TDA4VM: Edgeai: Calibration issue with Batch Normalization layer implemented for constant multiply broadcast.
Part Number: TDA4VM
We are trying to run out model on EdgeAI 9.20.07 https://github.com/TexasInstruments/edgeai-tidl-tools/tree/09_02_07_00?tab=readme-ov-file.
There is a problem with the int16/int8 quantization calibration when multiply broadcast with a constant is implemented with Batch Normalization as is done in SDK9.2. The first quantized calibration iteration runs fine, but in the second iteration the multiply broadcast layer returns all zeros and in the third iteration it returns all -1s.
Please Note that the above problem doesn't occur when the constant multiply broadcast is implemented as element wise layer.
7457.4_fnc_int16.txt
  • Please validate the observation on latest tidl tools SDK tag : 9.2.9.0
  • EdgeAI default tidl_tools have never worked for us, EdgeAI 9.2.9 https://github.com/TexasInstruments/edgeai-tidl-tools/tree/09_02_09_00 also doesn't work for us. It gives error, free(): double free detected in tcache 2.
    ***** WARNING : tensor_bits = 32 -- Compiling for floating point - target execution is not supported for 32 bit compilation !! *****
    tidl_tools_path                                 = /home/deepanshu/EdgeAI/new/edgeai-tidl-tools/tidl_tools
    artifacts_folder                                = ../../../model-artifacts//fnc_safety_fp32/
    tidl_tensor_bits                                = 32
    debug_level                                     = 4
    num_tidl_subgraphs                              = 16
    tidl_denylist                                   =
    tidl_denylist_layer_name                        =
    tidl_denylist_layer_type                         =
    tidl_allowlist_layer_name                        =
    model_type                                      =
    tidl_calibration_accuracy_level                 = 7
    tidl_calibration_options:num_frames_calibration = 3
    tidl_calibration_options:bias_calibration_iterations = 3
    mixed_precision_factor = -1.000000
    model_group_id = 0
    power_of_2_quantization                         = 2
    ONNX QDQ Enabled                                = 0
    enable_high_resolution_optimization             = 0
    pre_batchnorm_fold                              = 1
    add_data_convert_ops                            = 3
    output_feature_16bit_names_list                 =
    m_params_16bit_names_list                       =
    m_single_core_layers_names_list                    =
    reserved_compile_constraints_flag               = 1601
    ti_internal_reserved_1                          =
    WARNING : 'meta_layers_names_list' is not provided - running OD post processing in ARM mode
    Number of OD backbone nodes = 0
    Size of odBackboneNodeIds = 0
    Layer 0 -- layer name -- Conv_0
     Input dims size = 4     dims --- 1   3   320   800
    Supported TIDL layer type ---            Conv -- Conv_0
    Layer 1 -- layer name -- Relu_1
     Input dims size = 4     dims --- 1   64   160   400
    Supported TIDL layer type ---            Relu -- Relu_1
    Layer 2 -- layer name -- MaxPool_2
    Supported TIDL layer type ---         MaxPool -- MaxPool_2
    Layer 3 -- layer name -- Conv_3
     Input dims size = 4     dims --- 1   64   80   200
    Supported TIDL layer type ---            Conv -- Conv_3
    Layer 4 -- layer name -- Relu_4
    Supported TIDL layer type ---            Relu -- Relu_4
    Layer 5 -- layer name -- Conv_5
    Supported TIDL layer type ---            Conv -- Conv_5
    Layer 6 -- layer name -- Add_6
    Supported TIDL layer type ---             Add -- Add_6
    Layer 7 -- layer name -- Relu_7
    Supported TIDL layer type ---            Relu -- Relu_7
    Layer 8 -- layer name -- Conv_8
    Supported TIDL layer type ---            Conv -- Conv_8
    Layer 9 -- layer name -- Relu_9
    Supported TIDL layer type ---            Relu -- Relu_9
    Layer 10 -- layer name -- Conv_10
    Supported TIDL layer type ---            Conv -- Conv_10
    Layer 11 -- layer name -- Add_11
    Supported TIDL layer type ---             Add -- Add_11
    Layer 12 -- layer name -- Relu_12
    Supported TIDL layer type ---            Relu -- Relu_12
    Layer 13 -- layer name -- Conv_13
    Supported TIDL layer type ---            Conv -- Conv_13
    Layer 14 -- layer name -- Relu_14
     Input dims size = 4     dims --- 1   128   40   100
    Supported TIDL layer type ---            Relu -- Relu_14
    Layer 15 -- layer name -- Conv_15
    Supported TIDL layer type ---            Conv -- Conv_15
    Layer 16 -- layer name -- Conv_16
    Supported TIDL layer type ---            Conv -- Conv_16
    Layer 17 -- layer name -- Add_17
    Supported TIDL layer type ---             Add -- Add_17
    Layer 18 -- layer name -- Relu_18
    Supported TIDL layer type ---            Relu -- Relu_18
    Layer 19 -- layer name -- Conv_19
    Supported TIDL layer type ---            Conv -- Conv_19
    Layer 20 -- layer name -- Relu_20
    Supported TIDL layer type ---            Relu -- Relu_20
    Layer 21 -- layer name -- Conv_21
    Supported TIDL layer type ---            Conv -- Conv_21
    Layer 22 -- layer name -- Add_22
    Supported TIDL layer type ---             Add -- Add_22
    Layer 23 -- layer name -- Relu_23
    Supported TIDL layer type ---            Relu -- Relu_23
    Layer 24 -- layer name -- Conv_24
    Supported TIDL layer type ---            Conv -- Conv_24
    Layer 25 -- layer name -- Relu_25
     Input dims size = 4     dims --- 1   256   20   50
    Supported TIDL layer type ---            Relu -- Relu_25
    Layer 26 -- layer name -- Conv_26
    Supported TIDL layer type ---            Conv -- Conv_26
    Layer 27 -- layer name -- Conv_27
    Supported TIDL layer type ---            Conv -- Conv_27
    Layer 28 -- layer name -- Add_28
    Supported TIDL layer type ---             Add -- Add_28
    Layer 29 -- layer name -- Relu_29
    Supported TIDL layer type ---            Relu -- Relu_29
    Layer 30 -- layer name -- Conv_30
    Supported TIDL layer type ---            Conv -- Conv_30
    Layer 31 -- layer name -- Relu_31
    Supported TIDL layer type ---            Relu -- Relu_31
    Layer 32 -- layer name -- Conv_32
    Supported TIDL layer type ---            Conv -- Conv_32
    Layer 33 -- layer name -- Add_33
    Supported TIDL layer type ---             Add -- Add_33
    Layer 34 -- layer name -- Relu_34
    Supported TIDL layer type ---            Relu -- Relu_34
    Layer 35 -- layer name -- Conv_35
    Supported TIDL layer type ---            Conv -- Conv_35
    Layer 36 -- layer name -- Relu_36
     Input dims size = 4     dims --- 1   512   10   25
    Supported TIDL layer type ---            Relu -- Relu_36
    Layer 37 -- layer name -- Conv_37
    Supported TIDL layer type ---            Conv -- Conv_37
    Layer 38 -- layer name -- Conv_38
    Supported TIDL layer type ---            Conv -- Conv_38
    Layer 39 -- layer name -- Add_39
    Supported TIDL layer type ---             Add -- Add_39
    Layer 40 -- layer name -- Relu_40
    Supported TIDL layer type ---            Relu -- Relu_40
    Layer 41 -- layer name -- Conv_41
    Supported TIDL layer type ---            Conv -- Conv_41
    Layer 42 -- layer name -- Relu_42
    Supported TIDL layer type ---            Relu -- Relu_42
    Layer 43 -- layer name -- Conv_43
    Supported TIDL layer type ---            Conv -- Conv_43
    Layer 44 -- layer name -- Add_44
    Supported TIDL layer type ---             Add -- Add_44
    Layer 45 -- layer name -- Relu_45
    Supported TIDL layer type ---            Relu -- Relu_45
    Layer 46 -- layer name -- Conv_46
    Supported TIDL layer type ---            Conv -- Conv_46
    Layer 47 -- layer name -- Relu_47
     Input dims size = 4     dims --- 1   64   10   25
    Supported TIDL layer type ---            Relu -- Relu_47
    Layer 48 -- layer name -- Add_58
    Supported TIDL layer type ---             Add -- Add_58
    Layer 49 -- layer name -- Conv_59
    Supported TIDL layer type ---            Conv -- Conv_59
    Layer 50 -- layer name -- Reshape_64
     Input dims size = 4     dims --- 1   16   10   25
    Supported TIDL layer type ---         Reshape -- Reshape_64
    Layer 51 -- layer name -- Transpose_65
     Input dims size = 3     dims --- 1   16   250
    Supported TIDL layer type ---       Transpose -- Transpose_65
    Layer 52 -- layer name -- Conv_66
    Supported TIDL layer type ---            Conv -- Conv_66
    Layer 53 -- layer name -- Reshape_71
    Supported TIDL layer type ---         Reshape -- Reshape_71
    Layer 54 -- layer name -- MatMul_72
     Input dims size = 3     dims --- 1   250   16
    Supported TIDL layer type ---          MatMul -- MatMul_72
    Layer 55 -- layer name -- reshape_Unsqueeze_73
     Input dims size = 3     dims --- 1   250   250
    Supported TIDL layer type ---         Reshape -- reshape_Unsqueeze_73
    Layer 56 -- layer name -- Softmax_74
     Input dims size = 4     dims --- 1   1   250   250
    Supported TIDL layer type ---         Softmax -- Softmax_74
    Layer 57 -- layer name -- Squeeze_75
    Supported TIDL layer type ---         Squeeze -- Squeeze_75
    Layer 58 -- layer name -- Transpose_76
    Supported TIDL layer type ---       Transpose -- Transpose_76
    Layer 59 -- layer name -- Conv_77
    Supported TIDL layer type ---            Conv -- Conv_77
    Layer 60 -- layer name -- Reshape_82
    Supported TIDL layer type ---         Reshape -- Reshape_82
    Layer 61 -- layer name -- MatMul_83
     Input dims size = 3     dims --- 1   64   250
    Supported TIDL layer type ---          MatMul -- MatMul_83
    Layer 62 -- layer name -- Reshape_88
    Supported TIDL layer type ---         Reshape -- Reshape_88
    Layer 63 -- layer name -- Mul_89
     Input dims size = 0     dims ---
    Supported TIDL layer type ---             Mul -- Mul_89
    Layer 64 -- layer name -- Add_90
    Supported TIDL layer type ---             Add -- Add_90
    Layer 65 -- layer name -- Conv_91
    Supported TIDL layer type ---            Conv -- Conv_91
    Layer 66 -- layer name -- Relu_92
    Supported TIDL layer type ---            Relu -- Relu_92
    Layer 67 -- layer name -- Conv_93
    Supported TIDL layer type ---            Conv -- Conv_93
    Layer 68 -- layer name -- Relu_94
    Supported TIDL layer type ---            Relu -- Relu_94
    Layer 69 -- layer name -- Add_105
    Supported TIDL layer type ---             Add -- Add_105
    Layer 70 -- layer name -- Conv_106
    Supported TIDL layer type ---            Conv -- Conv_106
    Layer 71 -- layer name -- Reshape_111
    Supported TIDL layer type ---         Reshape -- Reshape_111
    Layer 72 -- layer name -- Transpose_112
    Supported TIDL layer type ---       Transpose -- Transpose_112
    Layer 73 -- layer name -- Conv_113
    Supported TIDL layer type ---            Conv -- Conv_113
    Layer 74 -- layer name -- Reshape_118
    Supported TIDL layer type ---         Reshape -- Reshape_118
    Layer 75 -- layer name -- MatMul_119
    Supported TIDL layer type ---          MatMul -- MatMul_119
    Layer 76 -- layer name -- reshape_Unsqueeze_120
    Supported TIDL layer type ---         Reshape -- reshape_Unsqueeze_120
    Layer 77 -- layer name -- Softmax_121
    Supported TIDL layer type ---         Softmax -- Softmax_121
    Layer 78 -- layer name -- Squeeze_122
    Supported TIDL layer type ---         Squeeze -- Squeeze_122
    Layer 79 -- layer name -- Transpose_123
    Supported TIDL layer type ---       Transpose -- Transpose_123
    Layer 80 -- layer name -- Conv_124
    Supported TIDL layer type ---            Conv -- Conv_124
    Layer 81 -- layer name -- Reshape_129
    Supported TIDL layer type ---         Reshape -- Reshape_129
    Layer 82 -- layer name -- MatMul_130
    Supported TIDL layer type ---          MatMul -- MatMul_130
    Layer 83 -- layer name -- Reshape_135
    Supported TIDL layer type ---         Reshape -- Reshape_135
    Layer 84 -- layer name -- Mul_136
    Supported TIDL layer type ---             Mul -- Mul_136
    Layer 85 -- layer name -- Add_137
    Supported TIDL layer type ---             Add -- Add_137
    Layer 86 -- layer name -- Conv_138
    Supported TIDL layer type ---            Conv -- Conv_138
    Layer 87 -- layer name -- Relu_139
    Supported TIDL layer type ---            Relu -- Relu_139
    Layer 88 -- layer name -- Conv_142
    Supported TIDL layer type ---            Conv -- Conv_142
    Layer 89 -- layer name -- Upsample_143
    Supported TIDL layer type ---        Upsample -- Upsample_143
    Layer 90 -- layer name -- Conv_141
    Supported TIDL layer type ---            Conv -- Conv_141
    Layer 91 -- layer name -- Add_144
     Input dims size = 4     dims --- 1   64   20   50
    Supported TIDL layer type ---             Add -- Add_144
    Layer 92 -- layer name -- Conv_148
    Supported TIDL layer type ---            Conv -- Conv_148
    Layer 93 -- layer name -- Conv_152
    Supported TIDL layer type ---            Conv -- Conv_152
    Layer 94 -- layer name -- Relu_153
    Supported TIDL layer type ---            Relu -- Relu_153
    Layer 95 -- layer name -- Conv_154
    Supported TIDL layer type ---            Conv -- Conv_154
    Layer 96 -- layer name -- Sigmoid_170
     Input dims size = 4     dims --- 1   1   20   50
    Supported TIDL layer type ---         Sigmoid -- Sigmoid_170
    Layer 97 -- layer name -- Add_172
    Supported TIDL layer type ---             Add -- Add_172
    Layer 98 -- layer name -- Relu_173
    Supported TIDL layer type ---            Relu -- Relu_173
    Layer 99 -- layer name -- Add_175
    Supported TIDL layer type ---             Add -- Add_175
    Layer 100 -- layer name -- Mul_177
    Supported TIDL layer type ---             Mul -- Mul_177
    Layer 101 -- layer name -- Add_179
    Supported TIDL layer type ---             Add -- Add_179
    Layer 102 -- layer name -- Relu_180
    Supported TIDL layer type ---            Relu -- Relu_180
    Layer 103 -- layer name -- Mul_182
    Supported TIDL layer type ---             Mul -- Mul_182
    Layer 104 -- layer name -- Add_184
    Supported TIDL layer type ---             Add -- Add_184
    Layer 105 -- layer name -- MaxPool_204
    Supported TIDL layer type ---         MaxPool -- MaxPool_204
    Layer 106 -- layer name -- Mul_206
    Supported TIDL layer type ---             Mul -- Mul_206
    Layer 107 -- layer name -- Add_207
    Supported TIDL layer type ---             Add -- Add_207
    Layer 108 -- layer name -- Mul_209
    Supported TIDL layer type ---             Mul -- Mul_209
    Layer 109 -- layer name -- Add_211
    Supported TIDL layer type ---             Add -- Add_211
    Layer 110 -- layer name -- Relu_212
    Supported TIDL layer type ---            Relu -- Relu_212
    Layer 111 -- layer name -- Mul_214
    Supported TIDL layer type ---             Mul -- Mul_214
    Layer 112 -- layer name -- Mul_215
    Supported TIDL layer type ---             Mul -- Mul_215
    Layer 113 -- layer name -- Squeeze_216
    Supported TIDL layer type ---         Squeeze -- Squeeze_216
    Layer 114 -- layer name -- Reshape_218
     Input dims size = 3     dims --- 1   20   50
    Supported TIDL layer type ---         Reshape -- Reshape_218
    Layer 115 -- layer name -- TopK_219
     Input dims size = 1     dims --- 1000
    Unsupported (imports) TIDL layer type for ONNX op type --- TopK
    Layer 116 -- layer name -- Reshape_221
     Input dims size = 1     dims --- 6
    Supported TIDL layer type ---         Reshape -- Reshape_221
    Layer 117 -- layer name -- Squeeze_224
     Input dims size = 2     dims --- 6   1
    Supported TIDL layer type ---         Squeeze -- Squeeze_224
    Layer 118 -- layer name -- Conv_155
    Supported TIDL layer type ---            Conv -- Conv_155
    Layer 119 -- layer name -- Relu_156
    Supported TIDL layer type ---            Relu -- Relu_156
    Layer 120 -- layer name -- Conv_157
    Supported TIDL layer type ---            Conv -- Conv_157
    Layer 121 -- layer name -- Reshape_195
     Input dims size = 4     dims --- 1   134   20   50
    Supported TIDL layer type ---         Reshape -- Reshape_195
    Layer 122 -- layer name -- Transpose_196
     Input dims size = 5     dims --- 1   1   134   20   50
    Supported TIDL layer type ---       Transpose -- Transpose_196
    Layer 123 -- layer name -- Reshape_203
     Input dims size = 5     dims --- 1   134   1   20   50
    Supported TIDL layer type ---         Reshape -- Reshape_203
    Layer 124 -- layer name -- Conv_228
     Input dims size = 4     dims --- 1   134   1   1000
    Supported TIDL layer type ---            Conv -- Conv_228
    Layer 125 -- layer name -- Transpose_229
     Input dims size = 4     dims --- 1   67   1   1000
    Supported TIDL layer type ---       Transpose -- Transpose_229
    Layer 126 -- layer name -- Reshape_231
     Input dims size = 4     dims --- 1   1000   1   67
    Supported TIDL layer type ---         Reshape -- Reshape_231
    Layer 127 -- layer name -- Gather_233
     Input dims size = 2     dims --- 1000   67
    Supported TIDL layer type ---          Gather -- Gather_233
    Layer 128 -- layer name -- Transpose_245
     Input dims size = 2     dims --- 6   67
    Supported TIDL layer type ---       Transpose -- Transpose_245
    Layer 129 -- layer name -- Reshape_248
     Input dims size = 2     dims --- 67   6
    Supported TIDL layer type ---         Reshape -- Reshape_248
    Layer 130 -- layer name -- Conv_253
     Input dims size = 4     dims --- 1   67   1   6
    Supported TIDL layer type ---            Conv -- Conv_253
    Layer 131 -- layer name -- Transpose_254
     Input dims size = 4     dims --- 1   1   1   6
    Supported TIDL layer type ---       Transpose -- Transpose_254
    Layer 132 -- layer name -- Reshape_256
     Input dims size = 4     dims --- 1   6   1   1
    Supported TIDL layer type ---         Reshape -- Reshape_256
    Layer 133 -- layer name -- Add_263
    Supported TIDL layer type ---             Add -- Add_263
    Layer 134 -- layer name -- Reshape_273
    Supported TIDL layer type ---         Reshape -- Reshape_273
    Layer 135 -- layer name -- Reshape_283
    Supported TIDL layer type ---         Reshape -- Reshape_283
    Layer 136 -- layer name -- Upsample_145
    Supported TIDL layer type ---        Upsample -- Upsample_145
    Layer 137 -- layer name -- Conv_140
    Supported TIDL layer type ---            Conv -- Conv_140
    Layer 138 -- layer name -- Add_146
     Input dims size = 4     dims --- 1   64   40   100
    Supported TIDL layer type ---             Add -- Add_146
    Layer 139 -- layer name -- Conv_147
    Supported TIDL layer type ---            Conv -- Conv_147
    Layer 140 -- layer name -- Conv_185
    Supported TIDL layer type ---            Conv -- Conv_185
    Layer 141 -- layer name -- Relu_186
    Supported TIDL layer type ---            Relu -- Relu_186
    Layer 142 -- layer name -- Conv_187
    Supported TIDL layer type ---            Conv -- Conv_187
    Layer 143 -- layer name -- Relu_188
    Supported TIDL layer type ---            Relu -- Relu_188
    Layer 144 -- layer name -- Conv_189
    Supported TIDL layer type ---            Conv -- Conv_189
    Layer 145 -- layer name -- Relu_190
    Supported TIDL layer type ---            Relu -- Relu_190
    Layer 146 -- layer name -- Concat_241
    Supported TIDL layer type ---          Concat -- Concat_241
    Layer 147 -- layer name -- Reshape_rc_0
     Input dims size = 4     dims --- 1   66   40   100
    Supported TIDL layer type ---         Reshape -- Reshape_rc_0
    Layer 148 -- layer name -- Conv_249
    Supported TIDL layer type ---            Conv -- Conv_249
    Layer 149 -- layer name -- Transpose_250
     Input dims size = 4     dims --- 1   66   1   6
    Supported TIDL layer type ---       Transpose -- Transpose_250
    Layer 150 -- layer name -- Reshape_252
     Input dims size = 4     dims --- 1   6   1   66
    Supported TIDL layer type ---         Reshape -- Reshape_252
    Layer 151 -- layer name -- MatMul_rc_0
     Input dims size = 2     dims --- 6   66
    Supported TIDL layer type ---          MatMul -- MatMul_rc_0
    Layer 152 -- layer name -- Reshape_rc_1
     Input dims size = 2     dims --- 6   4000
    Supported TIDL layer type ---         Reshape -- Reshape_rc_1
    Layer 153 -- layer name -- Add_284
     Input dims size = 4     dims --- 1   6   40   100
    Unsupported (TIDL check) TIDL layer type ---             Add
    Layer 154 -- layer name -- Reshape_288
    Supported TIDL layer type ---         Reshape -- Reshape_288
    Layer 155 -- layer name -- Transpose_n_1
    Supported TIDL layer type ---       Transpose -- Transpose_n_1
    Layer 156 -- layer name -- Conv3_2
     Input dims size = 4     dims --- 1   100   6   40
    Supported TIDL layer type ---            Conv -- Conv3_2
    Layer 157 -- layer name -- Relu_359
     Input dims size = 4     dims --- 1   64   6   40
    Supported TIDL layer type ---            Relu -- Relu_359
    Layer 158 -- layer name -- Conv3_4
    Supported TIDL layer type ---            Conv -- Conv3_4
    Layer 159 -- layer name -- Transpose_n_6
     Input dims size = 4     dims --- 1   2   6   40
    Supported TIDL layer type ---       Transpose -- Transpose_n_6
    Layer 160 -- layer name -- Conv_363
    Supported TIDL layer type ---            Conv -- Conv_363
    Layer 161 -- layer name -- Relu_364
     Input dims size = 4     dims --- 1   1   6   40
    Supported TIDL layer type ---            Relu -- Relu_364
    Layer 162 -- layer name -- Transpose_365
    Supported TIDL layer type ---       Transpose -- Transpose_365
    Layer 163 -- layer name -- Conv_366
     Input dims size = 4     dims --- 1   40   1   6
    Supported TIDL layer type ---            Conv -- Conv_366
    Layer 164 -- layer name -- Transpose_367
     Input dims size = 4     dims --- 1   8   1   6
    Supported TIDL layer type ---       Transpose -- Transpose_367
    Layer 165 -- layer name -- Conv_289
    Supported TIDL layer type ---            Conv -- Conv_289
    Layer 166 -- layer name -- Transpose_290
    Supported TIDL layer type ---       Transpose -- Transpose_290
    Layer 167 -- layer name -- Reshape_292
    Supported TIDL layer type ---         Reshape -- Reshape_292
    Layer 168 -- layer name -- Gather_294
    Supported TIDL layer type ---          Gather -- Gather_294
    Layer 169 -- layer name -- Transpose_306
    Supported TIDL layer type ---       Transpose -- Transpose_306
    Layer 170 -- layer name -- Reshape_309
    Supported TIDL layer type ---         Reshape -- Reshape_309
    Layer 171 -- layer name -- Conv_314
    Supported TIDL layer type ---            Conv -- Conv_314
    Layer 172 -- layer name -- Transpose_315
    Supported TIDL layer type ---       Transpose -- Transpose_315
    Layer 173 -- layer name -- Reshape_317
    Supported TIDL layer type ---         Reshape -- Reshape_317
    Layer 174 -- layer name -- Add_324
    Supported TIDL layer type ---             Add -- Add_324
    Layer 175 -- layer name -- Reshape_334
    Supported TIDL layer type ---         Reshape -- Reshape_334
    Layer 176 -- layer name -- Reshape_344
    Supported TIDL layer type ---         Reshape -- Reshape_344
    Layer 177 -- layer name -- Conv_310
    Supported TIDL layer type ---            Conv -- Conv_310
    Layer 178 -- layer name -- Transpose_311
    Supported TIDL layer type ---       Transpose -- Transpose_311
    Layer 179 -- layer name -- Reshape_313
    Supported TIDL layer type ---         Reshape -- Reshape_313
    Layer 180 -- layer name -- MatMul_rc_1
    Supported TIDL layer type ---          MatMul -- MatMul_rc_1
    Layer 181 -- layer name -- Reshape_rc_2
    Supported TIDL layer type ---         Reshape -- Reshape_rc_2
    Layer 182 -- layer name -- Add_345
    Layer 183 -- layer name -- Reshape_349
    Supported TIDL layer type ---         Reshape -- Reshape_349
    Preliminary subgraphs created = 4
    Final number of subgraphs created are : 4, - Offloaded Nodes - 181, Total Nodes - 184
    INFORMATION -- [TIDL_ResizeLayer]  Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    Layers type not supported by TIDL --- layer type - TopK,  Node name -TopK_219
    ALLOWLISTING : ADD/MUL/SUB/DIV layer : The variable inputs must of be same dimensions --tidl_import_common_model_check.cpp , TIDL_checkAddMulSubDivTensorProperties , 403
    Running runtimes graphviz - /home/deepanshu/EdgeAI/new/edgeai-tidl-tools/tidl_tools/tidl_graphVisualiser_runtimes.out ../../../model-artifacts//fnc_safety_fp32//allowedNode.txt ../../../model-artifacts//fnc_safety_fp32//tempDir/graphvizInfo.txt ../../../model-artifacts//fnc_safety_fp32//tempDir/runtimes_visualization.svg
    *** In TIDL_createStateImportFunc ***
    Compute on node : TIDLExecutionProvider_TIDL_0_0
      0,            Conv, 3, 1, image, 717
      1,            Relu, 1, 1, 717, 227
      2,         MaxPool, 1, 1, 227, 228
      3,            Conv, 3, 1, 228, 720
      4,            Relu, 1, 1, 720, 231
      5,            Conv, 3, 1, 231, 723
      6,             Add, 2, 1, 723, 234
      7,            Relu, 1, 1, 234, 235
      8,            Conv, 3, 1, 235, 726
      9,            Relu, 1, 1, 726, 238
     10,            Conv, 3, 1, 238, 729
     11,             Add, 2, 1, 729, 241
     12,            Relu, 1, 1, 241, 242
     13,            Conv, 3, 1, 242, 738
     14,            Conv, 3, 1, 242, 732
     15,            Relu, 1, 1, 732, 245
     16,            Conv, 3, 1, 245, 735
     17,             Add, 2, 1, 735, 250
     18,            Relu, 1, 1, 250, 251
     19,            Conv, 3, 1, 251, 741
     20,            Relu, 1, 1, 741, 254
     21,            Conv, 3, 1, 254, 744
     22,             Add, 2, 1, 744, 257
     23,            Relu, 1, 1, 257, 258
     24,            Conv, 3, 1, 258, 753
     25,            Conv, 3, 1, 258, 747
     26,            Relu, 1, 1, 747, 261
     27,            Conv, 3, 1, 261, 750
     28,             Add, 2, 1, 750, 266
     29,            Relu, 1, 1, 266, 267
     30,            Conv, 3, 1, 267, 756
     31,            Relu, 1, 1, 756, 270
     32,            Conv, 3, 1, 270, 759
     33,             Add, 2, 1, 759, 273
     34,            Relu, 1, 1, 273, 274
     35,            Conv, 3, 1, 274, 406
     36,            Conv, 3, 1, 274, 768
     37,            Conv, 3, 1, 274, 762
     38,            Relu, 1, 1, 762, 277
     39,            Conv, 3, 1, 277, 765
     40,             Add, 2, 1, 765, 282
     41,            Relu, 1, 1, 282, 283
     42,            Conv, 3, 1, 283, 771
     43,            Relu, 1, 1, 771, 286
     44,            Conv, 3, 1, 286, 774
     45,             Add, 2, 1, 774, 289
     46,            Relu, 1, 1, 289, 290
     47,            Conv, 3, 1, 290, 777
     48,            Relu, 1, 1, 777, 293
     49,             Add, 2, 1, 293, 304
     50,            Conv, 3, 1, 304, 327
     51,         Reshape, 2, 1, 327, 334
     52,            Conv, 3, 1, 304, 314
     53,         Reshape, 2, 1, 314, 321
     54,            Conv, 3, 1, 304, 305
     55,         Reshape, 2, 1, 305, 312
     56,       Transpose, 1, 1, 312, 313
     57,          MatMul, 2, 1, 313, 322
     58,         Reshape, 2, 1, 322, 323
     59,         Softmax, 1, 1, 323, 324
     60,         Squeeze, 1, 1, 324, 325
     61,       Transpose, 1, 1, 325, 326
     62,          MatMul, 2, 1, 334, 335
     63,         Reshape, 2, 1, 335, 342
     64,             Mul, 2, 1, ortshared_6_1_1, 343
     65,             Add, 2, 1, 343, 344
     66,            Conv, 3, 1, 344, 780
     67,            Relu, 1, 1, 780, 347
     68,            Conv, 3, 1, 347, 783
     69,            Relu, 1, 1, 783, 350
     70,             Add, 2, 1, 350, 361
     71,            Conv, 3, 1, 361, 384
