Dear TI Support,
SK-TDA4VM boots normally with SD card, but with NFS, the device crashes. Serial port cannot be input, only press "reset" to restart.
log as follow:
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB2, 17:01:33
Press CTRL-A Z for help on special keys
U-Boot SPL 2023.04-gbd74e615a6 (Sep 06 2023 - 10:09:25 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0-dirty
NOTICE: BL31: Built : 14:12:59, May 22 2023
I/TC:
I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.0 (GCC)) #1 Fri Jan 20 15:42:54 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2023.04-gbd74e615a6 (Sep 06 2023 - 10:09:25 +0000)
SoC: J721E SR1.1 GP
Model: Texas Instruments J721E SK A72
Board: J721EX-EAIK rev A1
DRAM: 4 GiB
Core: 120 devices, 33 uclasses, devicetree: separate
Flash: 0 Bytes
MMC: mmc@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Hit any key to stop autobo 0
=>env default -f -a
## Resetting to default environment
=>saveenv
Unknown command 'saveenv' - try 'help'
=>reset
resetting ...
I/TC:
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: mmc@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
=>setenv serverip 10.160.45.222
=>setenv nfs_root /home/share/TI_SOC/SDK/targetNFS
=>setenv name_kern Image-j721e-sk.bin
=>setenv board_name j721e-sk
=>setenv init_net 'run args_all args_net; setenv autoload no; dhcp'
=>setenv args_net 'setenv bootargs console=${console} ${optargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp'
=>setenv get_kern_net 'tftp ${loadaddr} ${name_kern}'
=>setenv get_fdt_net 'tftp ${fdtaddr} ${name_fdt}'
=>setenv get_overlay_net 'fdt address ${fdtaddr}; fdt resize 0x100000; for overlay in ${name_overlays}; do; tftp ${dtboaddr} ${overlay} && fdt apply ${dtboaddr}; done'
=>setenv nfs_options 'nolock,v3,tcp,rsize=4096,wsize=4096'
=>setenv setup_mmc ''
=>setenv setup_net 'setenv autoload no; dhcp'
=>setenv bootcmd 'run findfdt; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern'
=>setenv kern_boot net
=>setenv rootfs_boot net
=>print
addr_fit=0x90000000
arch=arm
args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000 ${mtdparts}
args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype}
args_net=setenv bootargs console=${console} ${optargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp
args_ufs=setenv devtype scsi;setenv bootpart 1:1; run ufs_finduuid; setenv bootargs console = ${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${scsirootfstype}; setenv devtype scsi; setenv bootpart 1
:1
baudrate=115200
board=j721e
board_name=j721e-sk
board_rev=A1
board_serial=0975
board_software_revision=01
boot=mmc
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fd
tcontroladdr};fi
boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_fdt=try
boot_fit=0
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_rprocs=if test ${dorprocboot} -eq 1 && test ${boot} = mmc; then rproc init; run boot_rprocs_mmc; fi;
boot_rprocs_mmc=env set rproc_id; env set rproc_fw; env set secure_suffix; if test ${secure_rprocs} -eq 1; then env set secure_suffix -sec; fi; for i in ${rproc_fw_binaries} ; do if test -z "${rproc_id}" ; the
n env set rproc_id $i; else env set rproc_fw $i${secure_suffix}; run rproc_load_and_boot_one; env set rproc_id; env set rproc_fw; fi; done
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=ti_mmc mmc0 mmc1 usb0 pxe dhcp
bootcmd=run findfdt; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern
bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${
bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_
addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_ti_mmc=run findfdt; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}
; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;
bootcmd_usb0=devnum=0; run usb_boot
bootdelay=2
