Part Number: J721EXSOMXEVM
Based on our HW schematic, SerDes ports are shared between SGMII and PCIe. Since CPSW9g on Linux doesn't support SGMII connection we are planning to freeup/disable SerDes ports used for SGMII connection from Linux DTS file and enable it in Ethernet firmware on MCU2_1. However, on Linux side, we want to retain SerDes's PCIe connection.
I have a few questions on PCIe mapping -
1) How to disable SerDes Port 0, 1 & 4 from dts file and enable port 2 & 3 for PCIe2 & PCIe3 in Linux side?
2) How to enable "&pcie3_rc" in dts file?
These are the changes I made in my dts file but I don't see any pcie logs from "dmesg" , Also "lspci" doesn't show any bus.
Subject: [PATCH] reconfigure SerDes ports
.../dts/mbrdna/k3-j721e-common-proc-board.dts | 41 +++++++++++--------
1 file changed, 25 insertions(+), 16 deletions(-)
diff --git a/arch/arm64/boot/dts/mbrdna/k3-j721e-common-proc-board.dts b/arch/arm64/boot/dts/mbrdna/k3-j721e-common-proc-board.dts
index e2087b8cfcb9..9442011a7920 100644
--- a/arch/arm64/boot/dts/mbrdna/k3-j721e-common-proc-board.dts
+++ b/arch/arm64/boot/dts/mbrdna/k3-j721e-common-proc-board.dts
@@ -965,6 +965,7 @@
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz0 1>;
+ status = "disabled";
@@ -975,6 +976,7 @@
#phy-cells = <0>;
resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
@@ -993,6 +995,7 @@
phys = <&serdes0_pcie_link>;
phy-names = "pcie_phy";
num-lanes = <1>;
&pcie1_rc {
@@ -1000,6 +1003,7 @@
phys = <&serdes1_pcie_link>;
num-lanes = <2>;
&pcie2_rc {
@@ -1038,33 +1042,38 @@
-&usb_serdes_mux {
- idle-states = <1>, <0>; /* USB0 to SERDES3, USB1 to SERDES1 */
&serdes_ln_ctrl {
- idle-states = <SERDES0_LANE0_PCIE0_LANE0>, <SERDES0_LANE1_PCIE0_LANE1>,
- <SERDES1_LANE0_PCIE1_LANE0>, <SERDES1_LANE1_PCIE1_LANE1>,
- <SERDES2_LANE0_PCIE2_LANE0>, <SERDES2_LANE1_PCIE2_LANE1>,
- <SERDES3_LANE0_USB3_0_SWAP>, <SERDES3_LANE1_USB3_0>,
- <SERDES4_LANE0_EDP_LANE0>, <SERDES4_LANE1_EDP_LANE1>, <SERDES4_LANE2_EDP_LANE2>, <SERDES4_LANE3_EDP_LANE3>;
-&serdes_wiz3 {
- typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
- typec-dir-debounce-ms = <700>; /* TUSB321, tCCB_DEFAULT 133 ms */
+ idle-states = <SERDES2_LANE0_PCIE2_LANE0>, <SERDES2_LANE1_PCIE2_LANE1>,
+ <SERDES3_LANE0_PCIE3_LANE0>, <SERDES3_LANE1_PCIE3_LANE1>;
&serdes3 {
- serdes3_usb_link: link@0 {
+ serdes3_pcie_link: link@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
- cdns,phy-type = <PHY_TYPE_USB3>;
+ cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
+&serdes4 {
+&serdes_wiz0 {
+&serdes_wiz1 {
+&serdes_wiz4 {
&usbss0 {
ti,vbus-divider;
ti,usb2-only;
2.17.1
I have attached my DTS file just for your reference.
