I had been unable to get back to this for a long time, but I believe I have a working means of exporting carveout information from a remoteproc via sysFS such that it will create the carveout directory in the remoteproc directory and export the carveout address when the PRU starts up, and remove it when it shuts down. I'm just interested if Nick Saulnier or Suman have any critiques, like regarding what references are safe to keep globally between startup and shutdown, and if I should be getting some of my references differently to respect reference counting considerations. I'm also interested in if they have any new suggestions for handling high-bandwidth data exchange between PRU and Application processor.
#include <linux/init.h> #include <linux/module.h> #include <linux/kernel.h> #include <linux/of.h> #include <linux/of_device.h> #include <linux/remoteproc.h> #include <linux/kobject.h> #include <linux/sysfs.h> MODULE_LICENSE("GPL"); MODULE_AUTHOR("Bill Merryman"); MODULE_DESCRIPTION("A simple module to access information from the PRU rproc."); MODULE_VERSION("0.01"); /* /sys/class/remoteproc/remoteproc1 is a symbolic link for /sys/devices/platform/ocp/4a326004.pruss-soc-bus/4a300000.pruss/4a334000.pru/remoteproc/remoteproc1 /sys/class/remoteproc/remoteproc2 is a symbolic link for /sys/devices/platform/ocp/4a326004.pruss-soc-bus/4a300000.pruss/4a338000.pru/remoteproc/remoteproc2 */ struct rproc *rproc_ptr; struct kobject *remoteproc_device_kobj_ptr; struct kobject *carveout_dir_kobj_ptr; static struct rproc_subdev *rproc_subdev; static ssize_t carveout_show(struct kobject *kobj, struct kobj_attribute *attr, char *buf) { struct resource_table *table = rproc_ptr->table_ptr; struct fw_rsc_carveout *c; int i; if (!table) { return 0; } for (i = 0; i < table->num; i++) { int offset = table->offset[i]; struct fw_rsc_hdr *hdr = (void *)table + offset; void *rsc = (void *)hdr + sizeof(*hdr); if(hdr->type == RSC_CARVEOUT) c = rsc; } return sprintf(buf, "%x\n", (c) ? c->pa : 0); } static struct kobj_attribute carveout_attribute =__ATTR(carveout_address, 0440, carveout_show, NULL); int rproc_access_driver_probe(struct rproc_subdev *subdev) { int error = 0; carveout_dir_kobj_ptr = kobject_create_and_add("carveout", remoteproc_device_kobj_ptr); if(!carveout_dir_kobj_ptr) return -ENOMEM; printk(KERN_INFO "Carveout subdirectory created on PRU startup\n"); error = sysfs_create_file(carveout_dir_kobj_ptr, &carveout_attribute.attr); if (error) pr_debug("failed to create the carveout_address file in carveout directory\n"); return error; } void rproc_access_driver_remove(struct rproc_subdev *subdev) { if(carveout_dir_kobj_ptr) { kobject_put(carveout_dir_kobj_ptr); carveout_dir_kobj_ptr = NULL; printk(KERN_INFO "Carveout subdirectory removed on PRU shutdown\n"); } else { printk(KERN_INFO "rproc kobj null. Carveout subdirectory NOT removed\n"); } } static int __init rproc_access_driver_init(void) { struct device_node *pru_device_node_ptr; struct platform_device *pru_platform_device_ptr; struct device *remoteproc_device_ptr; pru_device_node_ptr = of_find_node_by_path("/ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000"); if(!pru_device_node_ptr) { printk(KERN_INFO "pru device node could not be acquired at init\n"); return -ENODEV; } printk(KERN_INFO "pru device node acquired at init. full_name: %s\n", pru_device_node_ptr->full_name); pru_platform_device_ptr = of_find_device_by_node(pru_device_node_ptr); of_node_put(pru_device_node_ptr); if (!pru_platform_device_ptr) return -EPROBE_DEFER; if (!strstr(dev_name(&pru_platform_device_ptr->dev), "pru") && !strstr(dev_name(&pru_platform_device_ptr->dev), "rtu")) { put_device(&pru_platform_device_ptr->dev); return -ENODEV; } rproc_ptr = platform_get_drvdata(pru_platform_device_ptr); put_device(&pru_platform_device_ptr->dev); if (!rproc_ptr) return -EPROBE_DEFER; printk(KERN_INFO "rproc acquired at init. name: %s\n", rproc_ptr->name); //I should probably use get_device here, but I'll live dangerously for now... remoteproc_device_ptr = &rproc_ptr->dev; remoteproc_device_kobj_ptr = &remoteproc_device_ptr->kobj; printk(KERN_INFO "remoteproc kobj name: %s\n", remoteproc_device_kobj_ptr->name); rproc_subdev = kzalloc(sizeof(*rproc_subdev), GFP_KERNEL); if(!rproc_subdev) return -ENOMEM; rproc_add_subdev(rproc_ptr, rproc_subdev, rproc_access_driver_probe, rproc_access_driver_remove); return 0; } static void __exit rproc_access_driver_exit(void) { /* * Here we will have to account for the possibility that the rproc * may have been already removed by the time we remove our driver. * So we need to check for its existance, and if it exists, remove * the subdevice we created for the carveout. We will also have to * account if the related PRU is running, in which case we will have * to do a full teardown before the main exit logic. */ struct device_node *pru_device_node_ptr; struct platform_device * pru_platform_device_ptr; struct rproc *rproc_ptr; pru_device_node_ptr = of_find_node_by_path("/ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000"); if(pru_device_node_ptr) { printk(KERN_INFO "pru device acquired at exit. full_name: %s\n", pru_device_node_ptr->full_name); pru_platform_device_ptr = of_find_device_by_node(pru_device_node_ptr); of_node_put(pru_device_node_ptr); if (pru_platform_device_ptr) { if (strstr(dev_name(&pru_platform_device_ptr->dev), "pru") || strstr(dev_name(&pru_platform_device_ptr->dev), "rtu")) { rproc_ptr = platform_get_drvdata(pru_platform_device_ptr); put_device(&pru_platform_device_ptr->dev); if (rproc_ptr) { printk(KERN_INFO "rproc acquired at exit. name: %s\n", rproc_ptr->name); rproc_remove_subdev(rproc_ptr, rproc_subdev); } } else { put_device(&pru_platform_device_ptr->dev); } } } printk(KERN_INFO "Freeing carveout subdevice memory\n"); kfree(rproc_subdev); } module_init(rproc_access_driver_init); module_exit(rproc_access_driver_exit);