bootdir=/boot
bootenvfile=uEnv.txt
bootm_size=0x10000000
bootpart=1:2
bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
console=ttyS2,115200n8
cpu=armv8
default_device_tree=ti/k3-j721e-common-proc-board.dtb
dfu_alt_info_emmc=rawemmc raw 0 0x800000 mmcpart 1; rootfs part 0 1; tiboot3.bin.raw raw 0x0 0x400 mmcpart 1; tispl.bin.raw raw 0x400 0x1000 mmcpart 1; u-boot.img.raw raw 0x1400 0x2000 mmcpart 1; u-env.raw raw
0x3400 0x100 mmcpart 1; sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
dfu_alt_info_mmc=boot part 1 1; rootfs part 1 2; tiboot3.bin fat 1 1; tispl.bin fat 1 1; u-boot.img fat 1 1; uEnv.txt fat 1 1; sysfw.itb fat 1 1
dfu_alt_info_nand=NAND.tiboot3 part 0 1; NAND.tispl part 0 2; NAND.tiboot3.backup part 0 3; NAND.u-boot part 0 4; NAND.u-boot-env part 0 5; NAND.u-boot-env.backup part 0 6; NAND.file-system part 0 7
dfu_alt_info_ospi=tiboot3.bin raw 0x0 0x080000; tispl.bin raw 0x080000 0x200000; u-boot.img raw 0x280000 0x400000; u-boot-env raw 0x680000 0x020000; sysfw.itb raw 0x6c0000 0x100000; rootfs raw 0x800000 0x38000
00
dfu_alt_info_ospi_nand=ospi_nand.tiboot3 part 1; ospi_nand.tispl part 2; ospi_nand.u-boot part 3; ospi_nand.env part 4; ospi_nand.env.backup part 5; ospi_nand.rootfs part 6; ospi_nand.phypattern part 7
dfu_alt_info_ram=tispl.bin ram 0x80080000 0x200000; u-boot.img ram 0x81000000 0x400000
distro_bootcmd=scsi_need_init=; for target in ${boot_targets}; do run bootcmd_${target}; done
dorprocboot=1
dtboaddr=0x89000000
efi_dtb_prefixes=/ /dtb/ /dtb/current/
envboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev}; if run loadbootscript; then run bootscript; else if run loadbootenv; then echo Loaded env from ${bootenvfile}; run importbo
otenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; fi; fi;
ethaddr=24:76:25:a5:96:6e
fdt_addr_r=0x88000000
fdtaddr=0x88000000
fdtcontroladdr=fde9a050
fdtoverlay_addr_r=0x89000000
findfdt=setenv name_fdt ${default_device_tree}; if test $board_name = j721e; then setenv name_fdt ti/k3-j721e-common-proc-board.dtb; fi; if test $board_name = BBONEAI-64-B0-; then setenv name_fdt k3-j721e-beag
leboneai64.dtb; fi; if test $board_name = j7200; then setenv name_fdt ti/k3-j7200-common-proc-board.dtb; fi; if test $board_name = j721e-eaik || test $board_name = j721e-sk; then setenv name_fdt ti/k3-j721e-sk
.dtb; fi; setenv fdtfile ${name_fdt}
finduuid=part uuid ${boot} ${bootpart} uuid
get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/dtb/${name_fdt}
get_fdt_net=tftp ${fdtaddr} ${name_fdt}
get_fdt_ufs=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
get_fit_config=setexpr name_fit_config gsub / _ conf-${fdtfile}
get_fit_mmc=load mmc ${bootpart} ${addr_fit} ${bootdir}/${name_fit}
get_kern_mmc=load mmc ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
get_kern_net=tftp ${loadaddr} ${name_kern}
get_kern_ufs=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${name_kern}
get_overlay_mmc=fdt address ${fdtaddr}; fdt resize 0x100000; for overlay in $name_overlays; do; load mmc ${bootpart} ${dtboaddr} ${bootdir}/dtb/${overlay} && fdt apply ${dtboaddr}; done;
get_overlay_net=fdt address ${fdtaddr}; fdt resize 0x100000; for overlay in ${name_overlays}; do; tftp ${dtboaddr} ${overlay} && fdt apply ${dtboaddr}; done
get_overlay_ufs=fdt address ${fdtaddr}; fdt resize 0x100000; for overlay in $name_overlays; do; load scsi ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && fdt apply ${dtboaddr}; done;
get_overlaystring=for overlay in $name_overlays; do; setenv overlaystring ${overlaystring}'#'${overlay}; done;
importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17; gpio clear gpio@22_16
init_mmc=run args_all args_mmc
init_net=run args_all args_net; setenv autoload no; dhcp
init_ufs=ufs init; scsi scan; run args_ufs
kern_boot=net
