In this link,it‘s on SDK 8.6 and the EVM is j721s2. I need to implement the same application but EVM is j721e. Could you share the step about j721e EVM on SDK 8.6?
Thanks.
I follow the step and encounter a error. I used the SDK8.6.
The log:
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 22:56:45, Mar 3 2023
ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Fri Mar 3 22:59:24 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Mar 3 23:00:40 UTC 2023
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff]
[ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Failed to reserve 512 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=9eb35a3b-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 2220652K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1973652K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a7030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008398] Console: colour dummy device 80x25
[ 0.012961] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023630] pid_max: default: 32768 minimum: 301
[ 0.028386] LSM: Security Framework initializing
[ 0.033139] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040713] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049527] rcu: Hierarchical SRCU implementation.
[ 0.054593] Platform MSI: msi-controller@1820000 domain created
[ 0.060843] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070147] EFI services will not be available.
[ 0.074867] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.093924] Detected PIPT I-cache on CPU1
[ 0.093948] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.093960] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
[ 0.093993] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.094043] smp: Brought up 1 node, 2 CPUs
[ 0.123387] SMP: Total of 2 processors activated.
[ 0.128193] CPU features: detected: 32-bit EL0 Support
[ 0.133446] CPU features: detected: CRC32 instructions
[ 0.147488] CPU: All CPU(s) started at EL2
[ 0.151682] alternatives: patching kernel code
[ 0.156742] devtmpfs: initialized
[ 0.165874] KASLR disabled due to lack of seed
[ 0.170518] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.180483] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.187537] pinctrl core: initialized pinctrl subsystem
[ 0.193108] DMI not present or invalid.
[ 0.197315] NET: Registered protocol family 16
[ 0.202123] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.209422] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.217417] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.225710] thermal_sys: Registered thermal governor 'step_wise'
[ 0.225713] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.232253] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.245885] ASID allocator initialised with 32768 entries
[ 0.268985] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.275842] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.282689] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.289535] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.296980] cryptd: max_cpu_qlen set to 1000
[ 0.303034] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.311847] vsys_3v3: supplied by evm_12v0
[ 0.316204] vsys_5v0: supplied by evm_12v0
[ 0.320939] iommu: Default domain type: Translated
[ 0.326113] SCSI subsystem initialized
[ 0.330244] mc: Linux media interface: v0.10
[ 0.334622] videodev: Linux video capture interface: v2.00
[ 0.340259] pps_core: LinuxPPS API ver. 1 registered
[ 0.345330] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.354667] PTP clock support registered
[ 0.358688] EDAC MC: Ver: 3.0.0
[ 0.362470] FPGA manager framework
[ 0.365977] Advanced Linux Sound Architecture Driver Initialized.
[ 0.372560] clocksource: Switched to clocksource arch_sys_counter
[ 0.378881] VFS: Disk quotas dquot_6.6.0
[ 0.382913] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.392514] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.398803] NET: Registered protocol family 2
[ 0.403527] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.412094] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.420851] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.429055] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.436853] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.443635] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.450527] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.457922] NET: Registered protocol family 1
[ 0.462640] RPC: Registered named UNIX socket transport module.
[ 0.468701] RPC: Registered udp transport module.
[ 0.473505] RPC: Registered tcp transport module.
