hi there!
i am using leopard board along with ridgerun default sd card image for TVP 5146 composite input.
i am trying to encode my video from composite input camera and streaming to udpsink using rtp.
here is the pipeline
gst-launch -v v4l2src always-copy=FALSE input-src=composite queue-size=6 ! priority scheduler=1 rtpriority=40 ! "video/x-raw-yuv,format=(fourcc)NV12,width=720,height=576,pitch=736" ! dmaiaccel ! dmaienc_h264 targetbitrate=8000000 maxbitrate=8000000 ! dmaiperf print-arm-load=true ! rtph264pay ! udpsink host=199.200.15.61 port=6666
the debug output of the pipeline is given below
Setting pipeline to PAUSED ...
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
vpfe-capture vpfe-capture: IPIPE Chained
vpfe-capture vpfe-capture: Resizer present
tvp514x 1-005d: tvp5146 (Version - 0x03) found at 0xba (DaVinci I2C adapter)
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
Pipeline is live and does not need PREROLL ...
WARNING: from element /GstPipeline:pipeline0/GstDmaiperf:dmaiperf0: Could not get/set settings from/on resource.
Additional debug info:
../../src/src/gsttidmaiperf.c(273): gst_dmaiperf_start (): /GstPipeline:pipeline0/GstDmaiperf:dmaiperf0:
Engine name not specified, not printing DSP information
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Video input device did not accept new frame rate setting.
../../../src/sys/v4l2/v4l2src_calls.c(342): gst_v4l2src_set_capture (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: Invalid argument
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstTIPriority:tipriority0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/GstTIPriority:tipriority0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/GstTIDmaiaccel:tidmaiaccel0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/GstTIDmaiaccel:tidmaiaccel0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/dmaienc_h264:dmaienc_h2640.GstPad:src: caps = video/x-h264, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/dmaienc_h264:dmaienc_h2640.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)25/1, width=(int)720, height=(int)576, pitch=(int)736
/GstPipeline:pipeline0/dmaienc_h264:dmaienc_h2640.GstPad:src: caps = video/x-h264, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)1/1, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d081242909c9e4f93f27f27e4f93cdcd9a6b405a0932001000468ee3cb0
/GstPipeline:pipeline0/GstDmaiperf:dmaiperf0.GstPad:src: caps = video/x-h264, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)1/1, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d081242909c9e4f93f27f27e4f93cdcd9a6b405a0932001000468ee3cb0
/GstPipeline:pipeline0/GstDmaiperf:dmaiperf0.GstPad:sink: caps = video/x-h264, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)1/1, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d081242909c9e4f93f27f27e4f93cdcd9a6b405a0932001000468ee3cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z2QAKK2EBUViuKxUdCAqKxXFYqOhAVFYrisVHQgKisVxWKjoQFRWK4rFR0ICorFcVio6ECSFITk8nyfk/k/J8nm5s00IEkKQnJ5Pk/J/J+T5PNzZprQFoJMg\\,aO48sA\\=\\=\", payload=(int)96, ssrc=(uint)604079724, clock-base=(uint)887806482, seqnum-base=(uint)30710
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:sink: caps = video/x-h264, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)1/1, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d081242909c9e4f93f27f27e4f93cdcd9a6b405a0932001000468ee3cb0
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 887806981
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 30710
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z2QAKK2EBUViuKxUdCAqKxXFYqOhAVFYrisVHQgKisVxWKjoQFRWK4rFR0ICorFcVio6ECSFITk8nyfk/k/J8nm5s00IEkKQnJ5Pk/J/J+T5PNzZprQFoJMg\\,aO48sA\\=\\=\", payload=(int)96, ssrc=(uint)604079724, clock-base=(uint)887806482, seqnum-base=(uint)30710
INFO:
Timestamp: 0:42:52.118738761; bps: 0; fps: 0.0CPU: 52;
INFO:
Timestamp: 0:42:53.130276978; bps: 1180865; fps: 24.72CPU: 86;
INFO:
Timestamp: 0:42:54.133441439; bps: 1043951; fps: 26.91CPU: 76;
INFO:
Timestamp: 0:42:55.133955814; bps: 1039331; fps: 25.0CPU: 75;
INFO:
Timestamp: 0:42:56.173321273; bps: 968163; fps: 25.2CPU: 61;
INFO:
Timestamp: 0:42:57.173779356; bps: 1037276; fps: 25.0CPU: 75;
INFO:
Timestamp: 0:42:58.190233856; bps: 974573; fps: 24.60CPU: 65;
INFO:
Timestamp: 0:42:59.214244814; bps: 965641; fps: 25.39CPU: 68;
INFO:
Timestamp: 0:43:00.214331314; bps: 1000813; fps: 25.0CPU: 71;
INFO:
Timestamp: 0:43:01.254275647; bps: 1008871; fps: 25.2CPU: 71;
also attaching the recorded video from vlc
as can be seen from the video, video stream is missing fields.
