Linux/AM5708: KEYBOARD Controller in a custom AM5708 board
Part Number: AM5708
Other Parts Discussed in Thread: DRA72, DRA718, AM5728, TMDXIDK5718, , DRA71XEVM, DRA71, AM5718
Tool/software: Linux
Hi:
I have a custom AM5708 based board and want to use keyboard controller to handle a key pad.
I am working with SDK Linux RT 5.00.00.15.
Attached are the dts and config file for Linux
During Linux startup I get the following message:
[    1.926557] omap4-keypad 4ae1c00000000080.keypad: no base address specified
[    1.933577] omap4-keypad: probe of 4ae1c00000000080.keypad failed with error2
Billa 0576.bridge_linux.dts.txt
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_PERF_EVENTS=y
CONFIG_PARTITION_ADVANCED=y
CONFIG_CMDLINE_PARTITION=y
# CONFIG_ARCH_MULTI_V5 is not set
# CONFIG_ARCH_MULTI_V4 is not set
CONFIG_MACH_ARTPEC6=y
CONFIG_MACH_ARMADA_370=y
CONFIG_MACH_ARMADA_375=y
CONFIG_MACH_ARMADA_38X=y
CONFIG_MACH_ARMADA_39X=y
CONFIG_MACH_ARMADA_XP=y
CONFIG_MACH_DOVE=y
CONFIG_SOC_SAMA5D2=y
CONFIG_SOC_SAMA5D3=y
CONFIG_SOC_SAMA5D4=y
CONFIG_ARCH_BCM2835=y
CONFIG_ARCH_BCM_63XX=y
CONFIG_MACH_BERLIN_BG2=y
CONFIG_MACH_BERLIN_BG2CD=y
CONFIG_MACH_BERLIN_BG2Q=y
CONFIG_SOC_IMX50=y
CONFIG_SOC_IMX51=y
CONFIG_SOC_IMX53=y
CONFIG_SOC_IMX6Q=y
CONFIG_SOC_IMX6SL=y
CONFIG_SOC_IMX6SX=y
CONFIG_SOC_IMX6UL=y
CONFIG_SOC_IMX7D=y
CONFIG_SOC_VF610=y
CONFIG_SOC_LS1021A=y
CONFIG_MACH_SPEAR1310=y
CONFIG_MACH_SPEAR1340=y
CONFIG_EXYNOS5420_MCPM=y
CONFIG_ARCH_R8A7743=y
CONFIG_ARCH_R8A7745=y
CONFIG_ARCH_R8A7792=y
CONFIG_MACH_HREFV60=y
CONFIG_MACH_SNOWBALL=y
CONFIG_TRUSTED_FOUNDATIONS=y
CONFIG_PCI_HOST_GENERIC=y
CONFIG_PCI_KEYSTONE=y
CONFIG_PCI_MSI=y
CONFIG_PCI_MVEBU=y
CONFIG_PCI_TEGRA=y
CONFIG_PCI_RCAR_GEN2=y
CONFIG_PCIE_RCAR=y
CONFIG_PCIEPORTBUS=y
CONFIG_HIGHPTE=y
CONFIG_CMA=y
CONFIG_EFI=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
CONFIG_ARM_IMX6Q_CPUFREQ=y
CONFIG_ARM_ZYNQ_CPUIDLE=y
CONFIG_ARM_EXYNOS_CPUIDLE=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_OPTIMISTIC_DAD=y
CONFIG_INET6_ESP=m
CONFIG_IPV6_MIP6=m
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_NET_DSA=m
CONFIG_NET_SWITCHDEV=y
CONFIG_CAN_RAW=y
CONFIG_CAN_BCM=y
CONFIG_CAN_DEV=y
CONFIG_CAN_AT91=m
CONFIG_CAN_RCAR=m
CONFIG_CAN_XILINXCAN=y
CONFIG_CAN_MCP251X=y
CONFIG_B53_SPI_DRIVER=m
CONFIG_B53_MDIO_DRIVER=m
CONFIG_B53_MMAP_DRIVER=m
CONFIG_B53_SRAB_DRIVER=m
CONFIG_CAN_SUN4I=y
CONFIG_BT=m
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
CONFIG_CFG80211=m
CONFIG_MAC80211=m
CONFIG_RFKILL=y
CONFIG_RFKILL_INPUT=y
CONFIG_RFKILL_GPIO=y
CONFIG_DMA_CMA=y
CONFIG_OMAP_OCP2SCP=y
CONFIG_SIMPLE_PM_BUS=y
CONFIG_SUNXI_RSB=y
CONFIG_MTD=y
CONFIG_MTD_BLOCK=y
CONFIG_MTD_M25P80=y
CONFIG_MTD_NAND=y
CONFIG_MTD_NAND_DENALI_DT=y
CONFIG_MTD_NAND_ATMEL=y
CONFIG_MTD_NAND_BRCMNAND=y
CONFIG_MTD_NAND_VF610_NFC=y
CONFIG_MTD_NAND_DAVINCI=y
CONFIG_MTD_SPI_NOR=y
CONFIG_SPI_FSL_QUADSPI=m
CONFIG_MTD_UBI=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=65536
CONFIG_VIRTIO_BLK=y
CONFIG_AD525X_DPOT=y
CONFIG_AD525X_DPOT_I2C=y
CONFIG_ATMEL_TCLIB=y
CONFIG_ICS932S401=y
CONFIG_ATMEL_SSC=m
CONFIG_QCOM_COINCELL=m
CONFIG_APDS9802ALS=y
CONFIG_ISL29003=y
CONFIG_EEPROM_AT24=y
CONFIG_BLK_DEV_SD=y
CONFIG_BLK_DEV_SR=y
CONFIG_SCSI_MULTI_LUN=y
CONFIG_AHCI_BRCM=y
CONFIG_AHCI_DM816=y
CONFIG_AHCI_ST=y
CONFIG_AHCI_IMX=y
CONFIG_AHCI_SUNXI=y
CONFIG_AHCI_TEGRA=y
CONFIG_SATA_HIGHBANK=y
CONFIG_SATA_MV=y
CONFIG_SATA_RCAR=y
CONFIG_NETDEVICES=y
CONFIG_VIRTIO_NET=y
CONFIG_HIX5HD2_GMAC=y
CONFIG_SUN4I_EMAC=y
CONFIG_MACB=y
CONFIG_BGMAC_BCMA=y
CONFIG_NET_CALXEDA_XGMAC=y
CONFIG_GIANFAR=y
CONFIG_MV643XX_ETH=y
CONFIG_MVNETA=y
CONFIG_PXA168_ETH=m
CONFIG_KS8851=y
CONFIG_R8169=y
CONFIG_SH_ETH=y
CONFIG_SMSC911X=y
CONFIG_STMMAC_ETH=y
CONFIG_STMMAC_PLATFORM=y
CONFIG_DWMAC_DWC_QOS_ETH=y
CONFIG_XILINX_EMACLITE=y
CONFIG_AT803X_PHY=y
CONFIG_SMSC_PHY=y
CONFIG_REALTEK_PHY=y
CONFIG_FIXED_PHY=y
CONFIG_ROCKCHIP_PHY=y
CONFIG_USB_SUPPORT=y
CONFIG_USB=m
CONFIG_USB_PEGASUS=y
CONFIG_USB_RTL8152=m
CONFIG_USB_NET_SMSC75XX=y
CONFIG_BRCMFMAC=m
CONFIG_RT2X00=m
CONFIG_RT2800USB=m
CONFIG_MWIFIEX=m
CONFIG_MWIFIEX_SDIO=m
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=y
CONFIG_KEYBOARD_QT1070=m
CONFIG_KEYBOARD_GPIO=y
CONFIG_KEYBOARD_TEGRA=y
CONFIG_KEYBOARD_SPEAR=y
CONFIG_KEYBOARD_ST_KEYSCAN=y
CONFIG_KEYBOARD_CROS_EC=m
CONFIG_KEYBOARD_SAMSUNG=m
CONFIG_KEYBOARD_OMAP4=y
CONFIG_MOUSE_PS2_ELANTECH=y
CONFIG_MOUSE_CYAPA=m
CONFIG_MOUSE_ELAN_I2C=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
CONFIG_TOUCHSCREEN_MMS114=m
CONFIG_TOUCHSCREEN_ST1232=m
CONFIG_TOUCHSCREEN_STMPE=y
CONFIG_TOUCHSCREEN_SUN4I=y
CONFIG_TOUCHSCREEN_WM97XX=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_MAX77693_HAPTIC=m
CONFIG_INPUT_MAX8997_HAPTIC=m
CONFIG_INPUT_AXP20X_PEK=m
CONFIG_INPUT_ADXL34X=m
CONFIG_SERIO_AMBAKMI=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_MT6577=y
CONFIG_SERIAL_8250_UNIPHIER=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_ATMEL=y
CONFIG_SERIAL_ATMEL_CONSOLE=y
CONFIG_SERIAL_ATMEL_TTYAT=y
CONFIG_SERIAL_BCM63XX=y
CONFIG_SERIAL_BCM63XX_CONSOLE=y
CONFIG_SERIAL_MESON=y
CONFIG_SERIAL_MESON_CONSOLE=y
CONFIG_SERIAL_SAMSUNG=y
CONFIG_SERIAL_SAMSUNG_CONSOLE=y
CONFIG_SERIAL_SIRFSOC=y
CONFIG_SERIAL_SIRFSOC_CONSOLE=y
CONFIG_SERIAL_TEGRA=y
CONFIG_SERIAL_IMX=y
CONFIG_SERIAL_IMX_CONSOLE=y
CONFIG_SERIAL_SH_SCI=y
CONFIG_SERIAL_SH_SCI_NR_UARTS=20
CONFIG_SERIAL_SH_SCI_CONSOLE=y
CONFIG_SERIAL_SH_SCI_DMA=y
CONFIG_SERIAL_MSM=y
CONFIG_SERIAL_MSM_CONSOLE=y
CONFIG_SERIAL_VT8500=y
CONFIG_SERIAL_VT8500_CONSOLE=y
CONFIG_SERIAL_OF_PLATFORM=y
CONFIG_SERIAL_OMAP_CONSOLE=y
CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y
CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
CONFIG_SERIAL_CONEXANT_DIGICOLOR_CONSOLE=y
CONFIG_SERIAL_ST_ASC_CONSOLE=y
CONFIG_HVC_DRIVER=y
CONFIG_VIRTIO_CONSOLE=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_DAVINCI=y
