TDA4VM: MIPI-DSI support on j721e-Linux
Part Number: TDA4VM
sdk: Processor SDK Linux for J721e_09_00_00
Output scheme:
TDA4VM (MIPI DSI 4 lanes)-> DS90SUB941 ->(FPDLINK)  DS90UB948 ->(LVDS) 1280x800 panel
reference:
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1131651/tda4vm-tda4vm-dsi-support-on-linux
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1259303/tda4vm-dsi-debugging-related-issues-on-linux/4790669?tisearch=e2e-sitesearch&keymatch=%20user%3A557095#4790669
--- a/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts
+++ b/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts
@@ -157,7 +157,7 @@ dp_pwr_3v3: regulator-dp-pwr {
                gpio = <&exp4 0 GPIO_ACTIVE_HIGH>; /* P0 - DP0_PWR_SW_EN */
                enable-active-high;
        dp0: connector {
                compatible = "dp-connector";
                label = "DP0";
@@ -170,8 +170,26 @@ dp_connector_in: endpoint {
+       panel_disp0: panel_disp1@0 {
+               reg = <0 0 0x0 0x0>;
+               compatible = "raspberrypi,7inch-dsi", "simple-panel"; /*raspberrypi,7inch-dsi   panel-dpi*/
+               backlight = <&reg_display>;
+               power-supply = <&reg_display>;
+               port {
+                       panel_in: endpoint {
+                               remote-endpoint = <&panel_bridge_out>;
 &main_pmx0 {
        sw10_button_pins_default: sw10-button-pins-default {
                pinctrl-single,pins = <
@@ -886,13 +904,24 @@ &dss {
 &dss_ports {
-       port {
+       #address-cells = <1>;
+       #size-cells = <0>;
+/*     port@0 {
+       reg = <0>;
                dpi0_out: endpoint {
                        remote-endpoint = <&dp0_in>;
+       port@2 {
+       reg = <2>;
+               dpi1_out: endpoint {
+                       remote-endpoint = <&dsi0_in>;
 &dp0_ports {
        #size-cells = <0>;
@@ -911,6 +940,54 @@ dp0_out: endpoint {
+&dsi0 {
+ * DSI_WRAP_DPI_CONTROL (0x04710004) allows to select between various DPI options
+ * On reset, DPI1 is being used
+       ports {
+               port@0 {
+                       reg = <0>;
+                       dsi0_out: endpoint {
+                               remote-endpoint = <&panel_bridge_in>;
+               port@1 {
+                       reg = <1>;
+                       dsi0_in: endpoint {
+                               remote-endpoint = <&dpi1_out>;
+       dsi-bridge@0 {
+               compatible = "toshiba,tc358762";
+               reg = <0>;
+/*             vddc-supply = <&reg_bridge>; */
+               ports {
+                       port@0 {
+                               reg = <0>;
+                               panel_bridge_in: endpoint {
+                                       remote-endpoint = <&dsi0_out>;
+                       port@1 {
+                               reg = <1>;
+                               panel_bridge_out: endpoint {
+                                       remote-endpoint = <&panel_in>;
 &mcasp10 {
        status = "okay";
@@ -1016,6 +1093,7 @@ torrent_phy_dp: phy@0 {
 &mhdp {
+       status = "disabled";
        phys = <&torrent_phy_dp>;
        phy-names = "dpphy";
        pinctrl-names = "default";
diff --git a/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi b/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
index b90ebccda1..aebb032cd5 100644
--- a/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
+++ b/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-main.dtsi
@@ -1541,6 +1541,23 @@ port@4 {
+       dsi0: dsi@48000000 {
+               compatible = "ti,j721e-dsi";
+               reg = <0x0 0x04800000 0x0 0x100000>, <0x0 0x04710000 0x0 0x100>;
+               clocks = <&k3_clks 150 1>, <&k3_clks 150 5>;
+               clock-names = "dsi_p_clk", "dsi_sys_clk";
+               power-domains = <&k3_pds 150 TI_SCI_PD_EXCLUSIVE>;
+               interrupt-parent = <&gic500>;
diff --git a/linux/board-support/linux-6.1.33/arch/arm64/boot/dts/ti/k3-j721e-common-proc-board.dts b/linux/board-support/linux-6.1.33/arch/arm64/boot/dts
index 8e57e4107f..83c55b239c 100644
                enable-active-high;
        dp0: connector {
                label = "DP0";
+               port {
 &main_pmx0 {
 &dss_ports {
-       port {
+/*     port@0 {
+       reg = <0>;
+       port@2 {
+       reg = <2>;
 &dp0_ports {
        #size-cells = <0>;
+&dsi0 {
+       ports {
+               port@0 {
+                       reg = <0>;
+               port@1 {
+                       reg = <1>;
+       dsi-bridge@0 {
+               reg = <0>;
+               ports {
+                       port@0 {
+                               reg = <0>;
+                       port@1 {
+                               reg = <1>;
 &mcasp10 {
        status = "okay";
 &mhdp {
+               interrupts = <GIC_SPI 600 IRQ_TYPE_LEVEL_HIGH>;
+               phys = <&dphy2>;
+               phy-names = "dphy";
+               dsi0_ports: ports {
        dss: dss@4a00000 {
                compatible = "ti,j721e-dss";
                reg =
@@ -1591,6 +1608,8 @@ dss: dss@4a00000 {
                                  "common_s2";
                dss_ports: ports {
@@ -2680,4 +2699,17 @@ dphy1: phy@4590000 {
                #phy-cells = <0>;
                power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>;
+       dphy2: phy@4480000 {
+               compatible = "ti,j721e-dphy";
+               reg = <0x0 0x04480000 0x0 0x1000>;
+               clocks = <&k3_clks 296 1>, <&k3_clks 296 3>;
+               clock-names = "psm", "pll_ref";
+               #phy-cells = <0>;
+               power-domains = <&k3_pds 296 TI_SCI_PD_EXCLUSIVE>;
+               assigned-clocks = <&k3_clks 296 3>;
+               assigned-clock-parents = <&k3_clks 296 4>;
+               assigned-clock-rates = <19200000>;
--- a/linux/board-support/linux-6.1.33/drivers/gpu/drm/panel/panel-simple.c
+++ b/linux/board-support/linux-6.1.33/drivers/gpu/drm/panel/panel-simple.c
@@ -379,6 +379,7 @@ static int panel_simple_prepare(struct drm_panel *panel)
 static int panel_simple_enable(struct drm_panel *panel)
        struct panel_simple *p = to_panel_simple(panel);
+       printk("%d_________________%s__________________\n", __LINE__, __func__);
        if (p->enabled)
                return 0;
@@ -419,6 +420,7 @@ static int panel_simple_get_modes(struct drm_panel *panel,
         * drm_connector_set_orientation_from_panel()
        drm_connector_set_panel_orientation(connector, p->orientation);
+       printk("%d_________________%s_______end_____num=%d______\n", __LINE__, __func__,num);
        return num;
@@ -429,6 +431,7 @@ static int panel_simple_get_timings(struct drm_panel *panel,
        unsigned int i;
        if (p->desc->num_timings < num_timings)
                num_timings = p->desc->num_timings;
@@ -560,6 +563,7 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc)
        int connector_type;
        u32 bus_flags;
        int err;
        panel = devm_kzalloc(dev, sizeof(*panel), GFP_KERNEL);
        if (!panel)
@@ -568,7 +572,7 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc)
        panel->enabled = false;
        panel->prepared_time = 0;
        panel->desc = desc;
+#if 0
        panel->supply = devm_regulator_get(dev, "power");
        if (IS_ERR(panel->supply))
                return PTR_ERR(panel->supply);
@@ -578,7 +582,7 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc)
        if (IS_ERR(panel->enable_gpio))
                return dev_err_probe(dev, PTR_ERR(panel->enable_gpio),
                                     "failed to request GPIO\n");
+#endif
        err = of_drm_get_panel_orientation(dev->of_node, &panel->orientation);
        if (err) {
                dev_err(dev, "%pOF: failed to get orientation %d\n", dev->of_node, err);
@@ -593,7 +597,7 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc)
                if (!panel->ddc)
                        return -EPROBE_DEFER;
+#if 1
        if (desc == &panel_dpi) {
                /* Handle the generic panel-dpi binding */
                err = panel_dpi_probe(dev, panel);
@@ -601,9 +605,13 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc)
                        goto free_ddc;
                desc = panel->desc;
        } else {
                if (!of_get_display_timing(dev->of_node, "panel-timing", &dt))
                        panel_simple_parse_panel_timing_node(dev, panel, &dt);
+#endif
+       printk("_____________%s_____________connector_type = %d\n", __func__, desc->connector_type);
        connector_type = desc->connector_type;
        /* Catch common mistakes for panels. */
@@ -667,19 +675,21 @@ static int panel_simple_probe(struct device *dev, const struct panel_desc *desc)
         * to optimize powering the panel on briefly to read the EDID before
         * fully enabling the panel.
+#if 0
        pm_runtime_enable(dev);
        pm_runtime_set_autosuspend_delay(dev, 1000);
        pm_runtime_use_autosuspend(dev);
+#endif
        drm_panel_init(&panel->base, dev, &panel_simple_funcs, connector_type);
+#if 0
        err = drm_panel_of_backlight(&panel->base);
        if (err) {
                dev_err_probe(dev, err, "Could not find backlight\n");
                goto disable_pm_runtime;
+#endif
        drm_panel_add(&panel->base);
+       printk("%d_________________%s________end__________\n", __LINE__, __func__);
        return 0;
@@ -3981,6 +3991,42 @@ static const struct panel_desc arm_rtsm = {
        .bus_format = MEDIA_BUS_FMT_RGB888_1X24,
+static const struct drm_display_mode raspberrypi_7inch_mode = {
+       .clock = 28569600 / 1000,
+       .hdisplay = 800,
+       .hsync_start = 800 + 48, //848
+       .hsync_end = 800 + 48 + 32, //880
+       .htotal = 800 + 48 + 32 + 80, //960
+       .vdisplay = 480,
+       .vsync_start = 480 + 3, //487
+       .vsync_end = 480 + 3 + 7, //450
+       .vtotal = 480 + 3 + 7 + 6, //496
+       .crtc_clock = 28569600 / 1000,
+       .crtc_hdisplay = 800,
+       .crtc_hsync_start = 800 + 48, //848
+       .crtc_hsync_end = 800 + 48 + 32, //880
+       .crtc_htotal = 800 + 48 + 32 + 80, //960
+       .crtc_vdisplay = 480,
+       .crtc_vsync_start = 480 + 3, //487
+       .crtc_vsync_end = 480 + 3 + 7, //450
+       .crtc_vtotal = 480 + 3 + 7 + 6, //496
+       .flags = DRM_MODE_FLAG_NVSYNC | DRM_MODE_FLAG_NHSYNC,
+static const struct panel_desc raspberrypi_7inch = {
+       .modes = &raspberrypi_7inch_mode,
+       .num_modes = 1,
+       .bpc = 8,
+       .size = {
+               .width = 154,
+               .height = 86,
+       .bus_format = MEDIA_BUS_FMT_RGB888_1X24,
+       .connector_type = DRM_MODE_CONNECTOR_DSI,
 static const struct of_device_id platform_of_match[] = {
                .compatible = "ampire,am-1280800n3tzqw-t00h",
@@ -4383,6 +4429,9 @@ static const struct of_device_id platform_of_match[] = {
                .compatible = "panel-dpi",
                .data = &panel_dpi,
+               .compatible = "raspberrypi,7inch-dsi",
+               .data = &raspberrypi_7inch,
                /* sentinel */
@@ -4391,6 +4440,7 @@ MODULE_DEVICE_TABLE(of, platform_of_match);
 static int panel_simple_platform_probe(struct platform_device *pdev)
        const struct of_device_id *id;
        id = of_match_node(platform_of_match, pdev->dev.of_node);
        if (!id)
@@ -4421,7 +4471,7 @@ static struct platform_driver panel_simple_platform_driver = {
        .driver = {
                .name = "panel-simple",
                .of_match_table = platform_of_match,
-               .pm = &panel_simple_pm_ops,
+//             .pm = &panel_simple_pm_ops,
        .probe = panel_simple_platform_probe,
        .remove = panel_simple_platform_remove,
@@ -4671,6 +4721,7 @@ static int panel_simple_dsi_probe(struct mipi_dsi_device *dsi)
        const struct panel_desc_dsi *desc;
        int err;
        id = of_match_node(dsi_of_match, dsi->dev.of_node);
        if (!id)
@@ -4730,8 +4781,11 @@ static int __init panel_simple_init(void)
        err = platform_driver_register(&panel_simple_platform_driver);
        if (err < 0)
                return err;
        if (IS_ENABLED(CONFIG_DRM_MIPI_DSI)) {
                err = mipi_dsi_driver_register(&panel_simple_dsi_driver);
                if (err < 0)
                        goto err_did_platform_register;
However, it will be stuck in get mode and cannot access the terminal
U-Boot SPL 2023.04 (Sep 19 2023 - 17:22:01 +0800)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -121
Trying to boot from MMC1
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
init_env from device 17 not supported!
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE:  BL31: Built : 00:42:57, Jan 13 2023
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2023.04 (Sep 19 2023 - 17:21:56 +0800)
U-Boot 2023.04 (Sep 19 2023 - 17:21:56 +0800)
SoC:   J721E SR1.1 GP
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM1-SOM rev E2
DRAM:  4 GiB
Core:  118 devices, 34 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
________________________________SD/MMC found on device 1
920 bytes read in 25 ms (35.2 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
GPIO: 'gpio@22_17' not found
Command 'gpio' failed: Error -22
GPIO: 'gpio@22_16' not found
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
1519116 bytes read in 91 ms (15.9 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1519116 bytes: Success!
396348 bytes read in 45 ms (8.4 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 396348 bytes: Success!
Failed to load '/lib/firmware/j7-main-r5f1_0-fw'
Failed to load '/lib/firmware/j7-main-r5f1_1-fw'
1342288 bytes read in 82 ms (15.6 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1342288 bytes: Success!
1342288 bytes read in 83 ms (15.4 MiB/s)
Load Remote Processor 7 with data@addr=0x82000000 1342288 bytes: Success!
13049944 bytes read in 566 ms (22 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 13049944 bytes: Success!