[ 0.478308] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.484890] NET: Registered protocol family 44
[ 0.489438] PCI: CLS 0 bytes, default 64
[ 0.493796] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.504167] Initialise system trusted keyrings
[ 0.508808] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.516941] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.523142] NFS: Registering the id_resolver key type
[ 0.528332] Key type id_resolver registered
[ 0.532604] Key type id_legacy registered
[ 0.536724] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.543572] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.551208] 9p: Installing v9fs 9p2000 file system support
[ 0.576833] Key type asymmetric registered
[ 0.581020] Asymmetric key parser 'x509' registered
[ 0.586019] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.593578] io scheduler mq-deadline registered
[ 0.598203] io scheduler kyber registered
[ 0.603896] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.610086] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.619103] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.625539] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.633521] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.639941] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.647882] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.654300] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.662229] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.668560] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.676513] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.682839] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.692516] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.700780] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.708844] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.715847] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.724186] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.737314] brd: module loaded
[ 0.743716] loop: module loaded
[ 0.747488] megasas: 07.714.04.00-rc1
[ 0.753264] tun: Universal TUN/TAP device driver, 1.6
[ 0.758718] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.765127] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.771205] sky2: driver version 1.30
[ 0.775547] VFIO - User Level meta-driver version: 0.3
[ 0.781328] i2c /dev entries driver
[ 0.785799] sdhci: Secure Digital Host Controller Interface driver
[ 0.792133] sdhci: Copyright(c) Pierre Ossman
[ 0.796793] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.803198] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.809527] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.816909] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.821466] optee: revision 3.20 (8e74d476)
[ 0.837873] optee: dynamic shared memory is enabled
[ 0.847332] optee: initialized driver
[ 0.852483] NET: Registered protocol family 17
[ 0.857105] 9pnet: Installing 9P2000 support
[ 0.861500] Key type dns_resolver registered
[ 0.865950] Loading compiled-in X.509 certificates
[ 0.879181] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[ 0.937617] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.945356] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.951438] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.957820] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.964279] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.971104] pca953x 3-0020: using no AI
[ 0.997341] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 1.004158] pca953x 3-0022: using AI
[ 1.008431] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 1.014406] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 1.020652] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 1.027142] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.034734] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.040892] pca953x 5-0020: supply vcc not found, using dummy regulator
[ 1.047708] pca953x 5-0020: using no AI
[ 1.073097] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.079180] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz
[ 1.085152] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz
[ 1.091576] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.101552] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.110363] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.120223] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.129616] ------------[ cut here ]------------
[ 1.134347] wiz bus@100000:wiz@5000000: Unable to create SERDES platform device
[ 1.141848] WARNING: CPU: 0 PID: 22 at drivers/phy/ti/phy-j721e-wiz.c:1597 wiz_probe+0xc28/0x1178
[ 1.150912] Modules linked in:
[ 1.154030] CPU: 0 PID: 22 Comm: kworker/0:1 Not tainted 5.10.162-g76b3e88d56 #1
[ 1.161584] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 1.167547] Workqueue: events deferred_probe_work_func
[ 1.172793] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 1.178927] pc : wiz_probe+0xc28/0x1178
[ 1.182839] lr : wiz_probe+0xc28/0x1178
[ 1.186750] sp : ffff8000113b3a80
[ 1.190128] x29: ffff8000113b3a80 x28: ffff00087fa18c78
[ 1.195552] x27: 0000000000000002 x26: 0000000000000002
