AWR2243BOOST: SPI Connection Issue while using DCA1000EVM for data capture
Part Number: AWR2243BOOST
This post is in continuation to my previous post - AWR2243BOOST: SPI Connection Issue while using DCA1000EVM for data capture. Unfortunately, that post is locked and I cannot post any replies there.
As mentioned in the Reply, I went through the linked post AWR2243BOOST: SPI connectivity status remains Disconnected, and followed every option specified there. However, in all cases, I am seeing the SPI connection issue and I am getting exactly the same behavior as mentioned by the original author.
In the original post, finally, it is concluded that the issue could be hardware-related and the TI expert recommended replacing the hardware. In my case also I am seeing the exact same behavior, so what should I do?
Do I need to get the hardware replaced?
    Although you have mentioned you have followed the same steps as the other discussion, can you please share photos of your hardware setup and connections?
    Has this setup worked in the past or is it a new setup?
    Adrian
