Other Parts Discussed in Thread: MMWAVE-SDK
Hi teams,
I tried to test if the mmwave ROS driver works but it failed.
I already flash the mmw EVM with the latest version of the mmWave SDK (MMWAVE-SDK v03.02.00.04) demo.bin, and can see the point cloud data on the mmwave demo visualizer.
When I try to test if the mmwave ROS driver can work.
I follow the "TI mmWave ROS Driver Setup Guide" (http://dev.ti.com/tirex/explore/node?a=VLyFKFf__3.5.0&node=APnFgppJ1ocfjvSKlwZ-rg__VLyFKFf__LATEST)
I download the mmWave sensor toolbox(3.6.2) from TI resource explore.
Then I find the "ti_mmwave_rospkg" in labs/ autonomous_robotics_ros and put it in the workspace:
And try to launch the TI mmWave ROS node and Rviz visualizer:
but it failed.
Could you kindly help me to check if the mmw ROS driver package in the toolbox 3.6.3 is the right version?
Or the "TI mmWave ROS Driver Setup Guide" didn't up to date and give the wrong command in running the driver step.
Thanks and best regards,
Jamie