[ 1.200976] x25: ffff000828cd30d8 x24: ffff800010bdfec0
[ 1.206400] x23: ffff800010be01a4 x22: ffff000828cd30c8
[ 1.211823] x21: 0000000000000000 x20: ffff000827c62410
[ 1.217247] x19: ffff000828cd3080 x18: 0000000000000010
[ 1.222670] x17: 0000000000000000 x16: 00000000253a7dd9
[ 1.228094] x15: ffff000827151390 x14: 0000000000000113
[ 1.233518] x13: ffff000827151390 x12: 00000000ffffffea
[ 1.238942] x11: ffff8000112205b0 x10: ffff800011208570
[ 1.244365] x9 : ffff8000112085c8 x8 : 0000000000017fe8
[ 1.249789] x7 : c0000000ffffefff x6 : 0000000000000001
[ 1.255212] x5 : 0000000000000000 x4 : 0000000000000000
[ 1.260636] x3 : 00000000ffffffff x2 : ffff8000111b0540
[ 1.266059] x1 : 76123c0df295e500 x0 : 0000000000000000
[ 1.271484] Call trace:
[ 1.273975] wiz_probe+0xc28/0x1178
[ 1.277533] platform_drv_probe+0x54/0xa8
[ 1.281622] really_probe+0xec/0x3e0
[ 1.285268] driver_probe_device+0x58/0xb8
[ 1.289447] __device_attach_driver+0xb8/0xe0
[ 1.293893] bus_for_each_drv+0x78/0xc8
[ 1.297805] __device_attach+0xf8/0x188
[ 1.301717] device_initial_probe+0x14/0x20
[ 1.305983] bus_probe_device+0x9c/0xa8
[ 1.309895] deferred_probe_work_func+0x88/0xc0
[ 1.314520] process_one_work+0x1a0/0x328
[ 1.318610] worker_thread+0x1f8/0x420
[ 1.322433] kthread+0x140/0x160
[ 1.325724] ret_from_fork+0x10/0x34
[ 1.329369] ---[ end trace 1c919d16d1649eac ]---
[ 1.334348] wiz: probe of bus@100000:wiz@5000000 failed with error -12
[ 1.343306] ------------[ cut here ]------------
[ 1.348038] wiz bus@100000:wiz@5010000: Unable to create SERDES platform device
[ 1.355528] WARNING: CPU: 0 PID: 22 at drivers/phy/ti/phy-j721e-wiz.c:1597 wiz_probe+0xc28/0x1178
[ 1.364593] Modules linked in:
[ 1.367710] CPU: 0 PID: 22 Comm: kworker/0:1 Tainted: G W 5.10.162-g76b3e88d56 #1
[ 1.376686] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 1.382646] Workqueue: events deferred_probe_work_func
[ 1.387893] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 1.394026] pc : wiz_probe+0xc28/0x1178
[ 1.397938] lr : wiz_probe+0xc28/0x1178
[ 1.401849] sp : ffff8000113b3a80
[ 1.405227] x29: ffff8000113b3a80 x28: ffff00087fa1acf0
[ 1.410651] x27: 0000000000000000 x26: 0000000000000002
[ 1.416075] x25: 0000000000000002 x24: ffff000827c62810
[ 1.421499] x23: ffff000828cd3108 x22: ffff000828cd30e8
[ 1.426923] x21: 0000000000000002 x20: ffff000827c62810
[ 1.432346] x19: ffff000828cd3080 x18: 0000000000000010
[ 1.437770] x17: 0000000000000000 x16: 00000000253a7dd9
[ 1.443193] x15: ffff000827151390 x14: 000000000000013e
[ 1.448617] x13: ffff000827151390 x12: 00000000ffffffea
[ 1.454041] x11: ffff8000112205b0 x10: ffff800011208570
[ 1.459464] x9 : ffff8000112085c8 x8 : 0000000000017fe8
[ 1.464887] x7 : c0000000ffffefff x6 : 0000000000000001
[ 1.470311] x5 : 0000000000000000 x4 : 0000000000000000
[ 1.475734] x3 : 00000000ffffffff x2 : ffff8000111b0540
[ 1.481158] x1 : 76123c0df295e500 x0 : 0000000000000000
[ 1.486582] Call trace:
[ 1.489073] wiz_probe+0xc28/0x1178
[ 1.492630] platform_drv_probe+0x54/0xa8
[ 1.496719] really_probe+0xec/0x3e0
[ 1.500364] driver_probe_device+0x58/0xb8
[ 1.504542] __device_attach_driver+0xb8/0xe0
[ 1.508988] bus_for_each_drv+0x78/0xc8
[ 1.512901] __device_attach+0xf8/0x188
[ 1.516812] device_initial_probe+0x14/0x20
[ 1.521079] bus_probe_device+0x9c/0xa8
[ 1.524991] deferred_probe_work_func+0x88/0xc0
[ 1.529616] process_one_work+0x1a0/0x328
[ 1.533705] worker_thread+0x1f8/0x420
[ 1.537529] kthread+0x140/0x160
[ 1.540819] ret_from_fork+0x10/0x34
[ 1.544465] ---[ end trace 1c919d16d1649ead ]---
[ 1.549435] wiz: probe of bus@100000:wiz@5010000 failed with error -12
[ 1.558422] ------------[ cut here ]------------
[ 1.563182] wiz bus@100000:wiz@5020000: Unable to create SERDES platform device
[ 1.570676] WARNING: CPU: 0 PID: 22 at drivers/phy/ti/phy-j721e-wiz.c:1597 wiz_probe+0xc28/0x1178
[ 1.579739] Modules linked in:
[ 1.582856] CPU: 0 PID: 22 Comm: kworker/0:1 Tainted: G W 5.10.162-g76b3e88d56 #1
[ 1.591830] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 1.597791] Workqueue: events deferred_probe_work_func
[ 1.603037] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 1.609171] pc : wiz_probe+0xc28/0x1178
[ 1.613082] lr : wiz_probe+0xc28/0x1178
[ 1.616993] sp : ffff8000113b3a80
[ 1.620372] x29: ffff8000113b3a80 x28: ffff00087fa1ca10
[ 1.625796] x27: 0000000000000000 x26: 0000000000000002
[ 1.631219] x25: 0000000000000002 x24: ffff000827c62c10
[ 1.636643] x23: ffff000828cd3108 x22: ffff000828cd30e8
[ 1.642067] x21: 0000000000000002 x20: ffff000827c62c10
[ 1.647490] x19: ffff000828cd3080 x18: 0000000000000010
[ 1.652914] x17: 0000000000000000 x16: 00000000253a7dd9
[ 1.658338] x15: ffff000827151390 x14: 0000000000000169
[ 1.663762] x13: ffff000827151390 x12: 00000000ffffffea
[ 1.669185] x11: ffff8000112205b0 x10: ffff800011208570
[ 1.674609] x9 : ffff8000112085c8 x8 : 0000000000017fe8
[ 1.680033] x7 : c0000000ffffefff x6 : 0000000000000001
[ 1.685456] x5 : 0000000000000000 x4 : 0000000000000000
[ 1.690880] x3 : 00000000ffffffff x2 : ffff8000111b0540
[ 1.696303] x1 : 76123c0df295e500 x0 : 0000000000000000
[ 1.701727] Call trace:
[ 1.704218] wiz_probe+0xc28/0x1178
