Other Parts Discussed in Thread: TUSB8041
I have a AM5728 custom board.
I use ti-processor-sdk-linux-am57xx-evm-06.03.00.106-Linux-x86-Install.bin
This is USB logs
root@am57xx-evm:/# cat sys/kernel/debug/488d0000.usb/mode
otg
root@am57xx-evm:/# ls sys/kernel/debug/488d0000.usb/
link_state mode regdump testmode
root@am57xx-evm:/#
root@am57xx-evm:/# lsusb
Bus 001 Device 003: ID 0bda:b720 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 002: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
root@am57xx-evm:/#
root@am57xx-evm:/# dmesg |grep "usb"
[ 4.969166] usbcore: registered new interface driver usbfs
[ 4.974746] usbcore: registered new interface driver hub
[ 4.980188] usbcore: registered new device driver usb
[ 4.992293] usbcore: registered new interface driver ftdi_sio
[ 4.999623] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 6.809048] Modules linked in: omap_remoteproc(+) virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcor)
[ 7.297848] Modules linked in: omap_remoteproc virtio_rpmsg_bus remoteproc sch_fq_codel uio_module_drv(O) uio ftdi_sio usbserial usbcore u)
[ 8.063676] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id
[ 8.122928] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[ 8.149375] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 8.187439] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 8.257003] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup tables for GPIO lookup
[ 8.319898] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: No GPIO consumer id found
[ 8.396437] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus
[ 8.467417] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[ 8.533234] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[ 8.568328] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0)
[ 10.616253] dwc3 48890000.usb: Failed to get clk 'ref': -2
[ 10.719013] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[ 10.967998] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 10.987352] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.996588] usb usb1: Product: xHCI Host Controller
[ 11.002859] usb usb1: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
[ 11.010745] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 11.049577] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 11.058724] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 11.067480] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.075561] usb usb2: Product: xHCI Host Controller
[ 11.080877] usb usb2: Manufacturer: Linux 4.19.94-gbe5389fd85 xhci-hcd
[ 11.088144] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 11.387437] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 11.567796] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 11.576023] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 11.584379] usb 1-1: SerialNumber: 6906006168BF
[ 11.717469] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 11.757690] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 11.766054] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 12.007512] usb 1-1.2: new high-speed USB device number 3 using xhci-hcd
[ 12.137706] usb 1-1.2: config 1 interface 1 altsetting 0 endpoint 0x3 has wMaxPacketSize 0, skipping
[ 12.146889] usb 1-1.2: config 1 interface 1 altsetting 0 endpoint 0x83 has wMaxPacketSize 0, skipping
[ 12.164360] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=b720, bcdDevice= 2.00
[ 12.174000] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 12.182974] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 12.192859] usb 1-1.2: Manufacturer: Realtek
[ 12.197154] usb 1-1.2: SerialNumber: 00e04c000001
[ 12.407446] usb 1-1.4: new high-speed USB device number 4 using xhci-hcd
[ 12.547640] usb 1-1.4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 12.559972] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 12.572659] usb 1-1.4: Product: USB 2.0 Hub
[ 17.696742] usbcore: registered new interface driver option
[ 17.702556] usbserial: USB Serial support registered for GSM modem (1-port)
[ 17.746797] usbcore: registered new interface driver GobiNet