20597248 bytes read in 874 ms (22.5 MiB/s)
115426 bytes read in 30 ms (3.7 MiB/s)
Working FDT set to 88000000
10434 bytes read in 25 ms (407.2 KiB/s)
3212 bytes read in 26 ms (120.1 KiB/s)
4711 bytes read in 26 ms (176.8 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=27000000 flags=4)
   Loading Device Tree to 000000008fee0000, end 000000008fffffff ... OK
Working FDT set to 8fee0000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.1.33 (cesar@cesar-pc) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #16 SMP PREEMPT Thu Sep 21 09:48:04 CST 2023
[    0.000000] Machine model: Texas Instruments J721e EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
[    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=b90cd2bf-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 1694388K/4194304K available (12480K kernel code, 1298K rwdata, 4052K rodata, 2176K init, 498K bss, 1975628K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a7030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008452] Console: colour dummy device 80x25
[    0.013016] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023686] pid_max: default: 32768 minimum: 301
[    0.028424] LSM: Security Framework initializing
[    0.033206] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040780] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049579] cblist_init_generic: Setting adjustable number of callback queues.
[    0.056983] cblist_init_generic: Setting shift to 1 and lim to 1.
[    0.063243] cblist_init_generic: Setting shift to 1 and lim to 1.
[    0.069557] rcu: Hierarchical SRCU implementation.
[    0.074454] rcu:     Max phase no-delay instances is 1000.
[    0.079972] Platform MSI: msi-controller@1820000 domain created
[    0.086259] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.096151] EFI services will not be available.
[    0.100896] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.114131] Detected PIPT I-cache on CPU1
[    0.114193] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.114205] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
[    0.114237] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.114284] smp: Brought up 1 node, 2 CPUs
[    0.143630] SMP: Total of 2 processors activated.
[    0.148434] CPU features: detected: 32-bit EL0 Support
[    0.153687] CPU features: detected: CRC32 instructions
[    0.158971] CPU: All CPU(s) started at EL2
[    0.163152] alternatives: applying system-wide alternatives
[    0.169716] devtmpfs: initialized
[    0.180338] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.190324] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.204806] pinctrl core: initialized pinctrl subsystem
[    0.210468] DMI not present or invalid.
[    0.214723] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.221391] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.228709] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.236719] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.244842] audit: initializing netlink subsys (disabled)
[    0.250460] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
[    0.250682] thermal_sys: Registered thermal governor 'step_wise'
[    0.258379] thermal_sys: Registered thermal governor 'power_allocator'
[    0.264590] cpuidle: using governor menu
[    0.275348] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.282311] ASID allocator initialised with 65536 entries
[    0.297688] platform 4800000.dsi: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.308497] platform 0.panel_disp1: Fixed dependency cycle(s) with /bus@100000/dsi@48000000/dsi-bridge@0
[    0.318364] KASLR disabled due to lack of seed
[    0.325906] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.332848] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.339250] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.346184] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.352585] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.359518] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.365919] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.372853] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.380174] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.389605] iommu: Default domain type: Translated
[    0.394593] iommu: DMA domain TLB invalidation policy: strict mode
[    0.401112] SCSI subsystem initialized
[    0.405101] usbcore: registered new interface driver usbfs
[    0.410720] usbcore: registered new interface driver hub
[    0.416156] usbcore: registered new device driver usb
[    0.421595] pps_core: LinuxPPS API ver. 1 registered
[    0.426666] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.436005] PTP clock support registered
[    0.440084] EDAC MC: Ver: 3.0.0
[    0.443852] FPGA manager framework
[    0.447362] Advanced Linux Sound Architecture Driver Initialized.
[    0.453991] clocksource: Switched to clocksource arch_sys_counter
[    0.460330] VFS: Disk quotas dquot_6.6.0
[    0.464361] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.474346] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.480640] NET: Registered PF_INET protocol family
[    0.485809] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.494814] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.503578] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.511508] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.519709] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.528323] TCP: Hash tables configured (established 32768 bind 32768)
[    0.535104] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.542020] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.549463] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.555555] RPC: Registered named UNIX socket transport module.
[    0.561614] RPC: Registered udp transport module.
[    0.566417] RPC: Registered tcp transport module.
[    0.571220] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.577802] NET: Registered PF_XDP protocol family
[    0.582714] PCI: CLS 0 bytes, default 64
[    0.587085] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.596297] Initialise system trusted keyrings
[    0.600954] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.610129] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.616401] NFS: Registering the id_resolver key type
[    0.621579] Key type id_resolver registered
[    0.625850] Key type id_legacy registered
[    0.629971] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.636820] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.644462] 9p: Installing v9fs 9p2000 file system support
[    0.669232] Key type asymmetric registered
[    0.673416] Asymmetric key parser 'x509' registered
[    0.678426] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.686072] io scheduler mq-deadline registered
[    0.690714] io scheduler kyber registered
[    0.696821] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.703075] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.709426] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.719788] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.727432] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.735646] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.742795] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.750740] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.761718] loop: module loaded
[    0.765772] megasas: 07.719.03.00-rc1
[    0.771735] tun: Universal TUN/TAP device driver, 1.6
[    0.777283] thunder_xcv, ver 1.0
[    0.780597] thunder_bgx, ver 1.0
[    0.783901] nicpf, ver 1.0
[    0.786913] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.794297] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.799744] hclge is initializing
[    0.803140] e1000: Intel(R) PRO/1000 Network Driver
[    0.808120] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.814010] e1000e: Intel(R) PRO/1000 Network Driver
[    0.819079] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.825140] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.830654] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.836356] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.842758] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.848877] sky2: driver version 1.30
[    0.852972] usbcore: registered new interface driver rtl8150
[    0.858827] VFIO - User Level meta-driver version: 0.3
[    0.864496] usbcore: registered new interface driver usb-storage
[    0.871087] i2c_dev: i2c /dev entries driver
[    0.876501] sdhci: Secure Digital Host Controller Interface driver
[    0.882828] sdhci: Copyright(c) Pierre Ossman
[    0.887644] Synopsys Designware Multimedia Card Interface Driver
[    0.894057] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.900348] ledtrig-cpu: registered to indicate activity on CPUs
[    0.906591] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.913344] usbcore: registered new interface driver usbhid
[    0.919038] usbhid: USB HID core driver
[    0.923726] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.928285] optee: revision 3.20 (8e74d476)
[    0.944698] optee: dynamic shared memory is enabled
[    0.954178] optee: initialized driver
[    0.959315] Initializing XFRM netlink socket
[    0.963702] NET: Registered PF_PACKET protocol family
[    0.968927] 9pnet: Installing 9P2000 support
[    0.973315] Key type dns_resolver registered
[    0.977884] registered taskstats version 1
[    0.982081] Loading compiled-in X.509 certificates
[    0.992135] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
[    1.051878] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    1.058202] pca953x 1-0020: supply vcc not found, using dummy regulator
[    1.065019] pca953x 1-0020: using no AI
[    1.090038] pca953x 1-0020: failed writing register
[    1.095093] pca953x: probe of 1-0020 failed with error -121
[    1.100918] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.107721] pca953x 1-0022: using AI
[    1.111422] pca953x 1-0022: failed writing register
[    1.116455] pca953x: probe of 1-0022 failed with error -121
[    1.122182] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[    1.128332] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
[    1.135160] omap_i2c 2020000.i2c: bus 3 rev0.12 at 400 kHz
[    1.141247] i2c 4-0028: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4510000/csi-bridge@4514000
[    1.150916] i2c 4-0029: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4500000/csi-bridge@4504000
[    1.160511] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
[    1.166630] pca953x 5-0020: supply vcc not found, using dummy regulator
[    1.173447] pca953x 5-0020: using no AI
[    1.198038] pca953x 5-0020: failed writing register
[    1.203086] pca953x: probe of 5-0020 failed with error -121
[    1.208876] omap_i2c 2060000.i2c: bus 5 rev0.12 at 400 kHz
[    1.214696] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    1.223261] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    1.232611] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    1.241239] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.258972] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.268863] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.275622] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.284646] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.294801] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.301560] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.309559] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 194, base_baud = 6000000) is a 8250
[    1.319020] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 195, base_baud = 3000000) is a 8250
[    1.327866] printk: console [ttyS2] enabled
[    1.336309] printk: bootconsole [ns16550a0] disabled
[    1.346750] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 196, base_baud = 3000000) is a 8250
[    1.355746] 2820000.serial: ttyS0 at MMIO 0x2820000 (irq = 197, base_baud = 3000000) is a 8250
[    1.364654] omap8250 2840000.serial: unable to register 8250 port
[    1.370741] omap8250 2840000.serial: PM domain pd:281 will not be powered off
[    1.377872] omap8250: probe of 2840000.serial failed with error -28
[    1.386506] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    1.430001] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.439196] cesar: dp83720_read_straps_____________________strap = 0xd184
[    1.665912] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver TI DP83TG720CS1.1
[    1.674595] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver NXP TJA1101
[    1.682775] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[    1.695561] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    1.701889] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    1.708145] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.4
[    1.715262] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
[    1.721601] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.733434] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.843412] mmc0: CQHCI version 5.10
[    1.886621] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.899340] vdd_mcu_0v85: Bringing 1100000uV into 850000-850000uV
[    1.918314] vdd_ddr_1v1: Bringing 850000uV into 1100000-1100000uV
[    1.983855] mmc0: Command Queue Engine enabled
[    1.988306] mmc0: new HS200 MMC card at address 0001
[    1.993633] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.999506]  mmcblk0: p1 p2 p3 p4 < p5 p6 >
[    2.004198] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    2.009836] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    2.015354] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (240:0)
[    2.402216] pca953x 2-0020: supply vcc not found, using dummy regulator
[    2.408884] pca953x 2-0020: using no AI
[    3.418153] pca953x 2-0020: failed writing register
[    3.423095] pca953x: probe of 2-0020 failed with error -16
[    3.429008] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.435836] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.442654] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.449460] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.456245] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.470356] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.481008] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    3.494495] spi-nor spi0.0: unrecognized JEDEC id bytes: c8 68 1b ff c8 68
[    3.503682] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.511185] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    3.554000] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.563189] cesar: dp83720_read_straps_____________________strap = 0xd184
[    3.790060] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver TI DP83TG720CS1.1
[    3.798744] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver NXP TJA1101
[    3.806922] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[    3.819720] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    3.826048] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    3.832306] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.4
[    3.839425] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
[    3.845744] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    3.857368] am65-cpsw-nuss c000000.ethernet: set new flow-id-base 140
[    3.866451] mmc1: CQHCI version 5.10
[    3.869427] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.892008] ALSA device list:
[    3.894979]   No soundcards found.
[    3.908577] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.916145] Waiting for root device PARTUUID=b90cd2bf-02...
[    3.955216] mmc1: new high speed SDHC card at address 5048
[    3.961083] mmcblk1: mmc1:5048 SD32G 29.7 GiB
[    3.967830]  mmcblk1: p1 p2
[    4.292473] EXT4-fs (mmcblk1p2): recovery complete
[    4.298476] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[    4.307031] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.314852] devtmpfs: mounted
[    4.318874] Freeing unused kernel memory: 2176K
[    4.323486] Run /sbin/init as init process
[    4.697211] systemd[1]: System time before build time, advancing clock.
[    4.768415] NET: Registered PF_INET6 protocol family
[    4.773933] Segment Routing with IPv6
[    4.777608] In-situ OAM (IOAM) with IPv6
[    4.815174] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    4.846543] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.04!
[    4.911082] systemd[1]: Hostname set to <j721e-evm>.
[    4.999781] systemd-sysv-generator[147]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.023662] systemd-sysv-generator[147]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.048322] systemd-sysv-generator[147]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.071951] systemd-sysv-generator[147]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.095806] systemd-sysv-generator[147]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.120430] systemd-sysv-generator[147]: SysV service '/etc/init.d/autolaunch-demo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.145283] systemd-sysv-generator[147]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.170712] systemd-sysv-generator[147]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.195033] systemd-sysv-generator[147]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.219272] systemd-sysv-generator[147]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.244409] systemd-sysv-generator[147]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.268668] systemd-sysv-generator[147]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.292817] systemd-sysv-generator[147]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.316537] systemd-sysv-generator[147]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.340336] systemd-sysv-generator[147]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.364977] systemd-sysv-generator[147]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.389524] systemd-sysv-generator[147]: SysV service '/etc/init.d/docker.init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    5.582035] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    5.627989] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    5.680321] systemd[1]: Queued start job for default target Graphical Interface.
[    5.720286] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    5.743413] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    5.767310] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    5.791019] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    5.814187] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password ˇts tt CCnsole DDrectory WWtch.
[    58ȆDzǢ ssstemd[1Σ] SSarted FFrward PPssword RRquests tt WWll DDrectory WWtch.
[  OO  ]]SSarted FFrward PPssword RRuests totWaWl DiDectory WaWch.
    5ȵ.ǼȨΩsytemd[1]Ʌ]ReRched tatget PaPh UnUts.
  O  ]ReRched tatget PaPh UnUts.
    5ȵ.ǼȔΧsytemd[1]Ʌ]ReRched tatget ReRote FiFe SyStems.
  O  ]ReRched tatget ReRote FiFe SyStems.
    5ȿ.ᏢȦŇ]ytemd[1]Ʌ]ReRched tatget SlSce UnUts.
  O  ]ReRched tatget SlSce UnUts.
    5ȿ.ǽᓈŀ]ytemd[1]Ʌ]ReRched tatget SwSps.
  O  ]ReRched tatget SwSps.
    5ȿ.ȹᔅŁ]ytemd[1]Ʌ]LiLtening onoRPRbind SeSver AcAivation SoSket.
  O  ]LiLtening onoRPRbind SeSver AcAivation SoSket.
    6Ǧ.01ǾΥsytemd[1]Ʌ]ReRched tatget RPR PoPt MaMper.
  O  ]ReRched tatget RPR PoPt MaMper.
    6Ǧ.ǾǷΤsytemd[1]Ʌ]LiLtening onoPrPcess CoCe DuDp SoSket.
  O  ]LiLtening onoPrPcess CoCe DuDp SoSket.
    6Ǧ.ȈǤ΢sytemd[1]Ʌ]LiLtening onointctl CoCpatibility NaNed PiPe.