now i changed my pipeline, i brought dmairesizer into the pipeline and switched off chain-ipie property, the video frame looks nice without any missing field
but now the frame rate drops to half and CPU load crosses 90 %, why is it happening.
pipeline and the debug result are attached below
gst-launch -v v4l2src always-copy=FALSE input-src=composite chain-ipipe=false queue-size=6 ! dmairesizer ! priority scheduler=1 rtpriority=40 ! "video/x-raw-yuv,format=(fourcc)NV12,width=720,height=576,pitch=736" ! dmaiaccel ! dmaienc_h264 targetbitrate=8000000 maxbitrate=8000000 ! dmaiperf print-arm-load=true ! rtph264pay ! udpsink host=199.200.15.61 port=6666
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)0/1
/GstPipeline:pipeline0/GstTIDmaiResizer:tidmairesizer0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstTIDmaiResizer:tidmairesizer0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)25/1, width=(int)720, height=(int)576, pixel-aspect-ratio=(fraction)0/1
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:1:0:196
/GstPipeline:pipeline0/GstTIPriority:tipriority0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstTIPriority:tipriority0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstTIDmaiaccel:tidmaiaccel0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstTIDmaiaccel:tidmaiaccel0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/dmaienc_h264:dmaienc_h2640.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)720, height=(int)576, framerate=(fraction)25/1, pitch=(int)736, pixel-aspect-ratio=(fraction)1/1, dmaioutput=(boolean)true
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z2QAKK2EBUViuKxUdCAqKxXFYqOhAVFYrisVHQgKisVxWKjoQFRWK4rFR0ICorFcVio6ECSFITk8nyfk/k/J8nm5s00IEkKQnJ5Pk/J/J+T5PNzZprQFoJMg\\,aO48sA\\=\\=\", payload=(int)96, ssrc=(uint)2492036591, clock-base=(uint)2418381961, seqnum-base=(uint)18223
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: timestamp = 2418383413
/GstPipeline:pipeline0/GstRtpH264Pay:rtph264pay0: seqnum = 18223
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, sprop-parameter-sets=(string)\"Z2QAKK2EBUViuKxUdCAqKxXFYqOhAVFYrisVHQgKisVxWKjoQFRWK4rFR0ICorFcVio6ECSFITk8nyfk/k/J8nm5s00IEkKQnJ5Pk/J/J+T5PNzZprQFoJMg\\,aO48sA\\=\\=\", payload=(int)96, ssrc=(uint)2492036591, clock-base=(uint)2418381961, seqnum-base=(uint)18223
INFO:
Timestamp: 0:40:43.213763262; bps: 0; fps: 0.0CPU: 50;
INFO:
Timestamp: 0:40:44.267973435; bps: 542114; fps: 10.43CPU: 94;
INFO:
Timestamp: 0:40:45.322482146; bps: 487149; fps: 11.38CPU: 91;
INFO:
Timestamp: 0:40:46.392227977; bps: 496485; fps: 11.22CPU: 92;
INFO:
Timestamp: 0:40:47.412496186; bps: 444150; fps: 11.76CPU: 93;
INFO:
Timestamp: 0:40:48.442236811; bps: 453206; fps: 11.66CPU: 92;
INFO:
Timestamp: 0:40:49.496955894; bps: 489095; fps: 11.38CPU: 90;
INFO:
Timestamp: 0:40:50.519943728; bps: 448559; fps: 11.74CPU: 93;
INFO:
Timestamp: 0:40:51.572846021; bps: 488337; fps: 11.40CPU: 94;
INFO:
Timestamp: 0:40:52.591048105; bps: 443508; fps: 11.78CPU: 90;
INFO:
Timestamp: 0:40:53.618277146; bps: 452556; fps: 11.68CPU: 92;
INFO:
Timestamp: 0:40:54.670530605; bps: 482093; fps: 11.40CPU: 94;
INFO:
Timestamp: 0:40:55.689224313; bps: 442477; fps: 11.78CPU: 93;
INFO:
Timestamp: 0:40:56.746034396; bps: 489577; fps: 11.36CPU: 92;
INFO:
Timestamp: 0:40:57.760125563; bps: 439807; fps: 11.83CPU: 91;
INFO:
Timestamp: 0:40:58.776009312; bps: 439599; fps: 11.82CPU: 94;
INFO:
Timestamp: 0:40:59.830885228; bps: 486219; fps: 11.38CPU: 93;
INFO:
Timestamp: 0:41:00.854431894; bps: 450979; fps: 11.73CPU: 95;
INFO:
Timestamp: 0:41:01.907918810; bps: 488485; fps: 11.39CPU: 91;
sampled video is also attached below
