Hello Everyone,
I'd like to ask for help to achieve RX NCO switching via GPIO. I've already managed to change TX NCO this way, as written in this topic:
https://e2e.ti.com/support/rf-microwave-group/rf-microwave/f/rf-microwave-forum/1295365/afe7900evm-nco-frequency-configuration
Then I tried replacing the TX specific parts of the code by RX related things (device.TT->device.RRF, TXDIG->RXDIG, etc...). Although the first element of the RX NCO array is loaded, the others don't seem to have effect and I can't control the GPIO functions even by IOWRAP.OverrideFunction. The LMK configuration is below:
############## Read me ############## #In HSDC Pro DAC tab, Select AFE79xx_2x2TX_44210; Data Rate = 491.52M #In HSDC Pro ADC tab, Select AFE79xx_2x2RX_44210; Data Rate = 491.52M ---> To capture 4 RX channels sysParams=AFE.systemParams sysParams.__init__();sysParams.chipVersion=chipVersion setupParams.skipFpga = 1 # setup FPGA (TSW14J56) using HSDC Pro ############## Top Level ############## sysParams.FRef = 506 sysParams.FadcRx = 2530 sysParams.FadcFb = 2530 sysParams.Fdac = 2530*4 sysParams.externalClockRx=False sysParams.externalClockTx=False ############## Digital Chain ############## ##### RX ##### sysParams.ncoFreqMode="FCW" sysStatus.rxChainDirectCtrl=True sysParams.rxChainDirectCtrl=True sysParams.broadcastRxNcoSel=1 sysParams.numRxNco=16 sysParams.ncoRxMode=[6,6] sysParams.ddcFactorRx = [5,5,5,5] #DDC decimation factor for RX A, B, C and D sysParams.rxNco0 = [[1800,5400], #Band0, Band1 for RXA [750,750], #Band0, Band1 for RXB [3000,2500], #Band0, Band1 for RXC [1800,1800]] #Band0, Band1 for RXD ##### FB ##### sysParams.fbEnable = [False,False] sysParams.ddcFactorFb = [5,5] #DDC decimation factor for FB 1 and 2 sysParams.fbNco0 = [750,750] #Band0 for FB1 and FB2 ##### TX ##### sysParams.ducFactorTx = [20,20,20,20] #DUC interpolation factor for TX A, B, C and D sysParams.txNco0 = [[875.5,1800], #Band0, Band1 for TXA [1987.5,1800], #Band0, Band1 for TXB [3605,2500], #Band0, Band1 for TXC [1800,1800]] #Band0, Band1 for TXD ############## JESD ############## ##### ADC-JESD ##### sysParams.jesdSystemMode= [3,3] #SystemMode 0: 2R1F-FDD ; rx1-rx2-fb -fb #SystemMode 1: 1R1F-FDD ; rx -rx -fb -fb #SystemMode 2: 2R-FDD ; rx1-rx1-rx2-rx2 #SystemMode 3: 1R ; rx -rx -rx -rx #SystemMode 4: 1F ; fb -fb- fb -fb #SystemMode 5: 1R1F-TDD ; rx/fb-rx/fb-rx/fb-rx/fb sysParams.jesdTxProtocol= [0,0] # 0 - 8b/10b encoding; 2 - 64b/66b encoding sysParams.LMFSHdRx = ["44210","44210","44210","44210"] # The 2nd and 4th are valid only for jesdSystemMode values in (0,2). # For other modes, select 4 converter modes for 1st and 3rd. sysParams.LMFSHdFb = ["22210","22210"] sysParams.rxJesdTxScr = [True,True,True,True] sysParams.fbJesdTxScr = [True,True] sysParams.rxJesdTxK = [16,16,16,16] sysParams.fbJesdTxK = [16,16] sysParams.jesdTxLaneMux = [0,1,2,3,4,5,6,7] # Enter which lanes you want in each location. # For example, if you want to exchange the first two lines of each 2T, # this should be [[1,0,2,3],[5,4,6,7]] ##### DAC-JESD ##### sysParams.jesdRxProtocol= [0,0] sysParams.LMFSHdTx = ["44210","44210","44210","44210"] sysParams.jesdRxLaneMux = [0,1,2,3,4,5,6,7] # Enter which lanes you want in each location. # For example, if you want to exchange the first two lines of each 2R # this should be [[1,0,2,3],[5,4,6,7]] sysParams.jesdRxRbd = [4, 4] sysParams.jesdRxScr = [True,True,True,True] sysParams.jesdRxK = [16,16,16,16] ##### JESD Common ##### sysParams.jesdABLvdsSync= False sysParams.jesdCDLvdsSync= False sysParams.syncLoopBack = True #JESD Sync signal is connected to FPGA ############## GPIO ############## sysParams.gpioMapping = { 'H8': 'ADC_SYNC0', 'H7': 'DAC_SYNC0', 'N8': 'ADC_SYNC2', 'N7': 'ADC_SYNC3', 'H9': 'ADC_SYNC1', 'G9': 'DAC_SYNC1', 'N9': 'DAC_SYNC2', 'P9': 'DAC_SYNC3', 'P14': 'GLOBAL_PDN', 'K14': 'FBABTDD', 'R6': 'FBCDTDD', 'H15': ['TXATDD','TXBTDD'], 'V5': ['TXCTDD','TXDTDD'], 'E7': ['RXATDD','RXBTDD'], 'R15': ['RXCTDD','RXDTDD'], 'L14': ['RX_NCOSEL_3'], 'M14': ['RX_NCOSEL_2'], 'P13': ['RX_NCOSEL_1'], 'N12': ['RX_NCOSEL_0']} ############## LMK Params ############## lmkParams.pllEn = False lmkParams.inputClk = 506 #983.04 # Valid only when lmkParams.pllEn = False lmkParams.lmkFrefClk = True setupParams.fpgaRefClk = 126.5 # Should be equal to LaneRate/40 for TSW14J56 ############## Logging ############## logDumpInst.setFileName(ASTERIX_DIR+DEVICES_DIR+r"\Afe79xxPg1.txt") logDumpInst.logFormat=0x21 #Modify to 0x1 to save register scequence to log file. Script takes more time to execute. logDumpInst.rewriteFile=1 logDumpInst.rewriteFileFormat4=1 device.optimizeWrites=0 device.rawWriteLogEn=1 device.delay_time = 0 #-------------------------------------------------------------------------------------------------# setupParams.skipLmk = False AFE.initializeConfig() lmkParams.sysrefFreq = AFE.systemStatus.sysrefFreq lmkParams.lmkPulseSysrefMode = False AFE.LMK.lmkConfig()
And the AFE configuration is as follows:
## Initiates AFE79xx Bring-up setupParams.skipLmk = True AFE.deviceBringup() AFE.TOP.overrideTdd(15,3,15) #for i in range(4): AFE.DSA.setRxDsa(i,4) ### ADC Ramp Out # for i in range(3): # AFE.JESD.ADCJESD[0].adcRampTestPattern(i,1,1) # AFE.JESD.ADCJESD[1].adcRampTestPattern(i,1,1) #chNo, En, RampInc ### RX NCO Update rx_nco_freqs_ch_A=[ 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690] rx_nco_freqs_ch_B=[ 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690] rx_nco_freqs_ch_C=[ 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690] rx_nco_freqs_ch_D=[ 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690, 920.5,1185,290,690] id_ch_A=0 id_ch_B=1 id_ch_C=2 id_ch_D=3 for i,freq in enumerate(rx_nco_freqs_ch_A): AFE.updateRxNcoInfiniteNcoMode(id_ch_A,freq,i) for i,freq in enumerate(rx_nco_freqs_ch_B): AFE.updateRxNcoInfiniteNcoMode(id_ch_B,freq,i) for i,freq in enumerate(rx_nco_freqs_ch_C): AFE.updateRxNcoInfiniteNcoMode(id_ch_C,freq,i) for i,freq in enumerate(rx_nco_freqs_ch_D): AFE.updateRxNcoInfiniteNcoMode(id_ch_D,freq,i) for i in range(2): for j in range(2): device.RRF[j].RXDIG[i].RXDIG.REGGROUP_4.config_fmixer_update_pulse=0 device.RRF[j].RXDIG[i].RXDIG.REGGROUP_4.config_fmixer_update_pulse=1
What do you think is missing? Thank you for your help in advance!
Norbert