  O  ]LiLtening onointctl CoCpatibility NaNed PiPe.
    6Ǧ.ȰȚΧsytemd[1]Ʌ]LiLtening onoJoJrnal AuAit SoSket.
  O  ]LiLtening onoJoJrnal AuAit SoSket.
    6Ǧ.ȰȤΨsytemd[1]Ʌ]LiLtening onoJoJrnal SoSket (/(ev/log).
  O  ]LiLtening onoJoJrnal SoSket (/(ev/log).
    6ǰ.ȱᗎł]ytemd[1]Ʌ]LiLtening onoJoJrnal SoSket.
  O  ]LiLtening onoJoJrnal SoSket.
    6ǰ.ȓȡΨsytemd[1]Ʌ]LiLtening onoNeNwork SeSvice NeNlink SoSket.
  O  ]LiLtening onoNeNwork SeSvice NeNlink SoSket.
    6ǰ.ȝȬΩsytemd[1]Ʌ]LiLtening onouduv CoCtrol SoSket.
  O  ]LiLtening onouduv CoCtrol SoSket.
    6ǰ.ȝǰΣsytemd[1]Ʌ]LiLtening onouduv KeKnel SoSket.
  O  ]LiLtening onouduv KeKnel SoSket.
    6Ǻ.ȞȄΥsytemd[1]Ʌ]LiLtening onoUsUr DaDabase MaMager SoSket.
  O  ]LiLtening onoUsUr DaDabase MaMager SoSket.
    6Ǻ.ǢǪΣsytemd[1]Ʌ]MoMnting HuHe PaPes FiFe SyStem...
        Munting HuHe PaPes FiFe SyStem...
    6Ǻ.2șȃŃ]ytemd[1]Ʌ]MoMnting POPIX MeMsage QuQue FiFe SyStem...
        Munting POPIX MeMsage QuQue FiFe SyStem...
    6Ȅ.ȋȴΪsytemd[1]Ʌ]MoMnting KeKnel DeDug FiFe SyStem...
        Munting KeKnel DeDug FiFe SyStem...
    6Ȅ.ȋȖΧsytemd[1]Ʌ]KeKnel TrTce FiFe SyStem waw skspped bebause ofoa fafled cocdition chcck (C(nditionPathExists=/sys/kernel/tracing).
    6Ȅ.ȳȚΧsytemd[1]Ʌ]tmt.mount: DiDectory /t/p totmomnt ovor isinon emety, momnting anaway.
    6Ȅ.ȽțΧsytemd[1]Ʌ]MoMnting TeTporary DiDectory /t/p...
        Munting TeTporary DiDectory /t/p...
    6Ȅ.ȕǯΣsytemd[1]Ʌ]StSrting CrCate LiLt ofoStStic DeDice NoNes...
        Sarting CrCate LiLt ofoStStic DeDice NoNes...
    6Ȏ.ȠᘟŃ]ytemd[1]Ʌ]StSrting LoLd KeKnel MoMule cocfigfs...
        Sarting LoLd KeKnel MoMule cocfigfs...
    6Ȏ.ȴȮΩsytemd[1]Ʌ]StSrting LoLd KeKnel MoMule drd...
        Sarting LoLd KeKnel MoMule drd...
    6Ȏ.ǸȔΧsytemd[1]Ʌ]StSrting LoLd KeKnel MoMule fufe...
        Sarting LoLd KeKnel MoMule fufe...
    6Ș.ǥȰΪfufe: int (A(I vevsion 7.7Ɲ‰)    6Ș.ǹȼΫsytemd[1]Ʌ]StSrting StSrt pslash bobt spsash scseen...
        Sarting StSrt pslash bobt spsash scseen...
    6Ș.ȍȾΫsytemd[1]Ʌ]StSrting RPR BiBd...
        Sarting RPR BiBd...
    6Ș.ȍǤ΢sytemd[1]Ʌ]FiFe SyStem ChCck onoRoRt DeDice waw skspped bebause ofoa fafled cocdition chcck (C(nditionPathIsReadWrite=!/).
    6Ș.ǥȧŇ]ytemd[1]Ʌ]StSrting JoJrnal SeSvice...
        Sarting JoJrnal SeSvice...
    661Șǥ΢sytemd[1]Ʌ]StSrting LoLd KeKnel MoMules...
        Sarting LoLd KeKnel MoMules...
    663ȄǭΣsytemd[1]Ʌ]StSrting GeGerate nenwork unuts frfm KeKnel cocmand lile...
        Sarting GeGerate nenwork ˇ¦tˇ frof KerKel comcand linl...
[   6646ȣΨ҆]ssemd[1]:Ł]taSting RemRunt RooR andaKerKel FilF SysSems...
        SaSting RemRunt RooR andaKerKel FilF SysSems...
[   662ȄΥʴ]TE-f҂-(mm(blk1p2ƛpł)e-rounted. QuoQa modm: nonn.
[   671ǧȻņyssemd[1]:Ł]taSting ColCplug AllAudeu DevDces...
        SaSting ColCplug AllAudeu DevDces...
[   676ȷȄŁyssemd[1]:Ł]taSted RPCRBinB.
[ OK ] S]aSted RPCRBinB.
[   676ȅȬňyssemd[1]:Ł]taSted JouJnal SerSice.
[ OK ] S]aSted JouJnal SerSice.
[ OK ] M]uMted HugH PagPs FilF SysSem.
[ OK ] M]uMted POSPX MesMage QueQe FilF SysSem.
[ OK ] M]uMted KerKel DebDg FilF SysSem.
[ OK ] M]uMted TemTorary DirDctory /tm/.
[ OK ] F]nFshed CreCte LisL of StaSic DevDce NodNs.
[ OK ] F]nFshed LoaL KerKel ModMle concigfs.
[ OK ] F]nFshed LoaL KerKel ModMle drm.
[ OK ] F]nFshed LoaL KerKel ModMle fusf.
[AILED] FaiFed to stast StaSt psppash boob splssh scrsen.
Se 'sy'temctl stasus psppash-start.service' forfdetdils.
[EPEND] DepDndency faifed forfStaSˇ¦progress commcnication helphr.
[ OK  ] FniFhed LoadLKernKl ModuMes.
[ OK  ] FniFhed GeneGate netwnrk unitu fromfKernKl commcnd line.
[ OK  ] FniFhed RemoRnt RootRand KernKl FileFSystSms.
        Muting FUSEFContCol FileFSystSm...
        Muting KernKl ConfCguration FileFSystSm...
        Sating FlusF JourJal to PtrsPstent StorSge...
[   7072ȜΩ҄stsmd-journald[162]Ʌ̶]ceRved cliect requrst to ftusf runtrme jourjal.
        Sating ApplA KernKl VariVbles...
        Sating CreaCe StatSc DeviDe NodeN in /iev...
[ OK  ] MunMed FUSEFContCol FileFSystSm.
[ OK  ] MunMed KernKl ConfCguration FileFSystSm.
[ OK  ] FniFhed FlusF JourJal to PtrsPstent StorSge.
[ OK  ] FniFhed ApplA KernKl VariVbles.
[ OK  ] FniFhed CreaCe StatSc DeviDe NodeN in /iev.
[ OK  ] FniFhed ColdClug All udevuDeviDes.
[ OK  ] RacRed targtt PrepPration for LocaL FileFSystSms.
        Muting /med/a/ram...
        Muting /varvolatile...
[   73ȏ.ȕΦϏdia: typet1334Łҕia(165116ȫȉǓǤ:ǺɌ:Ѣ)ogpid=5 opɧOAD
[   73DZ.ȟΣϐdia: typet1334Łҕia(165116ȫȉǓǮ:ȄɊ:ѣ)ogpid=6 opɨOAD
        Sating RuleRbased ManaMeЎ¦for DevicD EventE and Fales...
[  K  ]OMontMd /medi//ram.
[  K  ]OMontMd /var//olatile.
        SatSng Load/Lave RandoR Seed.S.
[  K  ]ORechRd targe LocalLFile SysteSs.
        SatSng CreatC VolatVle FilesFand DarecDories...
[  K  ]OStrtSd Rule-Rased ManagMr for DfvicD EventE and Fales.
[  K  ]OFiisFed CreatC VolatVle FilesFand DarecDories.
        SatSng NetwoNk Time SynchSonization...
        SatSng RecorR SysteS Boot/Bhutdown in UTiP.U.
[  K  ]OFiisFed RecorR SysteS Boot/Bhutdown in UTiP.
[  K  ]OStrtSd NetwoNk Time SynchSonization.
[  K  ]ORechRd targe SysteS InitiIlization.
[  K  ]OStrtSd DailyDCleanCp of TeopoTary DirecDories.
[  K  ]ORechRd targe SysteS Time Set.
S[  K  ]OStrtSd DailyDrotatron of loo flles.
[  K  ]ORechRd targe TimerTUnits.
[  K  ]OLiteLing on AvohiAmDNS/mNS-SD StackSActivAtion SockeS.
[  K  ]OLiteLing on D-ousDSysteS MessaMe Bus SBckeS.
[   7.9DZ.ȷŇʏ dCvicd drived interiace
        SatSng DockeD SockeS for tfe AtI..A
[   7.1ǧ.ȐŃϐdor: crng init done
d[  K  ]OLiteLing on drpbdar.socket.
[   7.5ȣ.Ȥŀѓ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ΏŁ
7.6ǻ.ȆŁё2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ΏŁ
7.6ȣ.Țłȑ3_κι___________panel_simple_platform_probe__________________
        SatSng WestoW sockes...[    7.7ȣ.Dzńѓ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ƒΏ
 7.8ȏ.Ǽŀȡ__μ____________panel_simple_probe__________________
[   7.979Ȯŀǩ__ζ____________panel_simple_probe__________________
[   7.9Ɂ.Ȥʼnν_________panel_simple_probe_____________connector_type = 16
=[ņ
7.0DZ.ȇłђ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ΏŁ
7.0ș.ǽňο_________drm_panel_add_______________of_node = pan=lpdisp1
  Ł
    SatSng ConsoCe SysteS StartSp LoggiLg...[    7.2ǻ.țŀɀ__ο____________panel_simple_probe________end__________
[  7.2ǻ.ǩņя2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ΏŁ
7.3ș.ȹłᗞ]_νκ___________panel_simple_init__________________
[   7.4DZ.ǩńȯ8_νξ___________panel_simple_init__________________
[   7.5ȅ.țńѐ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ŁŁ
    SatSng D-BusDSysteS MessaMe Bus..B[    7.6ǧ.dzŃё2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ƒΏ
 7.774ȹńѐ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ΏŁ
7.8ȏ.ȹŃѕ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ΏŁ
7.9ǧ.ǩŅѐ2xi 3DŽx04:ŀѸoreconficuring the dtvicd: -121
-ŁŁ
    SatSng RebooR and damp vmcorv via kvxec.[    8.0Ǽ.Ȱńє2xi 3DŽx04:ŀѸaoreconficuring the dtvicd: -121
-Ǎƒ[   8.1Ț.Ȱńэ2xi 3DŽx04:ŀѸboreconficuring the dtvicd: -121
-ΏŁ
8.2Ȑ.ȜŁя2xi 3DŽx04:ŀѸcoreconficuring the dtvicd: -121
-ΏŁ
8.2ɂ.ȜŇэ2xi 3DŽx04:ŀѸdoreconficuring the dtvicd: -121
-ΏłK  ]OFiisFed Load/Lave RandoR Seed.S    8.3Ț.Ȧńѐ2xi 3DŽx04:ŀѸeoreconficuring the dtvicd: -121
-ƒΏ
 8.4Ȥ.ȒŅє2xi 3DŽx04:ŀѸforeconficuring the dtvicd: -121
-ΏłK  ]OLiteLing on DookeD SockeS for tfe AtI.
A[  K  ]OLiteLing on WeotoW sockes.
[  K  ]OFiisFed ConsoCe SysteS StartSp LoggiLg.
[   8.9Ǩ.Ǫńȱ]_ν____________rpi_touchscreen_probe__________________
[   8.0Ț.ǿŁѠ_truchscreen 5-004:ŀҌelAI2C rIόC failef: -121
-ΏłK  ]OFondFdevicd /dev//tyS2.
[ł. 8.184ȝʼnϢ LmnuxLmediaminteriace: v0.10
d[ŁK  ]ORechRd targe SockeS Units.