[ 1.707776] platform_drv_probe+0x54/0xa8
[ 1.711865] really_probe+0xec/0x3e0
[ 1.715510] driver_probe_device+0x58/0xb8
[ 1.719688] __device_attach_driver+0xb8/0xe0
[ 1.724134] bus_for_each_drv+0x78/0xc8
[ 1.728046] __device_attach+0xf8/0x188
[ 1.731958] device_initial_probe+0x14/0x20
[ 1.736225] bus_probe_device+0x9c/0xa8
[ 1.740137] deferred_probe_work_func+0x88/0xc0
[ 1.744762] process_one_work+0x1a0/0x328
[ 1.748852] worker_thread+0x1f8/0x420
[ 1.752675] kthread+0x140/0x160
[ 1.755966] ret_from_fork+0x10/0x34
[ 1.759611] ---[ end trace 1c919d16d1649eae ]---
[ 1.764586] wiz: probe of bus@100000:wiz@5020000 failed with error -12
[ 1.772548] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.780268] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.788550] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.796831] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.805640] j721e-pcie 2900000.pcie: Failed to init phy
[ 1.811390] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.819067] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.827346] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.835623] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.844279] j721e-pcie 2910000.pcie: Failed to init phy
[ 1.849994] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 1.857670] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 1.865948] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 1.874225] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.883020] j721e-pcie 2920000.pcie: Failed to init phy
[ 1.889168] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 1.899052] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.905812] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.914820] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 1.924972] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.931731] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.939700] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 1.949099] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 1.957844] printk: console [ttyS2] enabled
[ 1.966280] printk: bootconsole [ns16550a0] disabled
[ 1.976744] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 1.985696] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 1.995361] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 2.005871] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 2.016025] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 2.026262] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 2.037034] scsi host0: ufshcd
[ 2.046139] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.059077] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 2.092636] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.100290] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 2.101259] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.120182] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 2.120229] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.144180] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.144184] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 2.151387] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.151776] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.175053] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 2.183531] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.192089] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 2.293179] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 2.299845] mmc1: CQHCI version 5.10
[ 2.308343] vdd_mmc1: supplied by vsys_3v3
[ 2.313383] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.320227] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.327068] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 2.333886] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 2.340687] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 2.343133] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.350763] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 2.362225] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 2.370359] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 2.378449] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.386977] j721e-pcie 2900000.pcie: Failed to init phy
[ 2.392691] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.400234] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.408370] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.416501] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.425012] j721e-pcie 2910000.pcie: Failed to init phy
[ 2.430688] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 2.438185] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 2.446265] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 2.454351] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.462819] j721e-pcie 2920000.pcie: Failed to init phy
[ 2.469003] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 2.479574] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 2.493593] spi-nor spi7.0: mt35xu512aba (65536 Kbytes)
[ 2.498846] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
[ 2.505888] Creating 8 MTD partitions on "47040000.spi.0":