CONFIG_I2C_ARB_GPIO_CHALLENGE=m
CONFIG_I2C_MUX_PCA954x=y
CONFIG_I2C_MUX_PINCTRL=y
CONFIG_I2C_DEMUX_PINCTRL=y
CONFIG_I2C_AT91=m
CONFIG_I2C_BCM2835=y
CONFIG_I2C_CADENCE=y
CONFIG_I2C_DIGICOLOR=m
CONFIG_I2C_EMEV2=m
CONFIG_I2C_EXYNOS5=y
CONFIG_I2C_IMX=m
CONFIG_I2C_MV64XXX=y
CONFIG_I2C_RIIC=y
CONFIG_I2C_S3C2410=y
CONFIG_I2C_SH_MOBILE=y
CONFIG_I2C_SIRF=y
CONFIG_I2C_ST=y
CONFIG_I2C_SUN6I_P2WI=y
CONFIG_I2C_TEGRA=y
CONFIG_I2C_UNIPHIER=y
CONFIG_I2C_UNIPHIER_F=y
CONFIG_I2C_RCAR=y
CONFIG_I2C_CROS_EC_TUNNEL=m
CONFIG_I2C_SLAVE_EEPROM=y
CONFIG_SPI=y
CONFIG_SPI_ATMEL=m
CONFIG_SPI_BCM2835=y
CONFIG_SPI_BCM2835AUX=y
CONFIG_SPI_DAVINCI=y
CONFIG_SPI_GPIO=m
CONFIG_SPI_FSL_DSPI=m
CONFIG_SPI_OMAP24XX=y
CONFIG_SPI_ORION=y
CONFIG_SPI_PL022=y
CONFIG_SPI_RSPI=y
CONFIG_SPI_S3C64XX=m
CONFIG_SPI_SH_MSIOF=m
CONFIG_SPI_SH_HSPI=y
CONFIG_SPI_SIRF=y
CONFIG_SPI_SUN4I=y
CONFIG_SPI_SUN6I=y
CONFIG_SPI_TEGRA114=y
CONFIG_SPI_TEGRA20_SFLASH=y
CONFIG_SPI_TEGRA20_SLINK=y
CONFIG_SPMI=y
CONFIG_PINCTRL_AS3722=y
CONFIG_PINCTRL_PALMAS=y
CONFIG_PINCTRL_BCM2835=y
CONFIG_PINCTRL_APQ8064=y
CONFIG_PINCTRL_APQ8084=y
CONFIG_PINCTRL_IPQ8064=y
CONFIG_PINCTRL_MSM8660=y
CONFIG_PINCTRL_MSM8960=y
CONFIG_PINCTRL_MSM8X74=y
CONFIG_PINCTRL_MSM8916=y
CONFIG_PINCTRL_QCOM_SPMI_PMIC=y
CONFIG_PINCTRL_QCOM_SSBI_PMIC=y
CONFIG_GPIO_DAVINCI=y
CONFIG_GPIO_RCAR=y
CONFIG_GPIO_ZYNQ=y
CONFIG_GPIO_PCA953X_IRQ=y
CONFIG_GPIO_TWL4030=y
CONFIG_GPIO_PALMAS=y
CONFIG_GPIO_SYSCON=y
CONFIG_GPIO_TPS65910=y
CONFIG_BATTERY_ACT8945A=y
CONFIG_BATTERY_SBS=y
CONFIG_BATTERY_MAX17040=m
CONFIG_BATTERY_MAX17042=m
CONFIG_CHARGER_MAX14577=m
CONFIG_CHARGER_MAX77693=m
CONFIG_CHARGER_MAX8997=m
CONFIG_CHARGER_MAX8998=m
CONFIG_CHARGER_TPS65090=y
CONFIG_AXP20X_POWER=m
CONFIG_POWER_RESET_AS3722=y
CONFIG_POWER_RESET_GPIO=y
CONFIG_POWER_RESET_GPIO_RESTART=y
CONFIG_POWER_RESET_KEYSTONE=y
CONFIG_POWER_RESET_RMOBILE=y
CONFIG_POWER_RESET_ST=y
CONFIG_POWER_AVS=y
CONFIG_ROCKCHIP_IODOMAIN=y
CONFIG_SENSORS_IIO_HWMON=y
CONFIG_SENSORS_LM90=y
CONFIG_SENSORS_LM95245=y
CONFIG_SENSORS_NTC_THERMISTOR=m
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_INA2XX=m
CONFIG_BRCMSTB_THERMAL=m
CONFIG_ROCKCHIP_THERMAL=y
CONFIG_RCAR_THERMAL=y
CONFIG_ARMADA_THERMAL=y
CONFIG_DAVINCI_WATCHDOG=m
CONFIG_EXYNOS_THERMAL=m
CONFIG_ST_THERMAL_MEMMAP=y
CONFIG_DA9063_WATCHDOG=m
CONFIG_ARM_SP805_WATCHDOG=y
CONFIG_AT91SAM9X_WATCHDOG=y
CONFIG_SAMA5D4_WATCHDOG=y
CONFIG_ORION_WATCHDOG=y
CONFIG_ST_LPC_WATCHDOG=y
CONFIG_SUNXI_WATCHDOG=y
CONFIG_IMX2_WDT=y
CONFIG_TEGRA_WATCHDOG=m
CONFIG_MESON_WATCHDOG=y
CONFIG_DIGICOLOR_WATCHDOG=y
CONFIG_BCM2835_WDT=y
CONFIG_BCM47XX_WDT=y
CONFIG_BCM_KONA_WDT=y
CONFIG_MFD_ACT8945A=y
CONFIG_MFD_AC100=y
CONFIG_MFD_AXP20X_RSB=y
CONFIG_MFD_QCOM_RPM=y
CONFIG_MFD_SPMI_PMIC=y
CONFIG_REGULATOR_ACT8945A=y
CONFIG_REGULATOR_AB8500=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_REGULATOR_MAX8997=m
CONFIG_REGULATOR_MAX8998=m
CONFIG_REGULATOR_QCOM_RPM=y
CONFIG_REGULATOR_QCOM_SMD_RPM=y
CONFIG_REGULATOR_WM8994=m
CONFIG_USB_GSPCA=y
CONFIG_SOC_CAMERA=m
CONFIG_SOC_CAMERA_PLATFORM=m
CONFIG_VIDEO_RCAR_VIN=m
CONFIG_VIDEO_ATMEL_ISI=m
CONFIG_VIDEO_SAMSUNG_EXYNOS4_IS=m
CONFIG_VIDEO_S5P_FIMC=m
CONFIG_VIDEO_S5P_MIPI_CSIS=m
CONFIG_VIDEO_EXYNOS_FIMC_LITE=m
CONFIG_VIDEO_EXYNOS4_FIMC_IS=m
CONFIG_VIDEO_SAMSUNG_S5P_JPEG=m
CONFIG_VIDEO_SAMSUNG_S5P_MFC=m
CONFIG_VIDEO_SAMSUNG_EXYNOS_GSC=m
CONFIG_VIDEO_STI_BDISP=m
CONFIG_VIDEO_STI_HVA=m
CONFIG_VIDEO_STI_DELTA=m
CONFIG_VIDEO_RENESAS_JPU=m
CONFIG_VIDEO_RENESAS_VSP1=m
CONFIG_V4L_TEST_DRIVERS=y
CONFIG_VIDEO_ADV7180=m
CONFIG_VIDEO_ML86V7667=m
CONFIG_DRM_I2C_ADV7511_AUDIO=y
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
CONFIG_DRM_DUMB_VGA_DAC=m
CONFIG_DRM_EXYNOS_FIMD=y
CONFIG_DRM_EXYNOS_MIXER=y
CONFIG_DRM_EXYNOS_DPI=y
CONFIG_DRM_EXYNOS_DSI=y
CONFIG_DRM_EXYNOS_HDMI=y
CONFIG_DRM_ROCKCHIP=m
CONFIG_ROCKCHIP_ANALOGIX_DP=y
CONFIG_ROCKCHIP_DW_HDMI=y
CONFIG_ROCKCHIP_DW_MIPI_DSI=y
CONFIG_ROCKCHIP_INNO_HDMI=y
CONFIG_DRM_ATMEL_HLCDC=m
CONFIG_DRM_RCAR_DU=m
CONFIG_DRM_RCAR_LVDS=y
CONFIG_DRM_SUN4I=m
CONFIG_DRM_TEGRA=y
CONFIG_DRM_PANEL_SAMSUNG_LD9040=m
CONFIG_DRM_VC4=y
CONFIG_FB_ARMCLCD=y
CONFIG_FB_EFI=y
CONFIG_FB_WM8505=y
CONFIG_FB_SH_MOBILE_LCDC=y
CONFIG_FB_SIMPLE=y
CONFIG_FB_SH_MOBILE_MERAM=y
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_LCD_PLATFORM=m
CONFIG_BACKLIGHT_AS3711=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_HDA_TEGRA=m
CONFIG_SND_HDA_INPUT_BEEP=y
CONFIG_SND_HDA_PATCH_LOADER=y
CONFIG_SND_HDA_CODEC_REALTEK=m
CONFIG_SND_HDA_CODEC_HDMI=m
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_ATMEL_SOC_WM8904=m
CONFIG_SND_ATMEL_SOC_PDMIC=m
CONFIG_SND_BCM2835_SOC_I2S=m
CONFIG_SND_SOC_ROCKCHIP=m
CONFIG_SND_SOC_ROCKCHIP_SPDIF=m
CONFIG_SND_SOC_ROCKCHIP_MAX98090=m
CONFIG_SND_SOC_ROCKCHIP_RT5645=m
CONFIG_SND_SOC_SAMSUNG=m
CONFIG_SND_SOC_SAMSUNG_SMDK_WM8994=m
CONFIG_SND_SOC_SMDK_WM8994_PCM=m
CONFIG_SND_SOC_SNOW=m
CONFIG_SND_SOC_SH4_FSI=m
CONFIG_SND_SOC_RCAR=m
CONFIG_SND_SIMPLE_SCU_CARD=m
CONFIG_SND_SUN4I_CODEC=m
CONFIG_SND_SOC_TEGRA=m
CONFIG_SND_SOC_TEGRA20_I2S=m
CONFIG_SND_SOC_TEGRA30_I2S=m
CONFIG_SND_SOC_TEGRA_RT5640=m
CONFIG_SND_SOC_TEGRA_WM8753=m
CONFIG_SND_SOC_TEGRA_WM8903=m
CONFIG_SND_SOC_TEGRA_WM9712=m
CONFIG_SND_SOC_TEGRA_TRIMSLICE=m
CONFIG_SND_SOC_TEGRA_ALC5632=m
CONFIG_SND_SOC_TEGRA_MAX98090=m
CONFIG_SND_SOC_SPDIF=m
CONFIG_SND_SOC_STI=m
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_MVEBU=y
CONFIG_USB_XHCI_RCAR=m
CONFIG_USB_XHCI_TEGRA=m
CONFIG_USB_XHCI_PLATFORM=m
CONFIG_USB_EHCI_MSM=m
CONFIG_USB_EHCI_EXYNOS=y
CONFIG_USB_EHCI_TEGRA=y
CONFIG_USB_EHCI_HCD_STI=y
CONFIG_USB_EHCI_HCD_PLATFORM=y
CONFIG_USB_ISP1760=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_STI=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
CONFIG_USB_OHCI_EXYNOS=m
CONFIG_USB_R8A66597_HCD=m
CONFIG_USB_RENESAS_USBHS=m
CONFIG_USB_STORAGE=y
CONFIG_USB_MUSB_SUNXI=m
CONFIG_USB_CHIPIDEA_UDC=y
