TDA4VM: sdk9.2 with imx390 (built-in isp)
Part Number: TDA4VM
hi ti
I have a problem, my current environment is J721EVM
And sub-board Fusion Application Board, the compilation environment is linux sdk 9.2, we're using an IMX390 with in-built ISP(imx390+5200+ub953)All ends up being yuv output, but the following question arises when configuring whether the environment now supports yuv output?
root@j721e-evm:/opt/edgeai-gst-apps# dmesg | grep "390"
[    3.753903] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    9.390948] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[   10.054370] imx390 7-001a: inck rate: 27027027 Hz
[   10.134815] imx390 7-001a: imx390_read: failed to read reg 0x0330: -121
[   10.144655] imx390: probe of 7-001a failed with error -121
  • If the output of senser is whether yuv 8bit is supported or not
  • Hello Zhiyong,
    Our expert handling this topic is currently out of the office; please expect a 1-2 day delay in response.
    Thanks.
  • Hello Zhiyong,
    YUV format is supported. Please keep in mind that we currently do not support IMX390 with built-in ISP. For more information on what will be required to enable IMX390 with built-in ISP, see the following thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1233573/sk-am62a-lp-debug-about-csi2rx
    Thank you,
    Fabiana
  • e2e.ti.com/.../quote]
    Thank you very much, I have changed the connection and used gst-launch-1.0v4l2src device="/dev/video18"! video/x-raw, width=1920, height=1080, format=UYVY ! autovideosink command, it can be successfully displayed on the dp screen, but I do not understand this command, media-ctl-R '" 45000000.ticsi2rx "[0/0 -> 1/0 [1]]' and media-ctl-R '"ds90ub960 9-003d" [0/0 -> 4/0 [1]]' if I'm on route 4 How should this command be set, and what do the parameters mean? Also, because it is my own isp, I configured a fake 390. Do you have a demo code that allows me to get buffer and save it
  • Hi Zhiyong,
    Could you start by sharing the output of media-ctl -p?
    Thank you,
    Fabiana
  • C
    root@j7-evm:/opt/edgeai-gst-apps# ^C
    root@j7-evm:/opt/edgeai-gst-apps# media-ctl -p
    Media controller API version 5.10.162
    Media device information
    driver          j721e-csi2rx
    model           TI-CSI2RX
    serial
    bus info        platform:4500000.ticsi2rx
    hw revision     0x1
    driver version  5.10.162
    Device topology
    - entity 1: 4500000.ticsi2rx (17 pads, 17 links, 1 route)
                type V4L2 subdev subtype Unknown flags 0
                device node name /dev/v4l-subdev3
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
                    <- "cdns_csi2rx.4504000.csi-bridge":1 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4500000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
            pad2: Source
                    -> "4500000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
            pad3: Source
                    -> "4500000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
            pad4: Source
                    -> "4500000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
            pad5: Source
                    -> "4500000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
            pad6: Source
                    -> "4500000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
            pad7: Source
                    -> "4500000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE]
            pad8: Source
