Other Parts Discussed in Thread: ISO1050
CPU:AM437x
SDK:06.01.00.08
kernel:4.19.94
Customer tests a simple uart1 program. The function of this program is reading data from UART1. After executing the program for a short time and then kill it. After repeating this procedure several times, the whole system will be stuck and he uses strace to locate and finds it stuck when open uart.
Below is the log:
root@am437x-evm:/opt# strace ./uart_test
execve(
"./uart_test"
"./uart_test"
], 0xbef3aca0
/* 22 vars */
) = 0
brk(NULL) = 0x22000
uname({sysname=
"Linux"
, nodename=
"am437x-evm"
, ...}) = 0
access(
"/etc/ld.so.preload"
, R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD,
"/usr/local/lib/tls/v7l/neon/vfp/libc.so.6"
, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64(
"/usr/local/lib/tls/v7l/neon/vfp"
, 0xbe8810e8) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD,
"/usr/local/lib/tls/v7l/neon/libc.so.6"
stat64(
"/usr/local/lib/tls/v7l/neon"
openat(AT_FDCWD,
"/usr/local/lib/tls/v7l/vfp/libc.so.6"
stat64(
"/usr/local/lib/tls/v7l/vfp"
openat(AT_FDCWD,
"/usr/local/lib/tls/v7l/libc.so.6"
stat64(
"/usr/local/lib/tls/v7l"
openat(AT_FDCWD,
"/usr/local/lib/tls/neon/vfp/libc.so.6"
stat64(
"/usr/local/lib/tls/neon/vfp"
openat(AT_FDCWD,
"/usr/local/lib/tls/neon/libc.so.6"
stat64(
"/usr/local/lib/tls/neon"
openat(AT_FDCWD,
"/usr/local/lib/tls/vfp/libc.so.6"
stat64(
"/usr/local/lib/tls/vfp"
openat(AT_FDCWD,
"/usr/local/lib/tls/libc.so.6"
stat64(
"/usr/local/lib/tls"
openat(AT_FDCWD,
"/usr/local/lib/v7l/neon/vfp/libc.so.6"
stat64(
"/usr/local/lib/v7l/neon/vfp"
openat(AT_FDCWD,
"/usr/local/lib/v7l/neon/libc.so.6"
stat64(
"/usr/local/lib/v7l/neon"
openat(AT_FDCWD,
"/usr/local/lib/v7l/vfp/libc.so.6"
stat64(
"/usr/local/lib/v7l/vfp"
openat(AT_FDCWD,
"/usr/local/lib/v7l/libc.so.6"
stat64(
"/usr/local/lib/v7l"
openat(AT_FDCWD,
"/usr/local/lib/neon/vfp/libc.so.6"
stat64(
"/usr/local/lib/neon/vfp"
openat(AT_FDCWD,
"/usr/local/lib/neon/libc.so.6"
stat64(
"/usr/local/lib/neon"
openat(AT_FDCWD,
"/usr/local/lib/vfp/libc.so.6"
stat64(
"/usr/local/lib/vfp"
openat(AT_FDCWD,
"/usr/local/lib/libc.so.6"
stat64(
"/usr/local/lib"
, {st_mode=S_IFDIR|0755, st_size=32768, ...}) = 0
openat(AT_FDCWD,
"/etc/ld.so.cache"
, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=29912, ...}) = 0
mmap2(NULL, 29912, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb6f51000
close(3) = 0
openat(AT_FDCWD,
"/lib/libc.so.6"
read(3,
"\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\234x\1\0004\0\0\0"
..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=16537400, ...}) = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb6f4f000
mmap2(NULL, 1315620, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb6de7000