kernel_addr_r=0x82000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x82000000
loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile}
loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr
loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/dtb/${fdtfile}
loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
main_cpsw0_qsgmii_phyinit=if test $board_name = J721EX-PM1-SOM || test $board_name = J721EX-PM2-SOM || test $board_name = j721e; then do_main_cpsw0_qsgmii_phyinit=1; else do_main_cpsw0_qsgmii_phyinit=0; fi; if
test ${do_main_cpsw0_qsgmii_phyinit} -eq 1 && test ${dorprocboot} -eq 1 && test ${boot} = mmc; then run init_main_cpsw0_qsgmii_phy; fi;
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mmcboot=mmc dev ${mmcdev}; devnum=${mmcdev}; devtype=mmc; if mmc rescan; then echo SD/MMC found on device ${mmcdev}; if run loadimage; then run args_mmc; if test ${boot_fit} -eq 1; then run run_fit; else run m
mcloados; fi; fi; fi;
mmcdev=1
mmcloados=if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run get_fdt_mmc; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi;
fi; else bootz; fi;
mmcrootfstype=ext4 rootwait
name_fit=fitImage
name_kern=Image-j721e-sk.bin
nfs_options=nolock,v3,tcp,rsize=4096,wsize=4096
nfs_root=/home/share/TI_SOC/SDK/targetNFS
partitions=name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}
pxefile_addr_r=0x80100000
ramdisk_addr_r=0x88080000
rd_spec=-
rdaddr=0x88080000
rootfs_boot=net
rproc_fw_binaries=2 /lib/firmware/j7-main-r5f0_0-fw 3 /lib/firmware/j7-main-r5f0_1-fw 4 /lib/firmware/j7-main-r5f1_0-fw 5 /lib/firmware/j7-main-r5f1_1-fw 6 /lib/firmware/j7-c66_0-fw 7 /lib/firmware/j7-c66_1-fw
8 /lib/firmware/j7-c71_0-fw
rproc_load_and_boot_one=if load mmc ${bootpart} $loadaddr ${rproc_fw}; then if rproc load ${rproc_id} ${loadaddr} ${filesize}; then rproc start ${rproc_id}; fi; fi
run_fit=run get_fit_config; bootm ${addr_fit}#${name_fit_config}${overlaystring}
run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} boot
fstype; then part uuid ${devtype} ${devnum}:${distro_bootpart} distro_bootpart_uuid ; run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_boo
tmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; se
tenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo EXTLINUX FAILED: continuing...;
fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FA
ILED: continuing...; fi; done
scriptaddr=0x80000000
scsi_boot=run scsi_init; if scsi dev ${devnum}; then devtype=scsi; run scan_dev_for_boot_part; fi
scsi_init=if ${scsi_need_init}; then scsi_need_init=false; scsi scan; fi
scsirootfstype=ext4 rootwait
secure_rprocs=0
serial#=0000000000000975
serverip=10.160.45.222
setup_mmc=
setup_net=setenv autoload no; dhcp
soc=k3
stderr=serial@2800000
stdin=serial@2800000
stdout=serial@2800000
ubifs_boot=if ubi part ${bootubipart} ${bootubioff} && ubifsmount ubi0:${bootubivol}; then devtype=ubi; devnum=ubi0; bootfstype=ubifs; distro_bootpart=${bootubivol}; run scan_dev_for_boot; ubifsumount; fi
ufs_finduuid=part uuid scsi ${bootpart} uuid
update_to_fit=setenv loadaddr ${addr_fit}; setenv bootfile ${name_fit}
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=ti
Environment size: 11498/131067 bytes
=>saveenv
=>boot
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1520 bytes read in 22 ms (67.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 20 ms (0 Bytes/s)
Already setup.
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2
link up on port 1, speed 1000, full duplex
BOOTP broadcast 1
DHCP client bound to address 10.160.45.151 (126 ms)
BOOTP broadcast 1
DHCP client bound to address 10.160.45.151 (130 ms)
Using ethernet@46000000port@1 device
TFTP from server 10.160.45.222; our IP address is 10.160.45.151
Filename 'Image-j721e-sk.bin'.
