MMWCAS-DSP-EVM: AWR 2544 with DCA 1000, while using mmwave studio unable to get post proc
Part Number: MMWCAS-DSP-EVM
Other Parts Discussed in Thread: AWR2544
Hi Team, seeking for some support from a customer. Thank you.
Using AWR 2544 with DCA 1000, while using mmwave studio unable to get post proc
During the processing with mmwave studio post processing window is not opening
GM: Constructor
GM: Wed Mar 05 11:26:35 2025
RSTD.Transmit("/Settings")
[11:26:36]
[11:26:36] ### Running Startup script: "D:\ti\mmwave_studio_03_01_03_01\mmWaveStudio\Scripts\Startup.lua" ###
[11:26:36] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[11:26:36] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[11:26:36] Scripter ignored: Attempt to UnBuild() again or before Build.
[11:26:36] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "D:\\ti\\mmwave_studio_03_01_03_01\\mmWaveStudio\\Clients\\\\LabClient.dll")
[11:26:36] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[11:26:36] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[11:26:36] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
Client 3/Use" , "FALSE")
[11:26:36] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[11:26:36] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "D:\\ti\\mmwave_studio_03_01_03_01\\mmWaveStudio\\RunTime\\SAL.dll")
[11:26:36] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[11:26:36] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[11:26:36] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[11:26:36] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[11:26:36] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[11:26:36] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[11:26:36] RSTD.Transmit("/")
[11:26:36] RSTD.SaveSettings(): Settings saved to "C:\Users\DELL\AppData\Roaming\RSTD\config.xml"
[11:26:36] RSTD.Build(opens in new tab)()
[11:26:36] RSTD.AL(opens in new tab)_Build()
[11:26:36] RSTD.AL_LoadXml()
[11:26:36] RSTD.AL(opens in new tab)_Init()
[11:26:36] RSTD.Clients_Build()
[11:26:36] GM: Init
[11:26:36] GM: Loaded 'D:\ti\mmwave_studio_03_01_03_01\mmWaveStudio\Clients\\LabClient.dll'
[11:26:36] GM: 1 Guest (s) init
[11:26:36] GM: 1 Module(s) init
[11:26:36] GM: 2 Tab (s) init
[11:26:36] RSTD.Client_LoadXml()
[11:26:36] [RadarAPI]: ar1.GuiVersion()
[11:26:36] [RadarAPI]: ar1.select(opens in new tab)RadarMode(0)
[11:26:36] [RadarAPI]: Status: Passed
[11:26:36] Matlab Runtime Engine is installed
[11:26:36] [RadarAPI]: Starting Matlab Engine..
[11:26:40] [RadarAPI]: Matlab Engine Started!
[11:26:42] [RadarAPI]: ar1.selectCascadeMode(0)
[11:26:42] [RadarAPI]: Status: Passed
[11:26:42] [RadarAPI]: ar1.LoadSettings('C:\Users\DELL\AppData\Roaming\RSTD\ar1gui.ini')
[11:26:43] TESTING = false
[11:26:43] RstdNet: Port 2777: Listening..
[11:26:43]
[11:26:43] Script completed successfully.