CONFIG_USB_CHIPIDEA_HOST=y
CONFIG_AB8500_USB=y
CONFIG_KEYSTONE_USB_PHY=y
CONFIG_USB_GPIO_VBUS=y
CONFIG_USB_ISP1301=y
CONFIG_USB_MSM_OTG=m
CONFIG_USB_MXS_PHY=y
CONFIG_USB_FSL_USB2=y
CONFIG_USB_RENESAS_USBHS_UDC=m
CONFIG_MMC_BLOCK_MINORS=16
CONFIG_MMC_ARMMMCI=y
CONFIG_MMC_SDHCI_OF_ARASAN=y
CONFIG_MMC_SDHCI_OF_AT91=y
CONFIG_MMC_SDHCI_OF_ESDHC=y
CONFIG_MMC_SDHCI_ESDHC_IMX=y
CONFIG_MMC_SDHCI_DOVE=y
CONFIG_MMC_SDHCI_TEGRA=y
CONFIG_MMC_SDHCI_PXAV3=y
CONFIG_MMC_SDHCI_SPEAR=y
CONFIG_MMC_SDHCI_S3C=y
CONFIG_MMC_SDHCI_S3C_DMA=y
CONFIG_MMC_SDHCI_BCM_KONA=y
CONFIG_MMC_SDHCI_ST=y
CONFIG_MMC_OMAP=y
CONFIG_MMC_ATMELMCI=y
CONFIG_MMC_SDHCI_MSM=y
CONFIG_MMC_MVSDIO=y
CONFIG_MMC_SDHI=y
CONFIG_MMC_DW_PLTFM=y
CONFIG_MMC_DW_EXYNOS=y
CONFIG_MMC_DW_ROCKCHIP=y
CONFIG_MMC_SH_MMCIF=y
CONFIG_MMC_SUNXI=y
CONFIG_MMC_BCM2835=y
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS_FLASH=m
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_PWM=y
CONFIG_LEDS_MAX77693=m
CONFIG_LEDS_MAX8997=m
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_LEDS_TRIGGER_TRANSIENT=y
CONFIG_LEDS_TRIGGER_CAMERA=y
CONFIG_EDAC_HIGHBANK_MC=y
CONFIG_EDAC_HIGHBANK_L2=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_DRV_AC100=y
CONFIG_RTC_DRV_AS3722=y
CONFIG_RTC_DRV_MAX8907=y
CONFIG_RTC_DRV_MAX8998=m
CONFIG_RTC_DRV_MAX8997=m
CONFIG_RTC_DRV_MAX77686=y
CONFIG_RTC_DRV_RK808=m
CONFIG_RTC_DRV_ST_LPC=y
CONFIG_RTC_DRV_DA9063=m
CONFIG_RTC_DRV_EFI=m
CONFIG_RTC_DRV_DIGICOLOR=m
CONFIG_RTC_DRV_S5M=m
CONFIG_RTC_DRV_S3C=m
CONFIG_RTC_DRV_PL031=y
CONFIG_RTC_DRV_AT91RM9200=m
CONFIG_RTC_DRV_AT91SAM9=m
CONFIG_RTC_DRV_VT8500=y
CONFIG_RTC_DRV_SUN6I=y
CONFIG_RTC_DRV_SUNXI=y
CONFIG_RTC_DRV_MV=y
CONFIG_RTC_DRV_TEGRA=y
CONFIG_DMADEVICES=y
CONFIG_DW_DMAC=y
CONFIG_AT_HDMAC=y
CONFIG_AT_XDMAC=y
CONFIG_FSL_EDMA=y
CONFIG_MV_XOR=y
CONFIG_TEGRA20_APB_DMA=y
CONFIG_SH_DMAE=y
CONFIG_RCAR_DMAC=y
CONFIG_RENESAS_USB_DMAC=m
CONFIG_STE_DMA40=y
CONFIG_SIRF_DMA=y
CONFIG_TI_EDMA=y
CONFIG_PL330_DMA=y
CONFIG_IMX_SDMA=y
CONFIG_IMX_DMA=y
CONFIG_MXS_DMA=y
CONFIG_DMA_BCM2835=y
CONFIG_DMA_OMAP=y
CONFIG_QCOM_BAM_DMA=y
CONFIG_XILINX_DMA=y
CONFIG_DMA_SUN6I=y
CONFIG_ST_FDMA=m
CONFIG_SENSORS_ISL29018=y
CONFIG_SENSORS_ISL29028=y
CONFIG_MFD_NVEC=y
CONFIG_KEYBOARD_NVEC=y
CONFIG_SERIO_NVEC_PS2=y
CONFIG_NVEC_POWER=y
CONFIG_NVEC_PAZ00=y
CONFIG_BCMA=y
CONFIG_BCMA_HOST_SOC=y
CONFIG_BCMA_DRIVER_GMAC_CMN=y
CONFIG_BCMA_DRIVER_GPIO=y
CONFIG_QCOM_GSBI=y
CONFIG_QCOM_PM=y
CONFIG_QCOM_SMEM=y
CONFIG_QCOM_SMD_RPM=y
CONFIG_QCOM_SMP2P=y
CONFIG_QCOM_SMSM=y
CONFIG_QCOM_WCNSS_CTRL=m
CONFIG_ROCKCHIP_PM_DOMAINS=y
CONFIG_COMMON_CLK_QCOM=y
CONFIG_QCOM_CLK_RPM=y
CONFIG_STAGING_BOARD=y
CONFIG_CROS_EC_CHARDEV=m
CONFIG_COMMON_CLK_MAX77686=y
CONFIG_COMMON_CLK_RK808=m
CONFIG_COMMON_CLK_S2MPS11=m
CONFIG_APQ_MMCC_8084=y
CONFIG_MSM_GCC_8660=y
CONFIG_MSM_MMCC_8960=y
CONFIG_MSM_MMCC_8974=y
CONFIG_HWSPINLOCK_QCOM=y
CONFIG_ROCKCHIP_IOMMU=y
CONFIG_TEGRA_IOMMU_GART=y
CONFIG_TEGRA_IOMMU_SMMU=y
CONFIG_ST_REMOTEPROC=m
CONFIG_ARM_TEGRA_DEVFREQ=m
CONFIG_MEMORY=y
CONFIG_TI_AEMIF=y
CONFIG_IIO=y
CONFIG_IIO_SW_TRIGGER=y
CONFIG_AT91_ADC=m
CONFIG_AT91_SAMA5D2_ADC=m
CONFIG_BERLIN2_ADC=m
CONFIG_EXYNOS_ADC=m
CONFIG_VF610_ADC=m
CONFIG_XILINX_XADC=y
CONFIG_MPU3050_I2C=y
CONFIG_CM36651=m
CONFIG_AK8975=y
CONFIG_RASPBERRYPI_POWER=y
CONFIG_IIO_HRTIMER_TRIGGER=y
CONFIG_PWM=y
CONFIG_PWM_ATMEL=m
CONFIG_PWM_ATMEL_HLCDC_PWM=m
CONFIG_PWM_ATMEL_TCB=m
CONFIG_PWM_FSL_FTM=m
CONFIG_PWM_RENESAS_TPU=y
CONFIG_PWM_ROCKCHIP=m
CONFIG_PWM_SAMSUNG=m
CONFIG_PWM_SUN4I=y
CONFIG_PWM_TEGRA=y
CONFIG_PWM_VT8500=y
CONFIG_PHY_HIX5HD2_SATA=y
CONFIG_PWM_STI=y
CONFIG_PWM_BCM2835=y
CONFIG_PWM_BRCMSTB=m
CONFIG_GENERIC_PHY=y
CONFIG_OMAP_USB2=y
CONFIG_TI_PIPE3=y
CONFIG_PHY_BERLIN_USB=y
CONFIG_PHY_BERLIN_SATA=y
CONFIG_PHY_ROCKCHIP_DP=m
CONFIG_PHY_ROCKCHIP_USB=y
CONFIG_PHY_QCOM_APQ8064_SATA=m
CONFIG_PHY_MIPHY28LP=y
CONFIG_PHY_RCAR_GEN2=m
CONFIG_PHY_STIH407_USB=y
CONFIG_PHY_SUN4I_USB=y
CONFIG_PHY_SUN9I_USB=y
CONFIG_PHY_SAMSUNG_USB2=m
CONFIG_PHY_TEGRA_XUSB=y
CONFIG_PHY_BRCM_SATA=y
CONFIG_NVMEM=y
CONFIG_NVMEM_SUNXI_SID=y
CONFIG_BCM2835_MBOX=y
CONFIG_RASPBERRYPI_FIRMWARE=y
CONFIG_EFI_VARS=m
CONFIG_EFI_CAPSULE_LOADER=m
CONFIG_BCM47XX_NVRAM=y
CONFIG_BCM47XX_SPROM=y
CONFIG_EXT4_FS=y
CONFIG_AUTOFS4_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_NTFS_FS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_UBIFS_FS=y
CONFIG_TMPFS=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
CONFIG_PSTORE=y
CONFIG_PSTORE_CONSOLE=y
CONFIG_PSTORE_PMSG=y
CONFIG_PSTORE_RAM=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_ROOT_NFS=y
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ISO8859_1=y
CONFIG_NLS_UTF8=y
CONFIG_PRINTK_TIME=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_KEYSTONE_IRQ=y
CONFIG_HW_RANDOM=y
CONFIG_HW_RANDOM_ST=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_USER_API_AEAD=m
CONFIG_CRYPTO_DEV_MARVELL_CESA=m
CONFIG_CRYPTO_DEV_EXYNOS_RNG=m
CONFIG_CRYPTO_DEV_S5P=m
CONFIG_CRYPTO_DEV_SUN4I_SS=m
CONFIG_CRYPTO_DEV_ROCKCHIP=m
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=m
CONFIG_CRYPTO_SHA1_ARM_CE=m
CONFIG_CRYPTO_SHA2_ARM_CE=m
CONFIG_CRYPTO_AES_ARM=m
CONFIG_CRYPTO_AES_ARM_CE=m
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_CRC32_ARM_CE=m
CONFIG_CRYPTO_CRCT10DIF_ARM_CE=m
CONFIG_CRYPTO_GHASH_ARM_CE=m
CONFIG_CRYPTO_DEV_ATMEL_AES=m
CONFIG_CRYPTO_DEV_ATMEL_TDES=m
CONFIG_CRYPTO_DEV_ATMEL_SHA=m
CONFIG_VIDEO_VIVID=m
CONFIG_VIRTIO=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_PCI_LEGACY=y
CONFIG_VIRTIO_MMIO=y
# Add config flags here that only appear in the multi_v7_defconfig
CONFIG_ARCH_ALPINE=n
CONFIG_ARCH_ARTPEC=n
CONFIG_ARCH_AT91=n
CONFIG_ARCH_BCM=n
CONFIG_ARCH_BCM_CYGNUS=n
CONFIG_ARCH_BCM_NSP=n
CONFIG_ARCH_BCM_5301X=n
CONFIG_ARCH_BCM_281XX=n
CONFIG_ARCH_BCM_21664=n
CONFIG_ARCH_BRCMSTB=n
CONFIG_ARCH_BERLIN=n
CONFIG_ARCH_DIGICOLOR=n
CONFIG_ARCH_HIGHBANK=n
CONFIG_ARCH_HISI=n