                    -> "4500000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE]
            pad9: Source
                    -> "4500000.ticsi2rx context 8":0 [ENABLED,IMMUTABLE]
            pad10: Source
                    -> "4500000.ticsi2rx context 9":0 [ENABLED,IMMUTABLE]
            pad11: Source
                    -> "4500000.ticsi2rx context 10":0 [ENABLED,IMMUTABLE]
            pad12: Source
                    -> "4500000.ticsi2rx context 11":0 [ENABLED,IMMUTABLE]
            pad13: Source
                    -> "4500000.ticsi2rx context 12":0 [ENABLED,IMMUTABLE]
            pad14: Source
                    -> "4500000.ticsi2rx context 13":0 [ENABLED,IMMUTABLE]
            pad15: Source
                    -> "4500000.ticsi2rx context 14":0 [ENABLED,IMMUTABLE]
            pad16: Source
                    -> "4500000.ticsi2rx context 15":0 [ENABLED,IMMUTABLE]
    - entity 19: cdns_csi2rx.4504000.csi-bridge (5 pads, 2 links, 0 route)
                 device node name /dev/v4l-subdev4
            pad0: Sink
                    <- "ds90ub960 9-003d":4 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "4500000.ticsi2rx":0 [ENABLED,IMMUTABLE]
            pad2: Source
            pad3: Source
            pad4: Source
    - entity 25: ds90ub960 9-003d (6 pads, 2 links, 1 route)
                 device node name /dev/v4l-subdev5
            routes:
                    0/0 -> 4/0 [ACTIVE]
            pad0: Sink
                    [stream:0 fmt:UYVY8_2X8/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
                    <- "ds90ub953 9-0044":1 [ENABLED,IMMUTABLE]
            pad1: Sink
            pad2: Sink
            pad3: Sink
            pad4: Source
                    -> "cdns_csi2rx.4504000.csi-bridge":0 [ENABLED,IMMUTABLE]
            pad5: Source
    - entity 34: ds90ub953 9-0044 (2 pads, 2 links, 1 route)
                 device node name /dev/v4l-subdev6
            routes:
                    0/0 -> 1/0 [ACTIVE]
            pad0: Sink
                    <- "imx390dummy 10-0021":0 [ENABLED,IMMUTABLE]
            pad1: Source
                    -> "ds90ub960 9-003d":0 [ENABLED,IMMUTABLE]
    - entity 39: imx390dummy 10-0021 (1 pad, 1 link, 2 routes)
                 type V4L2 subdev subtype Sensor flags 0
                 device node name /dev/v4l-subdev7
            routes:
                    0/0 -> 0/0 [ACTIVE, IMMUTABLE, SOURCE]
                    0/0 -> 0/1 [INACTIVE, IMMUTABLE, SOURCE]
            pad0: Source
                    [stream:0 fmt:UYVY8_2X8/1920x1080@1/30 field:none colorspace:smpte170m]
                    -> "ds90ub953 9-0044":0 [ENABLED,IMMUTABLE]
    - entity 45: 4500000.ticsi2rx context 0 (1 pad, 1 link, 0 route)
                 type Node subtype V4L flags 0
                 device node name /dev/video18
            pad0: Sink
                    <- "4500000.ticsi2rx":1 [ENABLED,IMMUTABLE]
    - entity 51: 4500000.ticsi2rx context 1 (1 pad, 1 link, 0 route)
                 device node name /dev/video19
            pad0: Sink
                    <- "4500000.ticsi2rx":2 [ENABLED,IMMUTABLE]
    - entity 57: 4500000.ticsi2rx context 2 (1 pad, 1 link, 0 route)
                 device node name /dev/video20
            pad0: Sink
                    <- "4500000.ticsi2rx":3 [ENABLED,IMMUTABLE]
    - entity 63: 4500000.ticsi2rx context 3 (1 pad, 1 link, 0 route)
                 device node name /dev/video21
            pad0: Sink
                    <- "4500000.ticsi2rx":4 [ENABLED,IMMUTABLE]
    - entity 69: 4500000.ticsi2rx context 4 (1 pad, 1 link, 0 route)
