Other Parts Discussed in Thread: TMP112, TMP390, TMP392
Hi, team,
My customer is evaluating TMP112EVM for a new project. TM=1 for interrupt mode, only this bit of configuration register was set, other bits were using default value.
They found after connecting TMP112EVM to computer, If the temperature firstly dropped to below the low limit, there was no alert low given out. Then if temperature increased to above the high limit, there was alert low asserted. After that, if the temperature again dropped to below low limit, the alert can be asserted.
Why does the first TEMP < low limit after power on not recognized by the IC?
Actually not only customer, I also found this phenomenon on our EVM.