CONFIG_ARCH_HI3xxx=n
CONFIG_ARCH_HIP01=n
CONFIG_ARCH_HIP04=n
CONFIG_ARCH_HIX5HD2=n
CONFIG_ARCH_MESON=n
CONFIG_ARCH_MXC=n
CONFIG_ARCH_MEDIATEK=n
CONFIG_ARCH_QCOM=n
CONFIG_ARCH_MSM8X60=n
CONFIG_ARCH_MSM8960=n
CONFIG_ARCH_MSM8974=n
CONFIG_ARCH_ROCKCHIP=n
CONFIG_ARCH_SOCFPGA=n
CONFIG_ARCH_SPEAR13XX=n
CONFIG_ARCH_STI=n
CONFIG_ARCH_EXYNOS=n
CONFIG_ARCH_SHMOBILE_MULTI=n
CONFIG_ARCH_EMEV2=n
CONFIG_ARCH_R7S72100=n
CONFIG_ARCH_R8A73A4=n
CONFIG_ARCH_R8A7740=n
CONFIG_ARCH_R8A7778=n
CONFIG_ARCH_R8A7779=n
CONFIG_ARCH_R8A7790=n
CONFIG_ARCH_R8A7791=n
CONFIG_ARCH_R8A7793=n
CONFIG_ARCH_R8A7794=n
CONFIG_ARCH_RENESAS=n
CONFIG_ARCH_SH73A0=n
CONFIG_ARCH_SUNXI=n
CONFIG_ARCH_SIRF=n
CONFIG_ARCH_TEGRA=n
CONFIG_ARCH_TEGRA_2x_SOC=n
CONFIG_ARCH_TEGRA_3x_SOC=n
CONFIG_ARCH_TEGRA_114_SOC=n
CONFIG_ARCH_TEGRA_124_SOC=n
CONFIG_ARCH_UNIPHIER=n
CONFIG_ARCH_U8500=n
CONFIG_ARCH_VEXPRESS=n
CONFIG_ARCH_VEXPRESS_TC2_PM=n
CONFIG_ARCH_WM8850=n
CONFIG_ARCH_ZYNQ=n
CONFIG_ARCH_VIRT=n
CONFIG_ARCH_MVEBU=n
CONFIG_PLAT_SPEAR=n
CONFIG_CHROME_PLATFORMS=n
# TI Baseport Config Options
# Kernel compression
CONFIG_KERNEL_GZIP=n
CONFIG_KERNEL_LZMA=y
CONFIG_KERNEL_LZ4=n
CONFIG_KERNEL_XZ=n
CONFIG_KERNEL_LZO=n
# Enable process accounting
CONFIG_BSD_PROCESS_ACCT=y
# Have some way to pick up kernel config later on
# Always useful to look at /proc/config.gz
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
# Add Bin2c
CONFIG_BUILD_BIN2C=y
# Add base Cgroups functions
CONFIG_CGROUP_DEBUG=n
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_MEMCG_SWAP_ENABLED=y
CONFIG_DEBUG_BLK_CGROUP=n
CONFIG_CGROUP_WRITEBACK=y
# Choose CONFIG_EMBEDDED
CONFIG_EMBEDDED=y
CONFIG_EXPERT=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
# Enable all kernel symbols please
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
# Enable AEABI
CONFIG_AEABI=y
# How do we want kernel Modules to work?
CONFIG_BASE_FULL=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
CONFIG_MODULE_SIG=n
CONFIG_MODULE_COMPRESS=n
CONFIG_MODULES_TREE_LOOKUP=y
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
CONFIG_DEPRECATED_PARAM_STRUCT=n
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND=n
CONFIG_CMDLINE=""
CONFIG_CMDLINE_FROM_BOOTLOADER=y
CONFIG_CMDLINE_EXTEND=n
CONFIG_CMDLINE_FORCE=n
CONFIG_ATAGS_PROC=y
CONFIG_CRASH_DUMP=n
CONFIG_AUTO_ZRELADDR=y
# Mem allocator
CONFIG_SLAB=n
CONFIG_SLUB=y
# Enable NEON
CONFIG_VFP=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
# POSIX Message queue
CONFIG_POSIX_MQUEUE=y
# No Multi Cluster systems in TI yet..
CONFIG_MCPM=n
# Serial
CONFIG_SERIAL_8250_OMAP=y
CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
CONFIG_SERIAL_8250_NR_UARTS=10
CONFIG_SERIAL_8250_RUNTIME_UARTS=10
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_OMAP=n
CONFIG_SERIAL_8250_DW=n
CONFIG_SERIAL_8250_EM=n
CONFIG_SERIAL_AMBA_PL011=n
CONFIG_SERIAL_XILINX_PS_UART=n
CONFIG_SERIAL_FSL_LPUART=n
CONFIG_SERIAL_CONEXANT_DIGICOLOR=n
CONFIG_SERIAL_ST_ASC=n
CONFIG_JUMP_LABEL=y
# Disable Extra debug options
CONFIG_TIMER_STATS=n
CONFIG_DEBUG_SPINLOCK=n
CONFIG_DEBUG_MUTEXES=n
CONFIG_DEBUG_LOCK_ALLOC=n
CONFIG_PROVE_LOCKING=n
CONFIG_LOCKDEP=n
CONFIG_STACKTRACE=n
CONFIG_FTRACE=n
CONFIG_ARM_UNWIND=n
CONFIG_DEBUG_PREEMPT=n
CONFIG_SLUB_DEBUG=n
CONFIG_LOCKUP_DETECTOR=n
CONFIG_DETECT_HUNG_TASK=n
CONFIG_IRQ_DOMAIN_DEBUG=n
CONFIG_DEBUG_BUGVERBOSE=n
CONFIG_DEBUG_FS=y
# Enable System V IPC
CONFIG_SYSVIPC=y
# Power management options
CONFIG_SUSPEND_FREEZER=y
CONFIG_SUSPEND_SKIP_SYNC=n
CONFIG_HIBERNATION=n
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
CONFIG_PM_AUTOSLEEP=n
CONFIG_PM_WAKELOCKS=n
CONFIG_PM=y
CONFIG_PM_DEBUG=y
CONFIG_APM_EMULATION=n
CONFIG_PM_OPP=y
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=n
CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
CONFIG_PM_GENERIC_DOMAINS_OF=y
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# Clock framework stuff we need
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
CONFIG_COMMON_CLK_SI5351=n
CONFIG_COMMON_CLK_SI514=n
CONFIG_COMMON_CLK_SI570=n
CONFIG_COMMON_CLK_CDCE925=n
CONFIG_CLK_TWL6040=n
CONFIG_CLK_QORIQ=n
CONFIG_COMMON_CLK_PALMAS=y
CONFIG_COMMON_CLK_PWM=n
CONFIG_COMMON_CLK_PXA=n
CONFIG_COMMON_CLK_CDCE706=n
CONFIG_CLKSRC_OF=y
CONFIG_CLKSRC_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_CLKSRC_TI_32K=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
CONFIG_ARM_GLOBAL_TIMER=n
CONFIG_ARM_TIMER_SP804=n
# Clock cleanup please
CONFIG_OMAP_RESET_CLOCKS=y
# CPU Idle
CONFIG_CPU_IDLE_GOV_LADDER=y
CONFIG_CPU_IDLE_GOV_MENU=y
CONFIG_DT_IDLE_STATES=y
# ARM CPU Idle Drivers
CONFIG_ARM_CPUIDLE=y
CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=n
# CPU Frequency scaling
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_STAT_DETAILS=y
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
# CPUFreq Driver Options
CONFIG_CPUFREQ_DT=y
CONFIG_ARM_BIG_LITTLE_CPUFREQ=n
CONFIG_ARM_KIRKWOOD_CPUFREQ=n
CONFIG_ARM_OMAP2PLUS_CPUFREQ=n
CONFIG_ARM_TI_CPUFREQ=y
CONFIG_QORIQ_CPUFREQ=n
# AMx3 Power Config Options
CONFIG_MAILBOX=y
CONFIG_WKUP_M3_RPROC=m
CONFIG_SOC_TI=y
CONFIG_SOC_BRCMSTB=n
CONFIG_WKUP_M3_IPC=m
CONFIG_AMX3_PM=m
CONFIG_SRAM=y
CONFIG_TI_EMIF_SRAM=m
CONFIG_SUNXI_SRAM=n
CONFIG_PM_DEVFREQ=n
# K2G Power config options
# CONFIG_MAILBOX is enabled in AMx3
CONFIG_TI_MESSAGE_MANAGER=y
CONFIG_TI_SCI_PROTOCOL=y
CONFIG_TI_SCI_PM_DOMAINS=y
CONFIG_TI_SCI_CLK=y
# Enable Reset Controllers
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_TI_SYSCON=y
CONFIG_RESET_TI_SCI=y
# CPUFreq and OPP drivers
CONFIG_OPP_DOMAIN_TI=y
# Thermal
CONFIG_THERMAL=y
CONFIG_THERMAL_OF=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
CONFIG_THERMAL_GOV_FAIR_SHARE=y
CONFIG_THERMAL_GOV_STEP_WISE=y
CONFIG_THERMAL_GOV_BANG_BANG=y
CONFIG_THERMAL_GOV_USER_SPACE=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_CPU_THERMAL=y