mprotect(0xb6f14000, 61440, PROT_NONE) = 0
mmap2(0xb6f23000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12c000) = 0xb6f23000
mmap2(0xb6f26000, 8996, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6f26000
close(3) = 0
set_tls(0xb6f4fbc0) = 0
mprotect(0xb6f23000, 8192, PROT_READ) = 0
mprotect(0x20000, 4096, PROT_READ) = 0
mprotect(0xb6f59000, 4096, PROT_READ) = 0
munmap(0xb6f51000, 29912) = 0
openat(AT_FDCWD,
"/dev/ttyS1"
, O_RDWR|O_NOCTTY|O_NONBLOCK
[ 513.941557] rcu: INFO: rcu_preempt self-detected stall on CPU
[ 513.947335] rcu: 0-...!: (33265 ticks
this
GP) idle=8c6/1/0x40000004 softirq=46557/46557 fqs=0
[ 513.956152] rcu: (t=33615 jiffies g=21225 q=40)
[ 513.960878] rcu: rcu_preempt kthread starved
for
33615 jiffies! g21225 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=0
[ 513.971266] rcu: RCU grace-period kthread stack dump:
[ 513.976334] rcu_preempt R running task 0 10 2 0x00000000
[ 513.983412] Backtrace:
[ 513.985874] [<c0942600>] (__schedule) from [<c0942dc4>] (schedule+0x58/0xc4)
[ 513.992954] r10:c0e4e1d3 r9:c0e16340 r8:c0e16320 r7:c0e03048 r6:cf875ee4 r5:c0e16340
[ 514.000814] r4:ffffe000
[ 514.003358] [<c0942d6c>] (schedule) from [<c0946a54>] (schedule_timeout+0x180/0x288)
[ 514.011132] r5:c0e16340 r4:ffffd044
[ 514.014724] [<c09468d4>] (schedule_timeout) from [<c0183980>] (rcu_gp_kthread+0x5d4/0xbcc)
[ 514.023023] r9:c0e03108 r8:00000001 r7:c0e16320 r6:cf874000 r5:c0e15c54 r4:00000001
[ 514.030803] [<c01833ac>] (rcu_gp_kthread) from [<c014b774>] (kthread+0x158/0x160)
[ 514.038314] r7:cf874000
[ 514.040858] [<c014b61c>] (kthread) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 514.048109] Exception stack(0xcf875fb0 to 0xcf875ff8)
[ 514.053179] 5fa0: 00000000 00000000 00000000 00000000
[ 514.061392] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 514.069604] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 514.076246] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c014b61c
[ 514.084106] r4:cf840440
[ 514.086646] Task dump
for
CPU 0:
[ 514.089882] uart_test R running task 0 781 778 0x00000012
[ 514.096960] Backtrace:
[ 514.099418] [<c010cb64>] (dump_backtrace) from [<c010ced4>] (show_stack+0x18/0x1c)
[ 514.107019] r7:c0e15c54 r6:0000030a r5:c0e03048 r4:c8019200
[ 514.112703] [<c010cebc>] (show_stack) from [<c0156d08>] (sched_show_task.part.2+0xe8/0x104)
[ 514.121091] [<c0156c20>] (sched_show_task.part.2) from [<c0156e18>] (dump_cpu_task+0x38/0x3c)
[ 514.129649] r6:c0e03108 r5:00000000 r4:c0e15c54
[ 514.134287] [<c0156de0>] (dump_cpu_task) from [<c018545c>] (rcu_dump_cpu_stacks+0x90/0xd0)
[ 514.142587] [<c01853cc>] (rcu_dump_cpu_stacks) from [<c0184b3c>] (rcu_check_callbacks+0x628/0x8ec)