// SPDX-License-Identifier: GPL-2.0
* Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/
/dts-v1/;
#include "k3-j721e-som-p0.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/sound/ti-mcasp.h>
#include <dt-bindings/net/ti-dp83867.h>
chosen {
stdout-path = "serial9:115200n8";
bootargs = "console=ttyS9,115200n8 earlycon=ns16550a,mmio32,0x02870000";
gpio_keys: gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-names = "default";
pinctrl-0 = <&sw10_button_pins_default &sw11_button_pins_default>;
sw10: sw10 {
label = "GPIO Key USER1";
linux,code = <BTN_0>;
gpios = <&main_gpio0 0 GPIO_ACTIVE_LOW>;
sw11: sw11 {
label = "GPIO Key USER2";
linux,code = <BTN_1>;
gpios = <&wkup_gpio0 7 GPIO_ACTIVE_LOW>;
evm_12v0: fixedregulator-evm12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "evm_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
vsys_3v3: fixedregulator-vsys3v3 {
/* Output of LMS140 */
regulator-name = "vsys_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&evm_12v0>;
regulator-boot-on;
vsys_5v0: fixedregulator-vsys5v0 {
/* Output of LM5140 */
regulator-name = "vsys_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
/* Used for 48KHz family */
pll4: pll4_fixed {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <1179648000>;
/* Used for 44.1KHz family */
pll15: pll15_fixed {
#clock-cells = <0>;
clock-frequency = <1083801600>;
sound0: sound@0 {
compatible = "ti,j721e-cpb-audio";
ti,model = "j721e-cpb-analog";
ti,cpb-mcasp = <&mcasp10>;
ti,cpb-codec = <&pcm3168a_1>;
clocks = <&pll4>, <&pll15>,
<&k3_clks 184 1>,
<&k3_clks 184 2>, <&k3_clks 184 4>,
<&k3_clks 157 371>,
<&k3_clks 157 400>, <&k3_clks 157 401>;
clock-names = "pll4", "pll15",
"cpb-mcasp",
"cpb-mcasp-48000", "cpb-mcasp-44100",
"audio-refclk2",
"audio-refclk2-48000", "audio-refclk2-44100";
vdd_mmc1: fixedregulator-sd {
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vsys_3v3>;
gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
vdd_sd_dv_alt: gpio-regulator-TLV71033 {
compatible = "regulator-gpio";
pinctrl-0 = <&vdd_sd_dv_alt_pins_default>;
regulator-name = "tlv71033";
regulator-min-microvolt = <1800000>;
regulator-boot-on;
vin-supply = <&vsys_5v0>;
gpios = <&main_gpio0 117 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0
3300000 0x1>;
cpsw9g_virt_mac: main_r5fss_cpsw9g_virt_mac0 {
compatible = "ti,j721e-cpsw-virt-mac";
dma-coherent;
ti,psil-base = <0x4a00>;
ti,remote-name = "mpu_1_0_ethswitch-device-0";
dmas = <&main_udmap 0xca00>,
<&main_udmap 0xca01>,
<&main_udmap 0xca02>,
<&main_udmap 0xca03>,
<&main_udmap 0xca04>,
<&main_udmap 0xca05>,
<&main_udmap 0xca06>,
<&main_udmap 0xca07>,
<&main_udmap 0x4a00>;
dma-names = "tx0", "tx1", "tx2", "tx3",
"tx4", "tx5", "tx6", "tx7",
"rx";
virt_emac_port {
ti,label = "virt-port";
/* local-mac-address = [0 0 0 0 0 0]; */
dp0: connector {
compatible = "dp-connector";
label = "DP0";
port {
dp_connector_in: endpoint {
remote-endpoint = <&dp_bridge_output>;
&main_pmx0 {
sw10_button_pins_default: sw10_button_pins_default {