Load address: 0x82000000
Loading: #################################################################
######################################################### 0 Bytes
4.7 MiB/s
done
Bytes transferred = 20920832 (13f3a00 hex)
Filename 'ti/k3-j721e-sk.dtb'.
Load address: 0x88000000
Loading: ##################### 0 Bytes
4.1 MiB/s
done
Bytes transferred = 102536 (19088 hex)
Working FDT set to 88000000
Filename 'ti/k3-j721e-edgeai-apps.dtbo'.
Load address: 0x89000000
Loading: ### 0 Bytes
2 MiB/s
done
Bytes transferred = 10434 (28c2 hex)
Filename 'ti/k3-j721e-sk-csi2-rpi-imx219.dtbo'.
Loading: # 0 Bytes
1.3 MiB/s
done
Bytes transferred = 4216 (1078 hex)
ERROR: reserving fdt memory region failed (addr=880000000 size=27000000 flags=4)
Loading Device Tree to 000000008fee3000, end 000000008fffffff ... OK
Working FDT set to 8fee3000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.1.46-gf8110d9ce8 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Mon Sep 4 04:45:34 UTC 2023
[ 0.000000] Machine model: Texas Instruments J721E SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff]
[ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 systemd.hostname=tda4vm-sk rootfstype=nfs root=/dev/nfs rw nfsroot=10.160.45.222:/home/share/TI_SOC/SDK/targetNFS,
nolock,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 2.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 1694156K/4194304K available (12480K kernel code, 1294K rwdata, 4360K rodata, 2176K init, 498K bss, 1975860K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008a7030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008390] Console: colour dummy device 80x25
[ 0.012954] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023624] pid_max: default: 32768 minimum: 301
[ 0.028361] LSM: Security Framework initializing
[ 0.033135] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040706] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049480] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.056882] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.063143] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.070527] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.076830] rcu: Hierarchical SRCU implementation.
[ 0.081727] rcu: Max phase no-delay instances is 1000.
[ 0.087221] Platform MSI: msi-controller@1820000 domain created
[ 0.093461] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.103216] EFI services will not be available.
[ 0.107948] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.121173] Detected PIPT I-cache on CPU1
[ 0.121234] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.121247] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
[ 0.121275] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.121320] smp: Brought up 1 node, 2 CPUs
[ 0.150662] SMP: Total of 2 processors activated.
[ 0.155466] CPU features: detected: 32-bit EL0 Support
[ 0.160720] CPU features: detected: CRC32 instructions
[ 0.166004] CPU: All CPU(s) started at EL2
[ 0.170185] alternatives: applying system-wide alternatives
[ 0.176689] devtmpfs: initialized
[ 0.186464] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.196447] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.209892] pinctrl core: initialized pinctrl subsystem
[ 0.215552] DMI not present or invalid.
[ 0.219790] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.226414] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.233717] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.241715] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.249838] audit: initializing netlink subsys (disabled)
[ 0.255456] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
[ 0.255681] thermal_sys: Registered thermal governor 'step_wise'
[ 0.263375] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.269580] cpuidle: using governor menu
[ 0.280338] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.287298] ASID allocator initialised with 65536 entries
[ 0.300919] platform a000000.dp-bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[ 0.311335] platform a000000.dp-bridge: Fixed dependency cycle(s) with /connector
[ 0.319243] platform hdmi-connector: Fixed dependency cycle(s) with /dvi-bridge
[ 0.326741] platform 4a00000.dss: Fixed dependency cycle(s) with /dvi-bridge
[ 0.334169] KASLR disabled due to lack of seed
[ 0.341702] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.348645] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.355047] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.361981] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.368382] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.375315] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.381716] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.388650] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.395905] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.404975] iommu: Default domain type: Translated
[ 0.409960] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.416469] SCSI subsystem initialized
[ 0.420451] usbcore: registered new interface driver usbfs
[ 0.426072] usbcore: registered new interface driver hub
[ 0.431508] usbcore: registered new device driver usb
[ 0.436908] pps_core: LinuxPPS API ver. 1 registered
[ 0.441980] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.451318] PTP clock support registered
[ 0.455390] EDAC MC: Ver: 3.0.0
[ 0.459105] FPGA manager framework
[ 0.462614] Advanced Linux Sound Architecture Driver Initialized.