[ 2.511364] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 2.517366] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 2.523095] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 2.528918] 0x000000680000-0x0000006a0000 : "ospi.env"
[ 2.534485] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup"
[ 2.540641] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 2.546387] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 2.552196] 0x000003fe0000-0x000004000000 : "ospi.phypattern"
[ 2.561162] spi-nor spi8.0: mt25qu512a (65536 Kbytes)
[ 2.567431] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.575438] mmc1: Command Queue Engine enabled
[ 2.579876] mmc1: new HS200 MMC card at address 0001
[ 2.585114] mmcblk1: mmc1:0001 S0J56X 14.8 GiB
[ 2.589741] mmcblk1boot0: mmc1:0001 S0J56X partition 1 31.5 MiB
[ 2.595757] mmcblk1boot1: mmc1:0001 S0J56X partition 2 31.5 MiB
[ 2.601746] mmcblk1rpmb: mmc1:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 2.612594] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.621093] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.629406] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.642260] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.649466] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.655748] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.665968] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 2.674147] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 2.688457] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 2.695979] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 2.696084] mmc0: CQHCI version 5.10
[ 2.704072] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 2.715721] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.724212] j721e-pcie 2900000.pcie: Failed to init phy
[ 2.729862] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.737359] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.745442] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.753522] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.761978] j721e-pcie 2910000.pcie: Failed to init phy
[ 2.767544] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 2.775038] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 2.783117] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 2.791198] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.799660] j721e-pcie 2920000.pcie: Failed to init phy
[ 2.805476] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 2.812969] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 2.821048] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 2.829127] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.837591] j721e-pcie 2900000.pcie: Failed to init phy
[ 2.843145] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.850633] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.858712] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.866790] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.875248] j721e-pcie 2910000.pcie: Failed to init phy
[ 2.880800] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 2.888286] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 2.896366] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 2.904446] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.912906] j721e-pcie 2920000.pcie: Failed to init phy
[ 2.918469] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 2.925770] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 2.934144] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 2.941467] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 2.948775] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 2.956085] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 2.964417] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.971824] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 2.979314] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 2.985241] ALSA device list:
[ 2.987393] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 2.990350] No soundcards found.
[ 2.998413] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.010278] j721e-pcie 2900000.pcie: Failed to init phy
[ 3.015935] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.023423] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.031505] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.039586] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.048044] j721e-pcie 2910000.pcie: Failed to init phy
[ 3.053616] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.061104] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.069182] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.077263] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.085725] j721e-pcie 2920000.pcie: Failed to init phy
[ 3.761419] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 3.769527] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 3.777060] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 3.785150] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 3.793239] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.801741] j721e-pcie 2900000.pcie: Failed to init phy
[ 3.807092] Waiting for root device PARTUUID=9eb35a3b-02...