CONFIG_TI_SOC_THERMAL=y
CONFIG_TI_THERMAL=y
CONFIG_OMAP4_THERMAL=y
CONFIG_OMAP5_THERMAL=y
CONFIG_DRA752_THERMAL=y
# Since HWMON is needed by Sensors..
CONFIG_HWMON=y
CONFIG_SENSORS_TMP102=y
CONFIG_SENSORS_GPIO_FAN=y
# Enable the reset framework
CONFIG_POWER_RESET=y
CONFIG_POWER_SUPPLY=y
# Pinctrl
CONFIG_PINCTRL_TI_IODELAY=y
CONFIG_PINCTRL_SINGLE=y
# Multifunction device drivers
CONFIG_MFD_CORE=y
CONFIG_MFD_AS3711=n
CONFIG_MFD_AS3722=n
CONFIG_PMIC_ADP5520=n
CONFIG_MFD_AAT2870_CORE=n
CONFIG_MFD_ATMEL_FLEXCOM=n
CONFIG_MFD_ATMEL_HLCDC=n
CONFIG_MFD_BCM590XX=n
CONFIG_MFD_AXP20X=n
CONFIG_MFD_AXP20X_I2C=n
CONFIG_MFD_CROS_EC=n
CONFIG_MFD_CROS_EC_I2C=n
CONFIG_MFD_CROS_EC_SPI=n
CONFIG_MFD_ASIC3=n
CONFIG_PMIC_DA903X=n
CONFIG_MFD_DA9052_SPI=n
CONFIG_MFD_DA9052_I2C=n
CONFIG_MFD_DA9055=n
CONFIG_MFD_DA9062=n
CONFIG_MFD_DA9063=n
CONFIG_MFD_DA9150=n
CONFIG_MFD_DLN2=n
CONFIG_MFD_MC13XXX_SPI=n
CONFIG_MFD_MC13XXX_I2C=n
CONFIG_MFD_HI6421_PMIC=n
CONFIG_HTC_EGPIO=n
CONFIG_HTC_PASIC3=n
CONFIG_HTC_I2CPLD=n
CONFIG_LPC_ICH=n
CONFIG_LPC_SCH=n
CONFIG_INTEL_SOC_PMIC=n
CONFIG_MFD_JANZ_CMODIO=n
CONFIG_MFD_KEMPLD=n
CONFIG_MFD_88PM800=n
CONFIG_MFD_88PM805=n
CONFIG_MFD_88PM860X=n
CONFIG_MFD_MAX14577=n
CONFIG_MFD_MAX77686=n
CONFIG_MFD_MAX77693=n
CONFIG_MFD_MAX77843=n
CONFIG_MFD_MAX8907=n
CONFIG_MFD_MAX8925=n
CONFIG_MFD_MAX8997=n
CONFIG_MFD_MAX8998=n
CONFIG_MFD_MT6397=n
CONFIG_MFD_MENF21BMC=n
CONFIG_EZX_PCAP=n
CONFIG_MFD_VIPERBOARD=n
CONFIG_MFD_RETU=n
CONFIG_MFD_PCF50633=n
CONFIG_MFD_PM8XXX=n
CONFIG_MFD_PM8921_CORE=n
CONFIG_MFD_RDC321X=n
CONFIG_MFD_RTSX_PCI=n
CONFIG_MFD_RT5033=n
CONFIG_MFD_RTSX_USB=n
CONFIG_MFD_RC5T583=n
CONFIG_MFD_RK808=n
CONFIG_MFD_RN5T618=n
CONFIG_MFD_SEC_CORE=n
CONFIG_MFD_SI476X_CORE=n
CONFIG_MFD_SM501=n
CONFIG_MFD_SKY81452=n
CONFIG_MFD_SMSC=n
CONFIG_ABX500_CORE=n
CONFIG_AB3100_CORE=n
CONFIG_MFD_STMPE=n
CONFIG_STMPE_I2C=n
CONFIG_STMPE_SPI=n
CONFIG_MFD_SYSCON=y
CONFIG_MFD_TI_AM335X_TSCADC=m
CONFIG_MFD_LP3943=n
CONFIG_MFD_LP8788=n
CONFIG_MFD_OMAP_USB_HOST=y
CONFIG_MFD_PALMAS=y
CONFIG_TPS6105X=n
CONFIG_TPS65010=n
CONFIG_TPS6507X=n
CONFIG_MFD_TPS65086=n
CONFIG_MFD_TPS65090=y
CONFIG_MFD_TPS65217=y
CONFIG_MFD_TPS65218=y
CONFIG_MFD_TPS6586X=y
CONFIG_MFD_TPS65910=y
CONFIG_MFD_TPS65912_I2C=n
CONFIG_MFD_TPS65912_SPI=n
CONFIG_MFD_TPS80031=n
CONFIG_TWL4030_CORE=n
CONFIG_TWL4030_POWER=n
CONFIG_MFD_TWL4030_AUDIO=n
CONFIG_TWL6040_CORE=y
CONFIG_MFD_WL1273_CORE=n
CONFIG_MFD_LM3533=n
CONFIG_MFD_TI_LP873X=y
CONFIG_MFD_TI_LP87565=y
CONFIG_MFD_TC3589X=n
CONFIG_MFD_TMIO=n
CONFIG_MFD_T7L66XB=n
CONFIG_MFD_TC6387XB=n
CONFIG_MFD_TC6393XB=n
CONFIG_MFD_VX855=n
CONFIG_MFD_ARIZONA_I2C=n
CONFIG_MFD_ARIZONA_SPI=n
CONFIG_MFD_WM8400=n
CONFIG_MFD_WM831X_I2C=n
CONFIG_MFD_WM831X_SPI=n
CONFIG_MFD_WM8350_I2C=n
CONFIG_MFD_WM8994=n
CONFIG_MFD_VEXPRESS_SYSREG=n
# Regulators
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_DEBUG=n
CONFIG_REGULATOR_VIRTUAL_CONSUMER=n
CONFIG_REGULATOR_USERSPACE_CONSUMER=n
CONFIG_REGULATOR_ACT8865=n
CONFIG_REGULATOR_AD5398=n
CONFIG_REGULATOR_ANATOP=n
CONFIG_REGULATOR_AS3711=n
CONFIG_REGULATOR_AS3722=n
CONFIG_REGULATOR_AXP20X=n
CONFIG_REGULATOR_BCM590XX=n
CONFIG_REGULATOR_DA9210=n
CONFIG_REGULATOR_DA9211=n
CONFIG_REGULATOR_FAN53555=n
CONFIG_REGULATOR_GPIO=y
CONFIG_REGULATOR_ISL9305=n
CONFIG_REGULATOR_ISL6271A=n
CONFIG_REGULATOR_LP3971=n
CONFIG_REGULATOR_LP3972=n
CONFIG_REGULATOR_LP872X=n
CONFIG_REGULATOR_LP8755=n
CONFIG_REGULATOR_LP873X=y
CONFIG_REGULATOR_LP87565=y
CONFIG_REGULATOR_LTC3589=n
CONFIG_REGULATOR_MAX14577=n
CONFIG_REGULATOR_MAX1586=n
CONFIG_REGULATOR_MAX8649=n
CONFIG_REGULATOR_MAX8660=n
CONFIG_REGULATOR_MAX8907=n
CONFIG_REGULATOR_MAX8952=n
CONFIG_REGULATOR_MAX8973=n
CONFIG_REGULATOR_MAX77686=n
CONFIG_REGULATOR_MAX77693=n
CONFIG_REGULATOR_MAX77802=n
CONFIG_REGULATOR_MT6311=n
CONFIG_REGULATOR_PALMAS=y
CONFIG_REGULATOR_PBIAS=y
CONFIG_REGULATOR_PFUZE100=n
CONFIG_REGULATOR_PWM=n
CONFIG_REGULATOR_RK808=n
CONFIG_REGULATOR_S2MPA01=n
CONFIG_REGULATOR_S2MPS11=n
CONFIG_REGULATOR_S5M8767=n
CONFIG_REGULATOR_TI_ABB=y
CONFIG_REGULATOR_TPS51632=n
CONFIG_REGULATOR_TPS62360=y
CONFIG_REGULATOR_TPS65023=y
CONFIG_REGULATOR_TPS6507X=y
CONFIG_REGULATOR_TPS65090=y
CONFIG_REGULATOR_TPS65217=y
CONFIG_REGULATOR_TPS65218=y
CONFIG_REGULATOR_TPS6524X=y
CONFIG_REGULATOR_TPS6586X=y
CONFIG_REGULATOR_TPS65910=y
CONFIG_REGULATOR_TWL4030=n
CONFIG_REGULATOR_VEXPRESS=n
# Crypto Modules
CONFIG_CRYPTO_DEV_OMAP=m
CONFIG_CRYPTO_DEV_OMAP_SHAM=m
CONFIG_CRYPTO_DEV_OMAP_AES=m
CONFIG_CRYPTO_DEV_OMAP_DES=m
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_SHA1_ARM_NEON=m
CONFIG_CRYPTO_SHA256_ARM=m
CONFIG_CRYPTO_SHA512_ARM=m
CONFIG_CRYPTO_AES_ARM_BS=m
# RTC drivers
CONFIG_RTC_DRV_ABB5ZES3=n
CONFIG_RTC_DRV_ABX80X=n
CONFIG_RTC_DRV_DS1307=m
CONFIG_RTC_DRV_DS1374=n
CONFIG_RTC_DRV_DS1672=n
CONFIG_RTC_DRV_DS3232=n
CONFIG_RTC_DRV_HYM8563=n
CONFIG_RTC_DRV_MAX6900=n
CONFIG_RTC_DRV_RS5C372=n
CONFIG_RTC_DRV_ISL1208=n
CONFIG_RTC_DRV_ISL12022=n
CONFIG_RTC_DRV_ISL12057=n
CONFIG_RTC_DRV_X1205=n
CONFIG_RTC_DRV_PALMAS=m
CONFIG_RTC_DRV_PCF2127=n
CONFIG_RTC_DRV_PCF8523=n
CONFIG_RTC_DRV_PCF8563=n
CONFIG_RTC_DRV_PCF85063=n
CONFIG_RTC_DRV_PCF8583=n
CONFIG_RTC_DRV_M41T80=n
CONFIG_RTC_DRV_BQ32K=n
CONFIG_RTC_DRV_TPS6586X=m
CONFIG_RTC_DRV_TPS65910=m
CONFIG_RTC_DRV_TWL92330=y
CONFIG_RTC_DRV_TWL4030=n
CONFIG_RTC_DRV_S35390A=n
CONFIG_RTC_DRV_FM3130=n
CONFIG_RTC_DRV_RX8581=n
CONFIG_RTC_DRV_RX8025=n
CONFIG_RTC_DRV_EM3027=n
CONFIG_RTC_DRV_RV3029C2=n
CONFIG_RTC_DRV_RV8803=n
CONFIG_RTC_DRV_M41T93=n
CONFIG_RTC_DRV_M41T94=n
CONFIG_RTC_DRV_DS1305=n
CONFIG_RTC_DRV_DS1343=n
CONFIG_RTC_DRV_DS1347=n
CONFIG_RTC_DRV_DS1390=n
CONFIG_RTC_DRV_MAX6902=n
CONFIG_RTC_DRV_R9701=n
CONFIG_RTC_DRV_RS5C348=n
CONFIG_RTC_DRV_DS3234=n
CONFIG_RTC_DRV_PCF2123=n
CONFIG_RTC_DRV_RX4581=n
CONFIG_RTC_DRV_MCP795=n
CONFIG_RTC_DRV_CMOS=n
CONFIG_RTC_DRV_DS1286=n
CONFIG_RTC_DRV_DS1511=n
CONFIG_RTC_DRV_DS1553=n
CONFIG_RTC_DRV_DS1685_FAMILY=n
CONFIG_RTC_DRV_DS1742=n
CONFIG_RTC_DRV_DS2404=n
CONFIG_RTC_DRV_STK17TA8=n
CONFIG_RTC_DRV_M48T86=n
