Tool/software: TI-RTOS
Since DSP1_RST_VECT of CTRL_CORE_CONTROL_DSP1_RST_VECT can only fill 22 bits, I specified this specific address.
I want to know how to eliminate this warning and whether this warning has an impact on the software.
valvalvalval said:replace ">" with ">>" will be eliminate this warning.
Correct. FYI, that's mentioned here:
http://processors.wiki.ti.com/index.php/Accessing_c_int00#Using_SYS.2FBIOS
valvalvalval said:In the sysbios project, when I rebuild project or clean project, I had to re-add this sentence to the link script to specify _c_int00 to a specific address. Is there any other way that will not be deleted when rebuild project or clean project?
You can have more than one *.cmd file associated with your project. Instead of making the change in the *.cmd generated by sysbios, just create your own *.cmd and put the definition there.
