Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
DRV5056-Q1: Vout formula
Part Number: DRV5056-Q1
Other Parts Discussed in Thread: DRV5056
Hi team,
I have two questions would like to check with you.
1. Referring to below formula, the Vout in equation 1 stands for the device's output, correct? Or we should use this equation calculate the Vout in MCU?
2. Does the FIT rate, FMD document available for DRV5056-Q1 to share with customer? They used this device in some functional safety requirement application. So need this document to do some analysis.
If yes, please share with me through email.
email: ethan-wen@ti.com
Thanks!
Ethan Wen
