevd[238]: fixedregulator-sd: Process '/sbin/modprobe of:Nfixedregulator-sdT(null)Cregulator-fixed' failed with exit code 1.
    [   23.099821] systemd-udevd[239]: c000000.ethernet: Process '/sbin/modprobe of:NethernetT(null)Cti,j721e-cpswxg-nuss' failed with exit code 1.
    [   23.110355] systemd-udevd[232]: 5030000.serdes: Process '/sbin/modprobe of:NserdesT(null)Cti,sierra-phy-t0' failed with exit code 1.
    [   23.114460] systemd-udevd[240]: bus@100000:wiz@5050000: Process '/sbin/modprobe of:NwizT(null)Cti,j721e-wiz-10g' failed with exit code 1.
    [   23.133648] systemd-udevd[230]: dma_buf_phys: Process '/sbin/modprobe of:Ndma_buf_physT(null)Cti,dma_buf_phys' failed with exit code 1.
    [   23.185123] systemd-udevd[227]: fixedregulator-vusb-main5v0: Process '/sbin/modprobe of:Nfixedregulator-vusb-main5v0T(null)Cregulator-fixed' failed with exit code 1.
    [ ***  ] A start job is running for udev Wai…ice Initialization (10s / 3min 2s)
    [   23.376700] systemd-udevd[237]: gpio-regulator-tps659411: Process '/sbin/modprobe of:Ngpio-regulator-tps659411T(null)Cregulator-gpio' failed with exit code 1.
    [   23.397141] systemd-udevd[226]: fixedregulator-vsys3v3: Process '/sbin/modprobe of:Nfixedregulator-vsys3v3T(null)Cregulator-fixed' failed with exit code 1.
    [   23.541539] systemd-udevd[235]: reg-dummy: Process '/sbin/modprobe platform:reg-dummy' failed with exit code 1.
    [   23.588532] systemd-udevd[234]: serial8250: Process '/sbin/modprobe platform:serial8250' failed with exit code 1.
    [   23.601031] systemd-udevd[239]: l2-cache0: Process '/sbin/modprobe of:Nl2-cache0T(null)Ccache' failed with exit code 1.
    [   23.608153] systemd-udevd[238]: 5050000.serdes: Process '/sbin/modprobe of:NserdesT(null)Cti,j721e-serdes-10g' failed with exit code 1.
    [   23.662166] systemd-udevd[232]: timer-cl0-cpu0: Process '/sbin/modprobe of:Ntimer-cl0-cpu0T(null)Carm,armv8-timer' failed with exit code 1.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [   25.602985] systemd[1]: Found device /dev/mmcblk0p1.
    [  OK  ] Found device /dev/mmcblk0p1.
    [   25.672433] systemd[1]: Starting File System Check on /dev/mmcblk0p1...
    [   25.673520] systemd[782]: systemd-fsck@dev-mmcblk0p1.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   25.760308] systemd[1]: Found device /dev/mmcblk1p2.
    [  OK  ] Found device /dev/mmcblk1p2.
    [   25.819060] systemd[1]: Starting File System Check on /dev/mmcblk1p2...
    [   25.827152] systemd[785]: systemd-fsck@dev-mmcblk1p2.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   26.079134] systemd[1]: Started File System Check on /dev/mmcblk0p1.
    [  OK  ] Started File System Check on /dev/mmcblk0p1.
    [   26.121965] systemd[1]: Mounting /run/media/mmcblk0p1...
    [   26.134340] systemd[803]: run-media-mmcblk0p1.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   26.228855] systemd[1]: Mounted /run/media/mmcblk0p1.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [   26.266349] systemd-udevd[237]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
    [   26.310963] systemd[1]: Started File System Check on /dev/mmcblk1p2.
    [  OK  ] Started File System Check on /dev/mmcblk1p2.
    [   26.339224] systemd[1]: Mounting /run/media/mmcblk1p2...
    [   26.340309] systemd[806]: run-media-mmcblk1p2.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   26.429131] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [   26.454786] systemd[1]: Mounted /run/media/mmcblk1p2.