[ 514.151584] r10:c0e16320 r9:c0e030fc r8:00000000 r7:c0e15c54 r6:c0e16074 r5:c0e160e0
[ 514.159445] r4:c0e15c54 r3:91ae3010
[ 514.163036] [<c0184514>] (rcu_check_callbacks) from [<c018a938>] (update_process_times+0x3c/0x6c)
[ 514.171946] r10:20000193 r9:c019c3f4 r8:00000000 r7:00000077 r6:00000000 r5:c8019200
[ 514.179806] r4:ffffe000
[ 514.182351] [<c018a8fc>] (update_process_times) from [<c019c1cc>] (tick_sched_handle+0x5c/0x60)
[ 514.191085] r7:00000077 r6:a93619ed r5:c8dd7b38 r4:c0e17fc0
[ 514.196768] [<c019c170>] (tick_sched_handle) from [<c019c444>] (tick_sched_timer+0x50/0xac)
[ 514.205155] [<c019c3f4>] (tick_sched_timer) from [<c018b520>] (__hrtimer_run_queues.constprop.3+0x190/0x228)
[ 514.215024] r7:ffffe000 r6:c0e17480 r5:c0e17fc0 r4:c0e174c0
[ 514.220707] [<c018b390>] (__hrtimer_run_queues.constprop.3) from [<c018bce0>] (hrtimer_interrupt+0x120/0x30c)
[ 514.230664] r10:c0a43d00 r9:ffffffff r8:7fffffff r7:00000003 r6:20000193 r5:ffffe000
[ 514.238524] r4:c0e17480
[ 514.241069] [<c018bbc0>] (hrtimer_interrupt) from [<c010ed44>] (twd_handler+0x38/0x40)
[ 514.249020] r10:c0a43d00 r9:c8dd6000 r8:cf808000 r7:00000012 r6:cf8325c0 r5:c0e034d4
[ 514.256880] r4:00000001
[ 514.259425] [<c010ed0c>] (twd_handler) from [<c01770f8>] (handle_percpu_devid_irq+0x6c/0x104)
[ 514.267982] r5:c0e034d4 r4:cf807300
[ 514.271576] [<c017708c>] (handle_percpu_devid_irq) from [<c0171bac>] (generic_handle_irq+0x2c/0x3c)
[ 514.280658] r7:c8dd7c48 r6:00000001 r5:00000000 r4:c0e4c9f0
[ 514.286343] [<c0171b80>] (generic_handle_irq) from [<c017238c>] (__handle_domain_irq+0x5c/0xb0)
[ 514.295082] [<c0172330>] (__handle_domain_irq) from [<c0457c70>] (gic_handle_irq+0x44/0x70)
[ 514.303470] r9:c8dd6000 r8:fa241100 r7:c8dd7b38 r6:fa240100 r5:fa24010c r4:c0e034d4
[ 514.311248] [<c0457c2c>] (gic_handle_irq) from [<c0101a0c>] (__irq_svc+0x6c/0xa8)
[ 514.318759] Exception stack(0xc8dd7b38 to 0xc8dd7b80)
[ 514.323831] 7b20: 00404000 00404000
[ 514.332044] 7b40: c0e4df80 00000000 00000202 00000000 00000001 00000000 cf808000 c8dd6000
[ 514.340258] 7b60: c0a43d00 c8dd7be4 c8dd7be8 c8dd7b88 c0130e20 c0102220 60000113 ffffffff
[ 514.348471] r9:c8dd6000 r8:cf808000 r7:c8dd7b6c r6:ffffffff r5:60000113 r4:c0102220
[ 514.356250] [<c0102180>] (__do_softirq) from [<c0130e20>] (irq_exit+0x108/0x114)
[ 514.363678] r10:c0a43d00 r9:c8dd6000 r8:cf808000 r7:00000000 r6:00000001 r5:00000000
[ 514.371538] r4:c0e4c9f0
[ 514.374083] [<c0130d18>] (irq_exit) from [<c0172390>] (__handle_domain_irq+0x60/0xb0)
[ 514.381949] [<c0172330>] (__handle_domain_irq) from [<c0457c70>] (gic_handle_irq+0x44/0x70)
[ 514.390335] r9:c8dd6000 r8:fa241100 r7:c8dd7c48 r6:fa240100 r5:fa24010c r4:c0e034d4
[ 514.398112] [<c0457c2c>] (gic_handle_irq) from [<c0101a0c>] (__irq_svc+0x6c/0xa8)
