Part Number: TDA4VM
Hi,TI
Now we found Serror on our TDA4VM board when driverring WIFI module in PCIE0. The error log as follows:
Starting kernel ... failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.162 (root@wx-virtual-machine) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Jan 18 11:43:29 CST 2024 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=b2f596f9-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 1696388K/4194304K available (11200K kernel code, 1158K rwdata, 4296K rodata, 1856K init, 431K bss, 1973628K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008423] Console: colour dummy device 80x25 [ 0.012990] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023660] pid_max: default: 32768 minimum: 301 [ 0.028419] LSM: Security Framework initializing [ 0.033180] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040762] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049650] rcu: Hierarchical SRCU implementation. [ 0.054726] Platform MSI: msi-controller@1820000 domain created [ 0.060992] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070296] EFI services will not be available. [ 0.075029] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088416] Detected PIPT I-cache on CPU1 [ 0.088442] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088453] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000 [ 0.088488] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088539] smp: Brought up 1 node, 2 CPUs [ 0.117886] SMP: Total of 2 processors activated. [ 0.122691] CPU features: detected: 32-bit EL0 Support [ 0.127946] CPU features: detected: CRC32 instructions [ 0.142569] CPU: All CPU(s) started at EL2 [ 0.146766] alternatives: patching kernel code [ 0.151845] devtmpfs: initialized [ 0.161216] KASLR disabled due to lack of seed [ 0.165867] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.175831] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.190789] pinctrl core: initialized pinctrl subsystem [ 0.196464] DMI not present or invalid. [ 0.200713] NET: Registered protocol family 16 [ 0.206156] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.213485] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.221514] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.229830] thermal_sys: Registered thermal governor 'step_wise' [ 0.229833] thermal_sys: Registered thermal governor 'power_allocator' [ 0.236416] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.250056] ASID allocator initialised with 65536 entries [ 0.271229] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.278087] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.284933] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.291779] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.299275] cryptd: max_cpu_qlen set to 1000 [ 0.305354] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.314170] vsys_3v3: supplied by evm_12v0 [ 0.318568] vsys_5v0: supplied by evm_12v0 [ 0.322917] vdd_mmc1: supplied by vsys_3v3 [ 0.327669] iommu: Default domain type: Translated [ 0.332804] SCSI subsystem initialized [ 0.336823] mc: Linux media interface: v0.10 [ 0.341192] videodev: Linux video capture interface: v2.00 [ 0.346819] pps_core: LinuxPPS API ver. 1 registered [ 0.351892] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.361229] PTP clock support registered [ 0.365249] EDAC MC: Ver: 3.0.0 [ 0.369062] FPGA manager framework [ 0.372576] Advanced Linux Sound Architecture Driver Initialized. [ 0.379190] clocksource: Switched to clocksource arch_sys_counter [ 0.385515] VFS: Disk quotas dquot_6.6.0 [ 0.389549] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.399256] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.405544] NET: Registered protocol family 2 [ 0.410297] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.418948] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.427711] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.435913] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.443734] TCP: Hash tables configured (established 32768 bind 32768) [ 0.450538] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.457433] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.464842] NET: Registered protocol family 1 [ 0.469575] RPC: Registered named UNIX socket transport module. [ 0.475630] RPC: Registered udp transport module. [ 0.480446] RPC: Registered tcp transport module. [ 0.485250] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.491831] NET: Registered protocol family 44 [ 0.496379] PCI: CLS 0 bytes, default 64 [ 0.500757] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.511177] Initialise system trusted keyrings [ 0.515820] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.524027] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.530247] NFS: Registering the id_resolver key type [ 0.535437] Key type id_resolver registered [ 0.539708] Key type id_legacy registered [ 0.543831] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.550679] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.558322] 9p: Installing v9fs 9p2000 file system support [ 0.583136] Key type asymmetric registered [ 0.587323] Asymmetric key parser 'x509' registered [ 0.592321] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.599879] io scheduler mq-deadline registered [ 0.604505] io scheduler kyber registered [ 0.610129] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.616312] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.624859] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.631294] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.639302] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.645728] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.653666] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.660086] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.668025] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.674350] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.682302] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.688630] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.698288] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.706471] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.714764] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.722016] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.730835] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.744121] brd: module loaded [ 0.750786] loop: module loaded [ 0.754566] megasas: 07.714.04.00-rc1 [ 0.760221] tun: Universal TUN/TAP device driver, 1.6 [ 0.765671] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.772082] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.778162] sky2: driver version 1.30 [ 0.782410] VFIO - User Level meta-driver version: 0.3 [ 0.788193] i2c /dev entries driver [ 0.792613] sdhci: Secure Digital Host Controller Interface driver [ 0.798946] sdhci: Copyright(c) Pierre Ossman [ 0.803591] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.809944] ledtrig-cpu: registered to indicate activity on CPUs [ 0.816267] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.823618] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.828174] optee: revision 3.20 (8e74d476) [ 0.844583] optee: dynamic shared memory is enabled [ 0.854046] optee: initialized driver [ 0.859148] NET: Registered protocol family 17 [ 0.863775] 9pnet: Installing 9P2000 support [ 0.868173] Key type dns_resolver registered [ 0.872630] Loading compiled-in X.509 certificates [ 0.884898] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') [ 0.951959] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.959717] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz [ 0.966168] pca953x 1-0022: supply vcc not found, using dummy regulator [ 0.973002] pca953x 1-0022: using AI [ 0.999812] gpio-496 (PRG1_RGMII_INT): hogged as output/high [ 1.005788] gpio-497 (PRG0_RGMII_INT): hogged as output/high [ 1.011762] gpio-499 (ENET_RGMII_PWRDN_EN): hogged as output/high [ 1.018181] gpio-500 (VSYS_1V0_CSI_EN): hogged as output/high [ 1.024243] gpio-501 (HDMI_PWRDN_EN): hogged as output/high [ 1.030128] gpio-502 (CSI_PWRDN_EN1): hogged as output/high [ 1.036014] gpio-503 (CSI_PWRDN_EN2): hogged as output/high [ 1.042162] gpio-506 (VSYS_3V3_PCIE2_EN): hogged as output/high [ 1.048402] gpio-507 (EXP_3V3_WIFI_EN): hogged as output/high [ 1.054468] gpio-508 (MAX96712_STB): hogged as output/high [ 1.060265] gpio-509 (MAX96712_STB1): hogged as output/high [ 1.066149] gpio-510 (LT9611_RST): hogged as output/high [ 1.071768] gpio-511 (GPS_PWR_EN): hogged as output/high [ 1.077436] omap_i2c 2060000.i2c: bus 1 rev0.12 at 400 kHz [ 1.084039] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.094051] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.102894] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.112804] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.133337] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.141046] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.149325] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.157605] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.176915] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.183340] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.188946] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.198637] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.205692] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.211831] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.221782] pci 0000:00:00.0: supports D1 [ 2.225877] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.231763] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [ 2.238790] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [ 2.250884] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.261111] pci 0000:01:00.0: [8086:2526] type 00 class 0x028000 [ 2.268664] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 2.285478] SError Interrupt on CPU0, code 0xbf000000 -- SError [ 2.285480] CPU: 0 PID: 62 Comm: kworker/0:2 Not tainted 5.10.162 #1 [ 2.285481] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 2.285482] Workqueue: events deferred_probe_work_func [ 2.285485] pstate: 60000085 (nZCv daIf -PAN -UAO -TCO BTYPE=--) [ 2.285486] pc : pci_generic_config_read+0x9c/0xe0 [ 2.285487] lr : pci_generic_config_read+0x24/0xe0 [ 2.285488] sp : ffff800011873710 [ 2.285489] x29: ffff800011873710 x28: ffff000848934000 [ 2.285491] x27: 0000000000000000 x26: 0000000000000001 [ 2.285493] x25: ffff80001127aca8 x24: 0000000000000000 [ 2.285496] x23: ffff800011873814 x22: 0000000000000087 [ 2.285498] x21: ffff000848934800 x20: 0000000000000002 [ 2.285500] x19: ffff800011873794 x18: 0000000000000010 [ 2.285502] x17: 0000000000000000 x16: 000000009e896de5 [ 2.285504] x15: ffff000847d3a1d0 x14: 0000000000000121 [ 2.285506] x13: ffff000847d3a1d0 x12: 00000000ffffffea [ 2.285508] x11: ffff8000111a05b0 x10: ffff800011188570 [ 2.285510] x9 : ffff8000111885c8 x8 : 0000000000000405 [ 2.285512] x7 : 0000000fffffffe0 x6 : 0000000000000002 [ 2.285515] x5 : ffff000848934000 x4 : 000000000000000b [ 2.285517] x3 : 0000000000000001 x2 : ffff800013c00008 [ 2.285519] x1 : 0000000000000000 x0 : 0000000000000000 [ 2.285522] Kernel panic - not syncing: Asynchronous SError Interrupt [ 2.285523] CPU: 0 PID: 62 Comm: kworker/0:2 Not tainted 5.10.162 #1 [ 2.285525] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 2.285526] Workqueue: events deferred_probe_work_func [ 2.285527] Call trace: [ 2.285528] dump_backtrace+0x0/0x1a0 [ 2.285529] show_stack+0x18/0x68 [ 2.285530] dump_stack+0xd0/0x12c [ 2.285531] panic+0x16c/0x334 [ 2.285532] nmi_panic+0x8c/0x90 [ 2.285533] arm64_serror_panic+0x78/0x84 [ 2.285534] do_serror+0x38/0x98 [ 2.285535] el1_error+0x90/0x110 [ 2.285536] pci_generic_config_read+0x9c/0xe0 [ 2.285537] cdns_ti_pcie_config_read+0x18/0x38 [ 2.285538] pci_bus_read_config_word+0x7c/0xd8 [ 2.285539] pci_read_config_word+0x30/0x50 [ 2.285539] pci_device_add+0x4e4/0x6a0 [ 2.285540] pci_scan_single_device+0xc0/0xf8 [ 2.285541] pci_scan_slot+0x40/0x120 [ 2.285542] pci_scan_child_bus_extend+0x54/0x298 [ 2.285544] pci_scan_bridge_extend+0x29c/0x580 [ 2.285545] pci_scan_child_bus_extend+0x1e4/0x298 [ 2.285546] pci_scan_root_bus_bridge+0x64/0xd8 [ 2.285547] pci_host_probe+0x18/0xc8 [ 2.285548] cdns_pcie_host_setup+0x534/0x8f0 [ 2.285549] j721e_pcie_probe+0x534/0x7f0 [ 2.285550] platform_drv_probe+0x54/0xa8 [ 2.285551] really_probe+0xec/0x3e0 [ 2.285552] driver_probe_device+0x58/0xb8 [ 2.285553] __device_attach_driver+0xb8/0xe0 [ 2.285554] bus_for_each_drv+0x78/0xc8 [ 2.285555] __device_attach+0xf8/0x188 [ 2.285556] device_initial_probe+0x14/0x20 [ 2.285557] bus_probe_device+0x9c/0xa8 [ 2.285558] deferred_probe_work_func+0x88/0xc0 [ 2.285559] process_one_work+0x1a0/0x328 [ 2.285560] worker_thread+0x1f8/0x420 [ 2.285561] kthread+0x140/0x160 [ 2.285562] ret_from_fork+0x10/0x34 [ 2.285576] SMP: stopping secondary CPUs [ 2.285577] Kernel Offset: disabled [ 2.285578] CPU features: 0x28040022,20006008 [ 2.285579] Memory Limit: none
Starting kernel ...
[ 0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Mar 3 23:00:40 UTC 2023
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=f42c8474-02 rw rootfstype=ext4 rootwait
[ 0.000000] Memory: 1696388K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1973628K reserved, 524288K cma-reserved)
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008415] Console: colour dummy device 80x25
[ 0.012982] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023652] pid_max: default: 32768 minimum: 301
[ 0.028409] LSM: Security Framework initializing
[ 0.033171] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040752] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049643] rcu: Hierarchical SRCU implementation.
[ 0.054720] Platform MSI: msi-controller@1820000 domain created
[ 0.060986] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070289] EFI services will not be available.
[ 0.075018] smp: Bringing up secondary CPUs ...
[ 0.088303] Detected PIPT I-cache on CPU1
[ 0.088328] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.088340] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000
[ 0.088375] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.088427] smp: Brought up 1 node, 2 CPUs
[ 0.117774] SMP: Total of 2 processors activated.
[ 0.122579] CPU features: detected: 32-bit EL0 Support
[ 0.127833] CPU features: detected: CRC32 instructions
[ 0.142462] CPU: All CPU(s) started at EL2
[ 0.146657] alternatives: patching kernel code
[ 0.151740] devtmpfs: initialized
[ 0.161013] KASLR disabled due to lack of seed
[ 0.165666] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.175630] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.190520] pinctrl core: initialized pinctrl subsystem
[ 0.196199] DMI not present or invalid.
[ 0.200465] NET: Registered protocol family 16
[ 0.205908] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.213240] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.221270] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.229588] thermal_sys: Registered thermal governor 'step_wise'
[ 0.229591] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.236189] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.249829] ASID allocator initialised with 65536 entries
[ 0.270953] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.277811] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.284657] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.291503] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.299013] cryptd: max_cpu_qlen set to 1000
[ 0.305155] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.313959] vsys_3v3: supplied by evm_12v0
[ 0.318339] vsys_5v0: supplied by evm_12v0
[ 0.322676] vdd_mmc1: supplied by vsys_3v3
[ 0.327382] iommu: Default domain type: Translated
[ 0.332560] SCSI subsystem initialized
[ 0.336592] mc: Linux media interface: v0.10
[ 0.340963] videodev: Linux video capture interface: v2.00
[ 0.346592] pps_core: LinuxPPS API ver. 1 registered
[ 0.351662] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.360999] PTP clock support registered
[ 0.365018] EDAC MC: Ver: 3.0.0
[ 0.368829] FPGA manager framework
[ 0.372350] Advanced Linux Sound Architecture Driver Initialized.
[ 0.378992] clocksource: Switched to clocksource arch_sys_counter
[ 0.385323] VFS: Disk quotas dquot_6.6.0
[ 0.389355] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.399089] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.405380] NET: Registered protocol family 2
[ 0.410137] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.418749] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.427505] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.435709] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.443535] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.450341] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.457235] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.464634] NET: Registered protocol family 1
[ 0.469371] RPC: Registered named UNIX socket transport module.
[ 0.475428] RPC: Registered udp transport module.
[ 0.480244] RPC: Registered tcp transport module.
[ 0.485047] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.491630] NET: Registered protocol family 44
[ 0.496178] PCI: CLS 0 bytes, default 64
[ 0.500573] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.510982] Initialise system trusted keyrings
[ 0.515630] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.523829] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.530080] NFS: Registering the id_resolver key type
[ 0.535262] Key type id_resolver registered
[ 0.539534] Key type id_legacy registered
[ 0.543656] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.550505] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.558150] 9p: Installing v9fs 9p2000 file system support
[ 0.582888] Key type asymmetric registered
[ 0.587075] Asymmetric key parser 'x509' registered
[ 0.592072] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.599632] io scheduler mq-deadline registered
[ 0.604257] io scheduler kyber registered
[ 0.609919] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.616107] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.624905] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.631340] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.639348] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.645769] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.653702] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.660125] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.668070] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.674397] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.682362] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.688688] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.698330] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.706550] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.714835] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.722084] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.730850] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.744174] brd: module loaded
[ 0.750837] loop: module loaded
[ 0.754657] megasas: 07.714.04.00-rc1
[ 0.760274] tun: Universal TUN/TAP device driver, 1.6
[ 0.765735] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.772147] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.778226] sky2: driver version 1.30
[ 0.782477] VFIO - User Level meta-driver version: 0.3
[ 0.788244] i2c /dev entries driver
[ 0.792645] sdhci: Secure Digital Host Controller Interface driver
[ 0.798970] sdhci: Copyright(c) Pierre Ossman
[ 0.803688] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.810035] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.816365] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.823700] optee: probing for conduit method.