[ 0.469223] clocksource: Switched to clocksource arch_sys_counter
[ 0.475561] VFS: Disk quotas dquot_6.6.0
[ 0.479592] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.489528] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.495820] NET: Registered PF_INET protocol family
[ 0.500960] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.509959] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.518722] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.526646] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.534849] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.543348] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.550119] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.557029] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.564471] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.570530] RPC: Registered named UNIX socket transport module.
[ 0.576590] RPC: Registered udp transport module.
[ 0.581394] RPC: Registered tcp transport module.
[ 0.586196] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.592778] NET: Registered PF_XDP protocol family
[ 0.597686] PCI: CLS 0 bytes, default 64
[ 0.602055] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.611118] Initialise system trusted keyrings
[ 0.615770] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.624862] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.631142] NFS: Registering the id_resolver key type
[ 0.636328] Key type id_resolver registered
[ 0.640600] Key type id_legacy registered
[ 0.644728] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.651577] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.659219] 9p: Installing v9fs 9p2000 file system support
[ 0.684465] Key type asymmetric registered
[ 0.688647] Asymmetric key parser 'x509' registered
[ 0.693654] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.701282] io scheduler mq-deadline registered
[ 0.705912] io scheduler kyber registered
[ 0.711861] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.718046] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.727933] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.735487] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.743646] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.750736] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.758465] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.769327] loop: module loaded
[ 0.773257] megasas: 07.719.03.00-rc1
[ 0.778963] tun: Universal TUN/TAP device driver, 1.6
[ 0.784470] thunder_xcv, ver 1.0
[ 0.787782] thunder_bgx, ver 1.0
[ 0.791087] nicpf, ver 1.0
[ 0.794084] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.801464] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.806911] hclge is initializing
[ 0.810302] e1000: Intel(R) PRO/1000 Network Driver
[ 0.815282] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.821170] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.826239] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.832298] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.837811] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.843514] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.849916] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.856027] sky2: driver version 1.30
[ 0.860151] VFIO - User Level meta-driver version: 0.3
[ 0.865743] usbcore: registered new interface driver usb-storage
[ 0.872279] i2c_dev: i2c /dev entries driver
[ 0.877609] sdhci: Secure Digital Host Controller Interface driver
[ 0.883929] sdhci: Copyright(c) Pierre Ossman
[ 0.888621] Synopsys Designware Multimedia Card Interface Driver
[ 0.894998] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.901239] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.907467] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.914191] usbcore: registered new interface driver usbhid
[ 0.919884] usbhid: USB HID core driver
[ 0.924499] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.929062] optee: revision 3.20 (8e74d476)
[ 0.945477] optee: dynamic shared memory is enabled
[ 0.954941] optee: initialized driver
[ 0.959918] Initializing XFRM netlink socket
[ 0.964305] NET: Registered PF_PACKET protocol family
[ 0.969530] 9pnet: Installing 9P2000 support
[ 0.973918] Key type dns_resolver registered
[ 0.978453] registered taskstats version 1
[ 0.982663] Loading compiled-in X.509 certificates
[ 0.992409] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
[ 1.037190] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz
[ 1.065382] i2c i2c-1: Added multiplexed i2c bus 2
[ 1.070369] i2c i2c-1: Added multiplexed i2c bus 3
[ 1.075268] pca954x 1-0071: registered 2 multiplexed busses for I2C switch pca9543
[ 1.083027] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.089014] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
[ 1.117426] i2c 6-0010: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4500000/csi-bridge@4504000
[ 1.127034] i2c i2c-5: Added multiplexed i2c bus 6
[ 1.132061] i2c 7-0010: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4510000/csi-bridge@4514000
[ 1.141660] i2c i2c-5: Added multiplexed i2c bus 7
[ 1.146557] pca954x 5-0070: registered 2 multiplexed busses for I2C switch pca9543
[ 1.154361] i2c i2c-5: Failed to register i2c client pca9543 at 0x70 (-16)
[ 1.161389] i2c i2c-5: of_i2c: Failure registering /bus@100000/i2c@2030000/i2c-mux@70
[ 1.169394] i2c i2c-5: Failed to create I2C device for /bus@100000/i2c@2030000/i2c-mux@70
[ 1.177761] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 1.183822] omap_i2c 2050000.i2c: bus 8 rev0.12 at 400 kHz
[ 1.189643] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[ 1.198201] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[ 1.207552] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[ 1.216174] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.233658] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 1.243544] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.250305] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.259337] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 1.269495] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.276253] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 1.284191] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 193, base_baud = 6000000) is a 8250
[ 1.293692] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 194, base_baud = 3000000) is a 8250