pinctrl-single,pins = <
J721E_IOPAD(0x0, PIN_INPUT, 7) /* (AC18) EXTINTn.GPIO0_0 */
dp0_pins_default: dp0_pins_default {
J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
main_i2c1_exp4_pins_default: main-i2c1-exp4-pins-default {
J721E_IOPAD(0x230, PIN_INPUT, 7) /* (U2) ECAP0_IN_APWM_OUT.GPIO1_11 */
main_i2c0_pins_default: main-i2c0-pins-default {
J721E_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (AC5) I2C0_SCL */
J721E_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (AA5) I2C0_SDA */
main_i2c6_pins_default: main-i2c6-pins-default {
J721E_IOPAD(0x1d0, PIN_INPUT_PULLUP, 2) /* (AA3) SPI0_D1.I2C6_SCL */
J721E_IOPAD(0x1e4, PIN_INPUT_PULLUP, 2) /* (Y2) SPI1_D1.I2C6_SDA */
vdd_sd_dv_alt_pins_default: vdd_sd_dv_alt_pins_default {
J721E_IOPAD(0x1d8, PIN_INPUT, 7) /* (W4) SPI1_CS1.GPIO0_117 */
main_usbss0_pins_default: main_usbss0_pins_default {
J721E_IOPAD(0x290, PIN_OUTPUT, 0) /* (U6) USB0_DRVVBUS */
J721E_IOPAD(0x210, PIN_INPUT, 7) /* (W3) MCAN1_RX.GPIO1_3 */
main_usbss1_pins_default: main_usbss1_pins_default {
J721E_IOPAD(0x214, PIN_OUTPUT, 4) /* (V4) MCAN1_TX.USB1_DRVVBUS */
/* Pointing to IVP HW */
uart0_backplane_coex61_pins_default: uart0_backplane_coex61_pins_default {
J721E_IOPAD(0x4, PIN_INPUT, 14) /* (AC23) PRG1_PRU0_GPO0.UART0_RXD */
J721E_IOPAD(0x8, PIN_OUTPUT, 14) /* (AG22) PRG1_PRU0_GPO1.UART0_TXD */
uart1_backplane_coex60_pins_default: uart1_backplane_coex60_pins_default {
J721E_IOPAD(0xc, PIN_INPUT, 14) /* (AF22) PRG1_PRU0_GPO2.UART1_RXD */
J721E_IOPAD(0x10, PIN_OUTPUT, 14) /* (AJ23) PRG1_PRU0_GPO3.UART1_TXD */
uart2_bckplane_coex70_pins_default: uart2_bckplane_coex70_pins_default {
J721E_IOPAD(0x14, PIN_INPUT, 14) /* (AH23) PRG1_PRU0_GPO4.UART2_RXD */
J721E_IOPAD(0x1c, PIN_OUTPUT, 14) /* (AD22) PRG1_PRU0_GPO6.UART2_TXD */
uart3_backplane_rif0_pins_default: uart3_backplane_rif0_pins_default {
J721E_IOPAD(0xb8, PIN_INPUT, 8) /* (AE27) PRG0_PRU0_GPO2.UART3_RXD */
J721E_IOPAD(0xbc, PIN_OUTPUT, 8) /* (AD26) PRG0_PRU0_GPO3.UART3_TXD */
uart4_backplane_rif1_pins_default: uart4_backplane_rif1_pins_default {
J721E_IOPAD(0xe8, PIN_INPUT, 8) /* (AG28) PRG0_PRU0_GPO14.UART4_RXD */
J721E_IOPAD(0xec, PIN_OUTPUT, 8) /* (AG27) PRG0_PRU0_GPO15.UART4_TXD */
uart6_switch_mgmt_pins_default: uart6_switch_mgmt_pins_default {
J721E_IOPAD(0x210, PIN_INPUT, 1) /* (W3) MCAN1_RX.UART6_CTSn */
J721E_IOPAD(0x214, PIN_OUTPUT, 1) /* (V4) MCAN1_TX.UART6_RTSn */
J721E_IOPAD(0x218, PIN_INPUT, 8) /* (W2) I3C0_SCL.UART6_RXD */
J721E_IOPAD(0x21c, PIN_OUTPUT, 8) /* (W1) I3C0_SDA.UART6_TXD */
uart7_ftdi_pins_default: uart7_ftdi_pins_default {
J721E_IOPAD(0x248, PIN_INPUT, 1) /* (P24) MMC1_DAT1.UART7_CTSn */
J721E_IOPAD(0x24c, PIN_OUTPUT, 1) /* (R24) MMC1_DAT0.UART7_RTSn */
J721E_IOPAD(0x240, PIN_INPUT, 1) /* (R26) MMC1_DAT3.UART7_RXD */
J721E_IOPAD(0x244, PIN_OUTPUT, 1) /* (R25) MMC1_DAT2.UART7_TXD */
uart8_backplane_coex71_pins_default: uart8_backplane_coex71_pins_default {
J721E_IOPAD(0x124, PIN_INPUT, 14) /* (Y24) PRG0_PRU1_GPO9.UART8_RXD */
