I want to know IWR1443 output is temperature compensated or not. What is change in distance output of IWR1443 with temperature?
Akshay
Akshay
Hi Akshay,
IWR1443 device is temperature compensated. Is there a specific problem you are facing due to temperature?
Please find the below application note on "Self-Calibration in TI’s mmWave Radar Devices"
http://www.ti.com/lit/an/spracf4/spracf4.pdf
Thanks and regards,
CHETHAN KUMAR Y.B.
Hi Chethan,
Thanks for document. I found ~4 mm deviation in IWR1443 output (High accuracy FW) on increasing temperature to 70 deg C.
Akshay
Hi Akshay,
Are you using ES2.0 or ES3.0 Silicon?
Would you be able to support some data or plots to support your experiment?
Cheers,
Akash