CONFIG_RTC_DRV_M48T35=n
CONFIG_RTC_DRV_M48T59=n
CONFIG_RTC_DRV_MSM6242=n
CONFIG_RTC_DRV_BQ4802=n
CONFIG_RTC_DRV_RP5C01=n
CONFIG_RTC_DRV_V3020=n
CONFIG_RTC_DRV_ZYNQMP=n
CONFIG_RTC_DRV_OMAP=m
CONFIG_RTC_DRV_SNVS=n
CONFIG_RTC_DRV_HID_SENSOR_TIME=n
# WatchDog
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
CONFIG_WATCHDOG_NOWAYOUT=n
# Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=n
CONFIG_GPIO_WATCHDOG=n
CONFIG_XILINX_WATCHDOG=n
CONFIG_CADENCE_WATCHDOG=n
CONFIG_DW_WATCHDOG=n
CONFIG_OMAP_WATCHDOG=m
CONFIG_TWL4030_WATCHDOG=m
CONFIG_MAX63XX_WATCHDOG=n
CONFIG_ALIM7101_WDT=n
CONFIG_I6300ESB_WDT=n
CONFIG_BCM7038_WDT=n
CONFIG_MEN_A21_WDT=n
# No Staging drivers please
CONFIG_STAGING=n
# GPIO
CONFIG_GPIOLIB=y
CONFIG_GPIO_SYSFS=y
CONFIG_DEBUG_GPIO=y
# GPIO disable unused options
CONFIG_GPIO_DWAPB=n
CONFIG_GPIO_EM=n
CONFIG_GPIO_GENERIC_PLATFORM=n
CONFIG_GPIO_XILINX=n
CONFIG_GPIO_TPS6586X=n
# Enable options to facilitate testing
CONFIG_CRYPTO_TEST=m
CONFIG_RTC_DEBUG=y
CONFIG_THERMAL_EMULATION=y
# OPTEE Driver
CONFIG_TEE=y
CONFIG_OPTEE=y
# TI RPMsg/IPC Config Options
# HwSpinLock
CONFIG_HWSPINLOCK=y
CONFIG_HWSPINLOCK_OMAP=y
# Mailbox
CONFIG_OMAP2PLUS_MBOX=y
# IOMMU
CONFIG_IOMMU_SUPPORT=y
CONFIG_OMAP_IOMMU=y
CONFIG_OMAP_IOMMU_DEBUG=y
# Remoteproc
CONFIG_REMOTEPROC=m
CONFIG_OMAP_REMOTEPROC=m
CONFIG_KEYSTONE_REMOTEPROC=m
CONFIG_DA8XX_REMOTEPROC=m
CONFIG_PRUSS_REMOTEPROC=m
# RPMsg
CONFIG_RPMSG_VIRTIO=y
CONFIG_RPMSG_PROTO=y
CONFIG_RPMSG_RPC=y
CONFIG_RPMSG_PRU=y
# DSP Memory Mapper for Keystone MPM
CONFIG_KEYSTONE_DSP_MEM=m
# UIO Module
CONFIG_UIO=m
# TI Connectivity Configs
# Disable unused I2C options
CONFIG_I2C_MUX=n
CONFIG_I2C_DESIGNWARE_PLATFORM=n
CONFIG_I2C_GPIO=n
CONFIG_I2C_RK3X=n
CONFIG_I2C_XILINX=n
# I2C GPIO expanders
CONFIG_GPIO_PCF857X=y
CONFIG_GPIO_TPIC2810=m
#Networking drivers
CONFIG_NET_VENDOR_TI=y
CONFIG_KEYSTONE_NAVIGATOR_QMSS=y
CONFIG_KEYSTONE_NAVIGATOR_DMA=y
CONFIG_TI_KEYSTONE_NETCP=y
CONFIG_TI_KEYSTONE_NETCP_ETHSS=y
CONFIG_TI_DAVINCI_EMAC=y
CONFIG_TI_DAVINCI_MDIO=y
CONFIG_TI_DAVINCI_CPDMA=y
CONFIG_TI_CPSW_PHY_SEL=y
CONFIG_TI_CPSW_ALE=y
CONFIG_TI_CPSW=y
CONFIG_TI_CPTS=y
# non-TI Net vendors
CONFIG_NET_DSA_BCM_SF2=n
CONFIG_B53=n
CONFIG_SYSTEMPORT=n
CONFIG_NET_VENDOR_3COM=n
CONFIG_NET_VENDOR_ADAPTEC=n
CONFIG_NET_VENDOR_AGERE=n
CONFIG_NET_VENDOR_ALTEON=n
CONFIG_NET_VENDOR_AMAZON=n
CONFIG_NET_VENDOR_AMD=n
CONFIG_NET_VENDOR_ARC=n
CONFIG_NET_VENDOR_ATHEROS=n
CONFIG_NET_VENDOR_BROCADE=n
CONFIG_NET_VENDOR_CAVIUM=n
CONFIG_NET_VENDOR_CHELSIO=n
CONFIG_NET_CADENCE=n
CONFIG_BCMGENET=n
CONFIG_NET_VENDOR_CIRRUS=n
CONFIG_NET_VENDOR_CISCO=n
CONFIG_NET_VENDOR_DEC=n
CONFIG_NET_VENDOR_DLINK=n
CONFIG_NET_VENDOR_EMULEX=n
CONFIG_NET_VENDOR_EZCHIP=n
CONFIG_NET_VENDOR_EXAR=n
CONFIG_NET_VENDOR_FARADAY=n
CONFIG_NET_VENDOR_HISILICON=n
CONFIG_NET_VENDOR_HP=n
CONFIG_IGB=n
CONFIG_NET_VENDOR_I825XX=n
CONFIG_NET_VENDOR_MELLANOX=n
CONFIG_NET_VENDOR_MICROCHIP=n
CONFIG_NET_VENDOR_MYRI=n
CONFIG_NET_VENDOR_NATSEMI=n
CONFIG_NET_VENDOR_NETRONOME=n
CONFIG_NET_VENDOR_NVIDIA=n
CONFIG_NET_VENDOR_OKI=n
CONFIG_NET_VENDOR_8390=n
CONFIG_NET_VENDOR_QLOGIC=n
CONFIG_NET_VENDOR_QUALCOMM=n
CONFIG_NET_VENDOR_REALTEK=n
CONFIG_NET_VENDOR_RENESAS=n
CONFIG_NET_VENDOR_RDC=n
CONFIG_NET_VENDOR_ROCKER=n
CONFIG_NET_VENDOR_SAMSUNG=n
CONFIG_NET_VENDOR_SILAN=n
CONFIG_NET_VENDOR_SIS=n
CONFIG_NET_VENDOR_SEEQ=n
CONFIG_NET_VENDOR_STMICRO=n
CONFIG_NET_VENDOR_SUN=n
CONFIG_NET_VENDOR_SYNOPSYS=n
CONFIG_NET_VENDOR_TEHUTI=n
CONFIG_NET_VENDOR_VIA=n
CONFIG_NET_VENDOR_WIZNET=n
#Wireless LAN
CONFIG_WLCORE=m
CONFIG_WLCORE_SDIO=m
CONFIG_WL18XX=m
#MDIO phys
CONFIG_MARVELL_PHY=y
CONFIG_MICREL_PHY=y
# unused PHY drivers
CONFIG_BROADCOM_PHY=n
CONFIG_ICPLUS_PHY=n
#PRU MII PHYs for Industrial Boards
CONFIG_DP83848_PHY=y
# Enable phy for DRA72 evm
CONFIG_DP83867_PHY=y
#MTD
CONFIG_OMAP_GPMC=y
CONFIG_MTD_NAND_OMAP2=y
CONFIG_MTD_NAND_OMAP_BCH=y
CONFIG_MTD_NAND_OMAP_BCH_BUILD=y
CONFIG_MTD_TESTS=m
CONFIG_MTD_CMDLINE_PARTS=y
#PCIE
CONFIG_PCI=y
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
CONFIG_PCI_EPF_TEST=y
CONFIG_PCI_ENDPOINT_TEST=m
CONFIG_PCI_DRA7XX=y
CONFIG_PCI_DRA7XX_HOST=y
CONFIG_PCI_DRA7XX_EP=y
CONFIG_PCI_KEYSTONE_EP=y
#These drivers have been used with DRA7x/AM57x PCIe RC with some success
CONFIG_NET_VENDOR_BROADCOM=y
CONFIG_NET_VENDOR_MARVELL=y
CONFIG_NET_VENDOR_INTEL=y
CONFIG_TIGON3=m
CONFIG_SKGE=m
CONFIG_E1000=m
CONFIG_E1000E=m
CONFIG_IWLWIFI=m
CONFIG_IWLDVM=m
CONFIG_IWLMVM=m
#Generic Phys
CONFIG_PHY_TI_KEYSTONE_SERDES=y
# Networking
CONFIG_HSR_PRP=y
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CONNTRACK_IPV4=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_NAT=m
CONFIG_NF_NAT_IPV4=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_BRIDGE=m
CONFIG_XFRM_USER=m
CONFIG_NET_KEY=m
CONFIG_INET=y
CONFIG_INET_AH=m
CONFIG_INET6_AH=m
CONFIG_INET6_IPCOMP=m
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_MODE_TRANSPORT=m
CONFIG_INET_XFRM_MODE_TUNNEL=m
CONFIG_INET_XFRM_MODE_BEET=m
CONFIG_IPV6_TUNNEL=m
CONFIG_NETFILTER=y
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFB=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_DRR=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_CHOKE=m
CONFIG_NET_SCH_QFQ=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
CONFIG_NET_CLS_IND=y
CONFIG_NET_SCH_FIFO=y
CONFIG_IP_SCTP=m
CONFIG_VLAN_8021Q=m
CONFIG_IP_MULTICAST=y
#PRUSS Ethernet driver
CONFIG_TI_PRUETH=m
#MMC/SD support
CONFIG_MMC=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_OMAP_HS=y
CONFIG_MMC_SDHCI_OMAP=y
CONFIG_MMC_DW=n
#SPI
CONFIG_SPI_CADENCE_QUADSPI=y
CONFIG_SPI_TI_QSPI=y
#Disable unused SPI controllers
CONFIG_SPI_BITBANG=n
CONFIG_SPI_CADENCE=n
CONFIG_SPI_ROCKCHIP=n
CONFIG_SPI_XILINX=n
CONFIG_SPI_SPIDEV=n
#Disable SPI NOR 4K SECTORS
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=n
#SPI GPIO expanders
CONFIG_GPIO_PISOSR=m
#SATA
CONFIG_SATA_AHCI_PLATFORM=m
CONFIG_SATA_AHCI=m
CONFIG_ATA=m
#USB gadgets
CONFIG_USB_GADGET=m
CONFIG_USB_AUDIO=m
