Other Parts Discussed in Thread: IWR1843
Hello there,
I am using IWR1843 and got some data captured from the Demo Visualizer. While trying to parse them, even though I used the demo python scripts for parsing the data, I get weird results in the x y z columns.
I call them weird because even though in the oxygen it mentions that the values are in meters I get results like: 4.619.435.787.200.920 which is enormous. Same would go for velocity.
I would need some help to understand the structure of the data a bit better in order to properly parse the data.
What is the detailed structure of the binary data file? Could you provide documentation that explains each field in the data file, its data type, and its length in bytes?
Could you provide more information about the structure of each TLV in the data file? Specifically, how can I identify the number of detected objects in each TLV? Is this information included in the TLV header or elsewhere in the data file?
Could you provide an example of parsed data? This would be very helpful to validate our parsing process.
Could you provide any additional information or context that might be helpful in parsing and interpreting the data correctly?
Thank you so much in advance.