[ 1.302542] printk: console [ttyS2] enabled
[ 1.310988] printk: bootconsole [ns16550a0] disabled
[ 1.321446] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 195, base_baud = 3000000) is a 8250
[ 1.331570] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.377229] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.385652] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.393924] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 1.406735] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.413941] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.420237] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 1.430615] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 1.542693] gpio-388 (CSI_MUX_SEL_2): hogged as output/high
[ 1.551277] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 1.558110] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 1.564911] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 1.571712] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 1.578493] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 1.592265] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 1.602942] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 1.617531] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.622557] 8 fixed-partitions partitions found on MTD device 47040000.spi.0
[ 1.629594] Creating 8 MTD partitions on "47040000.spi.0":
[ 1.635066] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.641118] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.646865] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.652680] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.658251] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 1.664017] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[ 1.670187] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.676028] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.686422] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.729232] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.737665] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.745936] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 1.758740] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.765948] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.772193] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 1.782670] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 1.791264] mmc1: CQHCI version 5.10
[ 1.835864] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 1.850217] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 1.859688] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ 1.897571] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.904513] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[ 1.913429] mmcblk1: p1 p2
[ 5.974002] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 6.001226] Sending DHCP requests ., OK
[ 6.129055] IP-Config: Got DHCP answer from 10.160.45.1, my address is 10.160.45.151
[ 6.136787] IP-Config: Complete:
[ 6.140004] device=eth0, hwaddr=24:76:25:a5:96:6e, ipaddr=10.160.45.151, mask=255.255.255.0, gw=10.160.45.1
[ 6.150157] host=10.160.45.151, domain=corp.int, nis-domain=(none)
[ 6.156754] bootserver=0.0.0.0, rootserver=10.160.45.222, rootpath=
[ 6.156757] nameserver0=10.1.15.1, nameserver1=10.1.15.2
[ 6.179624] ALSA device list:
[ 6.182589] No soundcards found.
[ 6.193262] VFS: Mounted root (nfs filesystem) on device 0:20.
[ 6.199508] devtmpfs: mounted
[ 6.203414] Freeing unused kernel memory: 2176K
[ 6.225287] Run /sbin/init as init process
[ 6.325886] systemd[1]: System time before build time, advancing clock.
[ 6.359032] NET: Registered PF_INET6 protocol family
[ 6.365122] Segment Routing with IPv6
[ 6.368801] In-situ OAM (IOAM) with IPv6
[ 6.390581] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYP
TSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 6.422030] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.04!
[ 6.497356] systemd[1]: Hostname set to <tda4vm-sk>.
[ 6.593987] systemd[127]: /lib/systemd/system-generators/systemd-gpt-auto-generator failed with exit status 1.
[ 6.596717] systemd-sysv-generator[136]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a nativ
e systemd unit file, in order to make it more safe and robust.
[ 6.630600] systemd-sysv-generator[136]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to includ
e a native systemd unit file, in order to make it more safe and robust.
[ 6.663090] systemd-sysv-generator[136]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to incl
ude a native systemd unit file, in order to make it more safe and robust.
[ 6.688588] systemd-sysv-generator[136]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to inclu
[ 6.714005] systemd-sysv-generator[136]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a nativ
[ 6.980715] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting a
ltogether.
[ 7.050067] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the settin
g altogether.
[ 7.124859] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.162351] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 7.186729] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 7.210546] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 7.234312] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 7.257431] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 7.281356] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 7.305403] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 7.325280] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 7.345274] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 7.365283] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 7.407317] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 7.429409] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 7.454172] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 7.477465] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 7.502361] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 7.526360] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.549564] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.569949] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.595207] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 7.617496] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.638020] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 7.681492] systemd[1]: Mounting Huge Pages File System...
