PROCESSOR-SDK-AM68A: SK-AM68A: edgeai model composer issue
Part Number: PROCESSOR-SDK-AM68A
I train and comile the Example Project by this link: https://dev.ti.com/modelcomposer/
for this Example Project(image Classification)
there is no error during training and compiling using the default parameters except for the target-board,
when i downloaded the trained model to the target board, it could't run normally, the kernle log as below,
but if i use another Example Project(Object Detection), there is no exception when i downloaded to the target board(SK-AM68A)
How to fix this issue? thanks
    Which SDK version do you have flashed onto your SD card? What training and compilation parameters did you use? Are you able to view the real time inference through the live preview tab? Have you attempted to run either of the models on the target? Could you share any logs that indicate failure?
    Thank you,
    Fabiana