J721E_IOPAD(0x128, PIN_OUTPUT, 14) /* (AA25) PRG0_PRU1_GPO10.UART8_TXD */
i2c1_msp_pins_default: i2c1_msp_pins_default {
J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
i2c3_des_pins_default: i2c3_des_pins_default {
J721E_IOPAD(0x270, PIN_INPUT_PULLUP, 4) /* (T26) MMC2_CLK.I2C3_SCL */
J721E_IOPAD(0x274, PIN_INPUT_PULLUP, 4) /* (T25) MMC2_CMD.I2C3_SDA */
i2c4_audio_adc_pins_default: i2c4_audio_adc_pins_default {
J721E_IOPAD(0x250, PIN_INPUT_PULLUP, 4) /* (P25) MMC1_CLK.I2C4_SCL */
J721E_IOPAD(0x254, PIN_INPUT_PULLUP, 4) /* (R29) MMC1_CMD.I2C4_SDA */
i2c2_slot7_5_pins_default: i2c2_slot7_5_pins_default {
J721E_IOPAD(0x1c8, PIN_INPUT_PULLUP, 2) /* (AA1) SPI0_CLK.I2C2_SCL */
J721E_IOPAD(0x1cc, PIN_INPUT_PULLUP, 2) /* (AB5) SPI0_D0.I2C2_SDA */
i2c5_avb_clk_pins_default: i2c5_avb_clk_pins_default {
J721E_IOPAD(0x260, PIN_INPUT_PULLUP, 4) /* (T28) MMC2_DAT3.I2C5_SCL */
J721E_IOPAD(0x264, PIN_INPUT_PULLUP, 4) /* (T29) MMC2_DAT2.I2C5_SDA */
debug_pins_default: debug_pins_default {
J721E_IOPAD(0x158, PIN_OUTPUT, 5) /* (U23) RGMII5_TX_CTL.TRC_CLK */
J721E_IOPAD(0x15c, PIN_OUTPUT, 5) /* (U26) RGMII5_RX_CTL.TRC_CTL */
J721E_IOPAD(0x28c, PIN_INPUT, 0) /* (V2) TMS */
J721E_IOPAD(0x284, PIN_INPUT, 0) /* (V1) TDI */
J721E_IOPAD(0x288, PIN_OUTPUT, 0) /* (V3) TDO */
J721E_IOPAD(0x160, PIN_OUTPUT, 5) /* (V28) RGMII5_TD3.TRC_DATA0 */
J721E_IOPAD(0x164, PIN_OUTPUT, 5) /* (V29) RGMII5_TD2.TRC_DATA1 */
J721E_IOPAD(0x168, PIN_OUTPUT, 5) /* (V27) RGMII5_TD1.TRC_DATA2 */
J721E_IOPAD(0x16c, PIN_OUTPUT, 5) /* (U28) RGMII5_TD0.TRC_DATA3 */
J721E_IOPAD(0x170, PIN_OUTPUT, 5) /* (U29) RGMII5_TXC.TRC_DATA4 */
J721E_IOPAD(0x174, PIN_OUTPUT, 5) /* (U25) RGMII5_RXC.TRC_DATA5 */
J721E_IOPAD(0x178, PIN_OUTPUT, 5) /* (U27) RGMII5_RD3.TRC_DATA6 */
J721E_IOPAD(0x17c, PIN_OUTPUT, 5) /* (U24) RGMII5_RD2.TRC_DATA7 */
J721E_IOPAD(0x180, PIN_OUTPUT, 5) /* (R23) RGMII5_RD1.TRC_DATA8 */
J721E_IOPAD(0x184, PIN_OUTPUT, 5) /* (T23) RGMII5_RD0.TRC_DATA9 */
J721E_IOPAD(0x188, PIN_OUTPUT, 5) /* (Y28) RGMII6_TX_CTL.TRC_DATA10 */
J721E_IOPAD(0x18c, PIN_OUTPUT, 5) /* (V23) RGMII6_RX_CTL.TRC_DATA11 */
J721E_IOPAD(0x190, PIN_OUTPUT, 5) /* (W23) RGMII6_TD3.TRC_DATA12 */
J721E_IOPAD(0x194, PIN_OUTPUT, 5) /* (W28) RGMII6_TD2.TRC_DATA13 */
J721E_IOPAD(0x198, PIN_OUTPUT, 5) /* (V25) RGMII6_TD1.TRC_DATA14 */
J721E_IOPAD(0x19c, PIN_OUTPUT, 5) /* (W27) RGMII6_TD0.TRC_DATA15 */
J721E_IOPAD(0x1a0, PIN_OUTPUT, 5) /* (W29) RGMII6_TXC.TRC_DATA16 */
J721E_IOPAD(0x1a4, PIN_OUTPUT, 5) /* (W26) RGMII6_RXC.TRC_DATA17 */
J721E_IOPAD(0x1a8, PIN_OUTPUT, 5) /* (Y29) RGMII6_RD3.TRC_DATA18 */
J721E_IOPAD(0x1ac, PIN_OUTPUT, 5) /* (Y27) RGMII6_RD2.TRC_DATA19 */
J721E_IOPAD(0x1b0, PIN_OUTPUT, 5) /* (W24) RGMII6_RD1.TRC_DATA20 */
gpio0_pins_default: gpio0_pins_default {
J721E_IOPAD(0x24, PIN_INPUT, 7) /* (AJ20) PRG1_PRU0_GPO8.GPIO0_9 */
J721E_IOPAD(0x30, PIN_INPUT, 7) /* (AF24) PRG1_PRU0_GPO11.GPIO0_12 */
J721E_IOPAD(0x34, PIN_INPUT, 7) /* (AJ24) PRG1_PRU0_GPO12.GPIO0_13 */
J721E_IOPAD(0x4c, PIN_INPUT, 7) /* (AJ21) PRG1_PRU0_GPO17.GPIO0_18 */