    [  OK  ] Mounted /run/media/mmcblk1p2.
    [   26.534678] systemd[1]: Found device /dev/mmcblk0p2.
    [  OK  ] Found device /dev/mmcblk0p2.
    [   26.563832] systemd[1]: Starting File System Check on /dev/mmcblk0p2...
             Starting File System Check on /dev/mmcblk0p2   26.581518] systemd[814]: systemd-fsck@dev-mmcblk0p2.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    0m...
    [   26.788202] systemd[1]: Started File System Check on /dev/mmcblk0p2.
    [  OK  ] Started File System Check on /dev/mmcblk0p2.
    [   26.810813] systemd-vconsole-setup[819]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
    [   26.823031] systemd-vconsole-setup[819]: Fonts will not be copied to remaining consoles
    [   26.849431] systemd[1]: Mounting /run/media/mmcblk0p2...
    [   26.859151] systemd[826]: run-media-mmcblk0p2.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   26.927873] usbcore: registered new interface driver usbfs
    [   26.935653] usbcore: registered new interface driver hub
    [   26.941725] usbcore: registered new device driver usb
    [   27.003762] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [   27.027308] systemd[1]: Mounted /run/media/mmcblk0p2.
    [  OK  ] Mounted /run/media/mmcblk0p2.
    [   27.046218] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   27.054111] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   27.085918] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   27.146561] systemd-udevd[232]: video0: Failed to apply ACL: Operation not supported
    [   27.200471] systemd[1]: Found device /dev/mmcblk1p1.
    [  OK  ] Found device /dev/mmcblk1p1.
    [   27.223635] systemd[1]: Starting File System Check on /dev/mmcblk1p1...
    [   27.226245] systemd[842]: systemd-fsck@dev-mmcblk1p1.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   27.350276] remoteproc remoteproc8: b034000.pru is available
    [   27.411829] remoteproc remoteproc9: b004000.rtu is available
    [   27.471078] systemd-udevd[241]: video1: Failed to apply ACL: Operation not supported
    [   27.532127] systemd-udevd[234]: b026000.cfg: Process '/sbin/modprobe of:NcfgT(null)Cti,pruss-cfgCsyscon' failed with exit code 1.
    [   27.590178] systemd-udevd[228]: b033000.mii-g-rt: Process '/sbin/modprobe of:Nmii-g-rtT(null)Cti,pruss-mii-gCsyscon' failed with exit code 1.
    [   27.593107] systemd-udevd[240]: b032000.mii-rt: Process '/sbin/modprobe of:Nmii-rtT(null)Cti,pruss-miiCsyscon' failed with exit code 1.
    [   27.606798] systemd[1]: Started File System Check on /dev/mmcblk1p1.
    [   27.617096] remoteproc remoteproc10: b00a000.txpru is available
    [  OK  ] Started File System Check on /dev/mmcblk1p1.
    [   27.642095] remoteproc remoteproc11: b038000.pru is available
    [   27.661958] systemd[1]: Mounting /run/media/mmcblk1p1...
    [   27.662458] remoteproc remoteproc12: b006000.rtu is available
             Mounting /run/media/mmcblk1p1...[   27.677779] systemd[852]: run-media-mmcblk1p1.mount: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   27.680734] remoteproc remoteproc13: b00c000.txpru is available
    [   27.711319] remoteproc remoteproc14: b134000.pru is available
    [   27.811104] systemd[1]: Mounted /run/media/mmcblk1p1.
    [  OK  ] Mounted /run/media/mmcblk1p1.
    [   27.834741] remoteproc remoteproc15: b104000.rtu is available
    [   27.857609] systemd-udevd[239]: b126000.cfg: Process '/sbin/modprobe of:NcfgT(null)Cti,pruss-cfgCsyscon' failed with exit code 1.
    [   27.873211] systemd-udevd[240]: b132000.mii-rt: Process '/sbin/modprobe of:Nmii-rtT(null)Cti,pruss-miiCsyscon' failed with exit code 1.