[11:26:53] [RadarAPI]: Opening Gpio Control Port()
[11:26:53] [RadarAPI]: Status: Passed
[11:26:54] [RadarAPI]: Opening Board Control Port()
[11:26:54] [RadarAPI]: Status: Passed
[11:26:55] [RadarAPI]: ar1.FullReset()
[11:26:55] [RadarAPI]: Status: Passed
[11:26:56] [RadarAPI]: Closing Board Control Port()
[11:26:56] [RadarAPI]: Status: Passed
[11:26:56] [RadarAPI]: Closing Gpio Control Port()
[11:26:56] [RadarAPI]: ar1.SOPControl(2)
[11:26:59] [RadarAPI]: ar1.Connect(12,921600,1000)
[11:27:01] [RadarAPI]: Warning: Connected with baudrate 115200
[11:27:02] [RadarAPI]: Warning: TOP_CTRL:EFUSE_OVERRIDE_RS232_CLKMODE value: 23
[11:27:02] [RadarAPI]: Warning: RS232_BITINTERVAL value: 170929206
[11:27:03] [RadarAPI]: Warning: RS232_SOP11_BITINTERVAL value: 0input: 54
[11:27:03] [RadarAPI]: Warning: Disconnected existing BaudRate
[11:27:04] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[11:27:05] [RadarAPI]: ar1.Calling_IsConnected()
[11:27:06] [RadarAPI]: Part number of the device = 0xa1
[11:27:06] [RadarAPI]: Device type = GP
[11:27:06] [RadarAPI]: ar1.Select(opens in new tab)ChipVersion("AR1642")
[11:27:06] [RadarAPI]: Status: Passed
[11:27:06] [RadarAPI]: ar1.deviceVariantSelection("XWR2544")
[11:27:06] [RadarAPI]: ar1.frequencyBandSelection("77G")
[11:27:06] [RadarAPI]: ar1.Select(opens in new tab)ChipVersion("AWR2544")
[11:27:06] Device Status : AWR2544/GP/ASIL-B/SOP:2/ES:1.0
[11:27:06] [RadarAPI]: ar1.SaveSettings('C:\Users\DELL\AppData\Roaming\RSTD\ar1gui.ini')
[11:27:15] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_03_01_03_01\\rf_eval_firmware\\radarss\\xwr25xx_radarss_rprc.bin")
[11:27:19] [RadarAPI]: ar1.GetBSSFwVersion()
[11:27:19] [RadarAPI]: BSSFwVersion:(02.05.04.00 (16/05/23))
[11:27:20] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[11:27:20] [RadarAPI]: BSSPatchFwVersion:(02.05.06.00 (03/10/23))
[11:27:22] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_03_01_03_01\\rf_eval_firmware\\masterss\\xwr2xxx_masterss.bin")
[11:27:25] [RadarAPI]: Downloading MSS RPRC Binary..
[11:27:29] [RadarAPI]: ar1.GetMSSFwVersion()
[11:27:29] [RadarAPI]: MSSFwVersion:(02.04.02.12 (05/01/24))
[11:27:33] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[11:27:33] [RadarAPI]: Status: Passed
[11:27:33] MSS power up done async event received!
[11:27:35] [RadarAPI]: ar1.RfEnable()
[11:27:35] BSS power up done async event received!
[11:27:35] [RadarAPI]: Status: Passed
[11:27:35] [RadarAPI]: ar1.GetMSSFwVersion()
[11:27:35] [RadarAPI]: MSSFwVersion:(02.04.02.12 (05/01/24))
[11:27:35] [RadarAPI]: ar1.GetBSSFwVersion()
[11:27:35] [RadarAPI]: BSSFwVersion:(02.05.04.00 (16/05/23))
[11:27:36] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[11:27:36] [RadarAPI]: BSSPatchFwVersion:(02.05.06.00 (03/10/23))
[11:27:41] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[11:27:41] [RadarAPI]: Sending dll_version command to DCA1000
[11:27:42] [RadarAPI]:
[11:27:42] DLL Version : 1.0
[11:27:42] [RadarAPI]: ar1.Select(opens in new tab)CaptureDevice("DCA1000")
[11:27:42] [RadarAPI]: Status: Passed
[11:27:44] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[11:27:44] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[11:27:44] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[11:27:44] [RadarAPI]: Sending fpga command to DCA1000
[11:27:50] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[11:27:50] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[11:27:50] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[11:27:50] [RadarAPI]: Sending fpga command to DCA1000
[11:27:51] [RadarAPI]:
[11:27:51]
[11:27:51] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[11:27:51] Ethernet connection failed. [error -4051]
[11:27:51] [RadarAPI]: Sending record command to DCA1000