CONFIG_USB_ETH=m
CONFIG_USB_G_NCM=m
CONFIG_USB_GADGETFS=m
CONFIG_USB_FUNCTIONFS=m
CONFIG_USB_FUNCTIONFS_ETH=y
CONFIG_USB_FUNCTIONFS_RNDIS=y
CONFIG_USB_FUNCTIONFS_GENERIC=y
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET=m
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_G_ACM_MS=m
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_CDC=y
CONFIG_USB_G_HID=m
CONFIG_USB_G_DBGP=m
CONFIG_USB_G_WEBCAM=m
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
CONFIG_USB_ZERO=m
CONFIG_USB_CONFIGFS=m
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_LB_SS=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_UAC1=y
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_MIDI=y
CONFIG_USB_CONFIGFS_F_HID=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_USB_CONFIGFS_F_PRINTER=y
# USB DWC3
CONFIG_USB_DWC3=m
CONFIG_USB_DWC3_DUAL_ROLE=y
CONFIG_USB_DWC3_OMAP=m
CONFIG_USB_DWC3_PCI=n
CONFIG_USB_DWC2=n
CONFIG_USB_CHIPIDEA=n
#USB PHY
CONFIG_NOP_USB_XCEIV=m
#USB MUSB
CONFIG_USB_MUSB_HDRC=m
CONFIG_USB_MUSB_DUAL_ROLE=y
CONFIG_USB_MUSB_OMAP2PLUS=m
CONFIG_USB_MUSB_AM35X=m
CONFIG_USB_MUSB_DSPS=m
CONFIG_USB_MUSB_AM335X_CHILD=m
CONFIG_TI_CPPI41=y
CONFIG_USB_TI_CPPI41_DMA=y
CONFIG_AM335X_CONTROL_USB=y
CONFIG_AM335X_PHY_USB=y
#USB EHCI
CONFIG_USB=m
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_PCI=m
CONFIG_USB_EHCI_HCD_OMAP=m
#USB Networking
CONFIG_USB_USBNET=m
CONFIG_USB_NET_DRIVERS=m
CONFIG_USB_NET_SMSC95XX=m
#USB testing
CONFIG_USB_TEST=m
#USB Serial
CONFIG_USB_ACM=m
CONFIG_USB_SERIAL=m
# Extcon drivers
CONFIG_EXTCON=m
CONFIG_EXTCON_PALMAS=m
CONFIG_EXTCON_USB_GPIO=m
# PWM
CONFIG_PWM_TIECAP=y
CONFIG_PWM_TIEHRPWM=y
CONFIG_PWM_TIPWMSS=y
# 1-wire Bus Masters
CONFIG_W1=m
CONFIG_HDQ_MASTER_OMAP=m
# Matrix keypad
CONFIG_KEYBOARD_MATRIX=m
#Touchscreen/ADC
CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m
CONFIG_TI_AM335X_ADC=m
#CAN
CONFIG_CAN=m
CONFIG_CAN_C_CAN=m
CONFIG_CAN_C_CAN_PLATFORM=m
CONFIG_CAN_M_CAN=m
# Rotary Encoder
CONFIG_INPUT_GPIO_DECODER=m
# Filesystem extra options
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
CONFIG_CIFS=m
CONFIG_CIFS_STATS=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_ACL=y
# TI Audio/Display config options
CONFIG_CMA_SIZE_MBYTES=24
# backlight
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_TLC591XX=y
CONFIG_BACKLIGHT_PWM=y
CONFIG_BACKLIGHT_GPIO=y
CONFIG_BACKLIGHT_LED=y
# fbdev
CONFIG_FB_SSD1307=y
# drm
CONFIG_DRM=y
# SGX driver needs legacy support
CONFIG_DRM_LEGACY=y
CONFIG_DRM_VM=y
# Disable unneeded features
CONFIG_VGA_ARB=n
CONFIG_DRM_I2C_ADV7511=n
CONFIG_DRM_NOUVEAU=n
CONFIG_DRM_EXYNOS=n
CONFIG_DRM_PANEL_SIMPLE=n
CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0=n
CONFIG_DRM_NXP_PTN3460=n
CONFIG_DRM_PARADE_PS8622=n
CONFIG_DRM_STI=n
CONFIG_LCD_CLASS_DEVICE=n
# tilcdc
CONFIG_DRM_I2C_NXP_TDA998X=y
CONFIG_DRM_TILCDC=y
# omapdrm
CONFIG_DRM_OMAP=y
CONFIG_DRM_OMAP_WB=y
CONFIG_OMAP2_DSS=y
CONFIG_OMAP2_DSS_DEBUGFS=y
CONFIG_OMAP2_DSS_DPI=y
CONFIG_OMAP2_DSS_VENC=n
CONFIG_OMAP4_DSS_HDMI=y
CONFIG_OMAP5_DSS_HDMI=y
CONFIG_OMAP2_DSS_SDI=n
CONFIG_OMAP2_DSS_DSI=n
CONFIG_TI_DSS6=y
CONFIG_DRM_OMAP_PANEL_DPI=y
CONFIG_DRM_OMAP_CONNECTOR_HDMI=y
CONFIG_DRM_OMAP_CONNECTOR_DVI=y
CONFIG_DRM_OMAP_DRA7EVM_ENCODER_TPD12S015=y
CONFIG_DRM_OMAP_ENCODER_TPD12S015=y
CONFIG_DRM_OMAP_ENCODER_SII9022=y
CONFIG_DRM_OMAP_ENCODER_TC358768=y
CONFIG_DRM_OMAP_ENCODER_TFP410=y
# sound
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_SOC=y
CONFIG_SND_OMAP_SOC=y
CONFIG_SND_EDMA_SOC=y
CONFIG_SND_DAVINCI_SOC_MCASP=y
CONFIG_SND_AM33XX_SOC_EVM=m
CONFIG_SND_SIMPLE_CARD=m
CONFIG_SND_SOC_TLV320AIC31XX=m
CONFIG_SND_SOC_TLV320AIC3X=m
CONFIG_SND_SOC_HDMI_CODEC=m
CONFIG_SND_OMAP_SOC_HDMI_AUDIO=m
# Disable what we don't want in our config
CONFIG_SND_ARM=n
CONFIG_SND_SPI=n
CONFIG_SND_PCI=n
CONFIG_SND_ATMEL_SOC=n
CONFIG_SND_SOC_FSL_SAI=n
CONFIG_SND_OMAP_SOC_OMAP3_PANDORA=n
CONFIG_SND_SOC_AK4642=n
CONFIG_SND_SOC_SGTL5000=n
CONFIG_SND_SOC_STI_SAS=n
CONFIG_SND_SOC_WM8978=n
# v4l2
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_AM437X_VPFE=m
CONFIG_VIDEO_TI_CAL=m
CONFIG_VIDEO_TI_VIP=m
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_VIDEO_TI_VPE=m
CONFIG_MEDIA_SUBDRV_AUTOSELECT=n
CONFIG_VIDEO_OV2659=m
CONFIG_VIDEO_OV1063X=m
CONFIG_VIDEO_MT9T11X=m
CONFIG_GPIO_PCA953X=m
CONFIG_VIDEO_OV490=m
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
# Touchscreen
CONFIG_TOUCHSCREEN_EDT_FT5X06=m
CONFIG_TOUCHSCREEN_PIXCIR=m
CONFIG_TOUCHSCREEN_GOODIX=m
CONFIG_HID_MULTITOUCH=m
# TI Base OMAP generation SoCs generic default
CONFIG_KEYSTONE2_DMA_COHERENT=n
CONFIG_ARCH_OMAP=y
CONFIG_ARCH_OMAP2PLUS=y
CONFIG_OMAP_INTERCONNECT_BARRIER=y
CONFIG_ARM_PSCI=n
# Maximum Number of processors
CONFIG_NR_CPUS=2
# Kexec
CONFIG_KEXEC=y
# EDAC
CONFIG_EDAC=y
CONFIG_EDAC_TI=m
# TI DRA7 specific config options
# Supported ARM CPUs
CONFIG_ARCH_MULTI_V6=n
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=n
CONFIG_CPU_V6=n
# Enable CONFIG_SMP
CONFIG_SMP=y
# Disable Socs other than DRA7
CONFIG_ARCH_OMAP2=n
CONFIG_ARCH_OMAP3=n
CONFIG_ARCH_OMAP4=n
CONFIG_SOC_OMAP5=n
CONFIG_SOC_AM33XX=n
CONFIG_SOC_AM43XX=n
CONFIG_SOC_DRA7XX=y
CONFIG_ARCH_KEYSTONE=n
CONFIG_ARM_LPAE=y
CONFIG_TI_PTP_BC=y
CONFIG_TI_1PPS_DM_TIMER=y
# Real Time Linux Configs
CONFIG_PREEMPT=y
CONFIG_PREEMPT_RT_BASE=y
CONFIG_PREEMPT_RT_FULL=y
#Disable PM features
CONFIG_CPU_IDLE=n
CONFIG_CPU_FREQ=n
CONFIG_SUSPEND=n
CONFIG_HOTPLUG_CPU=y