[ 0.828259] optee: revision 3.20 (8e74d476)
[ 0.844669] optee: dynamic shared memory is enabled
[ 0.854142] optee: initialized driver
[ 0.859276] NET: Registered protocol family 17
[ 0.863892] 9pnet: Installing 9P2000 support
[ 0.868294] Key type dns_resolver registered
[ 0.872753] Loading compiled-in X.509 certificates
[ 0.884649] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[ 0.959634] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.967458] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.973867] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 0.980698] pca953x 1-0022: using AI
[ 1.007617] gpio-496 (PRG1_RGMII_INT): hogged as output/high
[ 1.013594] gpio-497 (PRG0_RGMII_INT): hogged as output/high
[ 1.019569] gpio-499 (ENET_RGMII_PWRDN_EN): hogged as output/high
[ 1.025987] gpio-500 (VSYS_1V0_CSI_EN): hogged as output/high
[ 1.032050] gpio-501 (HDMI_PWRDN_EN): hogged as output/high
[ 1.037936] gpio-502 (CSI_PWRDN_EN1): hogged as output/high
[ 1.043823] gpio-503 (CSI_PWRDN_EN2): hogged as output/high
[ 1.049973] gpio-506 (VSYS_3V3_PCIE2_EN): hogged as output/high
[ 1.056214] gpio-507 (EXP_3V3_WIFI_EN): hogged as output/high
[ 1.062277] gpio-508 (MAX96712_STB): hogged as output/high
[ 1.068074] gpio-509 (MAX96712_STB1): hogged as output/high
[ 1.073959] gpio-510 (LT9611_RST): hogged as output/high
[ 1.079579] gpio-511 (GPS_PWR_EN): hogged as output/high
[ 1.085244] omap_i2c 2060000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.091784] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.101791] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.110614] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.120528] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.140835] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.148543] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.156823] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.165100] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 1.284282] j721e-pcie 2900000.pcie: Link up
[ 1.288649] j721e-pcie 2900000.pcie: Link up
[ 1.293065] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 1.299472] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.305077] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 1.314767] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 1.321821] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 1.327959] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 1.337910] pci 0000:00:00.0: supports D1
[ 1.342004] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.347894] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 1.354921] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 1.366980] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.376698] pci 0000:01:00.0: [8086:2526] type 00 class 0x028000
[ 1.384650] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 1.399335] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 1.407402] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[ 1.458567] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.465343] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[ 1.472819] pci 0000:00:00.0: BAR 14: assigned [mem 0x10100000-0x101fffff]
[ 1.479847] pci 0000:01:00.0: BAR 0: assigned [mem 0x10100000-0x10103fff 64bit]
[ 1.487740] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.492814] pci 0000:00:00.0: bridge window [mem 0x10100000-0x101fffff]
[ 1.499855] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.506213] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
[ 1.512671] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.520342] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 1.528618] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 1.536895] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.550143] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 2.556568] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 2.562174] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 2.572042] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 2.579089] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.585227] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.595157] pci 0001:00:00.0: supports D1
[ 2.599251] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 2.607149] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.617187] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.623955] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 2.629248] pcieport 0001:00:00.0: PME: Signaling with IRQ 58
[ 2.636179] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 2.646064] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 2.652823] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 2.661880] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 2.672034] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 2.678797] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 2.686787] printk: console [ttyS2] disabled
[ 2.691182] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 20, base_baud = 3000000) is a 8250
[ 2.699927] printk: console [ttyS2] enabled
[ 2.708363] printk: bootconsole [ns16550a0] disabled
[ 2.718919] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 21, base_baud = 3000000) is a 8250
[ 2.727911] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 22, base_baud = 3000000) is a 8250
[ 2.737383] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 2.747894] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 2.758051] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 2.768290] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 2.779514] scsi host0: ufshcd
[ 2.787594] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 2.897270] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 2.903378] mmc0: CQHCI version 5.10
[ 2.914647] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 2.921588] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 2.928480] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 2.935351] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 2.942213] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 2.951777] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 2.953152] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 2.970323] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 2.982279] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 2.998063] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 2.998610] mmc1: CQHCI version 5.10
[ 3.005378] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.017376] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.024721] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.032051] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.039397] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.072464] ALSA device list:
[ 3.075442] No soundcards found.
[ 3.100520] mmc0: Command Queue Engine enabled
[ 3.104963] mmc0: new HS200 MMC card at address 0001
[ 3.110279] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
[ 3.114925] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
[ 3.120966] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
[ 3.126969] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
[ 3.192520] cdns-ufshcd 4e84000.ufs: link startup failed 1
[ 3.198003] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[ 3.203040] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[ 3.209292] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 3.215719] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[ 3.222578] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[ 3.229179] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[ 3.235516] cdns-ufshcd 4e84000.ufs: Clk gate=1
[ 3.240037] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 3.248196] cdns-ufshcd 4e84000.ufs: last intr at 3084407 us, last intr status=0x404
[ 3.255920] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[ 3.263384] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[ 3.272409] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[ 3.278402] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[ 3.284652] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[ 3.290729] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[ 3.296809] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[ 3.308969] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[ 3.315309] host_regs: 00000010: 00000000 00000000 00000000 00000000
[ 3.321646] host_regs: 00000020: 00000000 00000470 00000000 00000000
[ 3.327985] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 3.334324] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 3.340664] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 3.347002] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 3.353340] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 3.359678] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 3.366016] host_regs: 00000090: 00000000 00000000 00000000 00000000
[ 3.372360] cdns-ufshcd 4e84000.ufs: No record of pa_err
[ 3.377658] cdns-ufshcd 4e84000.ufs: No record of dl_err
[ 3.382955] cdns-ufshcd 4e84000.ufs: No record of nl_err
[ 3.388252] cdns-ufshcd 4e84000.ufs: No record of tl_err
[ 3.393549] cdns-ufshcd 4e84000.ufs: No record of dme_err
[ 3.398934] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[ 3.405099] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[ 3.410658] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3085529 us
[ 3.417777] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[ 3.423507] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[ 3.429324] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[ 3.434881] cdns-ufshcd 4e84000.ufs: No record of host_reset
[ 3.440528] cdns-ufshcd 4e84000.ufs: No record of task_abort
[ 4.069683] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 4.077577] Waiting for root device PARTUUID=f42c8474-02...
[ 4.131276] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 4.138251] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
[ 4.144160] mmcblk1: p1 p2
[ 4.218786] EXT4-fs (mmcblk1p2): recovery complete
[ 4.224720] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.232833] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 4.243291] devtmpfs: mounted
[ 4.247235] Freeing unused kernel memory: 1856K
[ 4.251849] Run /sbin/init as init process
[ 4.448407] systemd[1]: System time before build time, advancing clock.
[ 4.511829] NET: Registered protocol family 10
[ 4.516730] Segment Routing with IPv6
[ 4.552699] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 4.574454] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 4.615536] systemd[1]: Set hostname to <j7-evm>.
[ 4.817896] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
[ 4.843487] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 4.922481] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.930835] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 4.951092] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.958526] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.979073] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.986355] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.007215] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 5.031120] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 5.055110] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 5.075056] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.095048] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.115048] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 5.153949] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 5.175135] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 5.197703] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 5.219222] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 5.244718] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 5.253094] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 5.275338] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.291381] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 5.315291] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 5.335199] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 5.357559] systemd[1]: Mounting Huge Pages File System...
[ 5.377382] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.401436] systemd[1]: Mounting Kernel Debug File System...
[ 5.422027] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 5.441752] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 5.471413] systemd[1]: Starting Start psplash boot splash screen...
[ 5.498326] systemd[1]: Starting RPC Bind...
[ 5.511187] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 5.523824] systemd[1]: Starting Journal Service...
[ 5.543757] systemd[1]: Starting Load Kernel Modules...
[ 5.562332] cryptodev: loading out-of-tree module taints kernel.
[ 5.571243] systemd[1]: Starting Remount Root and Kernel File Systems...
Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded.
[0m...
[ 5.597179] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 5.605583] systemd[1]: Starting udev Coldplug all Devices...
[ 5.625991] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 5.639469] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 5.864643] systemd-journald[171]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 5.963731] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Reached target Local File Systems (Pre).
