Dear TI support team,
Please, can you indicate me the availability of DDR diagnostics tools for TDA2EEBEQCBDRQ1 device, and if there is an associated Aplication Note?
Thank you for your support and best regards,
There are no diagnostic tools. There is a register configuration tool here: https://www.ti.com/lit/pdf/sprac36
Kevin
Hi Kevin, thank you for your quick reply,
In the application report mentions about the Debug Resources:
Maybe this tool can help us to check if DDR is having an issue (even it is not able to make a diagnostic) if it returns any kind of error when running on a defective board. Please, is there available more documentation on how to connect to the target device and run the script, apart from the indicated in the README file?
Thank you again for your support and best regards