# SCHED_DEBUG provides a lot of additional options for scheduler
# tuning in /proc/sys/kernel/ and allows to see scheduler statistic in
# /proc/sched_debug
# CONFIG_SCHED_DEBUG
# --- RCU optimization options to reduce OS jitter
# RCU_BOOST : This option boosts the priority of preempted RCU readers that
# block the current preemptible RCU grace period for too long.
# This option also prevents heavy loads from blocking RCU
# callback invocation for all flavors of RCU
# CONFIG_RCU_BOOST=n
# RCU_NOCB_CPU : Use this option to reduce OS jitter for aggressive HPC or
# real-time workloads.	It can also be used to offload RCU
# callback invocation to energy-efficient CPUs in battery-powered
# asymmetric multiprocessors.
# CONFIG_RCU_NOCB_CPU=y
# RCU_NOCB_CPU_ALL: his option forces all CPUs to be no-CBs CPUs.
# The rcu_nocbs= boot parameter will be ignored.  All CPUs' RCU callbacks will
# be executed in the context of per-CPU rcuo kthreads created for
# this purpose.
# CONFIG_RCU_NOCB_CPU_ALL=y
# Kernel options needed for systemd enabled TI SDKs
# See https://cgit.freedesktop.org/systemd/systemd/tree/README#n38 for details
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_CGROUPS=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_PERF=y
CONFIG_INOTIFY_USER=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EPOLL=y
CONFIG_NET=y
CONFIG_SYSFS=y
CONFIG_PROC_FS=y
CONFIG_FHANDLE=y
# udev will fail to work with the legacy sysfs layout:
CONFIG_SYSFS_DEPRECATED=n
# Legacy hotplug slows down the system and confuses udev:
CONFIG_UEVENT_HELPER_PATH=""
# Userspace firmware loading is not supported and should
# be disabled in the kernel:
CONFIG_FW_LOADER_USER_HELPER=n
# Some udev rules and virtualization detection relies on it:
# Only for UEFI based systems
# http://cateee.net/lkddb/web-lkddb/DMI.html
CONFIG_DMIID=n
# Support for some SCSI devices serial number retrieval, to
# create additional symlinks in /dev/disk/ and /dev/tape:
CONFIG_BLK_DEV_BSG=y
# Required for PrivateNetwork and PrivateDevices in service units:
# Note that systemd-localed.service and other systemd units use
# PrivateNetwork and PrivateDevices so this is effectively required.
CONFIG_NAMESPACES=y
CONFIG_NET_NS=y
CONFIG_DEVPTS_MULTIPLE_INSTANCES=y
# Optional but strongly recommended options: those are nice to have and
# indeed recommended, but not necessarily systemd required. These to be
# enabled in corresponding domain fragments since they are not specific
# to supporting systemd.
CONFIG_SECCOMP=y
# for kcmp syscall
CONFIG_CHECKPOINT_RESTORE=y
# Required for CPUShares= in resource control unit settings
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
# Required for CPUQuota= in resource control unit settings
CONFIG_CFS_BANDWIDTH=y
# For systemd-bootchart, several proc debug interfaces are required:
# Systemd-debug.cfg?
CONFIG_SCHEDSTATS=y
CONFIG_SCHED_DEBUG=y
# We recommend to turn off Real-Time group scheduling in the
# kernel when using systemd. RT group scheduling effectively
# makes RT scheduling unavailable for most userspace, since it
# requires explicit assignment of RT budgets to each unit whose
# processes making use of RT. As there's no sensible way to
# assign these budgets automatically this cannot really be
# fixed, and it's best to disable group scheduling hence.
CONFIG_RT_GROUP_SCHED=n
# Note that kernel auditing is broken when used with systemd's
# container code. When using systemd in conjunction with
# containers, please make sure to either turn off auditing at
# runtime using the kernel command line option "audit=0", or
# turn it off at kernel compile time using:
CONFIG_AUDIT=n
  • Hi:
    I am only pressing/releasing key in row=0 and column=0. According to the dts "linux,keymap" I get the code 0x00000000. I changed this value to 0x00000001 to set key-code to 1 instead of 0.
    With this change, the function "is_event_supported(code, dev->keybit, KEYMAX)" returns other than 0 and works fine.
    I have been debugging the driver from that point on and it seems to be working fine, at least until I have debugged:
                         "static unsigned int input_to_handler( ...)" in "drivers/input/input.c" file.
    Inside this function I see that "handler->events()" and "handler-event()" function calls are executed.
    But I cannot see anything in "/dev/input/event0" file. Attached is a simple program to get pressed/released key.
    // SPDX-License-Identifier: GPL-2.0
    #include <stdio.h>
    #include <stdlib.h>
    #include <unistd.h>
    #include <fcntl.h>
    #include <string.h>
    #include <memory.h>
    #include <malloc.h>
    #include <time.h>
    #include <ctype.h>
    #include <sys/types.h>
    #include <sys/wait.h>
    #include <signal.h>
    #include <errno.h>
    #include <sys/time.h>
    #include <linux/hpet.h>
    #include <fcntl.h>
    #include <termios.h>
    #include <linux/serial.h>
    #include <sys/ioctl.h>
    int main(int argc, const char **argv)
    	char device[50], buffer[50];
    	int fd, counter, len, i;
    	// Device
    	sprintf(device, "/dev/input/event0");
    	// Open your specific device (e.g., /dev/mydevice):
    	fd = open (device, O_RDWR);
    	if (fd < 0)
    		{ printf("ERROR openning keypad device %s\n", device); return -1; }
    	printf("Waiting for key press in %s\n", device);
    	// Read
    	while(1)
    		len = read(fd, buffer, 1);
    		for(i=0;i<len;i++)
    			printf("Pressed key %0x ", buffer[0]);
    			fflush(stdout);
    	// Close the device when finished:
    	if (close (fd) < 0)
    		{ printf("ERROR closing keypad device %s\n", device); return -1; }
    	// Debug
    	printf("\nHasta luego Lucas desde %s\n", device);
    	// OK
    	return 0;
    Billa
  • Hi
    I realized that the way I programmed the key captures is not done properly. I changed the program and it is working fine.
    Billa
  • Billa,
    That's great news! I'm glad to hear you figured it out.
    So keyboard is fully functional now and we can close this thread?
    Brad
  • I think so.
    Thanks, Brad
    Billa
  • Hi Brad
    In a previous post we commented that the scanning period was two short (the oscillo picture was attached), in the order of usec, but it could be widened by setting a prescaler in a clock.
    Can you tell me how to modify this parameter in the register to get wider scanning periods?
    Billa
  • What's the value of KBD_CTRL (0x4AE1 C038)?  The PTV field (bits 4:2) of this register.  A PTV of 7 corresponds to /256.