[ 5.987192] random: systemd: uninitialized urandom read (16 bytes read)
Mounting /media/ram...
[ 5.998149] random: systemd-journal: uninitialized urandom read (16 bytes read)
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting udev Wait for Complete Device Initialization...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ 6.414597] CAN device driver interface
[ 6.457704] random: crng init done
[ 6.461300] random: 71 urandom warning(s) missed due to ratelimiting
[ OK ] Started Load/Save Random Seed.[ 6.491386] m_can_platform 2701000.can: m_can device registered (irq=32, version=32)
[ 6.518629] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 6.539624] m_can_platform 2721000.can: m_can device registered (irq=34, version=32)
[ 6.549807] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[ 6.559420] remoteproc remoteproc0: 4d80800000.dsp is available
[ 6.568036] remoteproc remoteproc0: attaching to 4d80800000.dsp
[ 6.586723] m_can_platform 2741000.can: m_can device registered (irq=36, version=32)
[ 6.608776] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[ 6.616297] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 6.628978] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 6.634542] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 6.643940] m_can_platform 2751000.can: m_can device registered (irq=38, version=32)
[ 6.651922] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 6.667048] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[ 6.680328] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ 6.689064] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 6.700066] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[ 6.708012] m_can_platform 2761000.can: m_can device registered (irq=40, version=32)
[ 6.709534] remoteproc remoteproc1: 4d81800000.dsp is available
[ 6.727915] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.735723] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[ 6.743607] m_can_platform 2771000.can: m_can device registered (irq=42, version=32)
[ 6.744205] remoteproc remoteproc1: attaching to 4d81800000.dsp
[ 6.758286] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[ 6.759771] img_dec 4300000.video-decoder: decoder registered as /dev/video1
[ 6.765213] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 6.784361] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[ 6.784860] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 6.794468] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 6.800933] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 6.811200] m_can_platform 2791000.can: m_can device registered (irq=44, version=32)
[ 6.813262] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
[ 6.830007] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.833744] PVR_K: 199: Read BVNC 22.104.208.318 from HW device registers
[ 6.843897] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 6.891558] Intel(R) Wireless WiFi driver for Linux
[ 6.902841] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 6.932078] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 6.936728] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 6.938104] PVR_K: 199: RGX Device registered with BVNC 22.104.208.318
[ 6.970105] platform 41000000.r5f: configured R5F for IPC-only mode
[ 6.970188] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[ 6.977113] remoteproc remoteproc2: 64800000.dsp is available
[ 6.988282] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 6.999828] remoteproc remoteproc3: 41000000.r5f is available
[ 7.005856] remoteproc remoteproc3: attaching to 41000000.r5f
[ 7.013376] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 7.023355] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 7.027123] remoteproc remoteproc2: attaching to 64800000.dsp
[ 7.033896] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 7.046509] remoteproc3#vdev0buffer: registered virtio2 (type 7)
[ 7.052634] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[ 7.060146] remoteproc remoteproc2: unsupported resource 65538
[ 7.060533] iwlwifi 0000:01:00.0: WRT: Overriding region id 0
[ 7.071774] iwlwifi 0000:01:00.0: WRT: Overriding region id 1
[ 7.077539] iwlwifi 0000:01:00.0: WRT: Overriding region id 2
[ 7.084321] iwlwifi 0000:01:00.0: WRT: Overriding region id 3
[ 7.090092] iwlwifi 0000:01:00.0: WRT: Overriding region id 4
[ 7.097273] iwlwifi 0000:01:00.0: WRT: Overriding region id 6
[ 7.097441] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 7.103054] iwlwifi 0000:01:00.0: WRT: Overriding region id 8
[ 7.114974] iwlwifi 0000:01:00.0: WRT: Overriding region id 9
[ 7.120807] iwlwifi 0000:01:00.0: WRT: Overriding region id 10
[ 7.122076] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 7.126738] iwlwifi 0000:01:00.0: WRT: Overriding region id 11
[ 7.139413] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 7.148540] iwlwifi 0000:01:00.0: WRT: Overriding region id 15
[ 7.154402] iwlwifi 0000:01:00.0: WRT: Overriding region id 16
[ 7.160280] iwlwifi 0000:01:00.0: WRT: Overriding region id 18
[ 7.166128] iwlwifi 0000:01:00.0: WRT: Overriding region id 19
[ 7.173918] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 7.183365] iwlwifi 0000:01:00.0: WRT: Overriding region id 20
[ 7.190489] iwlwifi 0000:01:00.0: WRT: Overriding region id 21
[ 7.194089] remoteproc remoteproc4: 5c00000.r5f is available
[ 7.201839] iwlwifi 0000:01:00.0: WRT: Overriding region id 28
[ 7.214964] iwlwifi 0000:01:00.0: loaded firmware version 46.50fdb42f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
[ 7.239557] remoteproc remoteproc4: attaching to 5c00000.r5f
[ 7.249705] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 7.252143] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 7.257888] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 7.268778] remoteproc2#vdev0buffer: registered virtio3 (type 7)
[ 7.269330] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 7.285380] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 7.299175] remoteproc remoteproc2: remote processor 64800000.dsp is now attached
[ 7.305837] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 7.309165] remoteproc4#vdev0buffer: registered virtio4 (type 7)
[ 7.320185] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
[ 7.332142] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 7.342061] iwlwifi 0000:01:00.0: Detected Intel(R) Wireless-AC 9260 160MHz, REV=0x324
[ 7.349226] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 7.512880] j721e-audio sound@0: CPB codec node is not provided
[ 7.531107] remoteproc remoteproc5: 5d00000.r5f is available
[ 7.537383] j721e-audio: probe of sound@0 failed with error -22
[ 7.548739] remoteproc remoteproc5: attaching to 5d00000.r5f
[ 7.560153] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 7.615062] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 7.705109] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 7.725677] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[ 7.745295] remoteproc5#vdev0buffer: registered virtio5 (type 7)
[ 7.753249] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
[ 7.794353] platform 5e00000.r5f: configured R5F for IPC-only mode
[ 7.811827] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 7.886575] j721e-pcie 2900000.pcie: LINK DOWN!
[ 7.911755] remoteproc remoteproc6: 5e00000.r5f is available
[ 7.939171] remoteproc remoteproc6: attaching to 5e00000.r5f
[ 7.945202] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[ 7.968742] remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 8.004927] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 8.025763] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[ 8.025880] remoteproc6#vdev0buffer: registered virtio6 (type 7)
[ 8.043573] remoteproc remoteproc6: remote processor 5e00000.r5f is now attached
[ 8.053863] platform 5f00000.r5f: configured R5F for IPC-only mode
[ 8.063172] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 8.076422] remoteproc remoteproc7: 5f00000.r5f is available
[ 8.091256] remoteproc remoteproc7: attaching to 5f00000.r5f
[ 8.098765] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[ 8.110813] remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ OK ] Created slice system-systemd\x2dfsc[ 8.121299] virtio_rpmsg_bus virtio7: rpmsg host is online
k.slice.
[ 8.133022] remoteproc7#vdev0buffer: registered virtio7 (type 7)
[ 8.139984] remoteproc remoteproc7: remote processor 5f00000.r5f is now attached
[ 8.141800] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[ 8.158922] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[ 8.182347] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.194145] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 8.201490] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.209106] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ 8.219139] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.228134] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 8.236835] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.236887] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 8.236943] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[ 8.236983] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.237026] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[ 8.275187] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
[ 8.275821] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 8.283272] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.297416] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
[ 8.305080] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
[ 8.315968] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 8/Jan/2024 SHA:5994a127
[ 8.329986] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-6: Device info: permissions: 3FFFFFFF uart_id: 2
[ 8.344150] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-6: FW ver 0.2 (rev 0) 8/Jan/2024 SHA:5994a127
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[ 8.373440] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
[ 8.404529] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[ 8.416004] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
[ 8.439041] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[ 8.446882] usbcore: registered new interface driver usbfs
[ 8.456662] usbcore: registered new interface driver hub
[ 8.458657] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.462038] usbcore: registered new device driver usb
[ 8.474148] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac6: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:6
[ 8.511150] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac6: virt_cpsw_nuss mac loaded
[ 8.526107] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac6: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:6
[ 8.547303] remoteproc remoteproc8: b034000.pru is available
[ 8.557208] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac6: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
[ 8.560245] remoteproc remoteproc9: b004000.rtu is available
[ 8.583834] remoteproc remoteproc10: b00a000.txpru is available
[ 8.590597] remoteproc remoteproc11: b038000.pru is available
[ 8.597353] remoteproc remoteproc12: b006000.rtu is available
[ 8.605176] remoteproc remoteproc13: b00c000.txpru is available
[ 8.611943] remoteproc remoteproc14: b134000.pru is available
[ 8.618205] remoteproc remoteproc15: b104000.rtu is available
[ 8.628415] remoteproc remoteproc16: b10a000.txpru is available
[ 8.635178] remoteproc remoteproc17: b138000.pru is available
[ 8.643026] remoteproc remoteproc18: b106000.rtu is available
[ 8.649731] remoteproc remoteproc19: b10c000.txpru is available
[ OK ] Found device /dev/mmcblk1p1.