J721E_IOPAD(0x5c, PIN_INPUT, 7) /* (AG23) PRG1_PRU1_GPO1.GPIO0_22 */
J721E_IOPAD(0x7c, PIN_INPUT, 7) /* (AF21) PRG1_PRU1_GPO9.GPIO0_30 */
J721E_IOPAD(0xb0, PIN_INPUT, 7) /* (AF28) PRG0_PRU0_GPO0.GPIO0_43 */
J721E_IOPAD(0xb4, PIN_INPUT, 7) /* (AE28) PRG0_PRU0_GPO1.GPIO0_44 */
J721E_IOPAD(0xe4, PIN_INPUT, 7) /* (AH29) PRG0_PRU0_GPO13.GPIO0_56 */
J721E_IOPAD(0xf0, PIN_INPUT, 7) /* (AH28) PRG0_PRU0_GPO16.GPIO0_59 */
J721E_IOPAD(0x104, PIN_INPUT, 7) /* (AD28) PRG0_PRU1_GPO1.GPIO0_64 */
J721E_IOPAD(0x108, PIN_INPUT, 7) /* (AD27) PRG0_PRU1_GPO2.GPIO0_65 */
J721E_IOPAD(0x110, PIN_INPUT, 7) /* (AD29) PRG0_PRU1_GPO4.GPIO0_67 */
J721E_IOPAD(0x118, PIN_INPUT, 7) /* (AC26) PRG0_PRU1_GPO6.GPIO0_69 */
J721E_IOPAD(0x13c, PIN_INPUT, 7) /* (AF29) PRG0_PRU1_GPO15.GPIO0_78 */
J721E_IOPAD(0x140, PIN_INPUT, 7) /* (AG29) PRG0_PRU1_GPO16.GPIO0_79 */
J721E_IOPAD(0x154, PIN_INPUT, 7) /* (AA27) PRG0_MDIO0_MDC.GPIO0_84 */
J721E_IOPAD(0x1c0, PIN_INPUT, 7) /* (AA2) SPI0_CS0.GPIO0_111 */
J721E_IOPAD(0x1e8, PIN_INPUT, 7) /* (AB2) UART0_RXD.GPIO0_121 */
J721E_IOPAD(0x1f8, PIN_INPUT, 7) /* (AA4) UART1_RXD.GPIO0_125 */
J721E_IOPAD(0x1fc, PIN_INPUT, 7) /* (AB4) UART1_TXD.GPIO0_126 */
gpio1_pins_default: gpio1_pins_default {
J721E_IOPAD(0x25c, PIN_INPUT, 7) /* (R28) MMC1_SDWP.GPIO1_22 */
J721E_IOPAD(0x268, PIN_INPUT, 7) /* (T27) MMC2_DAT1.GPIO1_25 */
J721E_IOPAD(0x26c, PIN_INPUT, 7) /* (T24) MMC2_DAT0.GPIO1_26 */
J721E_IOPAD(0x290, PIN_INPUT, 7) /* (U6) USB0_DRVVBUS.GPIO1_29 */
J721E_IOPAD(0x294, PIN_INPUT, 7) /* (AD1) MLB0_MLBSP.GPIO1_30 */
J721E_IOPAD(0x298, PIN_INPUT, 7) /* (AC1) MLB0_MLBSN.GPIO1_31 */
mdio_pins_default: mdio_pins_default {
J721E_IOPAD(0x1bc, PIN_OUTPUT, 0) /* (V24) MDIO0_MDC */
J721E_IOPAD(0x1b8, PIN_INPUT, 0) /* (V26) MDIO0_MDIO */
ext_audio_refclk_pins_default: ext_audio_refclk_pins_default {
J721E_IOPAD(0x1b4, PIN_INPUT, 4) /* (W25) RGMII6_RD0.AUDIO_EXT_REFCLK3 */
J721E_IOPAD(0x278, PIN_OUTPUT, 0) /* (T6) RESETSTATz */
J721E_IOPAD(0x280, PIN_INPUT, 0) /* (U4) SOC_SAFETY_ERRORn */
can0_faceplate_pins_default: can0_faceplate_pins_default {
J721E_IOPAD(0x208, PIN_INPUT, 0) /* (W5) MCAN0_RX */
J721E_IOPAD(0x20c, PIN_OUTPUT, 0) /* (W6) MCAN0_TX */
can6_faceplate_pins_default: can6_faceplate_pins_default {
J721E_IOPAD(0x44, PIN_INPUT, 6) /* (AE24) PRG1_PRU0_GPO16.MCAN6_RX */
J721E_IOPAD(0x40, PIN_OUTPUT, 6) /* (AC24) PRG1_PRU0_GPO15.MCAN6_TX */
&main_mcan0 {
status = "okay";
pinctrl-0 = <&can0_faceplate_pins_default>;
can-transceiver {
max-bitrate = <5000000>;
&main_mcan6 {
status = "okay";
pinctrl-0 = <&can6_faceplate_pins_default>;
can-transceiver {
&davinci_mdio {
pinctrl-0 = <&mdio_pins_default>;
status = "okay";
//phy0: ethernet-phy@0 {
// reg = <0>;
// compatible = "ti,davinci_mdio";
&wkup_pmx0 {
sw11_button_pins_default: sw11_button_pins_default {
J721E_WKUP_IOPAD(0xcc, PIN_INPUT, 7) /* (G28) WKUP_GPIO0_7 */
&wkup_pmx0 {
mywkup_debug_pins_default: mywkup_debug_pins_default {
J721E_WKUP_IOPAD(0x128, PIN_INPUT, 0) /* (C26) EMU0 */
