Part Number: TDA4VM
HI,
How to determine if this is a GP or HS device,Thank you for your help.
Best regards
huahui
Part Number: TDA4VM
HI,
Best regards
huahui
Please set the dip switch settings as below:
SW8: 00000000
SW9: 01110000
Connect to MCU UART port. If you are using J721e-EVM then that is micro-USB port below the Main UART. connect to the second instance that enumerates.
You will see characters like below: 01000000011a00006a3776636c00000000000000475020200200010002000100C
Typically 64 character on a GP device & on HS you will see many more characters:
02000000011a00006a376573000000000000000048535345020001000200010002a600000100010033c74f0c8631aa67a56d53b06f250d75cb2a9cf7a52d6eb5e21b5e824250d7e09c22d997f09dc9389ecaa3f7d2b64d3a76d6163aa09e928ea050e1da95507e661f6002b07cd9b0b7c47d9ca8d1aae57b8e8784a12f636b2b760d7d98a18f189760dfd0f23e2b0cb10ec7edc7c6edac3d9bdfefe0eddc3fff7fe9ad875195527d5c199b42993690b3792ac7c2a039e848ffe6c0b8b719ea6cd2809ca3a0bc15dd
Around 400 Characters. That is a quick way to distinguish GP vs HS.
Keerthy
Even for the code to execute you will need to know before hand that you need to sign binaries for HS & unsigned binaries
to boot with GP. My question is even if you are not booting anything How do you plan to look at registers?
What is your use case where in you will need to check the HS Vs GP dynamically?
- Keerthy
