Part Number: TDC1000-GASEVM
We cannot get the basic TDC1000-GASEVM to work through 4 inches of air. Thanks, Peter
PDF HAS PHOTOS OF TEST ATTEMPT www.lasso.com/.../LASSOULTRASONICSTEST.PDF
WE HAVE OTHER USONIC SENSORS BUT CANNOT EVEN GET THE OUT OF BOX TDC1000-GASEVM DEV SYSTEM TO WORK SO HAVE NOT TRIED OTHERS
WHY ALL OF THE RINGING? WE HAVE ADJUSTED REGISTERS AND READ MOST TI APP NOTES BUT NO IMPROVEMENTS.
COMP SIGNAL DOES NOT CHANGE AS SENSOR IS MOVED 1-4 INCHES FROM OBJECT. NO ECHO CAN BE SEEN, ONLY RINGING.
WILL THIS SIMPLY NOT WORK THROUGH SHORT AIR DISTANCES?
DO YOU HAVE ANY APP NOTES FOR 90KHZ OR OTHER FREQUENCIES TO ADJUST THE GAIN AMPLIFIERS ASSUMING WE GET THE BASICS TO WORK?
IS 2 METER SENSING THROUGH AIR FEASIBLE GIVEN THE PROPER SETUP, TRANSDUCERS, FREQUENCY OR EVEN SOUND GUIDE TUBE?
PLEASE FEEL FREE TO CALL ANY TIME. WE ARE A HEAVY USER OF OTHER TI PRODUCTS. THANKS