J721E_WKUP_IOPAD(0x12c, PIN_INPUT, 0) /* (B29) EMU1 */
J721E_WKUP_IOPAD(0x120, PIN_INPUT, 0) /* (E29) TCK */
J721E_WKUP_IOPAD(0x124, PIN_INPUT, 0) /* (F24) TRSTn */
wkup_gpio_pins_default: wkup_gpio_pins_default {
J721E_WKUP_IOPAD(0x4, PIN_INPUT, 7) /* (C21) MCU_OSPI0_LBCLKO.WKUP_GPIO0_17 */
wkup_system_pins_default: wkup_system_pins_default {
J721E_WKUP_IOPAD(0x11c, PIN_OUTPUT, 0) /* (B28) MCU_PORz_OUT */
J721E_WKUP_IOPAD(0x118, PIN_OUTPUT, 0) /* (C27) MCU_RESETSTATz */
J721E_WKUP_IOPAD(0x114, PIN_INPUT, 0) /* (D28) MCU_RESETz */
J721E_WKUP_IOPAD(0x110, PIN_INPUT, 0) /* (D27) MCU_SAFETY_ERRORn */
J721E_WKUP_IOPAD(0x10c, PIN_OUTPUT, 0) /* (G23) PMIC_POWER_EN1 */
J721E_WKUP_IOPAD(0x174, PIN_INPUT, 0) /* (J24) PORz */
J721E_WKUP_IOPAD(0x170, PIN_INPUT, 0) /* (C28) RESET_REQz */
&wkup_uart0 {
/* Wakeup UART is used by System firmware */
&main_uart0 {
pinctrl-0 = <&uart0_backplane_coex61_pins_default>;
power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart1 {
pinctrl-0 = <&uart1_backplane_coex60_pins_default>;
power-domains = <&k3_pds 278 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart2 {
pinctrl-0 = <&uart2_bckplane_coex70_pins_default>;
power-domains = <&k3_pds 279 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart3 {
pinctrl-0 = <&uart3_backplane_rif0_pins_default>;
power-domains = <&k3_pds 280 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart4 {
pinctrl-0 = <&uart4_backplane_rif1_pins_default>;
power-domains = <&k3_pds 281 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart5 {
/* UART not brought out */
&main_uart6 {
pinctrl-0 = <&uart6_switch_mgmt_pins_default>;
power-domains = <&k3_pds 283 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart7 {
pinctrl-0 = <&uart7_ftdi_pins_default>;
power-domains = <&k3_pds 284 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart8 {
pinctrl-0 = <&uart8_backplane_coex71_pins_default>;
power-domains = <&k3_pds 285 TI_SCI_PD_SHARED>;
status = "okay";
&main_uart9 {
&main_gpio2 {
&main_gpio3 {
&main_gpio4 {
&main_gpio5 {
&main_gpio6 {
&main_gpio7 {
&wkup_gpio1 {
&mailbox0_cluster0 {
interrupts = <436>;
mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
ti,mbox-rx = <2 0 0>;
ti,mbox-tx = <3 0 0>;
&mailbox0_cluster1 {
interrupts = <432>;
mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
&mailbox0_cluster2 {
interrupts = <428>;
mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 {
mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 {
&mailbox0_cluster3 {
interrupts = <424>;
mbox_c66_0: mbox-c66-0 {
mbox_c66_1: mbox-c66-1 {
&mailbox0_cluster4 {
interrupts = <420>;
mbox_c71_0: mbox-c71-0 {
&mailbox0_cluster5 {
&mailbox0_cluster6 {
&mailbox0_cluster7 {
&mailbox0_cluster8 {
&mailbox0_cluster9 {
&mailbox0_cluster10 {
&mailbox0_cluster11 {
&mcu_r5fss0_core0 {
mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>;
&mcu_r5fss0_core1 {
mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>;
&main_r5fss0_core0 {
mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>;
