  • TI Thinks Resolved
TDA2PXEVM: Temperature calculation at runtime
Prodigy 20 points
Part Number: TDA2PXEVM
I am running the use case on Tda2px.
1. How can I calculate the exact temperature of board at runtime ??
2. How to map the exact memory usage for different cores ?
Please suggest the solution.
Thank you in advance !
  • Hi Ashwini,
    do you run Linux or RTOS on A15?
    Yordan
  • In reply to Yordan Kamenov:
    Hello Yordan,
    we run on RTOS A15.
    Ashwini
  • In reply to Ashwini Patil2:
    Hi ,
    can you check "ADAS Power Management" Application note here:
    and see if you can find directions how to measure temperature.
    For memory usage you can press 'p' while running usecase to get statistics. You can also check section "7 Throughput and Data Traffic Profiling" in "Guide to Debugging With CCS on the DRA7x, TDA2x and TDA3x Family of Devices" here:
    Yordan
    Yordan