    [   27.919859] remoteproc remoteproc16: b10a000.txpru is available
    [   28.009686] remoteproc remoteproc17: b138000.pru is available
    [   28.016407] systemd-udevd[241]: 41000000.r5f: Process '/sbin/modprobe of:Nr5fT(null)Cti,j721e-r5f' failed with exit code 1.
    [   28.083221] systemd-udevd[232]: 41400000.r5f: Process '/sbin/modprobe of:Nr5fT(null)Cti,j721e-r5f' failed with exit code 1.
    [   28.094817] systemd-udevd[234]: b133000.mii-g-rt: Process '/sbin/modprobe of:Nmii-g-rtT(null)Cti,pruss-mii-gCsyscon' failed with exit code 1.
    [   28.124136] remoteproc remoteproc18: b106000.rtu is available
    [   28.151519] remoteproc remoteproc19: b10c000.txpru is available
    [   28.745953] systemd-udevd[234]: 5d00000.r5f: Process '/sbin/modprobe of:Nr5fT(null)Cti,j721e-r5f' failed with exit code 1.
    [   28.797672] systemd-udevd[230]: 5c00000.r5f: Process '/sbin/modprobe of:Nr5fT(null)Cti,j721e-r5f' failed with exit code 1.
    [   28.865111] systemd-udevd[235]: 5e00000.r5f: Process '/sbin/modprobe of:Nr5fT(null)Cti,j721e-r5f' failed with exit code 1.
    [   28.910148] systemd-udevd[239]: 5f00000.r5f: Process '/sbin/modprobe of:Nr5fT(null)Cti,j721e-r5f' failed with exit code 1.
    [   29.327419] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [   29.335142] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [   29.345310] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
    [   29.355670] xhci-hcd xhci-hcd.0.auto: irq 514, io mem 0x06410000
    [   29.364579] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   29.374628] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   29.384336] usb usb1: Product: xHCI Host Controller
    [   29.389668] usb usb1: Manufacturer: Linux 5.10.153-g90c3a58fd2 xhci-hcd
    [   29.396812] usb usb1: SerialNumber: xhci-hcd.0.auto
    [   29.404392] hub 1-0:1.0: USB hub found
    [   29.408302] hub 1-0:1.0: 1 port detected
    [   29.416368] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [   29.425799] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [   29.433786] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [   29.440531] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   29.449006] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [   29.457304] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   29.464546] usb usb2: Product: xHCI Host Controller
    [   29.469441] usb usb2: Manufacturer: Linux 5.10.153-g90c3a58fd2 xhci-hcd
    [   29.476068] usb usb2: SerialNumber: xhci-hcd.0.auto
    [   29.481847] hub 2-0:1.0: USB hub found
    [   29.485692] hub 2-0:1.0: 1 port detected
    [   29.763144] systemd[1]: Started udev Wait for Complete Device Initialization.
    [  OK  ] Started udev Wait for Complete Device Initialization.
    [   29.794945] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
    [   29.797239] systemd[913]: rngd.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [   29.829564] systemd[1]: Reached target System Initialization.
    [  OK  ] Reached target System Initialization.
    [   29.855816] systemd[1]: logrotate.timer: Not using persistent file timestamp Mon 2022-12-19 00:00:21 UTC as it is in the future.
    [   29.869533] systemd[1]: Started Daily rotation of log files.
    [  OK  ] Started Daily rotation of log files.
    [   29.891102] systemd[1]: Started Daily Cleanup of Temporary Directories.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [   29.917189] systemd[1]: Reached target Timers.
    [  OK  ] Reached target Timers.
    [   29.938918] systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [   29.962925] systemd[1]: Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [   29.999630] systemd[1]: Starting Docker Socket for the API.
    [   30.027326] systemd[1]: Listening on dropbear.socket.
    [  OK  ] Listening on dropbear.socket.
    [   30.061917] systemd[1]: Starting Reboot and dump vmcore via kexec...