[11:27:51]
[11:27:51] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[11:27:51] [RadarAPI]: Sending fpga_version command to DCA1000
[11:27:51]
[11:27:54] [RadarAPI]:
[11:27:54] FPGA Configuration :
[11:27:54] Timeout Error! System disconnected
[11:27:54] [RadarAPI]: Sending record command to DCA1000
[11:27:57] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[11:27:57] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[11:27:57] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[11:27:57] [RadarAPI]: Sending fpga command to DCA1000
[11:27:57]
[11:27:57] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[11:27:57] Ethernet connection failed. [error -4051]
[11:27:57] [RadarAPI]: Sending record command to DCA1000
[11:27:57]
[11:27:57] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[11:27:57] [RadarAPI]: Sending fpga_version command to DCA1000
[11:27:58] [RadarAPI]:
[11:27:58]
[11:27:58] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[11:27:58] Ethernet connection failed. [error -4051]
[11:28:04] [RadarAPI]:
[11:28:04] Configure Record :
[11:28:04] Timeout Error! System disconnected
[11:28:04] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[11:28:04] [RadarAPI]: Sending fpga_version command to DCA1000
[11:28:08] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 0, 1, 1, 1, 1, 2, 0, 0)
[11:28:09] [RadarAPI]: Status: Passed
[11:28:10] [RadarAPI]: ar1.LPModConfig(0, 0)
[11:28:10] [RadarAPI]: Status: Passed
[11:28:12] [RadarAPI]: ar1.RfInit()
[11:28:12] RF Init async event received!
[11:28:12] [RadarAPI]: Time stamp, Temperture: 37127,36; SynthVCO3 Status, Update: 0, 0; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 0, 0;
[11:28:12] [RadarAPI]: Status: Passed
[11:28:15] [RadarAPI]:
[11:28:15]
[11:28:15] Unable to read FPGA Version. [error -5]
[11:28:15]
[11:28:19] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[11:28:19] [RadarAPI]: Status: Passed
[11:28:25] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 2216755200, 0, 30, 0, 0, 0)
[11:28:25] [RadarAPI]: Status: Passed
[11:28:26] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 1, 0, 0)
[11:28:26] [RadarAPI]: Status: Passed
[11:28:27] Test Source Already Disabled...!!!
[11:28:27] [RadarAPI]: ar1.DisableTestSource(0)
[11:28:27] [RadarAPI]: Status: Passed
[11:28:27] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 1)
[11:28:28] [RadarAPI]: Status: Passed
[11:28:30] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("D:\\ti\\mmwave_studio_03_01_03_01\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[11:28:30] [RadarAPI]: Sending start_record command to DCA1000
[11:28:32] [RadarAPI]: ar1.StartFrame()
[11:28:32] [RadarAPI]: Status: Passed
[11:28:32] Frame start async event received!
[11:28:32] [RadarAPI]: Frame Ended
[11:28:41] [RadarAPI]:
[11:28:41] Frame End async event received!
[11:28:41] Start Record :
[11:28:41] Timeout Error! System disconnected
[11:28:41] [RadarAPI]: ar1.StartMatlabPostProc("D:\\ti\\mmwave_studio_03_01_03_01\\mmWaveStudio\\PostProc\\adc_data.bin")
[11:28:41] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 8
[11:28:41] Error : The number of files captured is zero!
[11:28:41] Error : The number of files captured [11:28:41] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 8
[11:28:50] [RadarAPI]: ar1.StartMatlabPostProc("D:\\ti\\mmwave_studio_03_01_03_01\\mmWaveStudio\\PostProc\\adc_data.bin")
[11:28:50] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 8
[11:28:50] Error : The number of files captured is zero!
[11:28:53] [RadarAPI]: ar1.StartMatlabPostProc("D:\\ti\\mmwave_studio_03_01_03_01\\mmWaveStudio\\PostProc\\adc_data.bin")
[11:28:53] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 8
[11:28:53] Error : The number of files captured is zero!
