I downloaded PROCESSOR-SDK-RTOS-AUTOMOTIVE-DRA7X Linux version from below link:
https://www.ti.com/tool/PROCESSOR-SDK-DRA7X
but when I install it on my ubuntu machine it gets stuck at below screen:
Any ideas on it?
James
Any ideas on it?
James
Hi Gaviraju,
It doesn't have something to do with the user guide.
I downloaded the SDK (ti-processor-sdk-rtos-automotive-dra7xx-evm-04.03.00.05-Linux-x86-Install.bin) from the link and run this binary in my ubuntu machine.
Then it will extract all the components (source code, docs, etc.) into my machine.
In the middle of this extraction it get stuck at the point I mentioned earlier.
Thanks.
James
Can you try with the Windows installer instead of Linux installer?
Gaviraju
HI Gaviraju,
I tried Windows installer and could see it worked well.
Could you please check the Linux installer if there are any issues in packaging?
I need to use Linux version.
Thanks.
James
Hi.
I'm also facing the same issue, so I will check with team & get back to you.
Gaviraju
I'm able install successfully on the Ubuntu 14.04 machine. So please try the same.
Note: We tested all J6 SDK on the Ubuntu 14.04 machine & all J7 SDK on Ubuntu 18.04 machine.
Gaviraju
