Part Number: AM5728
Hi TI team,
Find here attached the our schematics for your review and feedback, suggestions or recommendation for better functional & EMI/EMC performance.
Bharath
Part Number: AM5728
Hi TI team,
Bharath
We are no longer performing full schematic reviews for this family of processors. Is this a new design or and update of an existing deign? If an update, can you provide list of changes?
Do you have any specific questions on you design that needs TI's attention? Regarding the EMI/EMC performance question - does an existing design have issue in this area?
Hi Robert Eschler,
Thanks for your response,
I understood your point, yes this is an older design, updated with below few recent changes.
Below are the section we modified or updated, please check them and provide your valuable comments
1) USB Port & HUB Section is added new (Page 14 of 28)
2) In Processor "PRUSS ETHERNET" 100Mbps MII/RII Interface Section replaced older EOL Ethernet Phi with alternate mature part from TI (Page 16 of 28)
3) HDMI Interface 7inch TFT output Section is added new; Please refer latest schematic uploaded with some correction in HDMI Section.(Page 17 of 28)
Regarding EMI/EMC, we don't have any data of previous design report , In summary in current design we are completely reusing previous schematic design but the board form factors, interface connector arrangement and enclosure will be completely different or changed, hence we don't know what will be new challenges hence I just wanted you to review & provide any improvement/recommendation or best practice if any for this processor designsTI AM5728 Processor Schematics MFR Review2.pdf.
Hi Robert Eschler,
Please review & advise whether below comments they are coming TI AM57xx Schematic checklist.
Let us know if we can incorporate them & update the schematics accordingly.
Yes recommended to pull-up TCK and TMS. Most critical is pull-down on TRSTn, which design already includes.
Unclear why output of load switch (U48). This logic would allow 5V0 to connect with VBUS_3V3. Is this valid?
Yes - RTC clock input looks correct.
You have 33-ohm resistors in-line for all MMC1 signals (SD card). This R-value may vary (10 to 33-ohms), depending on PCB implementation. 10K pullup resistors should be OK. As mentioned in checklist, spec calls for 47K-50K pullups..
QSPI routed off-board, so unable to review. Does include series R option on clock (if signal integrity need to be adjusted)
Pulldown resistor (<10K) is recommended on DDR_RESET (help hold in reset during power cycles)
Hi Robert Eschler,
OK, Got it , Please share if any other comments.
Thanks & Regards
Bharath
I don't have any additional comments. Any additional specific questions regarding the design?
