Dear TI:
I Design a pcb used opt3101 and found xtalk offset too large compared with EVM board. doc.files
log.doc
readI2C: 88 , addr: 59, data: 18229
readI2C: 88 , addr: 60, data: ffd25a
readI2C: 88 , addr: 59, data: 181e1
iphase_xtalk: 18229, qphase_xtalk: ffd25a, iread: 181e1, qread: ffffd25a, mRead: 98785
c0: 16, small: 65536, big: 131072, xtalkScale: 2
(The laser tube is opened to cover the pd receiver tube, and the xtalk is large. )
Test process:1.Turn on the power, 2.Block pd,do measureAndCorrectInternalCrosstalk、measureIllumCrosstalk,3. remove pd obstacle,do measurePhaseOffset with a fixed distance。
The register read and write are all ok.
Can you give me some advise how to address the problem ? thanks
Dear Alex:
Residue crosstalk, maybe come from pcb layout, can you help to check on it. thanks
The current resistance-capacitance magnetic bead components are all purchased according to the reference version of bom.
The capacitor used is Murata. The pcb is an immersion gold process, and the laser emission module is purchased by a manufacturer specializing in laser ranging modules.
schematic:
pcb layout: 4-Layer
top layer:
Bottom layer:
GND Layer:
VCC Layer:
