Part Number: J722SXH01EVM
Other Parts Discussed in Thread: TDA4VM
I'm working on enabling SPI on the J722SXH01EVM, using the below app note and E2E threads for the TDA4VM as reference:
- https://www.ti.com/lit/an/sprad26/sprad26.pdf
- https://e2e.ti.com/support/processors-group/processors/f/processors-forum/947437/faq-ccs-tda4vm-how-to-use-spi-spi_dev-on-tda4-j721e
- https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1076517/tda4vm-tda4-spi-spi_dev-usage-issue-on-on-tda4-j721e
1. I added the device tree node and the corresponding pinmux node as shown below:
Pinmux node (k3-j722s-evm.dts, line 272):
// SPDX-License-Identifier: GPL-2.0-only OR MIT
* Device Tree file for the J722S EVM
* Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/
* Schematics: https://www.ti.com/lit/zip/sprr495
/dts-v1/;
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/phy/phy.h>
#include "k3-j722s.dtsi"
#include "k3-serdes.h"
compatible = "ti,j722s-evm", "ti,j722s";
model = "Texas Instruments J722S EVM";
aliases {
serial0 = &wkup_uart0;
serial2 = &main_uart0;
serial3 = &main_uart5;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
chosen {
stdout-path = &main_uart0;
memory@80000000 {
/* 8G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
<0x00000008 0x80000000 0x00000001 0x80000000>;
device_type = "memory";
bootph-all;
reserved_memory: reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
/* global cma region */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x00 0x38000000>;
linux,cma-default;
secure_tfa_ddr: tfa@9e780000 {
reg = <0x00 0x9e780000 0x00 0x80000>;
no-map;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>;
no-map;
wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
reg = <0x00 0xa0000000 0x00 0x100000>;
no-map;
wkup_r5fss0_core0_memory_region: r5f-memory@a0100000 {
reg = <0x00 0xa0100000 0x00 0xf00000>;
no-map;
mcu_r5fss0_core0_dma_memory_region: mcu-r5fss-dma-memory-region@a1000000 {
reg = <0x00 0xa1000000 0x00 0x100000>;
no-map;
mcu_r5fss0_core0_memory_region: mcu-r5fss-memory-region@a1100000 {
reg = <0x00 0xa1100000 0x00 0xf00000>;
no-map;
main_r5fss0_core0_dma_memory_region: main-r5fss-dma-memory-region@a2000000 {
reg = <0x00 0xa2000000 0x00 0x100000>;
no-map;
main_r5fss0_core0_memory_region: main-r5fss-memory-region@a2100000 {
reg = <0x00 0xa2100000 0x00 0xf00000>;
no-map;
c7x_0_dma_memory_region: c7x-dma-memory@a3000000 {
reg = <0x00 0xa3000000 0x00 0x100000>;
no-map;
c7x_0_memory_region: c7x-memory@a3100000 {
reg = <0x00 0xa3100000 0x00 0xf00000>;
no-map;
c7x_1_dma_memory_region: c7x-dma-memory@a4000000 {
reg = <0x00 0xa4000000 0x00 0x100000>;
no-map;
c7x_1_memory_region: c7x-memory@a4100000 {
reg = <0x00 0xa4100000 0x00 0xf00000>;
no-map;
rtos_ipc_memory_region: ipc-memories@a5000000 {
reg = <0x00 0xa5000000 0x00 0x1c00000>;
alignment = <0x1000>;
no-map;
vmain_pd: regulator-0 {
/* TPS65988 PD CONTROLLER OUTPUT */
compatible = "regulator-fixed";
regulator-name = "vmain_pd";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-always-on;
regulator-boot-on;
bootph-all;
vsys_5v0: regulator-vsys5v0 {
/* Output of LM5140 */
regulator-name = "vsys_5v0";
vin-supply = <&vmain_pd>;
regulator-boot-on;
vdd_mmc1: regulator-mmc1 {
/* TPS22918DBVR */
regulator-name = "vdd_mmc1";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
enable-active-high;
gpio = <&exp1 15 GPIO_ACTIVE_HIGH>;
bootph-all;
vdd_sd_dv: regulator-TLV71033 {
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-names = "default";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vsys_5v0>;
gpios = <&main_gpio0 70 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
vcc_3v3_aud: regulator-vcc3v3 {
regulator-name = "vcc_3v3";
regulator-boot-on;
vsys_io_1v8: regulator-vsys-io-1v8 {
regulator-name = "vsys_io_1v8";
regulator-max-microvolt = <1800000>;
regulator-boot-on;
vsys_io_1v2: regulator-vsys-io-1v2 {
regulator-name = "vsys_io_1v2";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-boot-on;
hdmi0: connector-hdmi {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&sii9022_out>;
transceiver0: can-phy0 {
compatible = "ti,tcan1042";
#phy-cells = <0>;
max-bitrate = <5000000>;
pinctrl-0 = <&mcu_mcan0_gpio_pins_default>;
standby-gpios = <&mcu_gpio0 12 GPIO_ACTIVE_HIGH>;
transceiver1: can-phy1 {
#phy-cells = <0>;
transceiver2: can-phy2 {
#phy-cells = <0>;
standby-gpios = <&exp1 17 GPIO_ACTIVE_HIGH>;
codec_audio: sound {
compatible = "simple-audio-card";
simple-audio-card,name = "J722S-EVM";
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Line", "Line In",
"Microphone", "Microphone Jack";
simple-audio-card,routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"LINE1L", "Line In",
"LINE1R", "Line In",
"MIC3R", "Microphone Jack",
"Microphone Jack", "Mic Bias";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp1>;
sound_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
clocks = <&audio_refclk1>;
&main_pmx0 {
/delete-property/ interrupts;
main_spi0_pins_default: main-spi0-default-pins {
pinctrl-single,pins = <
J722S_IOPAD(0x01bc, PIN_INPUT, 0) /* (D20) SPI0_CLK */
J722S_IOPAD(0x01b4, PIN_INPUT, 0) /* (B20) SPI0_CS0 */
J722S_IOPAD(0x01b8, PIN_INPUT, 0) /* (C20) SPI0_CS1 */
J722S_IOPAD(0x01d0, PIN_INPUT, 1) /* (E22) SPI0_CS2 */
J722S_IOPAD(0x01d4, PIN_INPUT, 1) /* (B21) SPI0_CS3 */
J722S_IOPAD(0x01c0, PIN_INPUT, 0) /* (E19) SPI0_D0 */
J722S_IOPAD(0x01c4, PIN_INPUT, 0) /* (E20) SPI0_D1 */
bootph-all;
main_i2c0_pins_default: main-i2c0-default-pins {
J722S_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (D23) I2C0_SCL */
J722S_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (B22) I2C0_SDA */
bootph-all;
main_i2c1_pins_default: main-i2c1-default-pins {
J722S_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (C24) I2C1_SCL */
J722S_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A22) I2C1_SDA */
bootph-all;
main_i2c2_pins_default: main-i2c2-default-pins {
J722S_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (P22) GPMC0_CSn2.I2C2_SCL */
J722S_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (P23) GPMC0_CSn3.I2C2_SDA */
main_uart0_pins_default: main-uart0-default-pins {
J722S_IOPAD(0x01c8, PIN_INPUT, 0) /* (A22) UART0_RXD */
J722S_IOPAD(0x01cc, PIN_OUTPUT, 0) /* (B22) UART0_TXD */
bootph-all;
main_uart5_pins_default: main-uart5-default-pins {
J722S_IOPAD(0x0108, PIN_INPUT, 3) /* (J27) UART5_RXD */
J722S_IOPAD(0x010c, PIN_OUTPUT, 3) /* (H27) UART5_TXD */
vdd_sd_dv_pins_default: vdd-sd-dv-default-pins {
J722S_IOPAD(0x0120, PIN_INPUT, 7) /* (F27) MMC2_CMD.GPIO0_70 */
bootph-all;
main_mmc1_pins_default: main-mmc1-default-pins {
J722S_IOPAD(0x023c, PIN_INPUT, 0) /* (H22) MMC1_CMD */
J722S_IOPAD(0x0234, PIN_OUTPUT, 0) /* (H24) MMC1_CLK */
J722S_IOPAD(0x0230, PIN_INPUT, 0) /* (H23) MMC1_DAT0 */
J722S_IOPAD(0x022c, PIN_INPUT_PULLUP, 0) /* (H20) MMC1_DAT1 */
J722S_IOPAD(0x0228, PIN_INPUT_PULLUP, 0) /* (J23) MMC1_DAT2 */
J722S_IOPAD(0x0224, PIN_INPUT_PULLUP, 0) /* (H25) MMC1_DAT3 */
J722S_IOPAD(0x0240, PIN_INPUT, 0) /* (B24) MMC1_SDCD */
bootph-all;
mdio_pins_default: mdio-default-pins {
J722S_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AC24) MDIO0_MDC */
J722S_IOPAD(0x015c, PIN_INPUT, 0) /* (AD25) MDIO0_MDIO */
ospi0_pins_default: ospi0-default-pins {
J722S_IOPAD(0x0000, PIN_OUTPUT, 0) /* (L24) OSPI0_CLK */
J722S_IOPAD(0x002c, PIN_OUTPUT, 0) /* (K26) OSPI0_CSn0 */
J722S_IOPAD(0x000c, PIN_INPUT, 0) /* (K27) OSPI0_D0 */
J722S_IOPAD(0x0010, PIN_INPUT, 0) /* (L27) OSPI0_D1 */
J722S_IOPAD(0x0014, PIN_INPUT, 0) /* (L26) OSPI0_D2 */
J722S_IOPAD(0x0018, PIN_INPUT, 0) /* (L25) OSPI0_D3 */
J722S_IOPAD(0x001c, PIN_INPUT, 0) /* (L21) OSPI0_D4 */
J722S_IOPAD(0x0020, PIN_INPUT, 0) /* (M26) OSPI0_D5 */
J722S_IOPAD(0x0024, PIN_INPUT, 0) /* (N27) OSPI0_D6 */
J722S_IOPAD(0x0028, PIN_INPUT, 0) /* (M27) OSPI0_D7 */
J722S_IOPAD(0x0008, PIN_INPUT, 0) /* (L22) OSPI0_DQS */
bootph-all;
rgmii1_pins_default: rgmii1-default-pins {
J722S_IOPAD(0x014c, PIN_INPUT, 0) /* (AC25) RGMII1_RD0 */
J722S_IOPAD(0x0150, PIN_INPUT, 0) /* (AD27) RGMII1_RD1 */
J722S_IOPAD(0x0154, PIN_INPUT, 0) /* (AE24) RGMII1_RD2 */
J722S_IOPAD(0x0158, PIN_INPUT, 0) /* (AE26) RGMII1_RD3 */
J722S_IOPAD(0x0148, PIN_INPUT, 0) /* (AE27) RGMII1_RXC */
J722S_IOPAD(0x0144, PIN_INPUT, 0) /* (AD23) RGMII1_RX_CTL */
J722S_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AF27) RGMII1_TD0 */
J722S_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AE23) RGMII1_TD1 */
J722S_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AG25) RGMII1_TD2 */
J722S_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AF24) RGMII1_TD3 */
J722S_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AG26) RGMII1_TXC */
J722S_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AF25) RGMII1_TX_CTL */
main_usb1_pins_default: main-usb1-default-pins {
J722S_IOPAD(0x0258, PIN_INPUT, 0) /* (B27) USB1_DRVVBUS */
main_gpio0_ioexp_intr_pins_default: main-gpio0-ioexp-intr-default-pins {
J722S_IOPAD(0x0110, PIN_INPUT, 7) /* (G27) MMC2_DAT1.GPIO0_67 */
main_dpi_pins_default: main-dpi-default-pins {
J722S_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AB23) VOUT0_VSYNC */
J722S_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
J722S_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC26) VOUT0_PCLK */
J722S_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (AC27) VOUT0_DE */
J722S_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (W27) VOUT0_DATA0 */
J722S_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA1 */
J722S_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA2 */
J722S_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W23) VOUT0_DATA3 */
J722S_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA4 */
J722S_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA5 */
J722S_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y26) VOUT0_DATA6 */
J722S_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (Y27) VOUT0_DATA7 */
J722S_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA8 */
J722S_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (AA27) VOUT0_DATA9 */
J722S_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA10 */
J722S_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA11 */
J722S_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA12 */
J722S_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA22) VOUT0_DATA13 */
J722S_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (AB26) VOUT0_DATA14 */
J722S_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AB27) VOUT0_DATA15 */
J722S_IOPAD(0x005c, PIN_OUTPUT, 1) /* (U27) GPMC0_AD8.VOUT0_DATA16 */
J722S_IOPAD(0x0060, PIN_OUTPUT, 1) /* (U26) GPMC0_AD9.VOUT0_DATA17 */
J722S_IOPAD(0x0064, PIN_OUTPUT, 1) /* (V27) GPMC0_AD10.VOUT0_DATA18 */
J722S_IOPAD(0x0068, PIN_OUTPUT, 1) /* (V25) GPMC0_AD11.VOUT0_DATA19 */
J722S_IOPAD(0x006c, PIN_OUTPUT, 1) /* (V26) GPMC0_AD12.VOUT0_DATA20 */
J722S_IOPAD(0x0070, PIN_OUTPUT, 1) /* (V24) GPMC0_AD13.VOUT0_DATA21 */
J722S_IOPAD(0x0074, PIN_OUTPUT, 1) /* (V22) GPMC0_AD14.VOUT0_DATA22 */
J722S_IOPAD(0x0078, PIN_OUTPUT, 1) /* (V23) GPMC0_AD15.VOUT0_DATA23 */
J722S_IOPAD(0x009c, PIN_OUTPUT, 1) /* (W26) GPMC0_WAIT1.VOUT0_EXTPCLKIN */
main_mcan0_pins_default: main-mcan0-default-pins {
J722S_IOPAD(0x1dc, PIN_INPUT, 0) /* (C22) MCAN0_RX */
J722S_IOPAD(0x1d8, PIN_OUTPUT, 0) /*(D22) MCAN0_TX */
main_mcasp1_pins_default: main-mcasp1-default-pins {
J722S_IOPAD(0x0090, PIN_INPUT, 2) /* (U24) GPMC0_BE0n_CLE.MCASP1_ACLKX */
J722S_IOPAD(0x0098, PIN_INPUT, 2) /* (AA24) GPMC0_WAIT0.MCASP1_AFSX */
J722S_IOPAD(0x008c, PIN_OUTPUT, 2) /* (T25) GPMC0_WEn.MCASP1_AXR0 */
J722S_IOPAD(0x0084, PIN_INPUT, 2) /* (R25) GPMC0_ADVn_ALE.MCASP1_AXR2 */
audio_ext_refclk1_pins_default: audio-ext-refclk1-default-pins {
J722S_IOPAD(0x0a0, PIN_OUTPUT, 1) /* (N24) GPMC0_WPn.AUDIO_EXT_REFCLK1 */
&cpsw3g {
status = "okay";
pinctrl-0 = <&rgmii1_pins_default>;
&cpsw3g_mdio {
status = "okay";
pinctrl-0 = <&mdio_pins_default>;
cpsw3g_phy0: ethernet-phy@0 {
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
&cpsw_port1 {
phy-mode = "rgmii-rxid";
phy-handle = <&cpsw3g_phy0>;
&cpsw_port2 {
status = "disabled";
&main_gpio1 {
status = "okay";
&main_uart0 {
pinctrl-0 = <&main_uart0_pins_default>;
status = "okay";
bootph-all;
&main_uart5 {
pinctrl-0 = <&main_uart5_pins_default>;
status = "reserved";
&mcu_pmx0 {
wkup_uart0_pins_default: wkup-uart0-default-pins {
J722S_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C7) WKUP_UART0_CTSn */
J722S_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (C6) WKUP_UART0_RTSn */
J722S_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (D8) WKUP_UART0_RXD */
J722S_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (D7) WKUP_UART0_TXD */
bootph-all;
wkup_i2c0_pins_default: wkup-i2c0-default-pins {
J722S_MCU_IOPAD(0x04c, PIN_INPUT_PULLUP, 0) /* (C7) WKUP_I2C0_SCL */
J722S_MCU_IOPAD(0x050, PIN_INPUT_PULLUP, 0) /* (C6) WKUP_I2C1_SDA */
bootph-all;
mcu_mcan0_pins_default: mcu-mcan0-default-pins {
J722S_MCU_IOPAD(0x038, PIN_INPUT, 0) /* (D8) MCU_MCAN0_RX */
J722S_MCU_IOPAD(0x034, PIN_OUTPUT, 0) /* (B2) MCU_MCAN0_TX */
mcu_mcan1_pins_default: mcu-mcan1-default-pins {
J722S_MCU_IOPAD(0x040, PIN_INPUT, 0) /* (B1) MCU_MCAN1_RX */
J722S_MCU_IOPAD(0x03C, PIN_OUTPUT, 0) /*(C1) MCU_MCAN1_TX */
mcu_mcan0_gpio_pins_default: mcu-mcan0-gpio-default-pins {
J722S_MCU_IOPAD(0x0030, PIN_OUTPUT, 7) /* (C3) MCU_GPIO0_12 */
&wkup_uart0 {
/* WKUP UART0 is used by Device Manager firmware */
pinctrl-0 = <&wkup_uart0_pins_default>;
bootph-all;
&wkup_i2c0 {
pinctrl-0 = <&wkup_i2c0_pins_default>;
clock-frequency = <400000>;
status = "okay";
bootph-all;
&k3_clks {
/* Configure AUDIO_EXT_REFCLK1 pin as output */
pinctrl-0 = <&audio_ext_refclk1_pins_default>;
&main_spi0 {
pinctrl-0 = <&main_spi0_pins_default>;
status = "okay";
spidev@0 {
spi-max-frequency=<24000000>;
reg = <0>;
compatible = "linux,spidev";
&main_i2c0 {
pinctrl-0 = <&main_i2c0_pins_default>;
status = "okay";
bootph-all;
exp1: gpio@23 {
compatible = "ti,tca6424";
reg = <0x23>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "TRC_MUX_SEL", "OSPI/ONAND_MUX_SEL",
"MCASP1_FET_SEL", "CTRL_PM_I2C_OE#",
"CSI_VIO_SEL", "USB2.0_MUX_SEL",
"CSI01_MUX_SEL_2", "CSI23_MUX_SEL_2",
"LMK1_OE1", "LMK1_OE0",
"LMK2_OE0", "LMK2_OE1",
"GPIO_RGMII1_RST#", "GPIO_AUD_RSTn",
"GPIO_eMMC_RSTn", "GPIO_uSD_PWR_EN",
"USER_LED2", "MCAN0_STB",
"PCIe0_1L_RC_RSTz", "PCIe0_1L_PRSNT#",
"ENET1_EXP_SPARE2", "ENET1_EXP_PWRDN",
"PD_I2ENET1_I2CMUX_SELC_IRQ", "ENET1_EXP_RESETZ";
p01_hog: p01-hog {
/* P01 - TRC_MUX_SEL */
gpio-hog;
gpios = <0 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "TRC_MUX_SEL";
p02_hog: p02-hog {
/* P02 - MCASP1_FET_SEL */
gpio-hog;
gpios = <2 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "MCASP1_FET_SEL";
p05-hog {
/* P05 - USB2.0_MUX_SEL */
gpio-hog;
gpios = <5 GPIO_ACTIVE_LOW>;
output-high;
p13_hog: p13-hog {
/* P13 - GPIO_AUD_RSTn */
gpio-hog;
gpios = <13 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "GPIO_AUD_RSTn";
tlv320aic3106: audio-codec@1b {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x1b>;
ai3x-micbias-vg = <1>; /* 2.0V */
AVDD-supply = <&vcc_3v3_aud>;
IOVDD-supply = <&vcc_3v3_aud>;
DRVDD-supply = <&vcc_3v3_aud>;
DVDD-supply = <&vsys_io_1v8>;
&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
clock-frequency = <100000>;
exp2: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "DSI_Mux_SEL_2", "GPIO_eDP_ENABLE",
"DP0_PWR_SW_EN", "GPIO_OLDI_RSTn",
"GPIO_HDMI_RSTn", "HDMI_LS_OE",
"DSI_GPIO0", "DSI_GPIO1",
"DSI_EDID", "IO_eDP_IRQ",
"OLDI_INT#", "HDMI_INTn",
interrupt-parent = <&main_gpio0>;
interrupts = <67 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
pinctrl-0 = <&main_gpio0_ioexp_intr_pins_default>;
bootph-all;
p04-hog {
/* P04 - GPIO_HDMI_RSTn */
gpio-hog;
gpios = <4 GPIO_ACTIVE_LOW>;
output-low;
line-name = "GPIO_HDMI_RSTn";
p03-hog {
/* P03 - GPIO_OLDI_RSTn */
gpio-hog;
gpios = <3 GPIO_ACTIVE_LOW>;
output-low;
line-name = "GPIO_OLDI_RSTn";
p05-hog {
/* P05 - HDMI_LS_OE */
gpio-hog;
gpios = <5 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "HDMI_LS_OE";
sii9022: bridge-hdmi@3b {
compatible = "sil,sii9022";
reg = <0x3b>;
interrupt-parent = <&exp2>;
interrupts = <13 IRQ_TYPE_EDGE_FALLING>;
sil,i2s-data-lanes = < 0 >;
hdmi_tx_ports: ports {
#address-cells = <1>;
#size-cells = <0>;
* HDMI can be serviced with 3 potential VPs -
* (DSS0 VP1 / DSS1 VP0 / DSS1 VP1).
* For now, we will service it with DSS1 VP0.
port@0 {
reg = <0>;
sii9022_in: endpoint {
remote-endpoint = <&dss1_dpi0_out>;
port@1 {
reg = <1>;
sii9022_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
&main_i2c2 {
status = "okay";
pinctrl-0 = <&main_i2c2_pins_default>;
pca9543_0: i2c-mux@70 {
compatible = "nxp,pca9543";
#size-cells = <0>;
reg = <0x70>;
pca9543_1: i2c-mux@71 {
#size-cells = <0>;
reg = <0x71>;
&ospi0 {
pinctrl-0 = <&ospi0_pins_default>;
status = "okay";
ospi0_nor: flash@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <8>;
spi-rx-bus-width = <8>;
spi-max-frequency = <25000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <4>;
bootph-all;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "ospi.tiboot3";
reg = <0x00 0x80000>;
partition@80000 {
label = "ospi.tispl";
reg = <0x80000 0x200000>;
partition@280000 {
label = "ospi.u-boot";
reg = <0x280000 0x400000>;
partition@680000 {
label = "ospi.env";
reg = <0x680000 0x40000>;
partition@6c0000 {
label = "ospi.env.backup";
reg = <0x6c0000 0x40000>;
partition@800000 {
label = "ospi.rootfs";
reg = <0x800000 0x37c0000>;
partition@3fc0000 {
label = "ospi.phypattern";
reg = <0x3fc0000 0x40000>;
ospi0_nand: nand@0 {
compatible = "spi-nand";
reg = <0x0>;
cdns,read-delay = <2>;
#size-cells = <1>;
partitions {
#size-cells = <1>;
partition@0 {
label = "ospi_nand.tiboot3";
reg = <0x0 0x80000>;
partition@80000 {
label = "ospi_nand.tispl";
partition@280000 {
label = "ospi_nand.u-boot";
partition@680000 {
label = "ospi_nand.env";
partition@6c0000 {
label = "ospi_nand.env.backup";
partition@2000000 {
label = "ospi_nand.rootfs";
reg = <0x2000000 0x5fc0000>;
partition@7fc0000 {
label = "ospi_nand.phypattern";
reg = <0x7fc0000 0x40000>;
&sdhci0 {
disable-wp;
bootph-all;
ti,driver-strength-ohm = <50>;
status = "okay";
&sdhci1 {
/* SD/MMC */
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vdd_sd_dv>;
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
status = "okay";
bootph-all;
&mailbox0_cluster0 {
status = "okay";
mbox_r5_0: mbox-r5-0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
&mailbox0_cluster1 {
status = "okay";
mbox_mcu_r5_0: mbox-mcu-r5-0 {
&mailbox0_cluster2 {
status = "okay";
mbox_c7x_0: mbox-c7x-0 {
&mailbox0_cluster3 {
status = "okay";
mbox_main_r5_0: mbox-main-r5-0 {
mbox_c7x_1: mbox-c7x-1 {
ti,mbox-rx = <2 0 0>;
ti,mbox-tx = <3 0 0>;
&main_timer0 {
&main_timer1 {
&main_timer2 {
&wkup_r5fss0 {
status = "okay";
&wkup_r5fss0_core0 {
mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
<&wkup_r5fss0_core0_memory_region>;
&mcu_r5fss0 {
status = "okay";
&mcu_r5fss0_core0 {
mboxes = <&mailbox0_cluster1 &mbox_mcu_r5_0>;
memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
<&mcu_r5fss0_core0_memory_region>;
&main_r5fss0 {
status = "okay";
&main_r5fss0_core0 {
mboxes = <&mailbox0_cluster3 &mbox_main_r5_0>;
memory-region = <&main_r5fss0_core0_dma_memory_region>,
<&main_r5fss0_core0_memory_region>;
&c7x_0 {
status = "okay";
mboxes = <&mailbox0_cluster2 &mbox_c7x_0>;
memory-region = <&c7x_0_dma_memory_region>,
<&c7x_0_memory_region>;
&c7x_1 {
status = "okay";
mboxes = <&mailbox0_cluster3 &mbox_c7x_1>;
memory-region = <&c7x_1_dma_memory_region>,
<&c7x_1_memory_region>;
&serdes_ln_ctrl {
idle-states = <J722S_SERDES0_LANE0_USB>,
<J722S_SERDES1_LANE0_PCIE0_LANE0>;
&serdes0 {
status = "okay";
serdes0_usb_link: phy@0 {
reg = <0>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_USB3>;
resets = <&serdes_wiz0 1>;
&serdes1 {
serdes1_pcie_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz1 1>;
&usbss0 {
ti,vbus-divider;
status = "okay";
&usb0 {
dr_mode = "otg";
usb-role-switch;
&usbss1 {
pinctrl-0 = <&main_usb1_pins_default>;
ti,vbus-divider;
status = "okay";
&usb1 {
dr_mode = "host";
maximum-speed = "super-speed";
phys = <&serdes0_usb_link>;
phy-names = "cdns3,usb3-phy";
&pcie0_rc {
status = "okay";
reset-gpios = <&exp1 18 GPIO_ACTIVE_HIGH>;
phys = <&serdes1_pcie_link>;
phy-names = "pcie-phy";
&dss1 {
status = "okay";
pinctrl-0 = <&main_dpi_pins_default>;
clocks = <&k3_clks 232 8>,
<&k3_clks 232 0>,
<&k3_clks 232 4>;
assigned-clocks = <&k3_clks 241 0>, /* DSS1-VP0 */
<&k3_clks 240 0>, /* DSS1-VP1 */
<&k3_clks 245 0>; /* DPI Output */
assigned-clock-parents = <&k3_clks 241 2>, /* PLL 17 HDMI */
<&k3_clks 240 1>, /* PLL 18 DSI */
<&k3_clks 245 2>; /* DSS1-DPI0 */
&dss1_ports {
/* DSS1-VP0: DPI/HDMI Output */
port@0 {
reg = <0>;
dss1_dpi0_out: endpoint {
remote-endpoint = <&sii9022_in>;
&mcu_mcan0 {
status = "okay";
pinctrl-0 = <&mcu_mcan0_pins_default>;
phys = <&transceiver0>;
&mcu_mcan1 {
status = "okay";
pinctrl-0 = <&mcu_mcan1_pins_default>;
phys = <&transceiver1>;
&main_mcan0 {
status = "okay";
pinctrl-0 = <&main_mcan0_pins_default>;
phys = <&transceiver2>;
&mcu_gpio0 {
status = "okay";
&mcasp1 {
status = "okay";
pinctrl-0 = <&main_mcasp1_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 0 2 0
0 0 0 0
0 0 0 0
0 0 0 0
&main_conf {
audio_refclk1: clock@82e4 {
compatible = "ti,am62-audio-refclk";
reg = <0x82e4 0x4>;
clocks = <&k3_clks 157 18>;
assigned-clocks = <&k3_clks 157 18>;
assigned-clock-parents = <&k3_clks 157 33>;
#clock-cells = <0>;
Pins correspond to SPI0 on the J722S. I have checked that these pins are not in conflict with any others in the .dts.
Device tree node (k3-j722s-main.dtsi, line 26):
* Device Tree file for the J722S main domain peripherals
* Copyright (C) 2023-2024 Texas Instruments Incorporated - https://www.ti.com/
#include <dt-bindings/phy/phy-cadence.h>
#include <dt-bindings/phy/phy-ti.h>
* USB1 controller on AM62P and J722S are of different IP.
* Delete AM62P's USBSS1 node definition and redefine it for J722S.
/delete-node/ &usbss1;
serdes_refclk: clk-0 {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <0>;
&cbass_main {
main_spi0: spi@20100000 {
compatible = "ti,am654-mcspi","ti,omap4-mcspi";
reg = <0x00 0x20100000 0x00 0x400>;
interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 141 1>;
power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <0>;
serdes_wiz0: phy@f000000 {
compatible = "ti,am64-wiz-10g";
ranges = <0x0f000000 0x0 0x0f000000 0x00010000>;
#size-cells = <1>;
power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 279 0>, <&k3_clks 279 1>, <&serdes_refclk>;
clock-names = "fck", "core_ref_clk", "ext_ref_clk";
num-lanes = <1>;
#reset-cells = <1>;
#clock-cells = <1>;
assigned-clocks = <&k3_clks 279 1>;
assigned-clock-parents = <&k3_clks 279 5>;
serdes0: serdes@f000000 {
compatible = "ti,j721e-serdes-10g";
reg = <0x0f000000 0x00010000>;
reg-names = "torrent_phy";
resets = <&serdes_wiz0 0>;
reset-names = "torrent_reset";
clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>,
<&serdes_wiz0 TI_WIZ_PHY_EN_REFCLK>;
clock-names = "refclk", "phy_en_refclk";
assigned-clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>,
<&serdes_wiz0 TI_WIZ_PLL1_REFCLK>,
<&serdes_wiz0 TI_WIZ_REFCLK_DIG>;
assigned-clock-parents = <&k3_clks 279 1>,
<&k3_clks 279 1>,
<&k3_clks 279 1>;
#size-cells = <0>;
#clock-cells = <1>;
status = "disabled"; /* Needs lane config */
serdes_wiz1: phy@f010000 {
ranges = <0x0f010000 0x0 0x0f010000 0x00010000>;
#size-cells = <1>;
power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 280 0>, <&k3_clks 280 1>, <&serdes_refclk>;
num-lanes = <1>;
#reset-cells = <1>;
#clock-cells = <1>;
assigned-clocks = <&k3_clks 280 1>;
assigned-clock-parents = <&k3_clks 280 5>;
serdes1: serdes@f010000 {
reg = <0x0f010000 0x00010000>;
resets = <&serdes_wiz1 0>;
clocks = <&serdes_wiz1 TI_WIZ_PLL0_REFCLK>,
<&serdes_wiz1 TI_WIZ_PHY_EN_REFCLK>;
assigned-clocks = <&serdes_wiz1 TI_WIZ_PLL0_REFCLK>,
<&serdes_wiz1 TI_WIZ_PLL1_REFCLK>,
<&serdes_wiz1 TI_WIZ_REFCLK_DIG>;
assigned-clock-parents = <&k3_clks 280 1>,
<&k3_clks 280 1>,
<&k3_clks 280 1>;
#size-cells = <0>;
#clock-cells = <1>;
pcie0_rc: pcie@f102000 {
compatible = "ti,j722s-pcie-host", "ti,j721e-pcie-host";
reg = <0x00 0x0f102000 0x00 0x1000>,
<0x00 0x0f100000 0x00 0x400>,
<0x00 0x0d000000 0x00 0x00800000>,
<0x00 0x68000000 0x00 0x00001000>;
reg-names = "intd_cfg", "user_cfg", "reg", "cfg";
ranges = <0x01000000 0x00 0x68001000 0x00 0x68001000 0x00 0x0010000>,
<0x02000000 0x00 0x68011000 0x00 0x68011000 0x00 0x7fef000>;
dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x10000 0x0>;
interrupt-names = "link_state";
interrupts = <GIC_SPI 99 IRQ_TYPE_EDGE_RISING>;
device_type = "pci";
max-link-speed = <3>;
num-lanes = <1>;
power-domains = <&k3_pds 259 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 259 0>, <&serdes1 CDNS_TORRENT_REFCLK_DRIVER>;
clock-names = "fck", "pcie_refclk";
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x0 0xff>;
vendor-id = <0x104c>;
device-id = <0xb010>;
cdns,no-bar-match-nbits = <64>;
ti,syscon-pcie-ctrl = <&pcie0_ctrl 0x0>;
msi-map = <0x0 &gic_its 0x0 0x10000>;
usbss1: usb@f920000 {
compatible = "ti,j721e-usb";
reg = <0x00 0x0f920000 0x00 0x100>;
power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 278 3>, <&k3_clks 278 1>;
clock-names = "ref", "lpm";
assigned-clocks = <&k3_clks 278 3>; /* USB2_REFCLK */
assigned-clock-parents = <&k3_clks 278 4>; /* HF0SC0 */
#size-cells = <2>;
ranges;
usb1: usb@31200000{
compatible = "cdns,usb3";
reg = <0x00 0x31200000 0x00 0x10000>,
<0x00 0x31210000 0x00 0x10000>,
<0x00 0x31220000 0x00 0x10000>;
reg-names = "otg",
"xhci",
"dev";
interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */
<GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */
<GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>; /* otgirq */
interrupt-names = "host",
"peripheral",
"otg";
dr_mode = "otg";
ti_csi2rx1: ticsi2rx@30122000 {
compatible = "ti,j721e-csi2rx-shim";
dmas = <&main_bcdma_csi 0 0x5100 0>, <&main_bcdma_csi 0 0x5101 0>,
<&main_bcdma_csi 0 0x5102 0>, <&main_bcdma_csi 0 0x5103 0>;
dma-names = "rx0", "rx1", "rx2", "rx3";
reg = <0x00 0x30122000 0x00 0x1000>;
power-domains = <&k3_pds 247 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <2>;
ranges;
cdns_csi2rx1: csi-bridge@30121000 {
compatible = "ti,j721e-csi2rx", "cdns,csi2rx";
reg = <0x00 0x30121000 0x00 0x1000>;
clocks = <&k3_clks 247 0>, <&k3_clks 247 3>, <&k3_clks 247 0>,
<&k3_clks 247 0>, <&k3_clks 247 4>, <&k3_clks 247 4>;
clock-names = "sys_clk", "p_clk", "pixel_if0_clk",
"pixel_if1_clk", "pixel_if2_clk", "pixel_if3_clk";
phys = <&dphy1>;
phy-names = "dphy";
ports {
#size-cells = <0>;
csi1_port0: port@0 {
reg = <0>;
csi1_port1: port@1 {
reg = <1>;
csi1_port2: port@2 {
reg = <2>;
csi1_port3: port@3 {
reg = <3>;
csi1_port4: port@4 {
reg = <4>;
ti_csi2rx2: ticsi2rx@30142000 {
dmas = <&main_bcdma_csi 0 0x5200 0>, <&main_bcdma_csi 0 0x5201 0>,
<&main_bcdma_csi 0 0x5202 0>, <&main_bcdma_csi 0 0x5203 0>;
reg = <0x00 0x30142000 0x00 0x1000>;
power-domains = <&k3_pds 248 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <2>;
ranges;
cdns_csi2rx2: csi-bridge@30141000 {
reg = <0x00 0x30141000 0x00 0x1000>;
clocks = <&k3_clks 248 0>, <&k3_clks 248 3>, <&k3_clks 248 0>,
<&k3_clks 248 0>, <&k3_clks 248 4>, <&k3_clks 248 4>;
phys = <&dphy2>;
phy-names = "dphy";
ports {
#size-cells = <0>;
csi2_port0: port@0 {
reg = <0>;
csi2_port1: port@1 {
reg = <1>;
csi2_port2: port@2 {
reg = <2>;
csi2_port3: port@3 {
reg = <3>;
csi2_port4: port@4 {
reg = <4>;
ti_csi2rx3: ticsi2rx@30162000 {
dmas = <&main_bcdma_csi 0 0x5300 0>, <&main_bcdma_csi 0 0x5301 0>,
<&main_bcdma_csi 0 0x5302 0>, <&main_bcdma_csi 0 0x5303 0>;
dma-names = "rx0", "rx1";
reg = <0x00 0x30162000 0x00 0x1000>;
power-domains = <&k3_pds 249 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <2>;
ranges;
cdns_csi2rx3: csi-bridge@30161000 {
reg = <0x00 0x30161000 0x00 0x1000>;
clocks = <&k3_clks 249 0>, <&k3_clks 249 3>, <&k3_clks 249 0>,
<&k3_clks 249 0>, <&k3_clks 249 4>, <&k3_clks 249 4>;
phys = <&dphy3>;
phy-names = "dphy";
ports {
#size-cells = <0>;
csi3_port0: port@0 {
reg = <0>;
csi3_port1: port@1 {
reg = <1>;
csi3_port2: port@2 {
reg = <2>;
csi3_port3: port@3 {
reg = <3>;
csi3_port4: port@4 {
reg = <4>;
dphy1: phy@30130000 {
compatible = "cdns,dphy-rx";
reg = <0x00 0x30130000 0x00 0x1100>;
#phy-cells = <0>;
power-domains = <&k3_pds 251 TI_SCI_PD_EXCLUSIVE>;
dphy2: phy@30150000 {
reg = <0x00 0x30150000 0x00 0x1100>;
#phy-cells = <0>;
power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>;
dphy3: phy@30170000 {
reg = <0x00 0x30170000 0x00 0x1100>;
#phy-cells = <0>;
power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>;
main_r5fss0: r5fss@78400000 {
compatible = "ti,am62-r5fss";
#size-cells = <1>;
ranges = <0x78400000 0x00 0x78400000 0x8000>,
<0x78500000 0x00 0x78500000 0x8000>;
power-domains = <&k3_pds 261 TI_SCI_PD_EXCLUSIVE>;
main_r5fss0_core0: r5f@78400000 {
compatible = "ti,am62-r5f";
reg = <0x78400000 0x00008000>,
<0x78500000 0x00008000>;
reg-names = "atcm", "btcm";
ti,sci = <&dmsc>;
ti,sci-dev-id = <262>;
ti,sci-proc-ids = <0x04 0xff>;
resets = <&k3_reset 262 1>;
firmware-name = "j722s-main-r5f0_0-fw";
ti,atcm-enable = <1>;
ti,btcm-enable = <1>;
ti,loczrama = <1>;
c7x_0: dsp@7e000000 {
compatible = "ti,j722s-c7xv-dsp";
reg = <0x00 0x7e000000 0x00 0x00200000>;
reg-names = "l2sram";
ti,sci = <&dmsc>;
ti,sci-dev-id = <208>;
ti,sci-proc-ids = <0x30 0xff>;
resets = <&k3_reset 208 1>;
firmware-name = "j722s-c71_0-fw";
c7x_1: dsp@7e200000 {
reg = <0x00 0x7e200000 0x00 0x00200000>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <268>;
ti,sci-proc-ids = <0x31 0xff>;
resets = <&k3_reset 268 1>;
firmware-name = "j722s-c71_1-fw";
/* MCU domain overrides */
&mcu_r5fss0_core0 {
firmware-name = "j722s-mcu-r5f0_0-fw";
/* Wakeup domain overrides */
firmware-name = "j722s-wkup-r5f0_0-fw";
&main_conf {
serdes_ln_ctrl: mux-controller@4080 {
compatible = "reg-mux";
reg = <0x4080 0x14>;
#mux-control-cells = <1>;
mux-reg-masks = <0x0 0x3>, /* SERDES0 lane0 select */
<0x10 0x3>; /* SERDES1 lane0 select */
&wkup_conf {
pcie0_ctrl: pcie0-ctrl@4070 {
compatible = "ti,j784s4-pcie-ctrl", "syscon";
reg = <0x4070 0x4>;
The parameters have been updated according to the J722S TRM and TISCI.
2. I added a spidev node inside the SPI- node as shown below (k3-j722s-evm.dts, line 561):
&main_spi0 {
status = "okay";
spidev@0 {
reg = <0>;
3. I enabled CONFIG_SPI_SPIDEV=y in arch/arm64/configs/defconfig. CONFIG_SPI_OMAP24XX=y by default.
Problem
When I make the SDK with these changes and boot Linux, spidev does not show, just spi_master (spi1). I'm not sure what the spi0 is doing there, but I see it on the default image as well.
I commented out all the other .dtbo for J722S besides k3-j722s-evm.dtb and make, but no difference in output.
# Boards with J722s SoC
dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm.dtb
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-csi2-ov5640.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-csi2-quad-rpi-cam-imx219.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-csi2-quad-tevi-ov5640.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-dsi-rpi-7inch-panel.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-fpdlink-fusion.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-microtips-mf101hie-panel.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-v3link-fusion.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-evm-pwm.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-vision-apps.dtbo
#dtb-$(CONFIG_ARCH_K3) += k3-j722s-edgeai-apps.dtbo
Could you advise?
Thank you,
Jin