[ 3.812739] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.820231] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.828320] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.836408] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.844879] j721e-pcie 2910000.pcie: Failed to init phy
[ 3.850484] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.857983] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.866069] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.874186] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.882661] j721e-pcie 2920000.pcie: Failed to init phy
[ 3.929818] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 3.936679] mmcblk0: mmc0:aaaa SR128 119 GiB
[ 3.942244] mmcblk0: p1 p2
[ 3.945970] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 3.953472] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 3.961554] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 3.969634] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.978104] j721e-pcie 2900000.pcie: Failed to init phy
[ 3.983687] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.991178] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.999260] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 4.007339] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.015792] j721e-pcie 2910000.pcie: Failed to init phy
[ 4.021350] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 4.028841] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 4.036920] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 4.044998] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.053459] j721e-pcie 2920000.pcie: Failed to init phy
Could you please add these changes to k3-j721e-common-proc-board.dts and rebuild the device tree and combined app?
/cfs-file/__key/communityserver-discussions-components-files/791/serdes_5F00_issue_5F00_fix.zip
Nikhil
Thanks for your reply. I can run vision_apps in SBL boot flow now. But there’s still a question. If I change the app on mcu1_0 to my own application, the Linux boot failed. I follwed the steps about modifying the mcu app path in config.mk and rebuilding the combined_appimage. The mcu1_0 app seems working,but Linux can’t boot sucessfully. What should do if I change the mcu app?
Thanks.
The logs:
I/TC:
E/TC:0 0 k3_sec_proxy_verify_thread:108 Queue is busy
E/TC:0 0 k3_sec_proxy_recv:196 Thread SEC_PROXY_RESPONSE_THREAD verification failed. ret = -65523
E/TC:0 0 ti_sci_get_response:101 Message receive failed (-65523)
E/TC:0 0 ti_sci_do_xfer:150 Failed to get response (-65523)
E/TC:0 0 sa2ul_init:59 Failed to get SA2UL device
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x00063c20 failed
E/TC:0 0
E/TC:0 0 Core data-abort at address 0x10 (translation fault)
E/TC:0 0 esr 0x96000005 ttbr0 0x9e894000 ttbr1 0x00000000 cidr 0x0
E/TC:0 0 cpu #0 cpsr 0x800003c4
E/TC:0 0 x0 000000009e867000 x1 0000000000000010
E/TC:0 0 x2 0000000000000000 x3 0000000000000000
E/TC:0 0 x4 0000000000000001 x5 0000000000ffffff
E/TC:0 0 x6 0000000000000002 x7 000000009e89c190
E/TC:0 0 x8 000000009e89c190 x9 000000009e884d70
E/TC:0 0 x10 0000000000000000 x11 0000000000000000
E/TC:0 0 x12 000000009e89c100 x13 000000000000000a
E/TC:0 0 x14 00000000ffffffff x15 0000000000000020
E/TC:0 0 x16 000000009e813c40 x17 0000000000000000
E/TC:0 0 x18 0000000000000000 x19 000000009e89eca0
E/TC:0 0 x20 000000009e89eca8 x21 0000000000000007
E/TC:0 0 x22 000000009e873000 x23 000000009e8736a0
E/TC:0 0 x24 0000000100000000 x25 0000000000000000
E/TC:0 0 x26 0000000000000000 x27 0000000000000000
E/TC:0 0 x28 0000000000000000 x29 000000009e89ec30
E/TC:0 0 x30 000000009e80e3ac elr 000000009e80e3cc
E/TC:0 0 sp_el0 000000009e89ec30
E/TC:0 0 TEE load address @ 0x9e800000
E/TC:0 0 Call stack:
E/TC:0 0 0x9e80e3cc
E/TC:0 0 Panic 'unhandled pageable abort' at core/arch/arm/kernel/abort.c:572 <abort_handler>
E/TC:0 0 0x9e8087dc
E/TC:0 0 0x9e81506c
E/TC:0 0 0x9e807fd8
E/TC:0 0 0x9e805520
This seems to be the same as (+) TDA4VM: Run vision_apps in SBL boot flow with combined_appImage on j721e - Processors forum - Processors - TI E2E support forums
Hence closing this thread to avoid duplication.
