Dear all,
With IPNC RDK 4.0, now it can works well. However, we have other special requirement to do H264 decode on board. I found the moduletest.out/alg_vidDec.c is a good example to do such work. But it can't works well.
I have already changed ./framework/alg/src/alg_server.cfg to support H264 decoder as follows:
var IPRUN = xdc.useModule('ti.sdo.codecs.iprun.ce.IPRUN');
var KTNF = xdc.useModule('ti.sdo.codecs.ktnf.ce.KTNF');
var MPEG4ENC = xdc.useModule('ti.sdo.codecs.mpeg4enc.ce.MPEG4ENC');
var H264ENC = xdc.useModule('ti.sdo.codecs.h264enc.ce.H264ENC');
var H264DEC = xdc.useModule('ti.sdo.codecs.h264dec.ce.H264DEC');
var JPEGENC = xdc.useModule('ti.sdo.codecs.jpegenc.ce.JPEGENC');
var AACLC_ENC = xdc.useModule('ittiam.codecs.aaclc_enc.ce.AACLC_ENC');
var AAC_DEC = xdc.useModule('ittiam.codecs.aac_dec.ce.AAC_DEC');
var Engine = xdc.useModule('ti.sdo.ce.Engine');
var myEngine = Engine.create("alg_server", [
{name: "g711enc", mod: G711ENC, local: true, groupId: 1},
{name: "h264enc", mod: H264ENC, local: true, groupId: 1},
{name: "h264dec", mod: H264DEC, local: true, groupId: 1},
{name: "mpeg4enc", mod: MPEG4ENC, local: true, groupId: 1},
I disabled alg_vidDec display function ( attached please find alg_vidDec.c and test.264) and only test h264 decode functionality, however it still reports errors as below:
./moduletest.out alg_vidDec
CLK Hz,
ARM Hz = 432000000
DDR Hz = 340000000
VPSS Hz = 340000000
IMCOP Hz = 340000000
[OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
DM365MM Init Successful [OSA_FILE ] Reading file [test.264] ... Done. [9869 bytes]
ALG: VidDec: Decode in progress!!!
ALG: VidDec: XDM_GETBUFINFO: min out bufs:2,size:516096 258048
ALG: VidDec: 42588:0:1077585056:352x288:0: 6705 bytes (1074325184, 1074323456)
ALG: VidDec: ALG_vidDecRun() ERROR !!!
ALG: VidDec: XDM_GETBUFINFO: min out bufs:2,size:294912 147456
ALG: VidDec: 0:0:0:352x288:1: 6705 bytes (24, 48)
ALG: VidDec: 0:0:0:352x288:1: 693 bytes (24, 48)
ALG: VidDec: 0:0:0:352x288:0: 795 bytes (24, 48)
ALG: VidDec: 0:0:0:352x288:0: 683 bytes (24, 48)
ALG: VidDec: 0:0:0:352x288:0: 102400 bytes (24, 48)
ALG: VidDec: Decode DONE!!!
Could you help to check the attachment including files: alg_vidDec.c and test.264, what's wrong setting?
Any help will be much appreciated!
Jesse.