    [   30.062636] systemd[917]: kdump.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.098912] systemd[1]: Listening on Docker Socket for the API.
    [  OK  ] Listening on Docker Socket for the API.
    [   30.125776] systemd[1]: Reached target Sockets.
    [  OK  ] Reached target Sockets.
    [   30.141318] systemd[1]: Reached target Basic System.
    [  OK  ] Reached target Basic System.
    [   30.169901] systemd[1]: Started Job spooling tools.
    [   30.170648] systemd[919]: atd.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [  OK  ] Started Job spooling tools.
    [   30.207199] systemd[1]: Started Periodic Command Scheduler.
    [  OK  ] Started Periodic Command Scheduler systemd[920]: crond.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [0m.
    [   30.254607] systemd[1]: Started D-Bus System Message Bus.
    [   30.255806] systemd[921]: dbus.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [  OK  ] Started D-Bus System Message Bus.
    [   30.334864] systemd[1]: Starting DEMO...
    [   30.346750] systemd[922]: demo.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
             Starting DEMO...
    [   30.376621] systemd[1]: Starting Print notice about GPLv3 packages...
    [   30.389012] systemd[923]: gplv3-notice.service: Failed to execute command: No such file or directory
    [   30.405968] systemd[1]: Starting set host name as per compatible name...
    [   30.408425] systemd[924]: hostname-update.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.425447] systemd[923]: gplv3-notice.service: Failed at step EXEC spawning /etc/init.d/gplv3-notice: No such file or directory
    [   30.511945] systemd[1]: Starting IPv6 Packet Filtering Framework...
    [   30.514564] systemd[928]: ip6tables.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.553742] systemd[1]: Starting IPv4 Packet Filtering Framework...
    [   30.555846] systemd[929]: iptables.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.597562] systemd[1]: Started irqbalance daemon.
    [  OK  ] Started irqbalance daemon.
    [   30.613252] systemd[931]: irqbalanced.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.641993] systemd[1]: Starting Telephony service...
    [   30.643941] systemd[932]: ofono.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.698003] systemd[1]: Starting Update pmic registers for tda4vm-sk to disable safety feature on power rails...
    [   30.731066] systemd[934]: pmic-fix.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
             Starting Update pmic regis…fety feature on power rails...
    [   30.779170] systemd[1]: Starting rc.pvr.service...
    [   30.779694] systemd[935]: rc.pvr.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.833366] systemd[1]: Starting startwlanap...
    [   30.853862] systemd[936]: startwlanap.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.876454] systemd[1]: Starting startwlansta...
    [   30.879007] systemd[938]: startwlansta.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   30.936622] systemd[938]: startwlansta.service: Failed to execute command: No such file or directory
    [   30.941211] systemd[1]: Starting Login Service...
    [   30.959723] systemd[938]: startwlansta.service: Failed at step EXEC spawning /etc/init.d/startwlansta.sh: No such file or directory
    [   30.973592] systemd[936]: startwlanap.service: Failed to execute command: No such file or directory
    systemd-logind.service: Failed to connect stdout [   30.998464] systemd[1]: Started TEE Supplicant.
    [   31.004647] systemd[942]: tee-supplicant.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [  OK  ] Started TEE Supplicant.
    [   31.049984] systemd[1]: Starting Update weston ini background image based on the platform name...
    [   31.068842] systemd[943]: weston-bg-update.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
             Starting Update weston ini… based on the platform name...
    [   31.108382] systemd[1]: Started Reboot and dump vmcore via kexec.
    [  OK  ] Started Reboot and dump vmcore via kexec.
    [   31.146669] systemd[1]: Started DEMO.
    [  OK  ] Started DEMO.
    [   31.166517] systemd[1]: gplv3-notice.service: Main process exited, code=exited, status=203/EXEC
    [   31.187235] systemd[1]: gplv3-notice.service: Failed with result 'exit-code'.
