HI,TI
We found a TDA4VM custom board keep repeated restarting. And we put SD on the other boards, it's OK. The restart log as follows:
See 'systemctl status sync-clocks.service' for details. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project j7-evm ttyS2 Arago 2021.09 j7-evm ttyS2 j7-evm login: root root@j7-evm:~# þÿÿÿ U-Boot 2021.01 (Jan 11 2024 - 19:21:21 +0800) SoC: J721E SR1.1 GP Model: Texas Instruments K3 J721E SoC EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Board: J721EX-PM1-SOM rev E2 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 cdns,sierra serdes@5000000: sierra probed Net: Could not get PHY for ethernet@46000000port@1: addr 0 am65_cpsw_nuss_port ethernet@46000000port@1: phy_connect() failed No ethernet found. ota_init bootfirst=0, trycount=255, bootpart=1:2 normal boot switch to success partion: Saving Environment to FAT... OK Hit any key to stop autoboot: 0 failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V switch to partitions #0, OK mmc1 is current device failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 10 ms (0 Bytes/s) Already setup. GPIO: 'gpio@22_17' not found Command 'gpio' failed: Error -22 GPIO: 'gpio@22_16' not found Command 'gpio' failed: Error -22 k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 1424760 bytes read in 72 ms (18.9 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 1424760 bytes: Success! 302028 bytes read in 26 ms (11.1 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success! Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' 1334036 bytes read in 68 ms (18.7 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1334036 bytes: Success! 1334036 bytes read in 68 ms (18.7 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1334036 bytes: Success! 12849048 bytes read in 217 ms (56.5 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 12849048 bytes: Success! 19079680 bytes read in 797 ms (22.8 MiB/s) 108084 bytes read in 14 ms (7.4 MiB/s) 11663 bytes read in 11 ms (1 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee2000, end 000000008fffffff ... OK Starting kernel ... failed to set vqmmc-voltage to 3.3V failed to set vqmmc-voltage to 3.3V [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.162-g76b3e88d56 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Fri Mar 3 23:00:40 UTC 2023 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=bc6f892c-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 1696388K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1973628K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008420] Console: colour dummy device 80x25 [ 0.012985] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023655] pid_max: default: 32768 minimum: 301 [ 0.028413] LSM: Security Framework initializing [ 0.033170] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040749] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049599] rcu: Hierarchical SRCU implementation. [ 0.054674] Platform MSI: msi-controller@1820000 domain created [ 0.060929] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070234] EFI services will not be available. [ 0.074960] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088318] Detected PIPT I-cache on CPU1 [ 0.088342] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088354] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000 [ 0.088390] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088442] smp: Brought up 1 node, 2 CPUs [ 0.117788] SMP: Total of 2 processors activated. [ 0.122594] CPU features: detected: 32-bit EL0 Support [ 0.127850] CPU features: detected: CRC32 instructions [ 0.142063] CPU: All CPU(s) started at EL2 [ 0.146258] alternatives: patching kernel code [ 0.151309] devtmpfs: initialized [ 0.160408] KASLR disabled due to lack of seed [ 0.165059] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.175023] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.189709] pinctrl core: initialized pinctrl subsystem [ 0.195367] DMI not present or invalid. [ 0.199620] NET: Registered protocol family 16 [ 0.205021] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.212333] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.220347] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.228657] thermal_sys: Registered thermal governor 'step_wise' [ 0.228660] thermal_sys: Registered thermal governor 'power_allocator' [ 0.235236] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.248874] ASID allocator initialised with 65536 entries [ 0.270205] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.277063] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.283908] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.290754] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.298221] cryptd: max_cpu_qlen set to 1000 [ 0.304305] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.313116] vsys_3v3: supplied by evm_12v0 [ 0.317509] vsys_5v0: supplied by evm_12v0 [ 0.321856] vdd_mmc1: supplied by vsys_3v3 [ 0.326606] iommu: Default domain type: Translated [ 0.331731] SCSI subsystem initialized [ 0.335756] mc: Linux media interface: v0.10 [ 0.340125] videodev: Linux video capture interface: v2.00 [ 0.345753] pps_core: LinuxPPS API ver. 1 registered [ 0.350825] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.360165] PTP