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Started File System Check on /dev/mmcblk1p1.
Mounting /run/media/mmcblk1p1...
[ OK ] Mounted /run/media/mmcblk1p1.
[ 9.305768] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 9.311323] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 9.319095] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 9.328554] xhci-hcd xhci-hcd.0.auto: irq 656, io mem 0x06410000
[ 9.334746] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 9.343015] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.350229] usb usb1: Product: xHCI Host Controller
[ 9.355099] usb usb1: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
[ 9.361705] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 9.366847] hub 1-0:1.0: USB hub found
[ 9.370612] hub 1-0:1.0: 1 port detected
[ 9.374725] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 9.380211] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 9.387864] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 9.394411] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 9.402555] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 9.410808] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.418017] usb usb2: Product: xHCI Host Controller
[ 9.422888] usb usb2: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
[ 9.429492] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 9.434602] hub 2-0:1.0: USB hub found
[ 9.438372] hub 2-0:1.0: 1 port detected
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily rotation of log files.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting set host name as per compatible name...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Telephony service...
Starting Update pmic regis…fety feature on power rails...
Starting rc.pvr.service...
Starting startwlanap...
Starting startwlansta...
Starting Login Service...
[ OK ] Started TEE Supplicant.
Starting Update weston ini… based on the platform name...
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Reached target Network (Pre).
Starting Network Service...
[ OK ] Started startwlansta.
[ OK ] Started set host name as per compatible name.
[ OK ] Started Update pmic regist…safety feature on power rails.
[ OK ] Started Update weston ini …ge based on the platform name.
[ OK ] Started Telephony service.
[ OK ] Started startwlanap.
[ 10.089453] Bluetooth: Core ver 2.22
[ 10.096242] NET: Registered protocol family 31
[ 10.104292] Bluetooth: HCI device and connection manager initialized
[ 10.116617] Bluetooth: HCI socket layer initialized
[ 10.125410] Bluetooth: L2CAP socket layer initialized
[ 10.134981] Bluetooth: SCO socket layer initialized
[ OK ] Started Network Service.
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ OK ] Started Login Service.
[ 10.189234] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac6: virt_cpsw_nuss mac started
[ 10.230926] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ OK ] Started rc.pvr.service.
Starting weston.service...
[ OK ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav-dev
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libidn2-0
libidn2-dev
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring-dev
libunistring2
m4-dev
m4
make
nettle-dev
nettle
parted
python3-rfc3987
python3-strict-rfc3339
tar
which
zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ 12.875004] iwlwifi 0000:01:00.0: Failed to load firmware chunk!
[ 12.881008] iwlwifi 0000:01:00.0: iwlwifi transaction failed, dumping registers
[ 12.894995] iwlwifi 0000:01:00.0: iwlwifi device config registers:
[ 12.901969] iwlwifi 0000:01:00.0: 00000000: 25268086 00100000 02800029 00000000 00000004 00000000 00000000 00000000
[ 12.922996] iwlwifi 0000:01:00.0: 00000020: 00000000 00000000 00000000 00148086 00000000 000000c8 00000000 00000100
[ 12.939008] iwlwifi 0000:01:00.0: 00000040: 00028010 10008ec0 00110c10 0045e812 10110000 00000000 00000000 00000000
[ 12.954993] iwlwifi 0000:01:00.0: 00000060: 00000000 00080812 00000005 00000000 00010002 00000000 00000000 00000000
[ 12.970990] iwlwifi 0000:01:00.0: 00000080: 000f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 12.986990] iwlwifi 0000:01:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 13.002990] iwlwifi 0000:01:00.0: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 13.013409] iwlwifi 0000:01:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 13.030990] iwlwifi 0000:01:00.0: 00000100: 14c10001 00000000 00000000 00462031 000031c1 00002000 00000000 00000000
[ 13.046994] iwlwifi 0000:01:00.0: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 13.062990] iwlwifi 0000:01:00.0: 00000140: 14c00000 ff000000 000000ff 15410018 00000000 0001001e 00481e1f 00000000
[ 13.078992] iwlwifi 0000:01:00.0: iwlwifi device memory mapped registers:
[ 13.086045] SError Interrupt on CPU0, code 0xbf000000 -- SError
[ 13.086046] CPU: 0 PID: 272 Comm: modprobe Tainted: G O 5.10.162-g76b3e88d56 #1
[ 13.086048] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 13.086049] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--)
[ 13.086050] pc : iwl_trans_pcie_read32+0x10/0x28 [iwlwifi]
[ 13.086051] lr : iwl_read32+0x18/0x28 [iwlwifi]
[ 13.086052] sp : ffff8000129536d0
[ 13.086053] x29: ffff8000129536d0 x28: ffff0008274a0000
[ 13.086056] x27: ffff800008f830d0 x26: ffff00084a70960c
[ 13.086058] x25: ffff800008f83098 x24: ffff00084cd45be0
[ 13.086061] x23: ffff00084a709400 x22: ffff00084cd44080
[ 13.086063] x21: ffff00084865b000 x20: ffff00084a709560
[ 13.086065] x19: 0000000000000000 x18: 0000000000000010
[ 13.086068] x17: 0000000000000000 x16: 0000000000000000
[ 13.086070] x15: ffff0008494a3e50 x14: 00000000000002a9
[ 13.086072] x13: ffff0008494a3e50 x12: 00000000ffffffea
[ 13.086074] x11: ffff8000111a05b0 x10: ffff800011188570
[ 13.086077] x9 : ffff8000111885c8 x8 : 0000000000017fe8
[ 13.086079] x7 : c0000000ffffefff x6 : 0000000000000001
[ 13.086081] x5 : 0000000000000000 x4 : ffff00087f9c9ab8
[ 13.086083] x3 : ffff00087f9d09f8 x2 : ffff800008f624f0
[ 13.086085] x1 : 0000000000000000 x0 : 0000000000000000
[ 13.086088] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 13.086089] CPU: 0 PID: 272 Comm: modprobe Tainted: G O 5.10.162-g76b3e88d56 #1
[ 13.086091] Hardware name: Texas Instruments K3 J721E SoC (DT)
[ 13.086092] Call trace:
[ 13.086093] dump_backtrace+0x0/0x1a0
[ 13.086094] show_stack+0x18/0x68
[ 13.086095] dump_stack+0xd0/0x12c
[ 13.086096] panic+0x16c/0x334
[ 13.086097] nmi_panic+0x8c/0x90
[ 13.086098] arm64_serror_panic+0x78/0x84
[ 13.086099] do_serror+0x38/0x98
[ 13.086100] el1_error+0x90/0x110
[ 13.086101] iwl_trans_pcie_read32+0x10/0x28 [iwlwifi]
[ 13.086102] iwl_trans_pcie_dump_regs+0x1b4/0x3f8 [iwlwifi]
[ 13.086103] iwl_pcie_load_section+0x334/0x368 [iwlwifi]
[ 13.086104] iwl_pcie_load_cpu_sections_8000.isra.0+0x70/0x240 [iwlwifi]
[ 13.086106] iwl_trans_pcie_start_fw+0x2ac/0x5c0 [iwlwifi]
[ 13.086107] iwl_mvm_load_ucode_wait_alive+0x1cc/0x418 [iwlmvm]
[ 13.086108] iwl_run_init_mvm_ucode+0x80/0x2e0 [iwlmvm]
[ 13.086109] iwl_op_mode_mvm_start+0x5ac/0x8e0 [iwlmvm]
[ 13.086110] _iwl_op_mode_start.isra.0+0x60/0xb0 [iwlwifi]
[ 13.086111] iwl_opmode_register+0x7c/0xf8 [iwlwifi]
[ 13.086113] iwl_mvm_init+0x48/0x1000 [iwlmvm]
[ 13.086113] do_one_initcall+0x54/0x1b8
[ 13.086114] do_init_module+0x44/0x1f0
[ 13.086115] load_module+0x1f08/0x24a8
[ 13.086116] __do_sys_finit_module+0xb8/0xf8
[ 13.086117] __arm64_sys_finit_module+0x20/0x30
[ 13.086118] el0_svc_common.constprop.0+0x78/0x1c8
[ 13.086119] do_el0_svc+0x24/0x90
[ 13.086120] el0_svc+0x14/0x20
[ 13.086121] el0_sync_handler+0xb0/0xb8
[ 13.086122] el0_sync+0x180/0x1c0
[ 13.086143] SMP: stopping secondary CPUs
[ 13.086144] Kernel Offset: disabled
[ 13.086146] CPU features: 0x28040022,20006008
[ 13.086146] Memory Limit: none
It's a question of probability, when it's OK. The log as follows:
U-Boot 2021.01 (Jan 11 2024 - 19:21:21 +0800)
SoC: J721E SR1.1 GP
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -19
Board: J721EX-PM1-SOM rev E2
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... failed to set vqmmc-voltage to 3.3V
OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
cdns,sierra serdes@5000000: sierra probed
Net: Could not get PHY for ethernet@46000000port@1: addr 0
am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed
No ethernet found.