     72,         Reshape, 2, 1, 384, 391
     73,            Conv, 3, 1, 361, 371
     74,         Reshape, 2, 1, 371, 378
     75,            Conv, 3, 1, 361, 362
     76,         Reshape, 2, 1, 362, 369
     77,       Transpose, 1, 1, 369, 370
     78,          MatMul, 2, 1, 370, 379
     79,         Reshape, 2, 1, 379, 380
     80,         Softmax, 1, 1, 380, 381
     81,         Squeeze, 1, 1, 381, 382
     82,       Transpose, 1, 1, 382, 383
     83,          MatMul, 2, 1, 391, 392
     84,         Reshape, 2, 1, 392, 399
     85,             Mul, 2, 1, ortshared_8_1_1, 400
     86,             Add, 2, 1, 400, 401
     87,            Conv, 3, 1, 401, 786
     88,            Relu, 1, 1, 786, 404
     89,            Conv, 3, 1, 404, 407
     90,        Upsample, 2, 1, 407, 411
     91,             Add, 2, 1, 406, 412
     92,            Conv, 3, 1, 412, 419
     93,            Conv, 3, 1, 419, 423
     94,            Relu, 1, 1, 423, 424
     95,            Conv, 3, 1, 424, 425
     96,         Sigmoid, 1, 1, 425, 441
     97,             Add, 2, 1, 441, 443
     98,            Relu, 1, 1, 443, 444
     99,             Add, 2, 1, 444, 446
    100,             Mul, 2, 1, 447, 448
    101,             Add, 2, 1, 449, 450
    102,            Relu, 1, 1, 450, 451
    103,             Mul, 2, 1, 447, 453
    104,             Add, 2, 1, 449, 455
    105,         MaxPool, 1, 1, 455, 486
    106,             Mul, 2, 1, 486, 488
    107,             Add, 2, 1, 455, 489
    108,             Mul, 2, 1, 489, 491
    109,             Add, 2, 1, 491, 493
    110,            Relu, 1, 1, 493, 494
    111,             Mul, 2, 1, 494, 496
    112,             Mul, 2, 1, 455, 497
    113,         Squeeze, 1, 1, 497, 498
    114,         Reshape, 2, 1, 498, 500
    Input tensor name -  image
    Output tensor name - 258
    Output tensor name - 412
    Output tensor name - 419
    Output tensor name - 500
    Compute on node : TIDLExecutionProvider_TIDL_1_1
      0,            Conv, 3, 1, 419, 426
      1,            Relu, 1, 1, 426, 427
      2,            Conv, 3, 1, 427, 428
      3,         Reshape, 2, 1, 428, 473
      4,       Transpose, 1, 1, 473, 474
      5,         Reshape, 2, 1, 474, 485
      6,            Conv, 2, 1, 485, 511
      7,       Transpose, 1, 1, 511, 512
      8,         Reshape, 2, 1, 512, 514
      9,         Reshape, 2, 1, 502, seeds
     10,         Squeeze, 1, 1, seeds, 507
     11,          Gather, 2, 1, 514, 516
     12,       Transpose, 1, 1, 516, 528
     13,         Reshape, 2, 1, 528, 537
     14,            Conv, 2, 1, 537, 538
     15,       Transpose, 1, 1, 538, 539
     16,         Reshape, 2, 1, 539, 541
     17,            Conv, 3, 1, 258, 405
     18,        Upsample, 2, 1, 412, 416
     19,             Add, 2, 1, 405, 417
     20,            Conv, 3, 1, 417, 418
     21,            Conv, 3, 1, 418, 789
     22,            Relu, 1, 1, 789, 458
     23,            Conv, 3, 1, 458, 792
     24,            Relu, 1, 1, 792, 461
     25,            Conv, 3, 1, 461, 795
     26,            Relu, 1, 1, 795, 464
     27,          Concat, 2, 1, 523, 524
     28,         Reshape, 2, 1, 524, 527
     29,          MatMul, 2, 1, 541, 573
     30,         Reshape, 2, 1, 573, 585
     31,            Conv, 2, 1, 537, 542
     32,       Transpose, 1, 1, 542, 543
     33,         Reshape, 2, 1, 543, 545
     34,             Add, 2, 1, 545, 554
     35,         Reshape, 2, 1, 554, 570
     36,         Reshape, 2, 1, 570, 594
    Input tensor name -  502
    Input tensor name -  419
    Input tensor name -  412
    Input tensor name -  258
    Output tensor name - seeds
    Output tensor name - 507
    Output tensor name - 485
    Output tensor name - 594
    Output tensor name - 527
    Output tensor name - 585
    Compute on node : TIDLExecutionProvider_TIDL_2_2
      0,            Conv, 2, 1, 485, 604
      1,       Transpose, 1, 1, 604, 605
      2,         Reshape, 2, 1, 605, 607
      3,          Gather, 2, 1, 607, 609
      4,       Transpose, 1, 1, 609, 621
      5,         Reshape, 2, 1, 621, 630
      6,            Conv, 2, 1, 630, 631
      7,       Transpose, 1, 1, 631, 632
      8,         Reshape, 2, 1, 632, 634
      9,          MatMul, 2, 1, 634, 666
     10,         Reshape, 2, 1, 666, 678
     11,            Conv, 2, 1, 630, 635
     12,       Transpose, 1, 1, 635, 636
     13,         Reshape, 2, 1, 636, 638
     14,             Add, 2, 1, 638, 647
     15,         Reshape, 2, 1, 647, 663
     16,         Reshape, 2, 1, 663, 687
     17,         Reshape, 2, 1, 595, masks
     18,       Transpose, 1, 1, masks, rout_tensor_1
