AWRL6432 Antenna Design same as EVM
require reduced PCB dimension
follow the rules at least lambda/2 space is required from the edge of the patch elements to the edge of the PCB
remove black area , only keep blue area
whether it is feasible ?
Yes. It should be feasible. You can get almost similar performance as the EVM antenna.
You can access the Altium files or layout files from the link provided below from where you can extract the antenna layout and use it.
Hi
I findn't AWRL6432BOOST antenna pattern EDA file
I would like my new Antenna Design board compares with AWRL6432BOOST
We cannot share the antenna design files in a public forum. Please contact the TI representative for your region and request for these files.