[ 18.320795] usbcore: registered new interface driver rtl8723bu
root@am57xx-evm:/#
I use am57xx-beagle-x15-common.dtsi,
* Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
/dts-v1/;
#include "dra74x.dtsi"
#include "am57xx-commercial-grade.dtsi"
#include "dra74x-mmc-iodelay.dtsi"
#include "dra74-ipu-dsp-common.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/irq.h>
compatible = "ti,am572x-beagle-x15", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7";
aliases {
rtc0 = &mcp_rtc;
rtc1 = &tps659038_rtc;
rtc2 = &rtc;
display0 = &hdmi0;
display1 = &lcd0;
sound0 = &sound0;
sound1 = &hdmi;
chosen {
stdout-path = &uart3;
rs485{
compatible = "dj8mm-rs485";
memory@0 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x80000000>;
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
ipu2_memory_region: ipu2-memory@95800000 {
compatible = "shared-dma-pool";
reg = <0x0 0x95800000 0x0 0x3800000>;
reusable;
status = "okay";
dsp1_memory_region: dsp1-memory@99000000 {
reg = <0x0 0x99000000 0x0 0x4000000>;
reusable;
status = "okay";
ipu1_memory_region: ipu1-memory@9d000000 {
reg = <0x0 0x9d000000 0x0 0x2000000>;
reusable;
status = "okay";
dsp2_memory_region: dsp2-memory@9f000000 {
reg = <0x0 0x9f000000 0x0 0x800000>;
reusable;
status = "okay";
main_12v0: fixedregulator-main_12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "main_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
evm_5v0: fixedregulator-evm_5v0 {
/* Output of TPS54531D */
regulator-name = "evm_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&main_12v0>;
regulator-boot-on;
vdd_3v3: fixedregulator-vdd_3v3 {
regulator-name = "vdd_3v3";
vin-supply = <®en1>;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
aic_dvdd: fixedregulator-aic_dvdd {
regulator-name = "aic_dvdd_fixed";
vin-supply = <&vdd_3v3>;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vtt_fixed: fixedregulator-vtt {
/* TPS51200 */
regulator-name = "vtt_fixed";
vin-supply = <&smps3_reg>;
regulator-boot-on;
enable-active-high;
gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
leds {
compatible = "gpio-leds";
led0 {
label = "beagle-x15:usr0";
gpios = <&gpio7 9 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
default-state = "off";
led1 {
label = "beagle-x15:usr1";
gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "cpu0";
led2 {
label = "beagle-x15:usr2";
gpios = <&gpio7 14 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "mmc0";
led3 {
label = "beagle-x15:usr3";
gpios = <&gpio7 15 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "disk-activity";
gpio_fan: gpio_fan {
/* Based on 5v 500mA AFB02505HHB */
compatible = "gpio-fan";
gpios = <&tps659038_gpio 2 GPIO_ACTIVE_HIGH>;
gpio-fan,speed-map = <0 0>,
<13000 1>;
#cooling-cells = <2>;
lcd0: display {
compatible = "osddisplays,osd070t1718-19ts", "panel-dpi";
backlight = <&lcd_bl>;
enable-gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>;
label = "lcd";
panel-timing {
clock-frequency = <33000000>;
de-active = <1>;
hactive = <800>;
hback-porch = <16>;
hfront-porch = <210>;
hsync-active = <0>;
hsync-len = <30>;
pixelclk-active = <1>;
vactive = <480>;
vback-porch = <10>;
vfront-porch = <22>;
vsync-active = <0>;
vsync-len = <13>;
port {
lcd_in: endpoint {
remote-endpoint = <&dpi_out>;
lcd_bl: backlight {
compatible = "pwm-backlight";
brightness-levels = <0 243 245 247 249 251 252 253 255>;
default-brightness-level = <8>;
pwms = <&ehrpwm1 0 50000 0>;
hdmi0: connector {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&tpd12s015_out>;
tpd12s015: encoder {
compatible = "ti,tpd12s015";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
tpd12s015_in: endpoint {
remote-endpoint = <&hdmi_out>;
port@1 {
reg = <1>;
tpd12s015_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
sound0: sound0 {
compatible = "simple-audio-card";
simple-audio-card,name = "BeagleBoard-X15";
simple-audio-card,widgets =
"Line", "Line Out",
"Line", "Line In";
simple-audio-card,routing =
"Line Out", "LLOUT",
"Line Out", "RLOUT",
"MIC2L", "Line In",
"MIC2R", "Line In";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound0_master>;