[ 7.695636] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.723700] systemd[1]: Mounting Kernel Debug File System...
[ 7.745533] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 7.762488] systemd[1]: Mounting Temporary Directory /tmp...
[ 7.801641] systemd[1]: Starting Create List of Static Device Nodes...
[ 7.827574] systemd[1]: Starting Load Kernel Module configfs...
[ 7.851579] systemd[1]: Starting Load Kernel Module drm...
[ 7.872516] systemd[1]: Starting Load Kernel Module fuse...
[ 7.894175] fuse: init (API version 7.37)
[ 7.895128] systemd[1]: Starting Start psplash boot splash screen...
[ 7.945700] systemd[1]: Starting RPC Bind...
[ 7.961784] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 7.978579] systemd[1]: Starting Journal Service...
[ 8.000571] systemd[1]: Starting Load Kernel Modules...
[ 8.020503] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel command line...
[ 8.037579] cryptodev: loading out-of-tree module taints kernel.
[ 8.044598] cryptodev: driver 1.12 loaded.
[ 8.052103] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.085944] systemd[1]: Starting Coldplug All udev Devices...
[ 8.103541] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 8.122405] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
[ 8.465648] systemd-journald[151]: Received client request to flush runtime journal.
Starting Create System Users...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ 8.525249] random: crng init done
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /media/ram...
Mounting /var/volatile...
[ 8.739563] audit: type=1334 audit(1651167747.412:2): prog-id=5 op=LOAD
[ 8.746501] audit: type=1334 audit(1651167747.420:3): prog-id=6 op=LOAD
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Create Volatile Files and Directories...
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create Volatile Files and Directories.
Starting Rebuild Journal Catalog...
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[ OK ] Reached target System Time Set.
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Finished Rebuild Journal Catalog.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ 9.696805] mc: Linux media interface: v0.10
[ 9.723413] videodev: Linux video capture interface: v2.00
[ OK ] Found device /dev/ttyS2.
[ 9.792680] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 9.804732] j721e-pcie-host 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 9.813290] j721e-pcie-host 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 9.825573] j721e-pcie-host 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 9.850683] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ 9.871162] imx219 6-0010: supply VANA not found, using dummy regulator
[ 9.890932] imx219 6-0010: supply VDIG not found, using dummy regulator
[ 9.897834] imx219 6-0010: supply VDDL not found, using dummy regulator
[ 9.916444] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[ 9.929456] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 9.930225] imx219 7-0010: supply VANA not found, using dummy regulator
[ 9.980857] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[ 10.003239] imx219 7-0010: supply VDIG not found, using dummy regulator
[ 10.013908] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[ 10.016919] img_dec 4300000.video-decoder: decoder registered as /dev/video1
[ 10.021619] PVR_K: 178: Device: 4e20000000.gpu
[ 10.034136] imx219 7-0010: supply VDDL not found, using dummy regulator
[ 10.057827] remoteproc remoteproc0: 4d80800000.dsp is available
[ 10.065319] cdns-mhdp8546 a000000.dp-bridge: invalid resource
[ 10.075067] PVR_K: 178: Read BVNC 22.104.208.318 from HW device registers
[ 10.088143] cdns-mhdp8546 a000000.dp-bridge: Failed to get SAPB memory resource, HDCP not supported
[ 10.098244] imx219 7-0010: failed to read chip id 219
[ 10.104442] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 10.126453] remoteproc remoteproc0: powering up 4d80800000.dsp
[ 10.131492] PVR_K: 178: RGX Device registered with BVNC 22.104.208.318
[ 10.134826] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 994096
[ 10.141153] imx219: probe of 7-0010 failed with error -5
[ 10.153720] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa864c800
[ 10.168332] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 10.181684] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.187915] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
[ 10.195298] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[ 10.197264] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[ 10.209897] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 10.217586] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[ 10.225422] [drm] Initialized pvr 23.1.6404501 20170530 for 4e20000000.gpu on minor 0
[ 10.236354] remoteproc remoteproc1: 4d81800000.dsp is available
[ 10.265463] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 10.289868] remoteproc remoteproc1: powering up 4d81800000.dsp
[ 10.296519] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 994096
[ 10.358358] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[ 10.359662] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa964c800
[ 10.368629] remoteproc remoteproc2: 64800000.dsp is available
[ 10.380061] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 10.392866] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.399195] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