&main_r5fss0_core1 {
mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>;
&main_r5fss1_core0 {
mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>;
&main_r5fss1_core1 {
mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>;
&c66_0 {
mboxes = <&mailbox0_cluster3 &mbox_c66_0>;
&c66_1 {
mboxes = <&mailbox0_cluster3 &mbox_c66_1>;
&c71_0 {
mboxes = <&mailbox0_cluster4 &mbox_c71_0>;
&tscadc0 {
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
&tscadc1 {
adc {
&dss {
status = "ok";
&dss_ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
dpi_out_real0: endpoint {
remote-endpoint = <&dp_bridge_input>;
&mhdp {
status = "ok";
pinctrl-0 = <&dp0_pins_default>;
&dp0_ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dp_bridge_input: endpoint {
remote-endpoint = <&dpi_out_real0>;
port@1 {
reg = <1>;
dp_bridge_output: endpoint {
remote-endpoint = <&dp_connector_in>;
&main_i2c0 {
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
exp1: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
exp2: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
p09 {
/* P11 - MCASP/TRACE_MUX_S0 */
gpio-hog;
gpios = <9 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "MCASP/TRACE_MUX_S0";
p10 {
/* P12 - MCASP/TRACE_MUX_S1 */
gpio-hog;
gpios = <10 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "MCASP/TRACE_MUX_S1";
&main_i2c1 {
pinctrl-0 = <&i2c1_msp_pins_default>;
exp4: gpio@20 {
compatible = "ti,tca6408";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
pinctrl-0 = <&main_i2c1_exp4_pins_default>;
interrupt-parent = <&main_gpio1>;
interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
p0 {
/* P0 - DP0_PWR_SW_EN */
gpio-hog;
gpios = <0 GPIO_ACTIVE_HIGH>;
output-high;
line-name = "DP0_PWR_SW_EN";
&k3_clks {
/* Confiure AUDIO_EXT_REFCLK2 pin as output */
pinctrl-0 = <&ext_audio_refclk_pins_default>;
&main_i2c3 {
pinctrl-0 = <&main_i2c3_pins_default>;
exp3: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
pcm3168a_1: audio-codec@44 {
compatible = "ti,pcm3168a";
reg = <0x44>;
#sound-dai-cells = <1>;
reset-gpios = <&exp3 0 GPIO_ACTIVE_LOW>;
/* C_AUDIO_REFCLK2 -> RGMII6_RXC (W26) */
clocks = <&k3_clks 157 371>;
clock-names = "scki";
/* HSDIV3_16FFT_MAIN_4_HSDIVOUT2_CLK -> REFCLK2 */
assigned-clocks = <&k3_clks 157 371>;
assigned-clock-parents = <&k3_clks 157 400>;
assigned-clock-rates = <24576000>; /* for 48KHz */
VDD1-supply = <&vsys_3v3>;
VDD2-supply = <&vsys_3v3>;
VCCAD1-supply = <&vsys_5v0>;
VCCAD2-supply = <&vsys_5v0>;
VCCDA1-supply = <&vsys_5v0>;
VCCDA2-supply = <&vsys_5v0>;
&main_i2c6 {
pinctrl-0 = <&main_i2c6_pins_default>;
exp5: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
&main_i2c2 {
pinctrl-0 = <&i2c2_slot7_5_pins_default>;
&main_i2c3 {
pinctrl-0 = <&i2c3_des_pins_default>;
&main_i2c4 {
pinctrl-0 = <&i2c4_audio_adc_pins_default>;
&main_i2c5 {
pinctrl-0 = <&i2c5_avb_clk_pins_default>;
&main_sdhci0 {
/* eMMC */
non-removable;
ti,driver-strength-ohm = <50>;
disable-wp;
&main_sdhci1 {
/* Unused */
&main_sdhci2 {