    [   31.196157] systemd[936]: startwlanap.service: Failed at step EXEC spawning /etc/init.d/startwlanap.sh: No such file or directory
    [   31.212208] systemd[1]: Failed to start Print notice about GPLv3 packages.
    [   31.220631] systemd[943]: weston-bg-update.service: Failed to execute command: No such file or directory
    [FAILED] Failed to start Print notice about GPLv3 packages.
    See 'systemctl status gplv3-notice.service' for details.
    [   31.262598] systemd[1]: Started set host name as per compatible name.
    [  OK  ] Started set host name as per compatible name.
    [   31.298952] systemd[1]: Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [   31.336337] systemd[1]: Started IPv4 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [   31.362014] systemd[943]: weston-bg-update.service: Failed at step EXEC spawning /etc/init.d/weston-bg-update: No such file or directory
    [   31.376245] systemd[1]: startwlanap.service: Main process exited, code=exited, status=203/EXEC
    [   31.385076] systemd[1]: startwlanap.service: Failed with result 'exit-code'.
    [   31.396524] systemd[1]: Failed to start startwlanap.
    [FAILED] Failed to start startwlanap.
    See 'systemctl status startwlanap.service' for details.
    [   31.438570] systemd[1]: startwlansta.service: Main process exited, code=exited, status=203/EXEC
    [   31.455301] systemd[1]: startwlansta.service: Failed with result 'exit-code'.
    [   31.473572] systemd[1]: Failed to start startwlansta.
    [FAILED] Failed to start startwlansta.
    See 'systemctl status startwlansta.service' for details.
    [   31.514421] systemd[1]: weston-bg-update.service: Main process exited, code=exited, status=203/EXEC
    [   31.534522] systemd[1]: weston-bg-update.service: Failed with result 'exit-code'.
    [   31.573150] systemd[1]: Failed to start Update weston ini background image based on the platform name.
    [   31.603228] Bluetooth: Core ver 2.22
    [FAILED] Failed to start Update wes…ge based on the platform name.
    [   31.613110] NET: Registered protocol family 31
    [   31.622619] Bluetooth: HCI device and connection manager initialized
    See 'systemctl status weston-bg-update.service' for details.
    [   31.636999] Bluetooth: HCI socket layer initialized
    [   31.644338] Bluetooth: L2CAP socket layer initialized
    [   31.664994] Bluetooth: SCO socket layer initialized
    [   31.675133] systemd[1]: Reached target Network (Pre).
    [  OK  ] Reached target Network (Pre).
    [   31.701616] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [   31.747886] systemd[1]: Starting Network Service...
    [   31.774796] systemd[1]: Started Telephony service.
    [  OK  ] Started Telephony service.
    [   31.786090] systemd[962]: systemd-networkd.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   31.991444] systemd[1]: Started Update pmic registers for tda4vm-sk to disable safety feature on power rails.
    [  OK  ] Started Update pmic regist…safety feature on power rails.
    systemd-logind.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   32.533213] systemd[1]: Started Network Service.
    [  OK  ] Started Network Service.
    [   32.560646] systemd[1]: Starting Wait for Network to be Configured...
    [   32.563011] systemd[970]: systemd-networkd-wait-online.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   32.615046] systemd[1]: Starting Network Name Resolution...
    [   32.698185] systemd[1]: Started Login Service.
    [  OK  ] Started Login Service.
    [   32.794845] systemd[1]: Started Wait for Network to be Configured.
    [  OK  ] Started Wait for Network to be Configured.
    [   33.244068] systemd[1]: Started Network Name Resolution.
    [  OK  ] Started Network Name Resolution.
    [   33.267039] systemd[1]: Reached target Network.
    [  OK  ] Reached target Network.
    [   33.289974] systemd[1]: Reached target Network is Online.
    [  OK  ] Reached target Network is Online.
    [   33.314051] systemd[1]: Reached target Host and Network Name Lookups.
    [  OK  ] Reached target Host and Network Name Lookups.
