Part Number: TDA4VM
When a node is replicated in the OpenVX, the parameters passed to the node instance0 will reused for all the replicated node. Typically only input and/our output images are replicated in application to provide different instance of the image for each replicated node.
This article explains how to provide different set of parameters for replicated nodes. It uses LDC as an example and provides different lookup table for each replicated LDC node.