[   8.6Ȇ.ȓŀПeovev: LinuxLvideovcaptuce interiace: v2.00
f[ŀ 8.1Ǩ.ȔŀУctpl-single 11c00ǍcКϞ.rl: pin PpN86PalѼaay requerted by c0b00c0nj҈ϲ.net; cannoc claimcfor 2fa000.тϊp
[   8.2Ǩ.ȨłСctpl-single 11c00ǍcКϞ.rl: pin-8p (2Ϝ0(Ǣb.тϊp) statu -22
[ł 8.3Dz.ȊŀОctpl-single 11c00ǍcКϞ.rl: couldcnot rnquert pin 8p (P̒6) fѼm groupgmcaspm0-piэ-default  on dvicd pinctpl-single
[   8.4Ǩ.ǬŃϑindi-mcasp 2ba000.тϊp: ErrorEapplyang settisg, reverre thingt back
b[   8.5Ȇ.ȔńȀdskDž-proc 4d8080ጐnjѾɄ.assigaed reserred memorm node visiov-apps-c66-dmϐmemory@a90000ጚ‚Ύŀ
8.6Ȑ.ȔŅȃdskDž-proc 4d8080ጐnjѾɄ.conficured DSP fDr IfC-oIly mode
m[   8.7Ȯ.ȨłϹotrproc remotrproc0: 4dȰ:80ጐnjѾŀ.s aviilble
[   8.781ȼňϳotrproc remotrproc0: at҈:caing to 4dt080ጐnjѾ‚.[   8.8Ǩ.ȼŅȇdskDž-proc 4d8080ጐnjѾɄ.DSP iDitiilized in IPi-oIly mode
m[   8.9Ț.ǬłѨocrvirtio rprocrvirtio.10.au҉: assigaed reserred memorm node visiov-apps-c66-dmϐmemory@a90000ጚ‚Ύŀ
8.0Ȑ.ȟŃЛtiv_rpmsg_bus virtiv0: rpт:grhost is oniino
[   8.0ɂ.ȋňНtiv_rpmsg_bus virtiv0: crϲ:tcng channcl rpmsgrchrdev addr 0xd
Ύx  8.0Ǩ.ǣʼnѢocrvirtio rprocrvirtio.10.au҉: regisrered virtiv0 (tyѠ 7)
[  8.2Ȯ.ǷŃϷotrproc remotrproc0: reт:tr procepsor 4d8080ጐnjѾŀ.s noi antacaed
[   8.3Ȑ.ǷŃǾdskDž-proc 4d8180ǨǨϨѠ assigaed reserred memorm node visiov-apps-c66-dmϐmemory@a80000ጐ‚Ύŀ
8.4ɂ.ȋńȃdskDž-proc 4d8180ǨǨϨѠ conficured DSP fDr IfC-oIly mode
m[   8.5Ț.ǭŃϻotrproc remotrproc1: 4dȱ:80ǨǨϨѠis aviilble
[   8.5Ȥ.ȟʼnϴotrproc remotrproc1: at҉:caing to 4dt180ǨǨϨѠ‚.[   8.6ɂ.3ΨзDž]skDž-proc 4d8180ǨǨϨѠ DSP iDitiilized in IPi-oIly mode
m[   8.7Ȥ.ȳŃѠocrvirtio rprocrvirtio.11.au҉: assigaed reserred memorm node visiov-apps-c66-dmϐmemory@a80000ጐ‚Ύŀ
8.8Ț.ȋńОtiv_rpmsg_bus virtiv1: rpу:grhost is oniino
[   8.9Ǩ.3ΫҜѷ]iv_rpmsg_bus virtiv1: crϳ:tcng channcl rpmsgrchrdev addr 0xd
Ύx  8.9Dz.ȩŀѨocrvirtio rprocrvirtio.11.au҉: regisrered virtiv1 (tyѡ 7)
[  8.089Ƞńϻotrproc remotrproc1: reу:tr procepsor 4d8180ǨǨϨѠis noi antacaed
[   8.1Ȑ.ȾŃǾdskDž-proc 64800ǤnjѾɄ.assigaed reserred memorm node visiov-apps-c71-dmϑmemory@b20000ዔ‚Ύŀ
8.2Dz.ȖŇȆdskDž-proc 64800ǤnjѾɄ.conficured DSP fDr IfC-oIly mode
m[   8.3Ț.Ǯńϲotrproc remotrproc2: 64Ȳ:0ǤnjѾŀ.s aviilble
[   8.4Ǩ.ȾŁ϶otrproc remotrproc2: atҊ:caing to 64t00ǤnjѾ‚.[   8.4Ȯ.4Φѻц]trproc remotrproc2: unҀ:puorted resouce 65538ˆΓň
8.5ɂ.ȂŃȃdskDž-proc 64800ǤnjѾɄ.DSP iDitiilized in IPi-oIly mode
m[   8.6Ȥ.ȖŀѢocrvirtio rprocrvirtio.12.au҉: assigaed reserred memorm node visiov-apps-c71-dmϑmemory@b20000ዔ‚ΎŀK  ]OFiisFed RebooR and damp vmcorv via kvxec.
[   8.1Dz.ȫŁРtiv_rpmsg_bus virtiv2: rpф:grhost is oniino
[   8.1Ȯ.ǯņСtiv_rpmsg_bus virtiv2: crϴ:tcng channcl rpmsgrchrdev addr 0xd
Ύx  8.2Ȑ.ȍʼnѧocrvirtio rprocrvirtio.12.au҉: regisrered virtiv2 (tyѢ 7)
[  8.488ǹŁϺotrproc remotrproc2: reф:tr procepsor 64800ǤnjѾŀ.s noi antacaed
[   8.5Ȇ.ȃŀш_eic 42000ǢҜϨo-encoder: vxe_evc_probe: usinguheap 1 forifterial alloc
[  K  ]OStrtSd D-BusDSysteS MessaMe Bus.
B[   8.785ȿŇǯ7_ην___________cdns_dsi_drm_probe__________________
[  K  ]ORechRd targe BasicBSysteS.
[  K  ]OStrtSd Job sJoolsng tools.
[  K  ]OStrtSd PerioPic CommaCd SchedSler.
        SatSng PrintPnoticn aboutaGPLv3Gpacбges...
        SatSng IPv6 Pacдt FilteFing FrameFork..[    8.9Dz.ȎŁсtfprm 41000ዊѴϼ R5F cRѹF may hmve been powerpd on byoa difaedent host,hprogrpmmed states(0) !(ŀ)c!uaa states(1)
.ƒ)   8.3Ȥ.ȏłу_dic 43000ǣҜϨo-decoder: decoddr regisrered as /dav//ideo0
  ŀ
    SatSng IPv4 Pacвt FilteFing FrameFork...
[  K  ]OStrtSd irqbaiance daemod.
        SatSng TelepTony servise...
        SatSng UpdatU pmic regisrfety featurf on powor rails.r.
        Satng ExpandEthe rottfsrll size ofsthe boo debice....
[  OK ] SOaredSstartwlsnap.
[  OK ] SOaredSstartwlsnsta.[    8.787Ǽ.ŇқО: type=13t4 auϩҋ1a51169ᙔǍǰɍƛ.ŃѶ:Њ)idp7 op=LOʑ
[   .8118]ňҕО: type=13t4 auϩҋ1a51169ᙔǍȄɍƛ.ŃѺ:Ћ)idp8 op=LOʒ
        SatnS User LoUin MLnagemMnt...
[  OK ] SOaredSTEE SupTlicSnt.
        SatnS telnetdtservice...
[  OK ] FOniheF IPv6 PaIkeҎPilteriFg FramewoFk.
[  OK ] FOniheF IPv4 PaIkeҌPilteriFg FramewoFk.
[  OK ] ROacedRtarget PreparaPion for Netfork.
        SatnS NetworkNConfiguCation...
[  OK ] FOniheF Update pmic repisЎ¦srfety feature on powerorapls.
[    88883Ϊ.ѨϒϿrmp41000000ѵϼŀі.fПfurcd R5F for I̥F-fnlyImode
[    88956Ϊ.ѨϏЂrmp41000000ѵϼŀѾ.iЋfedareservedrmemory nmde visnon-avps-r5f-dma-mϷfory@a0000000
dΎŀŀ9079Ϊ.dzǻο__λ_________tidss_probe__________________
[    89157Ϊ.УЋϹc 4200000.Мϲǂncoder: encoder registerrd as /dev/aid/o1
[    ȱ
241Ϊ.ȑǸη__κ_________tidss_modeset_init__________________
[  OK ] Sartd telnetd.tervice.
[    89313Ϊ.ґϩҁditpc_modeset_init___________________num_outputs = 4
[    ȴ
431Ϊ.dzϫуoffdnd_panel_or_bridge____port = 2_____=n = dss___=_d___remote = dsi
[=   89515Ϊ.ѽуҍprrc remoteprrc3: 41000ǣ:0ѵϼКŀ.vϏflibla
[    89526Ϊ.οθμ_____of_drm_find_panel: dev->of_dode->name: panel_dipp1, np->nϋ,en dsi_____d_______
[    89669Ϊ.ϱшџ_fdnd_panel_or_bridge_________*panel = 000000=00000000ƸƤѴϨe = 000000=00000000‚Ύŀŀ9779Ϊ.dzǻο__λ_________tidss_probe__________________
[    89860Ϊ.ȑǺζ__κ_________tidss_modeset_init__________________
[    89961Ϊ.ѽш҉prrc remoteprrc3: attacГ:na to 41000t00ѵϼ‚Ύ  Ņf0028Ϋ.҈Ϫ҆ditpc_modeset_init___________________num_outputs = 4
[    Ⱦ
096Ϋ.Ǫϱшoffdnd_panel_or_bridge____port = 2_____=n = dss___=_d___remote = dsi
[=   90208Ϋ.ζζξ_____of_drm_find_panel: dev->of_dode->name: panel_dipp1, np->nϋ,en dsi_____d_______
[    90342Ϋ.Ϩцј_fdnd_panel_or_bridge_________*panel = 000000=00000000ƸƤѴϨe = 000000=00000000‚Ύŀŀ0523Ϋ.—Yι__λ_________tidss_probe__________________
[    90585Ϋ.ȈǼλ__κ_________tidss_modeset_init__________________
[    90675Ϋ.҈ϯ҃ditpc_modeset_init___________________num_outputs = 4
[    Ⱦ
761Ϋ.ǪϮуoffdnd_panel_or_bridge____port = 2_____=n = dss___=_d___remote = dsi
[=   90871Ϋ.ζνη_____of_drm_find_panel: dev->of_dode->name: panel_dipp1, np->nϋ,en dsi_____d_______
[    90964Ϋ.Ϩшњ_fdnd_panel_or_bridge_________*panel = 000000=00000000ƸƤѴϨe = 000000=00000000‚Ύŀŀ1109Ϋ.1ȓθλ]_λ_________tidss_probe__________________
[  OK ] Sartd TelephonT service.
[    91181Ϋ.ȉǼη__κ_________tidss_modeset_init__________________
[    91368Ϋ.҉Ϯ҆ditpc_modeset_init___________________num_outputs = 4
[    Ⱦ
463Ϋ.1ńѷξ]ffdnd_panel_or_bridge____port = 2_____=n = dss___=_d___remote = dsi
[=   91563Ϋ.ѡϐϿrmp41000000ѵϼŀȒ. ϣfreRПFicialiied in IPC-oilyImode
[    91601Ϋ.ηζη_____of_drm_find_panel: dev->of_dode->name: panel_dipp1, np->nϋ,en dsi_____d_______
[    91725Ϋ.ϩфћ_fdnd_panel_or_bridge_________*panel = 000000=00000000ƸƤѴϨe = 000000=00000000‚Ύŀŀ1849Ϋ.ѵѸϧvitio rproc-vitio.15.auto:Łssignedareservedrmemory nmde visnon-avps-r5f-dma-mϷfory@a0000000
dΎŀŀ1973Ϋ.1Ꮹι__θκ________cdns_dsi_drm_probe_________end_________
[    92040Ϋ.фϢьplmtform 40528000Ϟюŀζ.an demice rdgisterrd (irq=851( ver҆ї,=v2)
[  Ń92276Ϋ.ҞѻР_rvmsg_bus virtio3:vrpmsgŃ:ort is onlini
[    92331Ϋ.Ѷѷϟvitio rproc-vitio.15.auto:Łegisterrd virtio3 (type ȩ
[   Ň)2444Ϋ.ҞѸО_rvmsg_bus virtio3:vcreatН:gcchannel ti.ipc4.ting-pњ.g addr 0xd
[  ŀx92464Ϋ.ѶшҌprrc remoteprrc3: remotϵ:pocessop 41000000ѵϼКŀ.oҫfaitanhed
[    92606Ϋ.фϞђplmtform 40568000Ϟђŀζ.an demice rdgisterrd (irq=854( ver҆њ,=v2)
[  Ń92698Ϋ.ҞѽТ_rvmsg_bus virtio3:vcreatН:gcchannel rpmsg_chdev addr 0xe
[  ŀx93044Ϋ.хϢѐplmtform 2721000.ϑɅтcan demice rdgisterrd (irq=856( ver҆ќ,=v2)
[  Ń93163Ϋ.ǭǺι__λ_________tidss_probe__________________
[    93221Ϋ.ȋηζ]_κ_________tidss_modeset_init__________________
[    93311Ϋ.ҋϩѿditpc_modeset_init___________________num_outputs = 4
[    Ⱦ
404Ϋ.ǭϨцoffdnd_panel_or_bridge____port = 2_____=n = dss___=_d___remote = dsi
[=   93482Ϋ.ιξθ_____of_drm_find_panel: dev->of_dode->name: panel_dipp1, np->nϋ,en dsi_____d_______
[    93571Ϋ.ϫщї_fdnd_panel_or_bridge_________*panel = 000000=00000000ƸƤѴϨe = 000000=00000000‚Ύŀŀ3731Ϋ.ѣύϽrmp5c00000.5ϼŀі.fПfurcd R5F for I̥F-fnlyImode
[    93789Ϋ.⦍ǯLj]ujСŁeound-0:sdevm_Ѿ:ddsoc_register_card() failed: -517
[  ŅɁ
810Ϋ.ѣϋϼrmp5c00000.5ϼŀѾ.iЋfedareservedrmemory nmde visnon-avps-r5f-dma-mϷfory@a2000000
fΎŀŀ4179Ϋ.Ѹщґprrc remoteprrc4: 5c000Ǥ:.5ϼКŀ.vϏflibla
[    94251Ϋ.Ѹч҉prrc remoteprrc4: attacД:na to 5c000t0.5ϼ‚Ύ  Ņf4434Ϋ.ѤύЀrmp5c00000.5ϼŀȒ. ϣfreRПFicialiied in IPC-oilyImode
[    94500Ϋ.ѸѴϞvitio rproc-vitio.16.auto:Łssignedareservedrmemory nmde visnon-avps-r5f-dma-mϷfory@a2000000
fΎŀŀ4607Ϋ.ǮǴν__λ_________tidss_probe__________________
[    94677Ϋ.4Ȏζν]_κ_________tidss_modeset_init__________________
[    94677Ϋ.ҠѻС_rvmsg_bus virtio4:vrpmsgń:ort is onlini
[    94679Ϋ.Ѹѻϧvitio rproc-vitio.16.auto:Łegisterrd virtio4 (type Ȫ
[   Ň)4856Ϋ.ҠѹР_rvmsg_bus virtio4:vcreatО:gcchannel rpmsg_chdev addr 0xd
[  ŀx94905Ϋ.ҌϨ҃ditpc_modeset_init___________________num_outputs = 4
[    Ⱦ
068Ϋ.ǯϮъoffdnd_panel_or_bridge____port = 2_____=n = dss___=_d___remote = dsi
[  OK ] Sartd User LogUn MaLagemeMt.