[ 10.413499] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[ 10.442359] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 10.556072] remoteproc remoteproc2: powering up 64800000.dsp
[ 10.565618] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 12968080
[ 10.585679] remoteproc remoteproc2: unsupported resource 65538
[ 10.600330] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xb2200000
[ 10.617324] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 10.635922] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 10.640244] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[ 10.643648] rproc-virtio rproc-virtio.2.auto: registered virtio2 (type 7)
[ 10.655713] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[ 10.871937] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 10.873402] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00
[ 10.886795] platform 41000000.r5f: configured R5F for IPC-only mode
[ 10.959387] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 10.981441] remoteproc remoteproc3: 41000000.r5f is available
[ 10.991776] remoteproc remoteproc3: attaching to 41000000.r5f
[ 11.039204] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 11.046547] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 11.053253] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 11.123835] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 11.133407] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[ 11.140851] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 11.141834] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[ 11.154191] rproc-virtio rproc-virtio.3.auto: registered virtio3 (type 7)
[ 11.162898] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 11.170098] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[ 11.173198] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 11.185496] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 11.199265] pci 0000:00:00.0: supports D1
[ 11.242221] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 11.312207] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 11.322135] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 11.338229] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 11.366623] pcieport 0000:00:00.0: PME: Signaling with IRQ 695
[ 11.376410] pcieport 0000:00:00.0: AER: enabled with IRQ 695
[ 11.397876] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 11.399280] platform 5c00000.r5f: configured R5F for remoteproc mode
[ 11.431943] j721e-pcie-host 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 11.443009] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 11.444523] j721e-pcie-host 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 11.479260] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[ 11.495709] cdns-mhdp8546 a000000.dp-bridge: CR: max swing reached
[ 11.518313] remoteproc remoteproc4: 5c00000.r5f is available
[ 11.533312] Console: switching to colour frame buffer device 240x67
[ 11.537644] j721e-pcie-host 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 11.538703] platform 5d00000.r5f: configured R5F for remoteproc mode
[ 11.539629] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
I believe you are using the 9.0 SDK. The saveenv command is deprecated. You ll have to have your bootargs in the uenv.txt file. In the boot logs you have shared I do not see any crash. Does it hang after the last line?
Keerthy
Hi @Keerthy
Yes, Crash on this line, Then after that the serial port doesn't output anything and can't input
Is the vision_apps overlay getting loaded during device tree loading?
Also is there any error log after the last line?
Keerthy
Hi, Keerthy
All the logs are up there, after that the device is stuck and doesn't output anything
That seems to be the root cause of the error. When you are trying to load the reserved memory from U-boot it's not able to reserve and potentially that gets overwritten.
Is this default SK booting or you have custom changes and also can you confirm if sd boot works as expected?
Keerthy
Reply for:
Hi, Keerthy
Yes, this is the default NFS boot configuration for j721e-sk, and you can see that there is an env print for u-boot in the log above. And SD card boot also has this error you mentioned, but it can boot normally, the log of normal SD card boot is as follows:
Just to narrow down the issue. Couple of things:
Keerthy
Reply for:
Hi Keerthy
1. Yes, I cheked the MD5 of all the files in lib/firmware/vision_apps_eaik in nfs and sd. I can confirm that the files are the same.
2. How to remove r5f node from dts? Can you elaborate?
Also, I tried to change bootcmd as follows and the nfs method booted normal. Is this the correct way to do it?
Original bootcmd:
bootcmd=run findfdt; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern'
Modify to:
bootcmd=run findfdt; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run envboot; run setup_${kern_boot}; run init_${rootfs_boot}; run get_kern_${kern_boot}; run get_fdt_${kern_boot}; run get_overlay_${kern_boot}; run run_kern'
Okay. I understood so in the case of NFS the remote cores were not booted from U-Boot which is a must. So your changes look good. Please go ahead and use the above bootargs. The expectation is U-Boot should boot the remote cores before kernel starts. So your changes are correct.
Keerthy
Okay, thank you for your support. Please synchronize the update of sbin/setup-uboot-env.sh in the SK-TDA4VM SDK if you can!