                 device node name /dev/video22
            pad0: Sink
                    <- "4500000.ticsi2rx":5 [ENABLED,IMMUTABLE]
    - entity 75: 4500000.ticsi2rx context 5 (1 pad, 1 link, 0 route)
                 device node name /dev/video23
            pad0: Sink
                    <- "4500000.ticsi2rx":6 [ENABLED,IMMUTABLE]
    - entity 81: 4500000.ticsi2rx context 6 (1 pad, 1 link, 0 route)
                 device node name /dev/video24
            pad0: Sink
                    <- "4500000.ticsi2rx":7 [ENABLED,IMMUTABLE]
    - entity 87: 4500000.ticsi2rx context 7 (1 pad, 1 link, 0 route)
                 device node name /dev/video25
            pad0: Sink
                    <- "4500000.ticsi2rx":8 [ENABLED,IMMUTABLE]
    - entity 93: 4500000.ticsi2rx context 8 (1 pad, 1 link, 0 route)
                 device node name /dev/video26
            pad0: Sink
                    <- "4500000.ticsi2rx":9 [ENABLED,IMMUTABLE]
    - entity 99: 4500000.ticsi2rx context 9 (1 pad, 1 link, 0 route)
                 device node name /dev/video27
            pad0: Sink
                    <- "4500000.ticsi2rx":10 [ENABLED,IMMUTABLE]
    - entity 105: 4500000.ticsi2rx context 10 (1 pad, 1 link, 0 route)
                  device node name /dev/video28
            pad0: Sink
                    <- "4500000.ticsi2rx":11 [ENABLED,IMMUTABLE]
    - entity 111: 4500000.ticsi2rx context 11 (1 pad, 1 link, 0 route)
                  device node name /dev/video29
            pad0: Sink
                    <- "4500000.ticsi2rx":12 [ENABLED,IMMUTABLE]
    - entity 117: 4500000.ticsi2rx context 12 (1 pad, 1 link, 0 route)
                  device node name /dev/video30
            pad0: Sink
                    <- "4500000.ticsi2rx":13 [ENABLED,IMMUTABLE]
    - entity 123: 4500000.ticsi2rx context 13 (1 pad, 1 link, 0 route)
                  device node name /dev/video31
            pad0: Sink
                    <- "4500000.ticsi2rx":14 [ENABLED,IMMUTABLE]
    - entity 129: 4500000.ticsi2rx context 14 (1 pad, 1 link, 0 route)
                  device node name /dev/video32
            pad0: Sink
                    <- "4500000.ticsi2rx":15 [ENABLED,IMMUTABLE]
    - entity 135: 4500000.ticsi2rx context 15 (1 pad, 1 link, 0 route)
                  device node name /dev/video33
            pad0: Sink
                    <- "4500000.ticsi2rx":16 [ENABLED,IMMUTABLE]
    root@j7-evm:/opt/edgeai-gst-apps# gst-launch-1.0 v4l2src device="/dev/video18" ! video/x-raw, width=1920, height=1080, format=UYVY ! autovideosink
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Setting pipeline to PLAYING ...
    New clock: GstSystemClock
    ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
    Additional debug info:
    ../gst-plugins-good-1.16.3/sys/v4l2/gstv4l2src.c(660): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
    Buffer pool activation failed
    Execution ended after 0:00:00.007780540
    Setting pipeline to NULL ...
    Freeing pipeline ...
    root@j7-evm:/opt/edgeai-gst-apps# media-ctl -V '"ds90ub953 9-0044":0 [fmt:UYVY8_2X8/1920x1080 field: none]'
    csi2rx" [0/0 -> 1/0 [1]]'root@j7-evm:/opt/edgeai-gst-apps# media-ctl -R '"ds90ub960 9-003d" [0/0 -> 4/0 [1]]'
    root@j7-evm:/opt/edgeai-gst-apps# media-ctl -V '"ds90ub960 9-003d":0 [fmt:UYVY8_2X8/1920x1080 field: none]'
    root@j7-evm:/opt/edgeai-gst-apps# media-ctl -R '"4500000.ticsi2rx" [0/0 -> 1/0 [1]]'
    ^Chandling interrupt.
    Interrupt: Stopping pipeline ...