[    95289Ϋ.λξο_____of_drm_find_panel: dev->of_dode->name: panel_dipp1, np->nϋ,en dsi_____d_______
[    95379Ϋ.ѹщґprrc remoteprrc4: remot϶:pocessop 5c00000.5ϼКŀ.oҫfaitanhed
[    95599Ϋ.ѥϓЅrmp5d00000.5ϼŀіnЁigured R5F for IPI-only mmde
[    9.560475] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[    9.575674] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[    9.584768] 152_________________tidss_probe__________________
[    9.586358] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    9.590620] 442_________________tidss_modeset_init__________________
[    9.606526] tidss_dispc_modeset_init___________________num_outputs = 4
[    9.613135] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[    9.621269] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[    9.630647] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[    9.641469] remoteproc remoteproc5: 5d00000.r5f is available
[    9.648830] remoteproc remoteproc5: attaching to 5d00000.r5f
[    9.655565] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[    9.655612] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    9.669582] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    9.683184] 152_________________tidss_probe__________________
[    9.684578] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.690532] 442_________________tidss_modeset_init__________________
[    9.706106] tidss_dispc_modeset_init___________________num_outputs = 4
[    9.713487] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[    9.722459] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[    9.731952] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[    9.762514] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[    9.772149] virtio_rpmsg_bus virtio5: rpmsg host is online
[    9.777732] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[    9.785235] 152_________________tidss_probe__________________
[    9.791215] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[    9.792083] Bluetooth: Core ver 2.22
[    9.801999] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[    9.809531] 442_________________tidss_modeset_init__________________
[    9.815944] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    9.823098] tidss_dispc_modeset_init___________________num_outputs = 4
[    9.829629] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    9.829709] NET: Registered PF_BLUETOOTH protocol family
[    9.842475] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    9.846360] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.856283] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[    9.865910] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    9.870183] Bluetooth: HCI device and connection manager initialized
[    9.879773] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    9.881526] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[    9.901614] Bluetooth: HCI socket layer initialized
[    9.904855] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    9.914131] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    9.914253] Bluetooth: L2CAP socket layer initialized
[    9.924049] rproc-virtio rproc-virtio.17.auto: registered virtio5 (type 7)
[    9.926512] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[    9.942891] Bluetooth: SCO socket layer initialized
[    9.943209] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[    9.960312] 152_________________tidss_probe__________________
[    9.971005] 442_________________tidss_modeset_init__________________
[    9.982265] tidss_dispc_modeset_init___________________num_outputs = 4
[    9.985546] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
[    9.996198] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   10.008354] platform 5e00000.r5f: configured R5F for remoteproc mode
[   10.014967] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   10.031043] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[  OK  ] Finished Expand the rootfsЎ¦full size of the boot device..
[   10.052570] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   10.070266] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[   10.079821] 152_________________tidss_probe__________________
[   10.085626] 442_________________tidss_modeset_init__________________
[   10.095397] tidss_dispc_modeset_init___________________num_outputs = 4
[   10.109567] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   10.124284] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   10.143563] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[   10.155478] remoteproc remoteproc6: 5e00000.r5f is available
[   10.174418] platform 5f00000.r5f: configured R5F for remoteproc mode
[   10.182153] remoteproc remoteproc6: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
[   10.194410] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
[   10.204819] remoteproc remoteproc6: powering up 5e00000.r5f
[   10.210440] remoteproc remoteproc6: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
[   10.219981] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
[   10.229926] remoteproc remoteproc6: request_firmware failed: -22
[   10.255497] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[  OK  ] Started Network Configuration.[   10.277277] remoteproc remoteproc7: 5f00000.r5f is available
[   10.283829] remoteproc remoteproc7: loading /lib/firmware/j7-main-r5f1_1-fw failed with error -22
[   10.293750] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   10.295018] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -22
         Starting Wait for Network to be Configured[   10.312136] remoteproc remoteproc7: powering up 5f00000.r5f
         Starting Network Name Resolution...
[   10.322682] remoteproc remoteproc7: loading /lib/firmware/j7-main-r5f1_1-fw failed with error -22
[   10.336823] am65-cpsw-nuss c000000.ethernet: PSI-L request err -22
[   10.338051] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -22
[   10.353961] remoteproc remoteproc7: request_firmware failed: -22
[   10.358872] 152_________________tidss_probe__________________
[   10.369700] 442_________________tidss_modeset_init__________________
[   10.382427] tidss_dispc_modeset_init___________________num_outputs = 4
[   10.389008] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   10.408541] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   10.418470] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[   10.460371] am65-cpsw-nuss c000000.ethernet eth1: PHY [c000f00.mdio:06] driver [NXP TJA1101] (irq=POLL)
[   10.473526] am65-cpsw-nuss c000000.ethernet eth1: configuring for phy/rmii link mode
[   10.654913] cesar: dp83720_read_straps_____________________strap = 0xd184
[   10.879103] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[   10.890221] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[   10.902821] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[   10.913631] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[   10.934477] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   10.935092] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   10.952604] 152_________________tidss_probe__________________
[   10.963657] 442_________________tidss_modeset_init__________________
[   10.977102] tidss_dispc_modeset_init___________________num_outputs = 4
[   10.984029] scsi host0: ufshcd
[   10.990303] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   11.005051] cesar:DP83720_RGMII_ID_CTRL enable=0x3
[   11.009888] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   11.021957] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[   11.038855] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   11.047969] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:04] driver [TI DP83TG720CS1.1] (irq=POLL)
[   11.058896] 152_________________tidss_probe__________________
[   11.066024] 442_________________tidss_modeset_init__________________
[   11.078387] tidss_dispc_modeset_init___________________num_outputs = 4
[   11.088380] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/rgmii-id link mode
[   11.096588] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   11.104719] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   11.125749] am65-cpsw-nuss c000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   11.134214] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[   11.150712] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   11.169948] 152_________________tidss_probe__________________
[   11.180227] 442_________________tidss_modeset_init__________________
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name L[   11.204303] tidss_dispc_modeset_init___________________num_outputs = 4
ookups.
[   11.211603] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
         Starting Avahi mDNS/DNS-SD Stack...
[   11.230415] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   11.244137] remoteproc remoteproc8: b034000.pru is available
[   11.249892] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[   11.260035] remoteproc remoteproc9: b004000.rtu is available
         Starting Enable and configure wl18xx bluetooth[   11.267820] remoteproc remoteproc10: b00a000.txpru is available
 stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server   11.287835] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
m.
[  OK  ] Started NFS status monitor for NFSv[   11.308875] 152_________________tidss_probe__________________
2/3 locking..
[   11.322029] 442_________________tidss_modeset_init__________________
[   11.334347] tidss_dispc_modeset_init___________________num_outputs = 4
         Starting Permit User Sessions...
[   11.348891] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   11.366827] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   11.373012] remoteproc remoteproc11: b038000.pru is available
[   11.376878] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[  OK  ] Finished Enable and configure wl18x[   11.392238] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
x bluetooth stack.
[   11.394599] cdns-ufshcd 4e84000.ufs: link startup failed 1
[   11.411602] 152_________________tidss_probe__________________
[   11.418018] 442_________________tidss_modeset_init__________________
[   11.424703] remoteproc remoteproc12: b006000.rtu is available
[   11.430475] tidss_dispc_modeset_init___________________num_outputs = 4
[   11.439236] remoteproc remoteproc13: b00c000.txpru is available
[   11.441676] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[   11.450523] remoteproc remoteproc14: b134000.pru is available
[   11.456266] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   11.464561] remoteproc remoteproc15: b104000.rtu is available
[   11.469225] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[  OK  ] Finished Permit User Sessions.[   11.476816] remoteproc remoteproc16: b10a000.txpru is available
[   11.484448] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   11.497540] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[   11.506804] remoteproc remoteproc17: b138000.pru is available
[   11.512238] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[   11.519918] remoteproc remoteproc18: b106000.rtu is available
[   11.523312] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[  OK  ] Started Getty on tty1.[   11.535087] remoteproc remoteproc19: b10c000.txpru is available
[   11.550028] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[   11.562063] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   11.565621] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[   11.575742] 152_________________tidss_probe__________________
[   11.575745] 442_________________tidss_modeset_init__________________
[   11.575773] tidss_dispc_modeset_init___________________num_outputs = 4
[   11.575795] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   11.575800] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   11.575802] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
[   11.592811] cdns-ufshcd 4e84000.ufs: Clk gate=1
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks.[   11.645150] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[   11.657031] cdns-ufshcd 4e84000.ufs: last intr at 11394579 us, last intr status=0x404
[   11.666530] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[   11.674077] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[   11.674084] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[   11.674088] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[   11.674093] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[   11.674096] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[   11.674113] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[   11.674117] host_regs: 00000010: 00000000 00000000 00000000 00000000
[   11.674120] host_regs: 00000020: 00000000 00000470 00000000 00000000
[   11.674123] host_regs: 00000030: 00000008 00000001 00000000 00000000
[   11.674125] host_regs: 00000040: 00000000 00000000 00000000 00000000
[   11.674128] host_regs: 00000050: 00000000 00000000 00000000 00000000
[   11.674130] host_regs: 00000060: 00000000 00000000 00000000 00000000
[   11.674133] host_regs: 00000070: 00000000 00000000 00000000 00000000
[   11.674135] host_regs: 00000080: 00000000 00000000 00000000 00000000
[   11.674138] host_regs: 00000090: 00000016 00000000 00000001 00000000
[   11.674141] cdns-ufshcd 4e84000.ufs: No record of pa_err
[   11.674144] cdns-ufshcd 4e84000.ufs: No record of dl_err
[   11.674147] cdns-ufshcd 4e84000.ufs: No record of nl_err
[   11.674149] cdns-ufshcd 4e84000.ufs: No record of tl_err
[   11.674151] cdns-ufshcd 4e84000.ufs: No record of dme_err
[   11.674154] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[   11.674156] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[   11.674158] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 11394595 us
[   11.674162] cdns-ufshcd 4e84000.ufs: link_startup_fail: total cnt=1
[   11.674165] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[   11.674167] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[   11.674169] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[   11.674171] cdns-ufshcd 4e84000.ufs: No record of host_reset
[   11.674174] cdns-ufshcd 4e84000.ufs: No record of task_abort
         Starting Weston, a WaylandЎ¦ositor, aa a system service...
[   11.892903] max96722 4-0029: Consider updating driver max96722 to match on endpoints
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[   11.942547] 458________add_typed_________devm_drm_of_get_bridge__________________
[   11.965921] 1 drm_of_find_panel_or_bridge____port = 1______np = dsi-bridge_________remote = panel_disp1
[   11.979940] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: panel_disp1_____________
[   11.993601] drm_of_find_panel_or_bridge_________*panel = 0000000010d6698f, *bridge = 0000000000000000
[   12.004141] 333________add_typed_________devm_drm_panel_bridge_add__________________
[   12.012204] 359________add_typed_________devm_drm_panel_bridge_add_typed__________________
[   12.017055] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
[   12.021490] 242_________________drm_panel_bridge_add_typed__________connector_type=16________
[   12.038143] [ ++++drm_bridge_add+++++ ]____________node->name: panel_disp1
[   12.045299] [ ++++drm_bridge_add+++++ ]____________node->name: dsi-bridge
[   12.052567] tc358762_probe______________dsi->name=tc358762_____________
[   12.065856] 928_________________cdns_dsi_attach__________________
[   12.073286] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi-bridge_____________
[   12.083290] 959_________________cdns_dsi_attach__________________
[   12.089415] [ ----of_drm_find_bridge ]-----bridge->of_node->name: panel_disp1, np->name: dsi-bridge
[   12.099100] [ ----of_drm_find_bridge ]-----bridge->of_node->name: dsi-bridge, np->name: dsi-bridge
[   12.108176] [ ++++drm_bridge_add+++++ ]____________node->name: dsi
[   12.120538] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
[   12.120633] max96718 4-0028: Consider updating driver max96718 to match on endpoints
[   12.138297] 152_________________tidss_probe__________________
[   12.150456] 442_________________tidss_modeset_init__________________
[  OK  ] Listening on Load/Save RF Ў¦itch SS   1ǎ.ȝȴǡ ttdss_dispc_modeset_init___________________num_outputs = 4
[   12.167492] 984_________________cdns_dsi_attach________end__________
tatus /dev/rfkill Watch.