clock support registered [ 0.364184] EDAC MC: Ver: 3.0.0 [ 0.367979] FPGA manager framework [ 0.371490] Advanced Linux Sound Architecture Driver Initialized. [ 0.378104] clocksource: Switched to clocksource arch_sys_counter [ 0.384425] VFS: Disk quotas dquot_6.6.0 [ 0.388459] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.398117] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.404403] NET: Registered protocol family 2 [ 0.409148] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.417781] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.426541] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.434745] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.442554] TCP: Hash tables configured (established 32768 bind 32768) [ 0.449356] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.456248] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.463651] NET: Registered protocol family 1 [ 0.468377] RPC: Registered named UNIX socket transport module. [ 0.474434] RPC: Registered udp transport module. [ 0.479250] RPC: Registered tcp transport module. [ 0.484053] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.490635] NET: Registered protocol family 44 [ 0.495183] PCI: CLS 0 bytes, default 64 [ 0.499582] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.509994] Initialise system trusted keyrings [ 0.514634] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.522802] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.529013] NFS: Registering the id_resolver key type [ 0.534202] Key type id_resolver registered [ 0.538475] Key type id_legacy registered [ 0.542593] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.549441] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.557083] 9p: Installing v9fs 9p2000 file system support [ 0.582401] Key type asymmetric registered [ 0.586587] Asymmetric key parser 'x509' registered [ 0.591585] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.599144] io scheduler mq-deadline registered [ 0.603770] io scheduler kyber registered [ 0.609381] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.615556] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.624319] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.630753] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.638759] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.645181] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.653123] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.659541] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.667471] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.673797] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.681751] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.688079] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.697705] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.705866] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.714096] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.721275] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.729944] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.743044] brd: module loaded [ 0.749557] loop: module loaded [ 0.753343] megasas: 07.714.04.00-rc1 [ 0.758984] tun: Universal TUN/TAP device driver, 1.6 [ 0.764430] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.770840] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.776916] sky2: driver version 1.30 [ 0.781154] VFIO - User Level meta-driver version: 0.3 [ 0.786898] i2c /dev entries driver [ 0.791296] sdhci: Secure Digital Host Controller Interface driver [ 0.797634] sdhci: Copyright(c) Pierre Ossman [ 0.802293] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.808636] ledtrig-cpu: registered to indicate activity on CPUs [ 0.814959] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.822312] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.826867] optee: revision 3.20 (8e74d476) [ 0.843278] optee: dynamic shared memory is enabled [ 0.852738] optee: initialized driver [ 0.857833] NET: Registered protocol family 17 [ 0.862456] 9pnet: Installing 9P2000 support [ 0.866856] Key type dns_resolver registered [ 0.871309] Loading compiled-in X.509 certificates [ 0.883197] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') [ 0.947332] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.954960] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz [ 0.961388] pca953x 1-0022: supply vcc not found, using dummy regulator [ 0.968215] pca953x 1-0022: using AI [ 0.994723] gpio-496 (PRG1_RGMII_INT): hogged as output/high [ 1.000700] gpio-497 (PRG0_RGMII_INT): hogged as output/high [ 1.006676] gpio-499 (ENET_RGMII_PWRDN_EN): hogged as output/high [ 1.013095] gpio-500 (VSYS_1V0_CSI_EN): hogged as output/high [ 1.019158] gpio-501 (HDMI_PWRDN_EN): hogged as output/high [ 1.025043] gpio-502 (CSI_PWRDN_EN1): hogged as output/high [ 1.030931] gpio-503 (CSI_PWRDN_EN2): hogged as output/high [ 1.037082] gpio-506 (VSYS_3V3_PCIE2_EN): hogged as output/high [ 1.043323] gpio-507 (EXP_3V3_WIFI_EN): hogged as output/high [ 1.049385] gpio-508 (MAX96712_STB): hogged as output/high [ 1.055185] gpio-509 (MAX96712_STB1): hogged as output/high [ 1.061071] gpio-510 (LT9611_RST): hogged as output/high [ 1.066690] gpio-511 (GPS_PWR_EN): hogged as output/high [ 1.072356] omap_i2c 2060000.i2c: bus 1 rev0.12 at 400 kHz [ 1.078922] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.088930] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.097749] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.107674] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.127284] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.134985] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.143263] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.151540] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.170873] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.177299] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.182905] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.192595] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.199649] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.205787] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.215737] pci 0000:00:00.0: supports D1 [ 2.219831] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.225718] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [ 2.232744] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [ 2.244805] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.254883] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.261654] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit] [ 2.269127] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.274421] pcieport 0000:00:00.0: PME: Signaling with IRQ 56 [ 2.280931] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.288599] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.296875] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.305154] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.316557] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 3.322986] pci_bus 0001:00: root bus resource [bus 00-ff] [ 3.328593] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 3.338461] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 3.345507] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.351646] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 3.361577] pci 0001:00:00.0: supports D1 [ 3.365671] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 3.373562] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.383630] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 3.390396] pci 0001:00:00.0: PCI bridge to [bus 01] [ 3.395682] pcieport 0001:00:00.0: PME: Signaling with IRQ 59 [ 3.402629] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 3.412511] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 3.419271] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 3.428279] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 3.438431] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 3.445193] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 3.453198] printk: console [ttyS2] disabled [ 3.457596] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250 [ 3.466340] printk: console [ttyS2] enabled [ 3.466340] printk: console [ttyS2] enabled [ 3.474776] printk: bootconsole [ns16550a0] disabled [ 3.474776] printk: bootconsole [ns16550a0] disabled [ 3.485391] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 22, base_baud = 3000000) is a 8250 [ 3.494410] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 23, base_baud = 3000000) is a 8250 [ 3.503874] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 3.514383] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 3.524535] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 3.534773] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 3.545873] scsi host0: ufshcd [ 3.554941] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 3.664690] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 3.670787] mmc0: CQHCI version 5.10 [ 3.681239] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 3.688158] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 3.695019] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 3.701874] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 3.708716] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 3.718347] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 3.719404] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 3.736798] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 3.751152] spi-nor spi7.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 3.758044] spi-nor: probe of spi7.0 failed with error -2 [ 3.763984] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 3.778853] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 3.779296] mmc1: CQHCI version 5.10 [ 3.786205] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 3.798077] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 3.805409] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 3.812738] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 3.820063] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 3.844287] ALSA device list: [ 3.847276] No soundcards found. [ 3.859639] mmc0: Command Queue Engine enabled [ 3.864084] mmc0: new HS200 MMC card at address 0001 [ 3.869366] mmcblk0: mmc0:0001 S0J57X 29.6 GiB [ 3.874020] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB [ 3.880049] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB [ 3.886048] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0) [ 