[ 514.405624] Exception stack(0xc8dd7c48 to 0xc8dd7c90)
[ 514.410696] 7c40: c0e8485c 00000000 00000730 00000000 c0e8485c cf00ea40
[ 514.418908] 7c60: 00000000 00000000 ca47f000 c8de6600 c0a43d00 c8dd7cbc c8dd7c68 c8dd7c98
[ 514.427119] 7c80: c01155a0 c0521e08 60000013 ffffffff
[ 514.432191] r9:c8dd6000 r8:ca47f000 r7:c8dd7c7c r6:ffffffff r5:60000013 r4:c0521e08
[ 514.439973] [<c0521cb0>] (omap_8250_startup) from [<c051be1c>] (serial8250_startup+0x1c/0x28)
[ 514.448533] r6:c8de6600 r5:c0e8485c r4:cf8530d0
[ 514.453172] [<c051be00>] (serial8250_startup) from [<c0516264>] (uart_startup.part.4+0x150/0x2cc)
[ 514.462085] [<c0516114>] (uart_startup.part.4) from [<c0516438>] (uart_port_activate+0x58/0x84)
[ 514.470820] r9:c8de6600 r8:c8dd6000 r7:cf853150 r6:c8ede840 r5:c8de6600 r4:cf8530d0
[ 514.478598] [<c05163e0>] (uart_port_activate) from [<c04fd038>] (tty_port_open+0xbc/0x114)
[ 514.486893] r5:c8de6600 r4:cf8530d0
[ 514.490484] [<c04fcf7c>] (tty_port_open) from [<c0514b74>] (uart_open+0x20/0x28)
[ 514.497912] r9:c8de6600 r8:c8dd6000 r7:c0c5efd4 r6:00400041 r5:c8de6600 r4:c8ede840
[ 514.505692] [<c0514b54>] (uart_open) from [<c04f5a38>] (tty_open+0xf0/0x464)
[ 514.512774] [<c04f5948>] (tty_open) from [<c023fe10>] (chrdev_open+0xf8/0x200)
[ 514.520028] r10:cf4033b8 r9:00000000 r8:c0a43d80 r7:c8ede840 r6:cf00d7d0 r5:c0e03048
[ 514.527888] r4:cf0036c0
[ 514.530435] [<c023fd18>] (chrdev_open) from [<c0237108>] (do_dentry_open+0x118/0x3b4)
[ 514.538299] r9:c023fd18 r8:c8ede848 r7:00000902 r6:00000000 r5:cf00d7d0 r4:c8ede840
[ 514.546078] [<c0236ff0>] (do_dentry_open) from [<c0238634>] (vfs_open+0x34/0x38)
[ 514.553505] r9:c8ede840 r8:c8dd7f50 r7:00000902 r6:00000000 r5:00000000 r4:c8dd7e90
[ 514.561285] [<c0238600>] (vfs_open) from [<c024ac64>] (path_openat+0x2a8/0x1138)
[ 514.568713] [<c024a9bc>] (path_openat) from [<c024cb78>] (do_filp_open+0x7c/0xe4)
[ 514.576228] r10:00000142 r9:c8dd6000 r8:00000001 r7:c8dd7f50 r6:c8dd7e90 r5:c0e03048
[ 514.584088] r4:c0e03048
[ 514.586633] [<c024cafc>] (do_filp_open) from [<c0238930>] (do_sys_open+0x170/0x1f4)
[ 514.594322] r8:fffff000 r7:cefda000 r6:ffffff9c r5:c0e03048 r4:00000003
[ 514.601053] [<c02387c0>] (do_sys_open) from [<c02389ec>] (sys_openat+0x14/0x18)
[ 514.608394] r10:00000142 r9:c8dd6000 r8:c0101204 r7:00000142 r6:000105ac r5:00000000
[ 514.616254] r4:00010934
[ 514.618799] [<c02389d8>] (sys_openat) from [<c01011e4>] (__sys_trace_return+0x0/0x1c)
[ 514.626659] Exception stack(0xc8dd7fa8 to 0xc8dd7ff0)
[ 514.631730] 7fa0: 00010934 00000000 ffffff9c 000109a8 00000902 00000000
[ 514.639942] 7fc0: 00010934 00000000 000105ac 00000142 00000000 00000000 b6f69000 be9edb44
[ 514.648152] 7fe0: b6f34000 be9ed2d0 000106c4 b6eb5c84