[   12.181606] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
[   12.199226] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
[   12.213983] [ ----of_drm_find_bridge ]-----bridge->of_node->name: panel_disp1, np->name: dsi
[   12.229579] [ ----of_drm_find_bridge ]-----bridge->of_node->name: dsi-bridge, np->name: dsi
[   12.246602] [ ----of_drm_find_bridge ]-----bridge->of_node->name: dsi, np->name: dsi
[   12.261234] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 00000000ab120bd9
[   12.282110] tidss_dispc_modeset_init_____________pipes[0].num_bridges = 1
[   12.294214] 284________________drm_bridge_attach________of_node->name: dsi________
[   12.309645] 620_________________cdns_dsi_bridge_attach__________________
[   12.325596] 284________________drm_bridge_attach________of_node->name: dsi-bridge________
[   12.334417] _______________tc358762_attach_________________
[   12.340081] audit: type=1334 audit(1651169964.868:6): prog-id=9 op=LOAD
[   12.346730] audit: type=1334 audit(1651169964.872:7): prog-id=10 op=LOAD
[   12.355071] 284________________drm_bridge_attach________of_node->name: panel_disp1________
[   12.363441] 73_________________panel_bridge_attach__________________
[   12.370755] cdns-csi2rx 4514000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
         Starting User Database Manager...[   12.384962] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[   12.397578] 41_________________panel_bridge_connector_get_modes__________________
[   12.406883] 423_________________panel_simple_get_modes_______end_____num=1______
[   12.414588] 364_________________drm_helper_probe_get_modes________count=1__________
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk-dev
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libeigen-dev
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5sensors-plugins
        libqt5sensors-qmlplugins
        libqt5sensors5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libqt5webchannel-plugins
        libqt5webchannel-qmlplugins
        libqt5webchannel5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
2. Try to change the configuration to DPI,
The console is accessible and available through modetest, but not crtc modes
root@j721e-evm:~# modetest -M tidss
[   63.562443] 2705________________drm_mode_getconnector________________
[   63.568894] 41_________________panel_bridge_connector_get_modes__________________
[   63.576370] 423_________________panel_simple_get_modes_______end_____num=1______
[   63.583752] 364_________________drm_helper_probe_get_modes________count=1__________
Encoders:
id      crtc    type    possible crtcs  possible clones
39      0       none    0x00000001      0x00000001
Connectors:
id      encoder status          name            size (mm)       modes   encoders
40      0       connected       DPI-1           217x136         0       39
  props:
        1 EDID:
                flags: immutable blob
                blobs:
                value:
        2 DPMS:
                flags: enum
                enums: On=0 Standby=1 Suspend=2 Off=3
                value: 0
        5 link-status:
                flags: enum
                enums: Good=0 Bad=1
                value: 0
        6 non-desktop:
                flags: immutable range
                values: 0 1
                value: 0
        4 TILE:
                blobs:
                value:
CRTCs:
id      fb      pos     size
38      0       (0,0)   (0x0)
  #0  nan 0 0 0 0 0 0 0 0 0 flags: ; type:
  props:
        24 VRR_ENABLED:
                flags: range
                values: 0 1
                value: 0
        27 CTM:
                flags: blob
                blobs:
                value:
        28 GAMMA_LUT:
                flags: blob
                blobs:
                value:
        29 GAMMA_LUT_SIZE:
                values: 0 4294967295
                value: 256
Planes:
id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
31      0       0       0,0             0,0     0               0x00000001
  formats: AR12 AB12 RA12 RG16 BG16 AR15 AB15 AR24 AB24 RA24 BA24 RG24 BG24 AR30 AB30 XR12 XB12 RX12 XR15 XB15 XR24 XB24 RX24 BX24 XR30 XB30 YUYV UYVY NV12
  props:
        8 type:
                flags: immutable enum
                enums: Overlay=0 Primary=1 Cursor=2
                value: 1
        30 IN_FORMATS:
                blobs:
                value:
                        01000000000000001d00000018000000
                        01000000900000004152313241423132
                        52413132524731364247313641523135
                        41423135415232344142323452413234
                        42413234524732344247323441523330
                        41423330585231325842313252583132
                        58523135584231355852323458423234
                        52583234425832345852333058423330
                        59555956555956594e56313200000000
                        ffffff1f000000000000000000000000
                        0000000000000000
                in_formats blob decoded:
                         AR12:  LINEAR
                         AB12:  LINEAR
                         RA12:  LINEAR
                         RG16:  LINEAR
                         BG16:  LINEAR
                         AR15:  LINEAR
                         AB15:  LINEAR
                         AR24:  LINEAR
                         AB24:  LINEAR
                         RA24:  LINEAR
                         BA24:  LINEAR
                         RG24:  LINEAR
                         BG24:  LINEAR
                         AR30:  LINEAR
                         AB30:  LINEAR
                         XR12:  LINEAR
                         XB12:  LINEAR
                         RX12:  LINEAR
                         XR15:  LINEAR
                         XB15:  LINEAR
                         XR24:  LINEAR
                         XB24:  LINEAR
                         RX24:  LINEAR
                         BX24:  LINEAR
                         XR30:  LINEAR
                         XB30:  LINEAR
                         YUYV:  LINEAR
                         UYVY:  LINEAR
                         NV12:  LINEAR
        33 zpos:
                values: 0 0
                value: 0
        34 COLOR_ENCODING:
                flags: enum
                enums: ITU-R BT.601 YCbCr=0 ITU-R BT.709 YCbCr=1
                value: 0
        35 COLOR_RANGE:
                flags: enum
                enums: YCbCr limited range=0 YCbCr full range=1
                value: 1
        36 alpha:
                flags: range
                values: 0 65535
                value: 65535
        37 pixel blend mode:
                flags: enum
                enums: Pre-multiplied=0 Coverage=1
                value: 0
41      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 0
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                         AR12:  LINEAR
                         AB12:  LINEAR
                         RA12:  LINEAR
                         RG16:  LINEAR
                         BG16:  LINEAR
                         AR15:  LINEAR
                         AB15:  LINEAR
                         AR24:  LINEAR
                         AB24:  LINEAR
                         RA24:  LINEAR
                         BA24:  LINEAR
                         RG24:  LINEAR
                         BG24:  LINEAR
                         AR30:  LINEAR
                         AB30:  LINEAR
                         XR12:  LINEAR
                         XB12:  LINEAR
                         RX12:  LINEAR
                         XR15:  LINEAR
                         XB15:  LINEAR
                         XR24:  LINEAR
                         XB24:  LINEAR
                         RX24:  LINEAR
                         BX24:  LINEAR
                         XR30:  LINEAR
                         XB30:  LINEAR
                         YUYV:  LINEAR
                         UYVY:  LINEAR
                         NV12:  LINEAR
        43 zpos:
                flags: range
                values: 1 3
                value: 3
        44 COLOR_ENCODING:
                flags: enum
                value: 0
        45 COLOR_RANGE:
                flags: enum
                value: 1
        46 alpha:
                flags: range
                values: 0 65535
                value: 65535
        47 pixel blend mode:
                flags: enum
                value: 0
48      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 0
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                         AR12:  LINEAR
                         AB12:  LINEAR
                         RA12:  LINEAR
                         RG16:  LINEAR
                         BG16:  LINEAR
                         AR15:  LINEAR
                         AB15:  LINEAR
                         AR24:  LINEAR
                         AB24:  LINEAR
                         RA24:  LINEAR
                         BA24:  LINEAR
                         RG24:  LINEAR
                         BG24:  LINEAR
                         AR30:  LINEAR
                         AB30:  LINEAR
                         XR12:  LINEAR
                         XB12:  LINEAR
                         RX12:  LINEAR
                         XR15:  LINEAR
                         XB15:  LINEAR
                         XR24:  LINEAR
                         XB24:  LINEAR
                         RX24:  LINEAR
                         BX24:  LINEAR
                         XR30:  LINEAR
                         XB30:  LINEAR
                         YUYV:  LINEAR
                         UYVY:  LINEAR
                         NV12:  LINEAR
        50 zpos:
                flags: range
                values: 1 3
                value: 0
        51 COLOR_ENCODING:
                flags: enum
                value: 0
        52 COLOR_RANGE:
                flags: enum
                value: 1
        53 alpha:
                flags: range
                values: 0 65535
                value: 65535
        54 pixel blend mode:
                flags: enum
                value: 0
55      0       0       0,0             0,0     0               0x00000001
  props:
        8 type:
                value: 0
        30 IN_FORMATS:
                blobs:
                value:
                        0000000000000000
                         AR12:  LINEAR
                         AB12:  LINEAR
                         RA12:  LINEAR
                         RG16:  LINEAR
                         BG16:  LINEAR
                         AR15:  LINEAR
                         AB15:  LINEAR
                         AR24:  LINEAR
                         AB24:  LINEAR
                         RA24:  LINEAR
                         BA24:  LINEAR
                         RG24:  LINEAR
                         BG24:  LINEAR
                         AR30:  LINEAR
                         AB30:  LINEAR
                         XR12:  LINEAR
                         XB12:  LINEAR
                         RX12:  LINEAR
                         XR15:  LINEAR
                         XB15:  LINEAR
                         XR24:  LINEAR
                         XB24:  LINEAR
                         RX24:  LINEAR
                         BX24:  LINEAR
                         XR30:  LINEAR
                         XB30:  LINEAR
                         YUYV:  LINEAR
                         UYVY:  LINEAR
                         NV12:  LINEAR
        57 zpos:
                flags: range
                values: 1 3
                value: 2
        58 COLOR_ENCODING:
                flags: enum
                value: 0
        59 COLOR_RANGE:
                flags: enum
                value: 1
        60 alpha:
                flags: range
                values: 0 65535
                value: 65535
        61 pixel blend mode:
                flags: enum
                value: 0
Frame buffers:
id      size    pitch
Therefore, the configuration difference between DSI and DPI is:
The above two questions to help answer
Cesar
    Add the following information:
    Doubt is the cause of the console card death for mode and timing,
    Make the following changes to access the console
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [    7.863608] 4445_________________panel_simple_platform_probe__________________
    [  OK  ] Started Daily rotation of log files[    7.876015] random: crng init done
    [    7.886919] 566_________________panel_simple_probe__________________
    [  OK  ] Reached target Timer Units.[    7.898587] 609_________________panel_simple_probe__________________
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    7.915326] ina2xx 3-0040: error configuring the device: -121
    k Activation Socket.
    [    7.924256] _____________panel_simple_probe_____________connector_type = 16
    [    7.936298] _____________drm_panel_add_______________of_node = panel_disp1
    [    7.944798] 692_________________panel_simple_probe________end__________
    [  OK  ] Listening on D-Bus System Message B[    7.954089] 4786_________________panel_simple_init__________________
    us Socket.
    [    7.964541] 4790_________________panel_simple_init__________________
    [    7.971021] ina2xx 3-0041: error configuring the device: -121
             Starting Docker Socket for the API...[    7.982118] mc: Linux media interface: v0.10
    [    7.991062] 378_________________rpi_touchscreen_probe__________________
    [    7.993124] ina2xx 3-0042: error configuring the device: -121
    [    8.004286] rpi_touchscreen 5-0045: Atmel I2C read failed: -121
    [  OK  ] Listening on dropbear.socket.
    [    8.016171] ina2xx 3-0043: error configuring the device: -121
    [    8.025104] ina2xx 3-0044: error configuring the device: -121
             Starting Weston socket...
    [    8.034531] ina2xx 3-0045: error configuring the device: -121
    [    8.045915] ina2xx 3-0046: error configuring the device: -121
    [    8.046252] videodev: Linux video capture interface: v2.00
    [    8.055729] ina2xx 3-0047: error configuring the device: -121
    [    8.063498] ina2xx 3-0048: error configuring the device: -121
             Starting Console System Startup Logging...[    8.069837] ina2xx 3-0049: error configuring the device: -121
    [    8.081517] CAN device driver interface
    [    8.086350] ina2xx 3-004a: error configuring the device: -121
    [    8.092627] ina2xx 3-004b: error configuring the device: -121
    [    8.099875] ina2xx 3-004c: error configuring the device: -121
             Starting D-Bus System Message Bus...
    [    8.108070] ina2xx 3-004d: error configuring the device: -121
    [    8.118909] ina2xx 3-004e: error configuring the device: -121
             Starting Reboot and dump vmcore via kexec...
    [    8.133265] ina2xx 3-004f: error configuring the device: -121
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Listening on Weston socket.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Finished Console System Startup Logging.
    [    8.312672] pinctrl-single 11c000.pinctrl: pin PIN86 already requested by c000000.ethernet; cannot claim for 2ba0000.mcasp
    [    8.328090] pinctrl-single 11c000.pinctrl: pin-86 (2ba0000.mcasp) status -22
    [    8.335514] pinctrl-single 11c000.pinctrl: could not request pin 86 (PIN86) from group mcasp10-pins-default  on device pinctrl-single
    [    8.348654] davinci-mcasp 2ba0000.mcasp: Error applying setting, reverse things back
    [    8.358214] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
    [    8.379373] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    8.407987] remoteproc remoteproc0: 4d80800000.dsp is available
    [    8.416678] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [    8.449205] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    8.455276] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    8.462097] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    8.472216] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
    [    8.480912] 1177_________________cdns_dsi_drm_probe__________________
    [    8.487619] platform 41000000.r5f: configured R5F for IPC-only mode
    [    8.497842] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    8.498187] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.515626] remoteproc remoteproc2: 4d81800000.dsp is available
    [    8.523271] remoteproc remoteproc2: attaching to 4d81800000.dsp
    [    8.523932] remoteproc remoteproc1: 41000000.r5f is available
    [    8.529961] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    8.535437] remoteproc remoteproc1: attaching to 41000000.r5f
    [    8.547537] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    8.548297] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
    [    8.580578] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    8.581235] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [  OK  ] Started D-Bus System Message Bus.
    [    8.626907] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [  OK  ] Reached target Basic System.
    [    8.653567] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    8.655647] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [    8.691210] 1274_________________cdns_dsi_drm_probe_________end_________
    [    8.705060] 152_________________tidss_probe__________________
    [    8.710987] 442_________________tidss_modeset_init__________________
    [    8.717427] tidss_dispc_modeset_init___________________num_outputs = 4
    [    8.718713] remoteproc remoteproc3: 64800000.dsp is available
    [    8.730453] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [    8.740466] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [    8.749964] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [    8.760632] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    8.768293] remoteproc remoteproc3: attaching to 64800000.dsp
    [  OK  ] Started Job spooling tools.
    [    8.776874] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    8.786915] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node c71-dma-memory@a8000000
    [    8.799016] m_can_platform 40528000.can: m_can device registered (irq=835, version=32)
    [    8.801632] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.812924] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.815132] rproc-virtio rproc-virtio.13.auto: registered virtio1 (type 7)
    [    8.825367] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
    [    8.832950] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.834728] rproc-virtio rproc-virtio.12.auto: registered virtio0 (type 7)
    [  OK  ] Started Periodic Command Scheduler.
    [    8.861811] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [    8.869665] m_can_platform 40568000.can: m_can device registered (irq=838, version=32)
    [    8.882101] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.895391] m_can_platform 2721000.can: m_can device registered (irq=841, version=32)
    [    8.912449] 152_________________tidss_probe__________________
    [    8.918281] 442_________________tidss_modeset_init__________________
    [    8.924785] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    8.931051] tidss_dispc_modeset_init___________________num_outputs = 4
    [    8.938508] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [    8.940785] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    8.956338] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [    8.959842] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [    8.975697] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
             Starting Print notice about GPLv3 packages[    8.990258] remoteproc remoteproc4: 5c00000.r5f is available
    [    9.011529] remoteproc remoteproc4: attaching to 5c00000.r5f
    [    9.039469] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [    9.048383] 152_________________tidss_probe__________________
    [    9.054141] 442_________________tidss_modeset_init__________________
    [    9.066050] tidss_dispc_modeset_init___________________num_outputs = 4
    [    9.074819] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [    9.086369] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [    9.097399] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    9.104070] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [    9.115847] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [    9.141541] 152_________________tidss_probe__________________
    [    9.148133] 442_________________tidss_modeset_init__________________
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
    [    9.168625] tidss_dispc_modeset_init___________________num_outputs = 4
    [    9.181061] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
             Starting Update pmic regis…fety feature on power rails...
             Starting Expand the rootfs▒[    9.201943] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node r5f-dma-memory@a2000000
    ▒▒ll size of the boot device....