ota_init
bootfirst=0, trycount=255, bootpart=1:2
normal boot
switch to success partion: Saving Environment to FAT... OK
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
483 bytes read in 8 ms (58.6 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 9 ms (0 Bytes/s)
Already setup.
GPIO: 'gpio@22_17' not found
Command 'gpio' failed: Error -22
GPIO: 'gpio@22_16' not found
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
1420664 bytes read in 72 ms (18.8 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1420664 bytes: Success!
302028 bytes read in 25 ms (11.5 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success!
191416 bytes read in 21 ms (8.7 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 191416 bytes: Success!
Load Remote Processor 5 with data@addr=0x82000000 191416 bytes: Success!
1334036 bytes read in 68 ms (18.7 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 1334036 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 1334036 bytes: Success!
12849048 bytes read in 216 ms (56.7 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 12849048 bytes: Success!
19079680 bytes read in 798 ms (22.8 MiB/s)
108084 bytes read in 14 ms (7.4 MiB/s)
11663 bytes read in 11 ms (1 MiB/s)
Loading Device Tree to 000000008fee2000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff]
[ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=085982e8-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008c7030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008412] Console: colour dummy device 80x25
[ 0.012978] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023648] pid_max: default: 32768 minimum: 301
[ 0.028408] LSM: Security Framework initializing
[ 0.033167] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.040747] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.049636] rcu: Hierarchical SRCU implementation.
[ 0.054713] Platform MSI: msi-controller@1820000 domain created
[ 0.060970] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070274] EFI services will not be available.
[ 0.075002] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[ 0.088403] Detected PIPT I-cache on CPU1
[ 0.088430] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.088441] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000
[ 0.088475] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.088531] smp: Brought up 1 node, 2 CPUs
[ 0.117880] SMP: Total of 2 processors activated.
[ 0.122684] CPU features: detected: 32-bit EL0 Support
[ 0.127940] CPU features: detected: CRC32 instructions
[ 0.142659] CPU: All CPU(s) started at EL2
[ 0.146856] alternatives: patching kernel code
[ 0.151938] devtmpfs: initialized
[ 0.161178] KASLR disabled due to lack of seed
[ 0.165831] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.175794] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.190729] pinctrl core: initialized pinctrl subsystem
[ 0.196403] DMI not present or invalid.
[ 0.200664] NET: Registered protocol family 16
[ 0.206115] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.213444] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.221473] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.229834] thermal_sys: Registered thermal governor 'step_wise'
[ 0.229836] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.236425] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.250059] ASID allocator initialised with 65536 entries
[ 0.271216] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.278076] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.284923] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.291770] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.299261] cryptd: max_cpu_qlen set to 1000
[ 0.305354] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.314179] vsys_3v3: supplied by evm_12v0
[ 0.318550] vsys_5v0: supplied by evm_12v0
[ 0.322896] vdd_mmc1: supplied by vsys_3v3
[ 0.327616] iommu: Default domain type: Translated
[ 0.332751] SCSI subsystem initialized
[ 0.336782] mc: Linux media interface: v0.10
[ 0.341153] videodev: Linux video capture interface: v2.00
[ 0.346790] pps_core: LinuxPPS API ver. 1 registered
[ 0.351859] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361195] PTP clock support registered
[ 0.365214] EDAC MC: Ver: 3.0.0
[ 0.369033] FPGA manager framework
[ 0.372556] Advanced Linux Sound Architecture Driver Initialized.
[ 0.379176] clocksource: Switched to clocksource arch_sys_counter
[ 0.385528] VFS: Disk quotas dquot_6.6.0
[ 0.389563] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.399274] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.405562] NET: Registered protocol family 2
[ 0.410325] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.418924] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.427681] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.435884] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.443718] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.450529] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.457423] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.464827] NET: Registered protocol family 1
[ 0.469567] RPC: Registered named UNIX socket transport module.
[ 0.475620] RPC: Registered udp transport module.
[ 0.480424] RPC: Registered tcp transport module.
[ 0.485230] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.491812] NET: Registered protocol family 44
[ 0.496358] PCI: CLS 0 bytes, default 64
[ 0.500774] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.511262] Initialise system trusted keyrings
[ 0.515880] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.524121] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.530343] NFS: Registering the id_resolver key type
[ 0.535519] Key type id_resolver registered
[ 0.539789] Key type id_legacy registered
[ 0.543908] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.550756] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.558405] 9p: Installing v9fs 9p2000 file system support
[ 0.584218] Key type asymmetric registered
[ 0.588404] Asymmetric key parser 'x509' registered
[ 0.593402] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.600962] io scheduler mq-deadline registered
[ 0.605587] io scheduler kyber registered
[ 0.611245] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.617425] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.626177] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.632620] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.640613] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.647033] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.654966] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.661384] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.669331] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.675656] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.683614] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.689942] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 0.699605] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.707827] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.716093] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.723340] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.732245] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.745502] brd: module loaded
[ 0.752220] loop: module loaded
[ 0.756029] megasas: 07.714.04.00-rc1
[ 0.761705] tun: Universal TUN/TAP device driver, 1.6
[ 0.767165] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.773571] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.779646] sky2: driver version 1.30
[ 0.783882] VFIO - User Level meta-driver version: 0.3
[ 0.789651] i2c /dev entries driver
[ 0.794058] sdhci: Secure Digital Host Controller Interface driver
[ 0.800383] sdhci: Copyright(c) Pierre Ossman
[ 0.805022] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.811363] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.817691] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.825032] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.829597] optee: revision 3.20 (8e74d476)
[ 0.846004] optee: dynamic shared memory is enabled
[ 0.855474] optee: initialized driver
[ 0.860644] NET: Registered protocol family 17
[ 0.865277] 9pnet: Installing 9P2000 support
[ 0.869679] Key type dns_resolver registered
[ 0.874145] Loading compiled-in X.509 certificates
[ 0.886284] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[ 0.951139] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.958835] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.965253] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 0.972073] pca953x 1-0022: using AI
[ 0.999800] gpio-496 (PRG1_RGMII_INT): hogged as output/high
[ 1.005777] gpio-497 (PRG0_RGMII_INT): hogged as output/high
[ 1.011752] gpio-499 (ENET_RGMII_PWRDN_EN): hogged as output/high
[ 1.018171] gpio-500 (VSYS_1V0_CSI_EN): hogged as output/high
[ 1.024234] gpio-501 (HDMI_PWRDN_EN): hogged as output/high
[ 1.030120] gpio-502 (CSI_PWRDN_EN1): hogged as output/high
[ 1.036007] gpio-503 (CSI_PWRDN_EN2): hogged as output/high
[ 1.042157] gpio-506 (VSYS_3V3_PCIE2_EN): hogged as output/high
[ 1.048399] gpio-507 (EXP_3V3_WIFI_EN): hogged as output/high
[ 1.054462] gpio-508 (MAX96712_STB): hogged as output/high
[ 1.060260] gpio-509 (MAX96712_STB1): hogged as output/high
[ 1.066145] gpio-510 (LT9611_RST): hogged as output/high
[ 1.071766] gpio-511 (GPS_PWR_EN): hogged as output/high
[ 1.077431] omap_i2c 2060000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.084046] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.094052] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.102883] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.112789] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.133178] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.140885] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.149165] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.157441] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.176760] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.183184] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.188791] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.198482] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.205536] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.211675] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.221626] pci 0000:00:00.0: supports D1
[ 2.225720] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.231607] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 2.238633] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 2.250698] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.260766] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.267538] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit]
[ 2.275011] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.280318] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 2.286869] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.294542] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.302819] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.311098] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.324491] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 3.330919] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.336525] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 3.346394] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.353439] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.359578] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 3.369507] pci 0001:00:00.0: supports D1
[ 3.373601] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 3.381493] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.391569] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.398336] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.403635] pcieport 0001:00:00.0: PME: Signaling with IRQ 59
[ 3.410604] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 3.420488] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 3.427247] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 3.436369] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 3.446520] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 3.453284] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 3.461353] printk: console [ttyS2] disabled
[ 3.465750] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
[ 3.474496] printk: console [ttyS2] enabled
[ 3.482932] printk: bootconsole [ns16550a0] disabled
[ 3.493519] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 22, base_baud = 3000000) is a 8250
[ 3.502525] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 23, base_baud = 3000000) is a 8250
[ 3.512024] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 3.522538] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 3.532696] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 3.542935] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 3.554188] scsi host0: ufshcd
[ 3.563858] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 3.609157] j721e-pcie 2900000.pcie: LINK DOWN!