simple-audio-card,frame-master = <&sound0_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp3>;
sound0_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3104>;
clocks = <&clkout2_clk>;
&ehrpwm1 {
status = "okay";
&epwmss1 {
status = "okay";
&i2c1 {
status = "okay";
clock-frequency = <400000>;
tps659038: tps659038@58 {
compatible = "ti,tps659038";
reg = <0x58>;
interrupt-parent = <&gpio1>;
interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
#interrupt-cells = <2>;
interrupt-controller;
ti,system-power-controller;
ti,palmas-override-powerhold;
tps659038_pmic {
compatible = "ti,tps659038-pmic";
regulators {
smps12_reg: smps12 {
/* VDD_MPU */
regulator-name = "smps12";
regulator-min-microvolt = < 850000>;
regulator-max-microvolt = <1250000>;
regulator-boot-on;
smps3_reg: smps3 {
/* VDD_DDR */
regulator-name = "smps3";
regulator-min-microvolt = <1350000>;
regulator-max-microvolt = <1350000>;
regulator-boot-on;
smps45_reg: smps45 {
/* VDD_DSPEVE, VDD_IVA, VDD_GPU */
regulator-name = "smps45";
regulator-boot-on;
smps6_reg: smps6 {
/* VDD_CORE */
regulator-name = "smps6";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
/* SMPS7 unused */
smps8_reg: smps8 {
/* VDD_1V8 */
regulator-name = "smps8";
regulator-boot-on;
/* SMPS9 unused */
ldo1_reg: ldo1 {
/* VDD_SD / VDDSHV8 */
regulator-name = "ldo1";
regulator-boot-on;
ldo2_reg: ldo2 {
/* VDD_SHV5 */
regulator-name = "ldo2";
regulator-boot-on;
ldo3_reg: ldo3 {
/* VDDA_1V8_PHYA */
regulator-name = "ldo3";
regulator-boot-on;
ldo4_reg: ldo4 {
/* VDDA_1V8_PHYB */
regulator-name = "ldo4";
regulator-boot-on;
ldo9_reg: ldo9 {
/* VDD_RTC */
regulator-name = "ldo9";
regulator-min-microvolt = <1050000>;
regulator-max-microvolt = <1050000>;
regulator-boot-on;
ldoln_reg: ldoln {
/* VDDA_1V8_PLL */
regulator-name = "ldoln";
regulator-boot-on;
ldousb_reg: ldousb {
/* VDDA_3V_USB: VDDA_USBHS33 */
regulator-name = "ldousb";
regulator-boot-on;
regen1: regen1 {
/* VDD_3V3_ON */
regulator-name = "regen1";
regulator-boot-on;
tps659038_rtc: tps659038_rtc {
compatible = "ti,palmas-rtc";
interrupt-parent = <&tps659038>;
interrupts = <8 IRQ_TYPE_EDGE_FALLING>;
wakeup-source;
tps659038_pwr_button: tps659038_pwr_button {
compatible = "ti,palmas-pwrbutton";
interrupts = <1 IRQ_TYPE_EDGE_FALLING>;
wakeup-source;
ti,palmas-long-press-seconds = <12>;
tps659038_gpio: tps659038_gpio {
compatible = "ti,palmas-gpio";
gpio-controller;
#gpio-cells = <2>;
extcon_usb2: tps659038_usb {
compatible = "ti,palmas-usb-vid";
ti,enable-vbus-detection;
vbus-gpio = <&gpio4 21 GPIO_ACTIVE_HIGH>;
tmp102: tmp102@48 {
compatible = "ti,tmp102";
reg = <0x48>;
interrupt-parent = <&gpio7>;
interrupts = <16 IRQ_TYPE_LEVEL_LOW>;
#thermal-sensor-cells = <1>;
tlv320aic3104: tlv320aic3104@18 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3104";
reg = <0x18>;
assigned-clocks = <&clkoutmux2_clk_mux>;
assigned-clock-parents = <&sys_clk2_dclk_div>;
status = "okay";
adc-settle-ms = <40>;
AVDD-supply = <&vdd_3v3>;
IOVDD-supply = <&vdd_3v3>;
DRVDD-supply = <&vdd_3v3>;
DVDD-supply = <&aic_dvdd>;
eeprom: eeprom@50 {
compatible = "atmel,24c32";
reg = <0x50>;
&i2c3 {
status = "okay";
mcp_rtc: rtc@6f {
compatible = "microchip,mcp7941x";
reg = <0x6f>;
interrupts-extended = <&crossbar_mpu GIC_SPI 2 IRQ_TYPE_EDGE_RISING>,
<&dra7_pmx_core 0x424>;
interrupt-names = "irq", "wakeup";
vcc-supply = <&vdd_3v3>;
wakeup-source;
&gpio7 {
ti,no-reset-on-init;
ti,no-idle-on-init;
&cpu0 {
vdd-supply = <&smps12_reg>;
voltage-tolerance = <1>;
&dra7_pmx_core {
uart4_pins_default: uart4_pins_default {
pinctrl-single,pins = <
0x33C ( PIN_INPUT_SLEW | MUX_MODE4) /* uart4_rxd */
0x340 ( PIN_INPUT_SLEW | MUX_MODE4) /* uart4_txd */
uart5_pins_default: uart5_pins_default {
0x040 (PIN_INPUT_SLEW | MUX_MODE8) /* uart5_rxd */
0x044 (PIN_INPUT_SLEW | MUX_MODE8) /* uart5_txd */
uart6_pins_default: uart6_pins_default {
0x050 ( PIN_INPUT_SLEW | MUX_MODE8) /* uart6_rxd */
0x054 ( PIN_INPUT_SLEW | MUX_MODE8) /* uart6_txd */
uart7_pins_default: uart7_pins_default {
0x048 ( PIN_INPUT_SLEW | MUX_MODE7) /* uart7_rxd */
0x04c ( PIN_INPUT_SLEW | MUX_MODE7) /* uart7_txd */