    Execution ended after 0:00:03.768887860
  • hi jaimes;
    I have another problem, I tried to write an application layer program, get buffer code as follows
    struct v4l2_format vfmt;
    vfmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; // Camera capture
    vfmt.fmt.pix.width = 1920; // Set camera acquisition parameters, not arbitrary Settings
    vfmt.fmt.pix.height = 1080;
    vfmt.fmt.pix.pixelformat = V4L2_PIX_FMT_YUYV;
    perror("2\n");
    int ret = ioctl(fd, VIDIOC_S_FMT, &vfmt);
    if (ret < 0) {
    perror(" Formatting failed 1");
    return -1;
    The PROBLEM is always in VIDIOC_S_FMT error, I check the format size and format because of the problem
    #include <fcntl.h>
    #include <linux/videodev2.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include <sys/ioctl.h>
    #include <sys/mman.h>
    #include <sys/stat.h>
    #include <sys/types.h>
    #include <unistd.h>
    int main(void) {
      int fd = open("/dev/video18", O_RDWR);
      if (fd < 0) {
        perror("打开设备失败");
        return -1;
      perror("1\n");
      // 获取摄像头支持格式 ioctl(文件描述符,命令,与命令对应的结构体)
      vfmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; // 摄像头采集
      vfmt.fmt.pix.width = 1920; // 设置摄像头采集参数,不可以任意设置
      perror("2\n");
      if (ret < 0) {
        perror("设置格式失败1");
        return -1;
      perror("3\n");
      // 申请内核空间
      struct v4l2_requestbuffers reqbuffer;
      reqbuffer.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
      reqbuffer.count = 4;                 // 申请4个缓冲区
      reqbuffer.memory = V4L2_MEMORY_MMAP; // 映射方式
      ret = ioctl(fd, VIDIOC_REQBUFS, &reqbuffer);
      if (ret < 0) {
        perror("申请空间失败");
        return -1;
      perror("4\n");
      // 映射
      unsigned char *mptr[4]; // 保存映射后用户空间的首地址
      unsigned int size[4];
      struct v4l2_buffer mapbuffer;
      // 初始化type和index
      mapbuffer.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
      for (int i = 0; i < 4; i++) {
        perror("5\n");
        mapbuffer.index = i;
        ret = ioctl(fd, VIDIOC_QUERYBUF,
                    &mapbuffer); // 从内核空间中查询一个空间作映射
        if (ret < 0) {
          perror("查询内核空间失败");
        return -1;
        // 映射到用户空间
        mptr[i] =
            (unsigned char *)mmap(NULL, mapbuffer.length, PROT_READ | PROT_WRITE,
                                  MAP_SHARED, fd, mapbuffer.m.offset);
        size[i] = mapbuffer.length; // 保存映射长度用于后期释放
        // 查询后通知内核已经放回
        ret = ioctl(fd, VIDIOC_QBUF, &mapbuffer);
        if (ret < 0) {
          perror("放回失败");
        return -1;
      // 开始采集
      int type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
      ret = ioctl(fd, VIDIOC_STREAMON, &type);
      if (ret < 0) {
        perror("开启失败");
        return -1;
      // 从队列中提取一帧数据
      struct v4l2_buffer readbuffer;
      readbuffer.type =
          V4L2_BUF_TYPE_VIDEO_CAPTURE; // 每个结构体都需要设置type为这个参赛要记住
      ret = ioctl(fd, VIDIOC_DQBUF, &readbuffer);
      if (ret < 0) {
        perror("读取数据失败");
        return -1;
      FILE *file = fopen("my.jpg", "w+"); // 打开一个文件
      fwrite(mptr[readbuffer.index], readbuffer.length, 1, file); // 写入文件
      fclose(file); // 写入完成,关闭文件
      perror("6\n");
      // 通知内核使用完毕
      ret = ioctl(fd, VIDIOC_QBUF, &readbuffer);
      if (ret < 0) {
        perror("放回队列失败");
        return -1;
      // 停止采集
      ret = ioctl(fd, VIDIOC_STREAMOFF, &type);
      perror("7\n");
      // 释放映射
        munmap(mptr[i], size[i]);
      perror("8\n");
      close(fd); // 关闭文件
      return 0;
    I recommend including your new sensor to /opt/edgeai-gst-apps/scripts/setup_cameras.sh to setup the camera for you upon boot. setup_ov5640() would be a good example to look at since OV5640 also has built-in ISP.
    We do not offer application development support. I recommend looking into external online resources for this.
    Thank you,
    Fabiana