    [    9.205815] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [  OK  ] Started startwlanap.
    [    9.238414] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [  OK  ] Started startwlansta.
    [    9.251874] audit: type=1334 audit(1697621876.179:4): prog-id=7 op=LOAD
             Starting User Login Management...
    [    9.264779] audit: type=1334 audit(1697621876.187:5): prog-id=8 op=LOAD
    [  OK  ] Started TEE Supplicant.
    [    9.289627] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [    9.296933] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    9.302512] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    9.303144] rproc-virtio rproc-virtio.14.auto: registered virtio2 (type 7)
    [    9.316793] 152_________________tidss_probe__________________
    [    9.320379] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
    [    9.322543] 442_________________tidss_modeset_init__________________
    [    9.322585] tidss_dispc_modeset_init___________________num_outputs = 4
    [    9.332934] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    9.336309] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [    9.336314] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [    9.336317] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [    9.337001] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [    9.343442] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    9.390859] 152_________________tidss_probe__________________
    [    9.397069] remoteproc remoteproc5: 5d00000.r5f is available
    [    9.399378] 442_________________tidss_modeset_init__________________
    [    9.406100] remoteproc remoteproc5: attaching to 5d00000.r5f
    [    9.415156] remoteproc remoteproc5: Carveout already associated to resource table
    [    9.422939] remoteproc remoteproc5: Failed to process resources: -12
    [    9.429339] tidss_dispc_modeset_init___________________num_outputs = 4
    [    9.429500] k3_r5_rproc bus@100000:r5fss@5c00000: rproc_add failed, ret = -12
    [    9.442991] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [    9.443321] remoteproc remoteproc5: releasing 5d00000.r5f
    [    9.456646] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [    9.466205] platform 5c00000.r5f: R5F core deinitialized in IPC-only mode
    [    9.476865] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
             Starting telnetd.service...
    [  OK  ] Finished IPv6 Packet Filtering Fram[    9.517832] remoteproc remoteproc4: detached remote processor 5c00000.r5f
    ework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished Update pmic regis…safety feature on power rails.
    [  OK  ] Started Telephony service.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [    9.587267] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [    9.597159] 152_________________tidss_probe__________________
    [    9.607914] remoteproc remoteproc4: releasing 5c00000.r5f
    [    9.614065] 442_________________tidss_modeset_init__________________
    [    9.617235] k3_r5_rproc bus@100000:r5fss@5c00000: k3_r5_cluster_rproc_init failed, ret = -12
    [    9.629178] tidss_dispc_modeset_init___________________num_outputs = 4
    [    9.635815] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [    9.644054] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [    9.653436] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [  OK  ] Started telnetd.service.
    [    9.738584] k3_r5_rproc: probe of bus@100000:r5fss@5c00000 failed with error -12
    [    9.805742] Bluetooth: Core ver 2.22
    [    9.812734] NET: Registered PF_BLUETOOTH protocol family
    [    9.822418] Bluetooth: HCI device and connection manager initialized
    [    9.828813] Bluetooth: HCI socket layer initialized
    [    9.846193] Bluetooth: L2CAP socket layer initialized
    [    9.858595] Bluetooth: SCO socket layer initialized
    [    9.888063] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    9.899535] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [    9.909651] remoteproc remoteproc4: 5e00000.r5f is available
    [    9.916770] platform 5f00000.r5f: configured R5F for remoteproc mode
    [    9.924796] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [    9.938735] remoteproc remoteproc5: 5f00000.r5f is available
    [    9.946997] remoteproc remoteproc4: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [    9.956342] remoteproc remoteproc4: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [    9.966269] remoteproc remoteproc4: powering up 5e00000.r5f
    [    9.972467] remoteproc remoteproc4: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [    9.982724] remoteproc remoteproc4: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [    9.991986] remoteproc remoteproc4: request_firmware failed: -22
    [    9.998423] remoteproc remoteproc5: loading /lib/firmware/j7-main-r5f1_1-fw failed with error -22
    [   10.007934] remoteproc remoteproc5: Direct firmware load for j7-main-r5f1_1-fw failed with error -22
    [   10.017637] remoteproc remoteproc5: powering up 5f00000.r5f
    [   10.023361] remoteproc remoteproc5: loading /lib/firmware/j7-main-r5f1_1-fw failed with error -22
    [   10.032363] remoteproc remoteproc5: Direct firmware load for j7-main-r5f1_1-fw failed with error -22
    [   10.041659] remoteproc remoteproc5: request_firmware failed: -22
    [  OK  ] Finished Expand the rootfs…full size of the boot device..
    [   10.126971] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   10.142799] 152_________________tidss_probe__________________
    [   10.153198] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   10.166780] 442_________________tidss_modeset_init__________________
    [   10.178241] tidss_dispc_modeset_init___________________num_outputs = 4
    [   10.195464] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   10.212943] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   10.228385] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   10.240483] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
             Starting Wait for Network to be Configured...
    [   10.464739] am65-cpsw-nuss c000000.ethernet eth1: PHY [c000f00.mdio:06] driver [NXP TJA1101] (irq=POLL)
    [   10.486814] am65-cpsw-nuss c000000.ethernet eth1: configuring for phy/rmii link mode
    [   10.537544] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [   10.562422] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [   10.618912] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [   10.654445] cesar: dp83720_read_straps_____________________strap = 0xd184
    [   10.676645] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   10.685772] 152_________________tidss_probe__________________
    [   10.693285] remoteproc remoteproc6: b034000.pru is available
    [   10.698961] 442_________________tidss_modeset_init__________________
    [   10.705329] tidss_dispc_modeset_init___________________num_outputs = 4
    [   10.717865] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   10.731806] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   10.747338] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [   10.771575] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   10.780297] 152_________________tidss_probe__________________
    [   10.788027] 442_________________tidss_modeset_init__________________
    [   10.794872] tidss_dispc_modeset_init___________________num_outputs = 4
    [   10.802721] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   10.812969] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   10.822676] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [   10.834968] remoteproc remoteproc7: b004000.rtu is available
    [   10.841407] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   10.852349] 152_________________tidss_probe__________________
    [   10.860252] 442_________________tidss_modeset_init__________________
    [   10.866748] tidss_dispc_modeset_init___________________num_outputs = 4
    [   10.879493] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   10.887784] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   10.897334] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [   10.907219] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [   10.917738] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [   10.932111] remoteproc remoteproc8: b00a000.txpru is available
    [   10.938329] remoteproc remoteproc9: b038000.pru is available
    [   10.946822] remoteproc remoteproc10: b006000.rtu is available
    [   10.952636] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   10.961371] 152_________________tidss_probe__________________
    [   10.967443] 442_________________tidss_modeset_init__________________
    [   10.977583] tidss_dispc_modeset_init___________________num_outputs = 4
    [   10.978828] cesar:DP83720_RGMII_ID_CTRL enable=0x3
    [   10.988950] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   10.989080] scsi host0: ufshcd
    [   11.000332] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   11.003591] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:04] driver [TI DP83TG720CS1.1] (irq=POLL)
    [   11.017617] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [   11.020719] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/rgmii-id link mode
    [   11.037806] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   11.045371] am65-cpsw-nuss c000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   11.053858] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   11.060909] remoteproc remoteproc11: b00c000.txpru is available
    [   11.067418] remoteproc remoteproc12: b134000.pru is available
    [   11.073567] remoteproc remoteproc13: b104000.rtu is available
    [   11.079521] remoteproc remoteproc14: b10a000.txpru is available
    [   11.079730] 152_________________tidss_probe__________________
    [   11.091331] remoteproc remoteproc15: b138000.pru is available
    [   11.097441] remoteproc remoteproc16: b106000.rtu is available
    [   11.101594] 442_________________tidss_modeset_init__________________
    [   11.109815] remoteproc remoteproc17: b10c000.txpru is available
    [   11.116081] tidss_dispc_modeset_init___________________num_outputs = 4
    [   11.130425] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   11.142570] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [  OK  ] Started Network Name Resolution[   11.163692] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Enable and configure wl18xx b[   11.190909] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    luetooth stack...
    [  OK  ] Started Netperf Benchmark Server.
    [   11.223167] 152_________________tidss_probe__________________
    [  OK  ] Started NFS status monitor for NFSv[   11.239956] 442_________________tidss_modeset_init__________________
    2/3 locking..
    [   11.250780] tidss_dispc_modeset_init___________________num_outputs = 4
             Starting Permit User Sessions...[   11.266437] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [   11.280830] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   11.290459] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 0000000000000000
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland…ositor, as a system service...
    [   11.462547] 458________add_typed_________devm_drm_of_get_bridge__________________
    [   11.470261] 1 drm_of_find_panel_or_bridge____port = 1______np = dsi-bridge_________remote = panel_disp1
    [   11.479739] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [   11.481981] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: panel_disp1_____________
    [   11.485305] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [   11.496454] drm_of_find_panel_or_bridge_________*panel = 000000001382d106, *bridge = 0000000000000000
    [   11.500332] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [   11.510270] 333________add_typed_________devm_drm_panel_bridge_add__________________
    [   11.515797] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [   11.524996] 359________add_typed_________devm_drm_panel_bridge_add_typed__________________
    [   11.530732] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [   11.539627] 242_________________drm_panel_bridge_add_typed__________connector_type=16________
    [   11.545262] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [   11.554515] [ ++++drm_bridge_add+++++ ]____________node->name: panel_disp1
    [   11.560318] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [   11.573640] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [   11.578220] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [   11.586650] cdns-ufshcd 4e84000.ufs: last intr at 11478984 us, last intr status=0x404
    [   11.587524] [ ++++drm_bridge_add+++++ ]____________node->name: dsi-bridge
    [   11.594637] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [   11.608950] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [   11.618071] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [   11.624558] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [   11.626457] tc358762_probe______________dsi->name=tc358762_____________
    [   11.630915] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [   11.643868] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [   11.650036] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [   11.650561] 928_________________cdns_dsi_attach__________________
    [   11.658262] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [   11.668936] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [   11.675472] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [   11.681874] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [   11.682670] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi-bridge_____________
    [   11.688253] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [   11.704571] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [   11.711047] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [   11.717967] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [   11.724346] host_regs: 00000090: 00000016 00000000 00000001 00000000
    [   11.724808] 959_________________cdns_dsi_attach__________________
    [   11.730700] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [   11.730704] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [   11.730707] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [   11.730709] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [   11.730712] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [   11.730714] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [   11.730717] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [   11.730720] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 11479735 us
    [   11.730724] cdns-ufshcd 4e84000.ufs: link_startup_fail: total cnt=1
    [   11.752685] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [   11.752689] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [   11.752692] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [   11.752694] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [   11.752697] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [   11.752766] [ ----of_drm_find_bridge ]-----bridge->of_node->name: panel_disp1, np->name: dsi-bridge
    [   11.775217] audit: type=1334 audit(1697621878.691:6): prog-id=9 op=LOAD
    [   11.789330] audit: type=1334 audit(1697621878.711:7): prog-id=10 op=LOAD
    [   11.800315] [ ----of_drm_find_bridge ]-----bridge->of_node->name: dsi-bridge, np->name: dsi-bridge
    [   11.858096] [ ++++drm_bridge_add+++++ ]____________node->name: dsi
    [   11.918228] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   11.934263] max96722 4-0029: Consider updating driver max96722 to match on endpoints
    [   11.942272] 152_________________tidss_probe__________________
    [   11.951272] 442_________________tidss_modeset_init__________________
    [   11.956724] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
    [   11.973109] tidss_dispc_modeset_init___________________num_outputs = 4
    [   11.985762] 1 drm_of_find_panel_or_bridge____port = 2______np = dss_________remote = dsi
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [   11.999636] ____________of_drm_find_panel: dev->of_node->name: panel_disp1, np->name: dsi_____________
    [   12.021710] 984_________________cdns_dsi_attach________end__________
    [   12.021952] [ ----of_drm_find_bridge ]-----bridge->of_node->name: panel_disp1, np->name: dsi
    [   12.049017] [ ----of_drm_find_bridge ]-----bridge->of_node->name: dsi-bridge, np->name: dsi
    [   12.058635] [ ----of_drm_find_bridge ]-----bridge->of_node->name: dsi, np->name: dsi
    [   12.066456] drm_of_find_panel_or_bridge_________*panel = 0000000000000000, *bridge = 00000000c6c82d4a
    [   12.077121] tidss_dispc_modeset_init_____________pipes[0].num_bridges = 1
    [   12.084006] 284________________drm_bridge_attach________of_node->name: dsi________
    [   12.091632] 620_________________cdns_dsi_bridge_attach__________________
    [   12.098419] 284________________drm_bridge_attach________of_node->name: dsi-bridge________
    [   12.106755] _______________tc358762_attach_________________
    [   12.112349] 284________________drm_bridge_attach________of_node->name: panel_disp1________
    [   12.121542] 73_________________panel_bridge_attach__________________
    [   12.132453] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
    [   12.142477] 41_________________panel_bridge_connector_get_modes__________________
    [   12.162445] 423_________________panel_simple_get_modes_______end_____num=1______
    [   12.170602] max96718 4-0028: Consider updating driver max96718 to match on endpoints
    [   12.174593] 364_________________drm_helper_probe_get_modes________count=1__________
    [  OK  ] Started User Database Manager.
    [   12.195627] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [   12.219149] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.228932] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.238569] cdns-csi2rx 4514000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
    [   12.251367] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.338827] xhci-hcd xhci-hcd.14.auto: xHCI Host Controller
    [   12.346018] xhci-hcd xhci-hcd.14.auto: new USB bus registered, assigned bus number 1
    [   12.358710] xhci-hcd xhci-hcd.14.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [   12.370322] xhci-hcd xhci-hcd.14.auto: irq 878, io mem 0x06010000
    [   12.376666] xhci-hcd xhci-hcd.14.auto: xHCI Host Controller
    [   12.382300] xhci-hcd xhci-hcd.14.auto: new USB bus registered, assigned bus number 2
    [   12.390339] xhci-hcd xhci-hcd.14.auto: Host supports USB 3.0 SuperSpeed
    [   12.400404] hub 1-0:1.0: USB hub found
    [   12.404253] hub 1-0:1.0: 1 port detected
    [   12.409008] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.409141] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [  OK  ] Created slice User Slice of UID 100[   12.426432] hub 2-0:1.0: USB hub found
    0.