uart10_pins_default: uart10_pins_default {
0x170 ( PIN_INPUT_SLEW | MUX_MODE8) /* uart10_rxd */
0x174 ( PIN_INPUT_SLEW | MUX_MODE8) /* uart10_txd */
0x17C ( PIN_INPUT_SLEW | MUX_MODE14)
&uart1 {
status = "okay";
&uart3 {
status = "okay";
interrupts-extended = <&crossbar_mpu GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x3f8>;
&uart4 {
status = "okay";
interrupts= <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x33C>;
pinctrl-names = "default";
pinctrl-0 = <&uart4_pins_default>;
&uart5 {
status = "okay";
interrupts = < GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x040>;
pinctrl-0 = <&uart5_pins_default>;
&uart6 {
status = "okay";
interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x050>;
pinctrl-0 = <&uart6_pins_default>;
&uart7 {
status = "okay";
interrupts = < GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x048>;
pinctrl-0 = <&uart7_pins_default>;
&uart8 {
status = "okay";
&uart9 {
status = "okay";
&uart10 {
status = "okay";
interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>,
<&dra7_pmx_core 0x170>;
pinctrl-0 = <&uart10_pins_default>;
&davinci_mdio {
phy0: ethernet-phy@1 {
reg = <1>;
phy1: ethernet-phy@2 {
reg = <2>;
&mac {
status = "okay";
dual_emac;
&cpsw_emac0 {
phy-handle = <&phy0>;
phy-mode = "rgmii";
dual_emac_res_vlan = <1>;
&cpsw_emac1 {
phy-handle = <&phy1>;
phy-mode = "rgmii";
dual_emac_res_vlan = <2>;
&mmc1 {
status = "okay";
pinctrl-0 = <&mmc1_pins_default>;
bus-width = <4>;
cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */
no-1-8-v;
&mmc2 {
status = "okay";
pinctrl-0 = <&mmc2_pins_default>;
vmmc-supply = <&vdd_3v3>;
vqmmc-supply = <&vdd_3v3>;
bus-width = <8>;
non-removable;
no-1-8-v;
&sata {
status = "okay";
&usb2_phy1 {
phy-supply = <&ldousb_reg>;
&usb2_phy2 {
&usb1 {
dr_mode = "host";
&omap_dwc3_2 {
extcon = <&extcon_usb2>;
&usb2 {
* Stand alone usage is peripheral only.
* However, with some resistor modifications
* this port can be used via expansion connectors
* as "host" or "dual-role". If so, provide
* the necessary dr_mode override in the expansion
* board's DT.
dr_mode = "otg";
&cpu_trips {
cpu_alert1: cpu_alert1 {
temperature = <50000>; /* millicelsius */
hysteresis = <2000>; /* millicelsius */
type = "active";
&cpu_cooling_maps {
map1 {
trip = <&cpu_alert1>;
cooling-device = <&gpio_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
&thermal_zones {
board_thermal: board_thermal {
polling-delay-passive = <1250>; /* milliseconds */
polling-delay = <1500>; /* milliseconds */
/* sensor ID */
thermal-sensors = <&tmp102 0>;
board_trips: trips {
board_alert0: board_alert {
temperature = <40000>; /* millicelsius */
type = "active";
board_crit: board_crit {
temperature = <105000>; /* millicelsius */
hysteresis = <0>; /* millicelsius */
type = "critical";
board_cooling_maps: cooling-maps {
map0 {
trip = <&board_alert0>;
cooling-device =
&gpu {
status = "ok";
&dss {
status = "ok";
vdda_video-supply = <&ldoln_reg>;
ports {
#size-cells = <0>;
port {
reg = <0>;
dpi_out: endpoint {
data-lines = <24>;
remote-endpoint = <&lcd_in>;
&bb2d {
status = "okay";
&hdmi {
status = "ok";
vdda-supply = <&ldo4_reg>;
port {
hdmi_out: endpoint {
remote-endpoint = <&tpd12s015_in>;
&pcie1_rc {
status = "ok";
gpios = <&gpio2 8 GPIO_ACTIVE_LOW>;
&mcasp3 {
assigned-clocks = <&l4per_clkctrl DRA7_MCASP3_CLKCTRL 24>;
assigned-clock-parents = <&sys_clkin2>;
status = "disabled";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializers */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 2 0 0
tx-num-evt = <32>;
rx-num-evt = <32>;
&pruss_soc_bus1 {
status = "okay";
pruss1: pruss@4b200000 {
status = "okay";
&pruss_soc_bus2 {
status = "okay";
pruss2: pruss@4b280000 {
status = "okay";
&ipu2 {
status = "okay";
memory-region = <&ipu2_memory_region>;
&ipu1 {
status = "okay";
memory-region = <&ipu1_memory_region>;
&dsp1 {
status = "okay";
memory-region = <&dsp1_memory_region>;
&dsp2 {
status = "okay";
memory-region = <&dsp2_memory_region>;
#include "dra7-ipu-common-early-boot.dtsi"
This is my schematic,Now r325 resistor connected, r327 disconnected
Now insert OTG and no device is detected. What should I do?