3.966767] cdns-ufshcd 4e84000.ufs: link startup failed 1 [ 3.972248] cdns-ufshcd 4e84000.ufs: UFS Host state=0 [ 3.977287] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0 [ 3.983538] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0 [ 3.989962] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0 [ 3.996819] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0 [ 4.003420] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0 [ 4.009757] cdns-ufshcd 4e84000.ufs: Clk gate=1 [ 4.014277] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0 [ 4.022435] cdns-ufshcd 4e84000.ufs: last intr at 3867541 us, last intr status=0x404 [ 4.030162] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0 [ 4.037627] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0 [ 4.046651] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0 [ 4.052642] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000 [ 4.058894] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000 [ 4.064972] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000 [ 4.071051] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0 [ 4.083212] host_regs: 00000000: 1587031f 00000000 00000210 00000000 [ 4.089550] host_regs: 00000010: 00000000 00000000 00000000 00000000 [ 4.095898] host_regs: 00000020: 00000000 00000470 00000000 00000000 [ 4.102237] host_regs: 00000030: 00000008 00000001 00000000 00000000 [ 4.108574] host_regs: 00000040: 00000000 00000000 00000000 00000000 [ 4.114911] host_regs: 00000050: 00000000 00000000 00000000 00000000 [ 4.121251] host_regs: 00000060: 00000000 00000000 00000000 00000000 [ 4.127588] host_regs: 00000070: 00000000 00000000 00000000 00000000 [ 4.133925] host_regs: 00000080: 00000000 00000000 00000000 00000000 [ 4.140263] host_regs: 00000090: 00000000 00000000 00000000 00000000 [ 4.146601] cdns-ufshcd 4e84000.ufs: No record of pa_err [ 4.151900] cdns-ufshcd 4e84000.ufs: No record of dl_err [ 4.157199] cdns-ufshcd 4e84000.ufs: No record of nl_err [ 4.162497] cdns-ufshcd 4e84000.ufs: No record of tl_err [ 4.167794] cdns-ufshcd 4e84000.ufs: No record of dme_err [ 4.173179] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err [ 4.179343] cdns-ufshcd 4e84000.ufs: No record of fatal_err [ 4.184902] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 3868664 us [ 4.192019] cdns-ufshcd 4e84000.ufs: No record of resume_fail [ 4.197749] cdns-ufshcd 4e84000.ufs: No record of suspend_fail [ 4.203567] cdns-ufshcd 4e84000.ufs: No record of dev_reset [ 4.209123] cdns-ufshcd 4e84000.ufs: No record of host_reset [ 4.214769] cdns-ufshcd 4e84000.ufs: No record of task_abort [ 4.846785] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 4.854659] Waiting for root device PARTUUID=bc6f892c-02... [ 4.910449] mmc1: new ultra high speed DDR50 SDHC card at address aaaa [ 4.917363] mmcblk1: mmc1:aaaa SD32G 29.7 GiB [ 4.923111] mmcblk1: p1 p2 [ 5.014825] EXT4-fs (mmcblk1p2): recovery complete [ 5.020377] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 5.028488] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 5.035979] devtmpfs: mounted [ 5.039832] Freeing unused kernel memory: 1856K [ 5.044463] Run /sbin/init as init process [ 5.245729] systemd[1]: System time before build time, advancing clock. [ 5.322177] NET: Registered protocol family 10 [ 5.327069] Segment Routing with IPv6 [ 5.361412] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 5.383143] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 5.418928] systemd[1]: Set hostname to <j7-evm>. [ 5.598616] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring. [ 5.621928] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly. [ 5.693751] random: systemd: uninitialized urandom read (16 bytes read) [ 5.702040] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 5.722242] random: systemd: uninitialized urandom read (16 bytes read) [ 5.729637] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 5.750184] random: systemd: uninitialized urandom read (16 bytes read) [ 5.757446] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 5.778316] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 5.802235] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 5.826224] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 5.842172] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 5.862161] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 5.878164] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 5.907622] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 5.930266] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 5.952629] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 5.974325] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 5.999798] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 6.008158] systemd[1]: Listening on Journal Socket (/dev/log).
Now we think the temperature sensor malfunctioned, because when the temperature is higher than 65 ° C(/sys/class/thermal/thermal_zone1/temp), a restart is triggered.
Could you give us some advices?
Zhang
Hi Zhang,
Is the reset periodic? I am suspecting any watchdog reset periodically. I am not sure if on that custom board some watchdog continuously is triggered?
How long does it take for the repeated resets?
Which SDK version is being used?
- Keerthy