[ 3.677801] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 3.683694] mmc0: CQHCI version 5.10
[ 3.694730] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 3.701649] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 3.708617] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 3.715611] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 3.722597] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 3.727725] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 3.733568] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 3.747622] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 3.762118] spi-nor spi7.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 3.769001] spi-nor: probe of spi7.0 failed with error -2
[ 3.775092] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 3.781350] mmc1: CQHCI version 5.10
[ 3.790573] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.797869] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.806319] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.813641] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.820969] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.828289] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.855720] ALSA device list:
[ 3.858694] No soundcards found.
[ 3.863505] mmc0: Command Queue Engine enabled
[ 3.867951] mmc0: new HS200 MMC card at address 0001
[ 3.873275] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
[ 3.877922] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
[ 3.883955] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
[ 3.889960] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
[ 3.969633] cdns-ufshcd 4e84000.ufs: link startup failed 1
[ 3.975116] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[ 3.980154] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[ 3.986407] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[ 3.992831] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[ 3.999688] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[ 4.006286] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[ 4.012624] cdns-ufshcd 4e84000.ufs: Clk gate=1
[ 4.017142] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[ 4.025300] cdns-ufshcd 4e84000.ufs: last intr at 3881334 us, last intr status=0x404
[ 4.033026] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[ 4.040491] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[ 4.049514] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[ 4.055506] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[ 4.061757] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[ 4.067835] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[ 4.073913] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[ 4.086083] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[ 4.092424] host_regs: 00000010: 00000000 00000000 00000000 00000000
[ 4.098763] host_regs: 00000020: 00000000 00000470 00000000 00000000
[ 4.105100] host_regs: 00000030: 00000008 00000001 00000000 00000000
[ 4.111439] host_regs: 00000040: 00000000 00000000 00000000 00000000
[ 4.117775] host_regs: 00000050: 00000000 00000000 00000000 00000000
[ 4.124113] host_regs: 00000060: 00000000 00000000 00000000 00000000
[ 4.130451] host_regs: 00000070: 00000000 00000000 00000000 00000000
[ 4.136789] host_regs: 00000080: 00000000 00000000 00000000 00000000
[ 4.143126] host_regs: 00000090: 00000000 00000000 00000000 00000000
[ 4.149464] cdns-ufshcd 4e84000.ufs: No record of pa_err
[ 4.154763] cdns-ufshcd 4e84000.ufs: No record of dl_err
[ 4.160061] cdns-ufshcd 4e84000.ufs: No record of nl_err
[ 4.165359] cdns-ufshcd 4e84000.ufs: No record of tl_err
[ 4.170656] cdns-ufshcd 4e84000.ufs: No record of dme_err
[ 4.176041] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[ 4.182203] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[ 4.187763] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3882457 us
[ 4.194882] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[ 4.200612] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[ 4.206430] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[ 4.211989] cdns-ufshcd 4e84000.ufs: No record of host_reset
[ 4.217633] cdns-ufshcd 4e84000.ufs: No record of task_abort
[ 4.845853] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 4.853730] Waiting for root device PARTUUID=085982e8-02...
[ 4.912047] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 4.918988] mmcblk1: mmc1:aaaa SA16G 14.8 GiB
[ 4.925368] mmcblk1: p1 p2
[ 5.014951] EXT4-fs (mmcblk1p2): recovery complete
[ 5.026750] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.034865] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 5.047832] devtmpfs: mounted
[ 5.051775] Freeing unused kernel memory: 1856K
[ 5.056397] Run /sbin/init as init process
[ 5.245416] systemd[1]: System time before build time, advancing clock.
[ 5.309819] NET: Registered protocol family 10
[ 5.314736] Segment Routing with IPv6
[ 5.350314] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 5.372075] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[ 5.416055] systemd[1]: Set hostname to <j7-evm>.
[ 5.597144] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
[ 5.622504] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 5.694425] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.702769] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 5.723340] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.730788] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.751268] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.758546] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.779400] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 5.803312] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 5.827314] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 5.843244] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.863235] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.879237] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 5.909773] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 5.931306] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 5.954366] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 5.975411] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 6.000935] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 6.009314] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 6.031510] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 6.047609] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 6.071479] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.091403] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 6.113649] systemd[1]: Mounting Huge Pages File System...
[ 6.137695] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.165644] systemd[1]: Mounting Kernel Debug File System...
[ 6.190685] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 6.213863] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 6.244815] systemd[1]: Starting Start psplash boot splash screen...
[ 6.269753] systemd[1]: Starting RPC Bind...
[ 6.287452] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 6.300127] systemd[1]: Starting Journal Service...
[ 6.319755] systemd[1]: Starting Load Kernel Modules...
[ 6.336317] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.353079] cryptodev: loading out-of-tree module taints kernel.
[ 6.365916] systemd[1]: Starting udev Coldplug all Devices...
[ 6.369367] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 6.371959] cryptodev: driver 1.10 loaded.
[ 6.394419] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 6.407728] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
[ 6.625516] systemd-journald[171]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started udev Coldplug all Devices.
[ 6.752123] random: systemd: uninitialized urandom read (16 bytes read)
[ OK ] Reached target Local File Systems (Pre).
[ 6.775289] random: systemd: uninitialized urandom read (16 bytes read)
Mounting /media/ram...
[ 6.787015] random: systemd-journal: uninitialized urandom read (16 bytes read)
Mounting /var/volatile...
Starting udev Wait for Complete Device Initialization...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started udev Kernel Device Manager.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ 7.223409] random: crng init done
[ 7.226808] random: 67 urandom warning(s) missed due to ratelimiting
[ OK ] Started Load/Save Random Seed.