    [   33.351250] systemd[972]: avahi-daemon.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   33.353737] systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
    [   33.413616] systemd[973]: bt-enable.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   33.415040] systemd[1]: Starting Enable and configure wl18xx bluetooth stack...
    [   33.437375] systemd[973]: bt-enable.service: Failed to execute command: No such file or directory
    [   33.451562] systemd[973]: bt-enable.service: Failed at step EXEC spawning /etc/init.d/bt-enable.sh: No such file or directory
    [   33.488515] systemd[1]: Starting Docker Application Container Engine...
    [   33.490075] systemd[974]: docker.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   33.531698] systemd[1]: Started Edge AI Init.
    [  OK  ] Started Edge AI Init.
    [   33.605022] systemd[1]: Started NFS status monitor for NFSv2/3 locking..
    [   33.606394] systemd[977]: nfs-statd.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
    [   33.668097] systemd[1]: Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Simple Network Ma…ent Protocol (SNM[   33.698661] systemd[978]: snmpd.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    P) Daemon....
    [   33.735231] systemd[1]: Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [   33.735800] systemd[979]: strongswan-starter.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
    [   33.786967] systemd[1]: Starting Permit User Sessions...
    [   33.788266] systemd[981]: systemd-user-sessions.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   33.839545] systemd[1]: bt-enable.service: Main process exited, code=exited, status=203/EXEC
    [   33.866062] systemd[1]: bt-enable.service: Failed with result 'exit-code'.
    [   33.901532] systemd[1]: Failed to start Enable and configure wl18xx bluetooth stack.
    [FAILED] Failed to start Enable and…figure wl18xx bluetooth stack.
    See 'systemctl status bt-enable.service' for details.
    [   33.953085] systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [   34.141587] systemd[1]: Started Permit User Sessions.
    [  OK  ] Started Permit User Sessions.
    [   34.185638] systemd[1]: Started Getty on tty1.
    [  OK  ] Started Getty on tty1.
    [   34.242210] systemd[1]: Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS2.
    [   34.296368] systemd[1]: Started Serial Getty on ttyS3.
    [  OK  ] Started Serial Getty on ttyS3.
    [   34.328663] systemd[1]: Reached target Login Prompts.
    [  OK  ] Reached target Login Prompts.
    [   34.382574] systemd[1]: Starting Synchronize System and HW clocks...
             Starting Synchronize System and HW clocks.[   34.413135] systemd[987]: sync-clocks.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   34.954703] systemd[1]: sync-clocks.service: Main process exited, code=exited, status=1/FAILURE
    [   34.979572] systemd[1]: sync-clocks.service: Failed with result 'exit-code'.
    [   35.018907] systemd[1]: Failed to start Synchronize System and HW clocks.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    ipsec_starter[979]: Starting strongSwan 5.8.4 IPsec [starter]...
    [   38.543124] systemd[985]: serial-getty@ttyS2.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   38.543718] systemd[986]: serial-getty@ttyS3.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   38.571815] systemd[975]: edgeai-init.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   38.585419] systemd[984]: getty@tty1.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
     _____                    _____   |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project tda4vm-sk ttyS2
    Arago 2021.09 tda4vm-sk ttyS2
    tda4vm-sk login: root (automatic login)
    [   39.345820] Initializing XFRM netlink socket
    snmpd[978]: Warning: no access control information configured.
      (Config search path: /etc/snmp:/usr/share/snmp:/usr/lib/snmp)
      It's unlikely this agent can serve any useful purpose in this state.
      Run "snmpconf -g basic_setup" to help you configure the snmpd.conf file for this agent.
    ipsec_starter[979]: charon (989) started after 1900 ms
    snmpd[978]: NET-SNMP version 5.8[   39.503532] systemd[1]: Started Simple Network Management Protocol (SNMP) Daemon..
    [   39.642494] systemd[1]: Created slice User Slice of UID 0.
    [   39.661021] systemd[1]: Starting User Runtime Directory /run/user/0...