/* Unused */
&serdes0 {
serdes0_pcie_link: link@0 {
reg = <0>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
&serdes1 {
serdes1_pcie_link: link@0 {
reg = <0>;
#phy-cells = <0>;
&serdes2 {
serdes2_pcie_link: link@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
&pcie0_rc {
reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
num-lanes = <1>;
&pcie1_rc {
reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
num-lanes = <2>;
&pcie2_rc {
reset-gpios = <&exp2 20 GPIO_ACTIVE_HIGH>;
phys = <&serdes2_pcie_link>;
num-lanes = <2>;
&pcie0_ep {
num-lanes = <1>;
&pcie1_ep {
num-lanes = <2>;
&pcie2_ep {
num-lanes = <2>;
&pcie3_rc {
&pcie3_ep {
&serdes_ln_ctrl {
&serdes3 {
reg = <0>;
#phy-cells = <0>;
&serdes4 {
&serdes_wiz0 {
&serdes_wiz1 {
&serdes_wiz4 {
&usbss0 {
ti,vbus-divider;
ti,usb2-only;
&usb0 {
dr_mode = "host";
maximum-speed = "high-speed";
&usbss1 {
ti,usb2-only;
&usb1 {
dr_mode = "host";
&main_mcan1 {
&main_mcan2 {
&main_mcan3 {
&main_mcan4 {
&main_mcan5 {
&main_mcan7 {
&main_mcan8 {
&main_mcan9 {
&main_mcan10 {
&main_mcan11 {
&main_mcan12 {
&main_mcan13 {
&main_gpio0 {
pinctrl-0 = <&gpio0_pins_default &debug_pins_default>;
power-domains = <&k3_pds 105 TI_SCI_PD_SHARED>;
status = "okay";
p84 {
gpio-hog;
gpios = <84 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "MCAN0_STB";
p125 {
gpio-hog;
gpios = <125 GPIO_ACTIVE_HIGH>;
output-low;
line-name = "MCAN6_STB";
&main_gpio1 {
pinctrl-0 = <&gpio1_pins_default>;
power-domains = <&k3_pds 106 TI_SCI_PD_SHARED>;
status = "okay";
&wkup_gpio0 {
pinctrl-0 = <&wkup_gpio_pins_default &mywkup_debug_pins_default &wkup_system_pins_default>;
power-domains = <&k3_pds 113 TI_SCI_PD_SHARED>;
status = "okay";
We are using SDK 7.1. Could you please help me to enable PCIe bus on our board?
Update on Feb 3. 20201: I forgot to mention but these changes were also added in dts file along with the aforementioned dts changes -
Subject: [PATCH] turn off SerDes ports
arch/arm64/boot/dts/mbrdna/k3-j721e-main.dtsi | 16 +++++-----------
1 file changed, 5 insertions(+), 11 deletions(-)
diff --git a/arch/arm64/boot/dts/mbrdna/k3-j721e-main.dtsi b/arch/arm64/boot/dts/mbrdna/k3-j721e-main.dtsi
index 8675a4887cab..23a79eb3ccff 100644
--- a/arch/arm64/boot/dts/mbrdna/k3-j721e-main.dtsi
+++ b/arch/arm64/boot/dts/mbrdna/k3-j721e-main.dtsi
@@ -53,17 +53,11 @@
serdes_ln_ctrl: serdes_ln_ctrl@4080 {
compatible = "mmio-mux";
#mux-control-cells = <1>;
- mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */
- <0x4090 0x3>, <0x4094 0x3>, /* SERDES1 lane0/1 select */
- <0x40a0 0x3>, <0x40a4 0x3>, /* SERDES2 lane0/1 select */
- <0x40b0 0x3>, <0x40b4 0x3>, /* SERDES3 lane0/1 select */
- <0x40c0 0x3>, <0x40c4 0x3>, <0x40c8 0x3>, <0x40cc 0x3>;
- /* SERDES4 lane0/1/2/3 select */
- <MUX_IDLE_AS_IS>, <SERDES3_LANE1_USB3_0>,
+ mux-reg-masks = <0x40a0 0x3>, <0x40a4 0x3>, /* SERDES2 lane0/1 select */
+ <0x40b0 0x3>, <0x40b4 0x3>; /* SERDES3 lane0/1 select */
usb_serdes_mux: mux-controller@4000 {
2.17.1
Thank you,
Satish