[ 7.250989] CAN device driver interface
[ 7.270323] m_can_platform 2701000.can: m_can device registered (irq=33, version=32)
[ 7.295798] m_can_platform 2721000.can: m_can device registered (irq=35, version=32)
[ 7.306911] m_can_platform 2741000.can: m_can device registered (irq=37, version=32)
[ 7.318310] m_can_platform 2751000.can: m_can device registered (irq=39, version=32)
[ 7.329564] m_can_platform 2761000.can: m_can device registered (irq=41, version=32)
[ 7.352161] m_can_platform 2771000.can: m_can device registered (irq=43, version=32)
[ 7.364709] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 7.377169] m_can_platform 2791000.can: m_can device registered (irq=45, version=32)
[ 7.386818] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[ 7.394467] remoteproc remoteproc0: 4d80800000.dsp is available
[ 7.404843] remoteproc remoteproc0: attaching to 4d80800000.dsp
[ 7.435524] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[ 7.462529] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 7.493444] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ 7.506251] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[ 7.513535] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[ 7.530341] PVR_K: 194: Read BVNC 22.104.208.318 from HW device registers
[ 7.537446] PVR_K: 194: RGX Device registered with BVNC 22.104.208.318
[ 7.544598] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[ 7.562737] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 7.568406] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 7.578030] img_dec 4300000.video-decoder: decoder registered as /dev/video1
[ 7.589356] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 7.598348] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 7.615123] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[ 7.625120] platform 41000000.r5f: configured R5F for IPC-only mode
[ 7.633089] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 7.643722] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 7.655243] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[ 7.664638] remoteproc remoteproc1: 41000000.r5f is available
[ 7.671761] remoteproc remoteproc2: 4d81800000.dsp is available
[ 7.679552] remoteproc remoteproc1: attaching to 41000000.r5f
[ 7.687081] remoteproc remoteproc2: attaching to 4d81800000.dsp
[ 7.695283] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 7.703797] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[ 7.712218] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 7.721483] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 7.725186] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 7.740060] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 7.744464] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[ 7.748690] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 7.763070] remoteproc1#vdev0buffer: registered virtio1 (type 7)
[ 7.767204] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
[ 7.788149] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[ 7.800634] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 7.817830] j721e-audio sound@0: CPB codec node is not provided
[ 7.831053] j721e-audio: probe of sound@0 failed with error -22
[ 7.860186] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 7.867253] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 7.882398] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 7.898290] remoteproc remoteproc3: 64800000.dsp is available
[ 7.940164] remoteproc remoteproc3: attaching to 64800000.dsp
[ 7.960652] remoteproc remoteproc4: 5c00000.r5f is available
[ 7.981305] remoteproc remoteproc3: unsupported resource 65538
[ 8.003482] remoteproc remoteproc4: attaching to 5c00000.r5f
[ 8.028464] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[ 8.038188] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[ 8.048190] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 8.063256] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.092436] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 8.098041] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 8.106512] remoteproc3#vdev0buffer: registered virtio3 (type 7)
[ 8.113876] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
[ 8.125024] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 8.134149] remoteproc4#vdev0buffer: registered virtio4 (type 7)
[ 8.140339] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached
[ 8.147802] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 8.160047] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 8.174316] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 8.286070] remoteproc remoteproc5: 5d00000.r5f is available
[ 8.345688] remoteproc remoteproc5: attaching to 5d00000.r5f
[ 8.387518] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[ 8.419824] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 8.433434] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 8.443330] remoteproc5#vdev0buffer: registered virtio5 (type 7)
[ 8.454119] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
[ 8.454200] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[ 8.471748] platform 5e00000.r5f: configured R5F for IPC-only mode
[ 8.480322] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 8.500437] remoteproc remoteproc6: 5e00000.r5f is available
[ 8.507286] remoteproc remoteproc6: attaching to 5e00000.r5f
[ 8.516242] platform 5e00000.r5f: R5F core initialized in IPC-only mode
[ 8.525121] remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 8.536509] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 8.543294] remoteproc6#vdev0buffer: registered virtio6 (type 7)
[ 8.550486] remoteproc remoteproc6: remote processor 5e00000.r5f is now attached
[ 8.557397] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
[ 8.567595] platform 5f00000.r5f: configured R5F for IPC-only mode
[ 8.575780] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 8.587584] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 8.661168] remoteproc remoteproc7: 5f00000.r5f is available
[ 8.675851] remoteproc remoteproc7: attaching to 5f00000.r5f
[ 8.730329] usbcore: registered new interface driver usbfs
[ 8.731574] platform 5f00000.r5f: R5F core initialized in IPC-only mode
[ 8.743876] remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 8.753839] virtio_rpmsg_bus virtio7: rpmsg host is online
[ 8.763161] remoteproc7#vdev0buffer: registered virtio7 (type 7)
[ 8.769280] remoteproc remoteproc7: remote processor 5f00000.r5f is now attached
[ 8.776833] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
[ 8.785184] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.793944] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[ 8.795713] usbcore: registered new interface driver hub
[ 8.801128] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[ 8.813665] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.823371] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 8.831443] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.841317] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[ 8.850064] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.860651] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 8.867915] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.879382] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 8.888666] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
[ 8.899288] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
[ 8.906396] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[ 8.917619] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.925828] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
[ 8.931290] usbcore: registered new device driver usb
[ 8.941746] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 25/Dec/2023 SHA:402d4744
[ 8.952703] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2
[ 8.965450] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 25/Dec/2023 SHA:402d4744
[ 8.976488] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 8.988136] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
[ 8.989287] remoteproc remoteproc8: b034000.pru is available
[ 9.024739] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[ 9.034493] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0
[ 9.042315] remoteproc remoteproc9: b004000.rtu is available
[ 9.054480] remoteproc remoteproc10: b00a000.txpru is available
[ 9.060417] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[ 9.061237] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
[ 9.072884] remoteproc remoteproc11: b038000.pru is available
[ 9.113002] remoteproc remoteproc12: b006000.rtu is available
[ 9.116707] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
[ 9.120534] remoteproc remoteproc13: b00c000.txpru is available
[ 9.130920] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1
[ 9.145409] remoteproc remoteproc14: b134000.pru is available
[ 9.146104] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
[ 9.163034] remoteproc remoteproc15: b104000.rtu is available
[ 9.169167] remoteproc remoteproc16: b10a000.txpru is available
[ 9.175372] remoteproc remoteproc17: b138000.pru is available
[ 9.181441] remoteproc remoteproc18: b106000.rtu is available
[ 9.187474] remoteproc remoteproc19: b10c000.txpru is available
[ 9.198658] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ 9.826155] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 9.831710] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 9.839459] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 9.848871] xhci-hcd xhci-hcd.0.auto: irq 658, io mem 0x06410000
[ 9.855055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 9.863316] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.870527] usb usb1: Product: xHCI Host Controller
[ 9.875395] usb usb1: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
[ 9.882004] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 9.887140] hub 1-0:1.0: USB hub found
[ 9.890954] hub 1-0:1.0: 1 port detected
[ 9.895077] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 9.900565] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 9.908237] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 9.914789] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 9.922926] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 9.931178] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.938387] usb usb2: Product: xHCI Host Controller
[ 9.943263] usb usb2: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
[ 9.949865] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 9.954975] hub 2-0:1.0: USB hub found
[ 9.958740] hub 2-0:1.0: 1 port detected
[ 10.626060] Bluetooth: Core ver 2.22
[ 10.632036] NET: Registered protocol family 31
[ 10.639964] Bluetooth: HCI device and connection manager initialized
[ 10.651709] Bluetooth: HCI socket layer initialized
[ 10.660867] Bluetooth: L2CAP socket layer initialized
[ 10.670548] Bluetooth: SCO socket layer initialized
[ 10.719875] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
[ 10.786944] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libidn2-0
libidn2-dev
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring-dev
libunistring2
m4-dev
m4
make
nettle-dev
nettle
parted
python3-rfc3987
tar
which
zeromq
[ OK ] Started weston.service.
Starting DEMO...
Starting telnetd.service...
[ OK ] Started DEMO.
[ OK ] Started telnetd.service.
[ 14.339900] PVR_K: 849: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[ 14.364128] PVR_K: 849: Shader binary image 'rgx.sh.22.104.208.318' loaded
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j7-evm ttyS2
Arago 2021.09 j7-evm ttyS2
j7-evm login:
Can you give us some advice?
Zhang