    [   39.662910] systemd[1020]: user-runtime-dir@0.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   39.776699] systemd[1]: Started User Runtime Directory /run/user/0.
    [   39.804733] systemd[1]: Starting User Manager for UID 0...
    [   39.805287] systemd[1021]: user@0.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   42.141877] systemd[1021]: Reached target Paths.
    [   42.146744] systemd[1021]: Reached target Timers.
    [   42.174465] systemd[1021]: Starting D-Bus User Message Bus Socket.
    [   42.178097] systemd[1050]: dbus.socket: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   42.994634] systemd[1021]: Listening on D-Bus User Message Bus Socket.
    [   43.016558] systemd[1021]: Reached target Sockets.
    [   43.034631] systemd[1021]: Reached target Basic System.
    [   43.051479] systemd[1]: Started User Manager for UID 0.
    [   43.064681] systemd[1021]: Reached target Main User Target.
    [   43.074802] systemd[1]: Started Session c1 of user root.
    [   43.083420] systemd[1021]: Startup finished in 3.110s.
    [   43.106205] systemd[1]: Started Session c2 of user root.
    rm: cannot remove '/home/root/.cache/gstreamer-1.0/registry.aarch64.bin': No such file or directory
    [   49.697170] systemd[1]: edgeai-init.service: Succeeded.
    [   50.503504] overlayfs: upper fs needs to support d_type.
    [   50.535075] overlayfs: upper fs does not support tmpfile.
    [   50.571781] overlayfs: upper fs does not support RENAME_WHITEOUT.
    [   50.589087] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
    [   50.616930] overlayfs: upper fs missing required features.
    [   50.960969] overlayfs: upper fs needs to support d_type.
    [   50.966363] overlayfs: upper fs does not support tmpfile.
    [   51.030282] overlayfs: upper fs does not support RENAME_WHITEOUT.
    [   51.077617] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off.
    [   51.109243] overlayfs: upper fs missing required features.
    [   51.299350] systemd[1]: Started rc.pvr.service.
    [   51.327335] systemd[1]: Starting LSB: network benchmark...
    [   51.341080] systemd[1166]: netperf.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   51.450235] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [   51.488720] Bridge firewalling registered
    [   51.506801] systemd[1]: Started LSB: network benchmark.
    [   51.530597] systemd[1]: Starting thermal-zone-init.service...
    [   51.532001] systemd[1172]: thermal-zone-init.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   51.584317] systemd[1]: Started thermal-zone-init.service.
    [   52.143203] systemd-udevd[1174]: Using default interface naming scheme 'v243'.
    [   52.192150] systemd-udevd[1174]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
    [   54.655849] process 'docker/tmp/qemu-check569783614/check' started with executable stack
    [   54.753966] systemd[1]: Started Docker Application Container Engine.
    [   54.762976] systemd[1]: Reached target Multi-User System.
    [   54.790822] systemd[1309]: systemd-update-utmp-runlevel.service: Failed to connect stdout to the journal socket, ignoring: No such file or directory
    [   54.791201] systemd[1]: Starting Update UTMP about System Runlevel Changes...
    [   54.857946] systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
    [   54.872747] systemd[1]: Started Update UTMP about System Runlevel Changes.
    [   54.887351] systemd[1]: Startup finished in 11.483s (kernel) + 43.283s (userspace) = 54.766s.
    Annie
  • Annie
    Are the other CAN instances enabled in the device tree?
    Karan
  • Hi Karan,
    In main_can0, only this instance is enabled.
    While MCU_CAN0 is registered successfully, and the method of the instances in the device tree is the same.
    Thanks and regards,
    Cherry
  • Cherry
    Can you please share you compiled DTB? The k3-j721e-main.dts will have the main_mcan* instances but these are enabled/disabled based on the *.dts.
    I don't see any probe function being called for any MCAN device apart from mcu_mcan0, this points to the other nodes being disabled from dts.
    Karan
  • Hi Karan,
    Thank you again and this issue has been resolved by the customer so we could close this thread.
    Thanks and regards,
    Cherry