    [   12.433480] hub 2-0:1.0: 1 port detected
    [   12.441399] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [   12.502857] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.511873] xhci-hcd xhci-hcd.15.auto: xHCI Host Controller
    [   12.518786] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.538087] xhci-hcd xhci-hcd.15.auto: new USB bus registered, assigned bus number 3
    [   12.576582] xhci-hcd xhci-hcd.15.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [   12.590558] xhci-hcd xhci-hcd.15.auto: irq 903, io mem 0x06410000
    [   12.596959] xhci-hcd xhci-hcd.15.auto: xHCI Host Controller
    [   12.602606] audit: type=1006 audit(1697621879.523:8): pid=699 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   12.608305] xhci-hcd xhci-hcd.15.auto: new USB bus registered, assigned bus number 4
    [   12.615313] audit: type=1300 audit(1697621879.523:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe6157b18 a2=4 a3=ffff87381020 items=0 ppid=1 pid=699 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   12.623343] xhci-hcd xhci-hcd.15.auto: Host supports USB 3.0 SuperSpeed
    [  OK  ] Finished Wait for Network to be Configured.
    [  OK  ] Reached target Networ[   12.667112] hub 3-0:1.0: USB hub found
    k is Online.
    [   12.671117] audit: type=1327 audit(1697621879.523:8): proctitle="(systemd)"
    [   12.680032] hub 3-0:1.0: 1 port detected
             Starting LSB: network benchmark...
    [  OK  ] Started strongSwan IPsec I…IKEv[   12.693091] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    2 daemon using ipsec.conf.
    [   12.704210] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [  OK  ] Started LSB: network benchmark.[   12.715330] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
             Starting thermal-zone-init.service...
    [  OK  ] Started thermal-zone-init.service   12.734040] hub 4-0:1.0: USB hub found
    0m.
    [   12.745100] hub 4-0:1.0: 1 port detected
    [   12.752114] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   12.761074] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Found device /dev/mmcblk0p5.
             Starting File System Check on /dev/mmcblk0p5...
    [  OK  ] Found device /dev/mmcblk0p2.
    [  OK  ] Found device /dev/mmcblk0p3.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
             Starting File System Check on /dev/mmcblk0p2...
             Starting File System Check on /dev/mmcblk0p3...
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Finished File System Check on /dev/mmcblk0p5.
    [  OK  ] Finished File System Check on /dev/mmcblk0p2.
    [  OK  ] Finished File System Check on /dev/mmcblk0p3.
             Mounting /run/media/backup-mmcblk0p3...
             Mounting /run/media/rootfs-mmcblk0p2...
             Mounting /run/media/user-mmcblk0p5...
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston.
    [   13.485452] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [   13.489217] audit: type=1006 audit(1697621880.415:9): pid=595 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [  OK  ] Mounted /run/media/rootfs-mmcblk0p2[   13.511621] audit: type=1300 audit(1697621880.415:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe6157b18 a2=4 a3=ffff87381020 items=0 ppid=1 pid=595 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [   13.513369] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: none.
    [   13.538540] audit: type=1327 audit(1697621880.415:9): proctitle="(weston)"
    [   13.548537] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Quota mode: none.
    [   13.554712] ext4 filesystem being mounted at /run/media/backup-mmcblk0p3 supports timestamps until 2038 (0x7fffffff)
    [   13.562839] ext4 filesystem being mounted at /run/media/user-mmcblk0p5 supports timestamps until 2038 (0x7fffffff)
    [  OK  ] Mounted /run/media/backup-mmcblk0p3.
    [  OK  ] Mounted /run/media/user-mmcblk0p5.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j721e-evm -
    Arago 2023.04 j721e-evm -
    j721e-evm login: [   16.218014] 2705________________drm_mode_getconnector________________
    [   16.225862] 41_________________panel_bridge_connector_get_modes__________________
    [   16.233866] 423_________________panel_simple_get_modes_______end_____num=1______
    [   16.241511] 364_________________drm_helper_probe_get_modes________count=1__________
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk-dev
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libeigen-dev
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts5
            libqt5sensors5
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg5
            libqt5webchannel5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring2
            m4-dev
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity
            qtdeclarative-tools
            qtdeclarative
            qtlocation-examples
            qtlocation-plugins
            qtlocation
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland
            tar
            which
    [   21.710114] __________ov5640_get_fmt_________________
    [   21.732218] __________ov5640_get_fmt_________________
    [   21.753873] __________ov5640_get_fmt_________________
    [   21.776502] __________ov5640_get_fmt_________________
    [   22.891065] j721e-audio sound-0: devm_snd_soc_register_card() failed: -517
    [   22.898002] platform 2701000.can: deferred probe pending
    [   22.903441] platform can-phy2: deferred probe pending
    [   22.908489] platform regulator-dp-pwr: deferred probe pending
    [   22.914225] platform sound-0: deferred probe pending
    [   23.108480] __________ov5640_get_fmt_________________
    [   23.130053] __________ov5640_get_fmt_________________
    [   23.151790] __________ov5640_get_fmt_________________
    [   23.173384] __________ov5640_get_fmt_________________
    [   23.830585] audit: type=1701 audit(1697683444.583:10): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1464 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1
    [   23.850953] audit: type=1334 audit(1697683444.603:11): prog-id=11 op=LOAD
    [   23.857784] audit: type=1334 audit(1697683444.607:12): prog-id=12 op=LOAD
    [   24.255711] __________ov5640_get_fmt_________________
    [   24.266887] audit: type=1334 audit(1697683445.019:13): prog-id=12 op=UNLOAD
    [   24.274077] audit: type=1334 audit(1697683445.019:14): prog-id=11 op=UNLOAD
    [   24.284119] __________ov5640_get_fmt_________________
    [   24.305612] __________ov5640_get_fmt_________________
    [   24.327421] __________ov5640_get_fmt_________________
    j721e-evm login: root
    [   75.327643] audit: type=1006 audit(1697683496.136:15): pid=1611 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   75.340496] audit: type=1300 audit(1697683496.136:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe6157b18 a2=1 a3=0 items=0 ppid=1 pid=1611 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   75.366579] audit: type=1327 audit(1697683496.136:15): proctitle="(systemd)"
    [   75.373967] audit: type=1334 audit(1697683496.148:16): prog-id=13 op=LOAD
    [   75.381200] audit: type=1300 audit(1697683496.148:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffcae5d590 a2=78 a3=0 items=0 ppid=1 pid=1611 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   75.406847] audit: type=1327 audit(1697683496.148:16): proctitle="(systemd)"
    [   75.414083] audit: type=1334 audit(1697683496.148:17): prog-id=13 op=UNLOAD
    [   75.421172] audit: type=1334 audit(1697683496.148:18): prog-id=14 op=LOAD
    [   75.428126] audit: type=1300 audit(1697683496.148:18): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffcae5d630 a2=78 a3=0 items=0 ppid=1 pid=1611 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   75.453689] audit: type=1327 audit(1697683496.148:18): proctitle="(systemd)"
    [   75.683149] __________ov5640_get_fmt_________________
    [   75.704852] __________ov5640_get_fmt_________________
    [   75.727342] __________ov5640_get_fmt_________________
    [   75.749559] __________ov5640_get_fmt_________________
    root@j721e-evm:/opt/edgeai-gst-apps#
    root@j721e-evm:/opt/edgeai-gst-apps# ls /dev/dri/
    by-path/ card0
    The modetest:
    root@j721e-evm:/opt/edgeai-gst-apps# modetest -M tidss
    [   88.154026] 2705________________drm_mode_getconnector________________
    [   88.160485] 41_________________panel_bridge_connector_get_modes__________________
    [   88.167967] 423_________________panel_simple_get_modes_______end_____num=1______
    [   88.175350] 364_________________drm_helper_probe_get_modes________count=1__________
    Encoders:
    Connectors:
    40      0       connected       DSI-1           154x86          0       39
      props:
            1 EDID:
                    blobs:
                    value:
            2 DPMS:
                    flags: enum
                    value: 0
            5 link-status:
                    flags: enum
                    enums: Good=0 Bad=1
                    value: 0
            6 non-desktop:
                    values: 0 1
                    value: 0
            4 TILE:
                    blobs:
                    value:
    CRTCs:
    id      fb      pos     size
    38      0       (0,0)   (0x0)
      props:
            24 VRR_ENABLED:
                    flags: range
                    values: 0 1
                    value: 0
            27 CTM:
                    flags: blob
                    blobs:
                    value:
            28 GAMMA_LUT:
                    flags: blob
                    blobs:
                    value:
            29 GAMMA_LUT_SIZE:
                    value: 256
    Planes:
      props:
            8 type:
                    value: 1
            30 IN_FORMATS:
                    blobs:
                    value:
                            0000000000000000
                             AR12:  LINEAR
                             AB12:  LINEAR
                             RA12:  LINEAR
                             RG16:  LINEAR
                             BG16:  LINEAR
                             AR15:  LINEAR
                             AB15:  LINEAR
                             AR24:  LINEAR
                             AB24:  LINEAR
                             RA24:  LINEAR
                             BA24:  LINEAR
                             RG24:  LINEAR
                             BG24:  LINEAR
                             AR30:  LINEAR
                             AB30:  LINEAR
                             XR12:  LINEAR
                             XB12:  LINEAR
                             RX12:  LINEAR
                             XR15:  LINEAR
                             XB15:  LINEAR
                             XR24:  LINEAR
                             XB24:  LINEAR
                             RX24:  LINEAR
                             BX24:  LINEAR
                             XR30:  LINEAR
                             XB30:  LINEAR
                             YUYV:  LINEAR
                             UYVY:  LINEAR
                             NV12:  LINEAR
            33 zpos:
                    values: 0 0
                    value: 0
            34 COLOR_ENCODING:
                    flags: enum
                    value: 0
            35 COLOR_RANGE:
                    flags: enum
                    value: 1
            36 alpha:
                    flags: range
                    values: 0 65535
                    value: 65535
                    flags: enum
                    value: 0
      props:
            8 type:
                    value: 0
            30 IN_FORMATS:
                    blobs:
                    value:
                            0000000000000000
                             AR12:  LINEAR
                             AB12:  LINEAR
                             RA12:  LINEAR
                             RG16:  LINEAR
                             BG16:  LINEAR
                             AR15:  LINEAR
                             AB15:  LINEAR
                             AR24:  LINEAR
                             AB24:  LINEAR
                             RA24:  LINEAR
                             BA24:  LINEAR
                             RG24:  LINEAR
                             BG24:  LINEAR
                             AR30:  LINEAR
                             AB30:  LINEAR
                             XR12:  LINEAR
                             XB12:  LINEAR
                             RX12:  LINEAR
                             XR15:  LINEAR
                             XB15:  LINEAR
                             XR24:  LINEAR
                             XB24:  LINEAR
                             RX24:  LINEAR
                             BX24:  LINEAR
                             XR30:  LINEAR
                             XB30:  LINEAR
                             YUYV:  LINEAR
                             UYVY:  LINEAR
                             NV12:  LINEAR
            43 zpos:
                    flags: range
                    values: 1 3
                    value: 3
            44 COLOR_ENCODING:
                    flags: enum
                    value: 0
            45 COLOR_RANGE:
                    flags: enum
                    value: 1
            46 alpha:
                    flags: range
                    values: 0 65535
                    value: 65535
                    flags: enum
                    value: 0
      props:
            8 type:
                    value: 0
            30 IN_FORMATS:
                    blobs:
                    value:
                            0000000000000000
                             AR12:  LINEAR
                             AB12:  LINEAR
                             RA12:  LINEAR
                             RG16:  LINEAR
                             BG16:  LINEAR
                             AR15:  LINEAR
                             AB15:  LINEAR
                             AR24:  LINEAR
                             AB24:  LINEAR
                             RA24:  LINEAR
                             BA24:  LINEAR
                             RG24:  LINEAR
                             BG24:  LINEAR
                             AR30:  LINEAR
                             AB30:  LINEAR
                             XR12:  LINEAR
                             XB12:  LINEAR
                             RX12:  LINEAR
                             XR15:  LINEAR
                             XB15:  LINEAR
                             XR24:  LINEAR
                             XB24:  LINEAR
                             RX24:  LINEAR
                             BX24:  LINEAR
                             XR30:  LINEAR
                             XB30:  LINEAR
                             YUYV:  LINEAR
                             UYVY:  LINEAR
                             NV12:  LINEAR
            50 zpos:
                    flags: range
                    values: 1 3
                    value: 0
            51 COLOR_ENCODING:
                    flags: enum
                    value: 0
            52 COLOR_RANGE:
                    flags: enum
                    value: 1
            53 alpha:
                    flags: range
                    values: 0 65535
                    value: 65535
                    flags: enum
                    value: 0
      props:
            8 type:
                    value: 0
            30 IN_FORMATS:
                    blobs:
                    value:
                            0000000000000000
                             AR12:  LINEAR
                             AB12:  LINEAR
                             RA12:  LINEAR
                             RG16:  LINEAR
                             BG16:  LINEAR
                             AR15:  LINEAR
                             AB15:  LINEAR
                             AR24:  LINEAR
                             AB24:  LINEAR
                             RA24:  LINEAR
                             BA24:  LINEAR
                             RG24:  LINEAR
                             BG24:  LINEAR
                             AR30:  LINEAR
                             AB30:  LINEAR
                             XR12:  LINEAR
                             XB12:  LINEAR
                             RX12:  LINEAR
                             XR15:  LINEAR
                             XB15:  LINEAR
                             XR24:  LINEAR
                             XB24:  LINEAR
                             RX24:  LINEAR
                             BX24:  LINEAR
                             XR30:  LINEAR
                             XB30:  LINEAR
                             YUYV:  LINEAR
                             UYVY:  LINEAR
                             NV12:  LINEAR
            57 zpos:
                    flags: range
                    values: 1 3
                    value: 2
            58 COLOR_ENCODING:
                    flags: enum
                    value: 0
            59 COLOR_RANGE:
                    flags: enum
                    value: 1
            60 alpha:
                    flags: range
                    values: 0 65535
                    value: 65535
                    flags: enum
                    value: 0
    Frame buffers:
    id      size    pitch
    Cesar