     19,            Conv, 3, 1, rout_tensor_1, 710
     20,            Relu, 1, 1, 710, 711
     21,       Transpose, 1, 1, 711, 712
     22,            Conv, 3, 1, 712, 713
     23,       Transpose, 1, 1, 713, cls_logits
     24,            Conv, 3, 1, rout_tensor_1, v_c2_2_
     25,            Relu, 1, 1, v_c2_2_, rout_tensor_3
     26,            Conv, 3, 1, rout_tensor_3, v_c2_4_
     27,       Transpose, 1, 1, v_c2_4_, feat_range
    Input tensor name -  595
    Input tensor name -  485
    Input tensor name -  507
    Input tensor name -  527
    Output tensor name - masks
    Output tensor name - feat_range
    Output tensor name - cls_logits
    Output tensor name - 687
    Output tensor name - 678
    Compute on node : TIDLExecutionProvider_TIDL_3_3
      0,         Reshape, 2, 1, 688, regs
    Input tensor name -  688
    Output tensor name - regs
     Graph Domain TO version : 9In TIDL_onnxRtImportInit subgraph_name=subgraph_0
    Layer 0, subgraph id subgraph_0, name=258
    Layer 1, subgraph id subgraph_0, name=412
    Layer 2, subgraph id subgraph_0, name=419
    Layer 3, subgraph id subgraph_0, name=500
    Layer 4, subgraph id subgraph_0, name=image
    In TIDL_runtimesOptimizeNet: LayerIndex = 120, dataIndex = 116
     ************** Frame index 1 : Running float import *************
    In TIDL_runtimesPostProcessNet
    In TIDL_runtimesPostProcessNet 1
    In TIDL_runtimesPostProcessNet 2
    In TIDL_runtimesPostProcessNet 3
    INFORMATION: [TIDL_ResizeLayer] Upsample_143 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    **          1 WARNINGS          0 ERRORS          **
    In TIDL_runtimesPostProcessNet 4
    ************ in TIDL_subgraphRtCreate ************
     The soft limit is 2048
    The hard limit is 2048
    MEM: Init ... !!!
    MEM: Init ... Done !!!
     0.0s:  VX_ZONE_INIT:Enabled
     0.7s:  VX_ZONE_ERROR:Enabled
     0.8s:  VX_ZONE_WARNING:Enabled
     0.2973s:  VX_ZONE_INIT:[tivxInit:190] Initialization Done !!!
    ************ TIDL_subgraphRtCreate done ************
    **********  Frame Index 1 : Running float inference **********
     Graph Domain TO version : 9In TIDL_onnxRtImportInit subgraph_name=subgraph_1
    Layer 0, subgraph id subgraph_1, name=seeds
    Layer 1, subgraph id subgraph_1, name=507
    Layer 2, subgraph id subgraph_1, name=485
    Layer 3, subgraph id subgraph_1, name=594
    Layer 4, subgraph id subgraph_1, name=527
    Layer 5, subgraph id subgraph_1, name=585
    Layer 6, subgraph id subgraph_1, name=502
    Layer 7, subgraph id subgraph_1, name=419
    Layer 8, subgraph id subgraph_1, name=412
    Layer 9, subgraph id subgraph_1, name=258
    In TIDL_runtimesOptimizeNet: LayerIndex = 47, dataIndex = 41
    Warning : Requested Input Data Convert Layer is not Added to the network, It is currently not Optimal
    INFORMATION: [TIDL_ResizeLayer] Upsample_145 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    Aborted (core dumped)
    log_int16.txt
  • Yes its the same model
  • I would recommend to close the current thread as the same model is being discussed in above shared link, adding here for reference again.
    An engineer is assigned for this lets continue discussion on the same thread, and avoid creating duplicates with almost no nuances.
    Thank You
  • Hello Pratik,
    The problems we have highlighted in both the tickets are different even though the model in use is the same.
    I discussed the issue of multiple tickets with our managers. We cannot close the ticket without a solution. Please ask for the details you require and focus on solving the issue.
    Also note that we are getting minimal response on the other tickets also.
  • Deepanshu,
    I understand the situation and will make sure we help you in this case.
    Looking at the logs provided above with tools version 9.2.9.0 seems like in one the four subgraphs during float inference the core dump issue occurred.
    I will reverify the same observation at my end update the thread.
    Thank You
  • Hi Deepanshu,
    I didnt had chance to go through this thread as of now, am in quest of planning few threads to my ready queue for coming week.
    Can you confirm this e2e is for which model ? lane det or other one ? We are currently supporting softmax e2e after our previous alignment.
    For the given model have you modified any model import code ? Are there any delta wrt std tools offering here ?
  • Hello Pratik,
    This is regarding the lane detection model. Our current changes are not related to this issue.
  • From 9/5,
    This is a priority for Lucid moving forward as it is on lane centering model.
    - Asha
