I have some questions about Rx noise performance of AWR1843.
I used AWR1843BOOST, DCA1000 and mmWave studio to monitor NF. I also have a custom board using AWR1843 chip and RO3003.
The custom board show NF degradation about 5dB. I’m looking for the reason and hope you can help.
The custom antenna is similar to your EVB and the transition is designed based on the http://www.ti.com/lit/an/spracg5/spracg5.pdf document.
The antenna S11 measurement shows <-15dB. The PMIC is the same with your EVB, the routing and bypass cap are similar.
I also checked reflection coefficient from TX Ball Break Monitoring and the results are -20.3, -15.1, -17.7 for 3 tx (EVB is -20.1, -24.9, -17.5).
I used the same antenna and transition for Tx and Rx.
The Tx spectrum shows 6dB higher PN inside 100kHz offset, above this offset frequency the PN is similar with EVB.
The config file, NF and gain results of center frequency is attached.
Please tell me if there is a possible reason for the degradation.
Is there any other parameter I should check?
Thank you!
<?xml version="1.0" encoding="utf-8" ?> <configuration> <apiname_channel_cfg> <param name="rx0En" value="1" /> <param name="tx0En" value="0" /> <param name="rx1En" value="1" /> <param name="cascadeMode" value="0" /> <param name="rx2En" value="1" /> <param name="tx2En" value="0" /> <param name="rx3En" value="1" /> <param name="tx1En" value="0" /> </apiname_channel_cfg> <apiname_adc_cfg> <param name="bitsVal" value="2" /> <param name="IQSwap" value="0" /> <param name="formatVal" value="2" /> </apiname_adc_cfg> <apiname_lp_cfg> <param name="lpAdcMode" value="0" /> </apiname_lp_cfg> <apiname_freqlimit_cfg> <param name="freqLimitLow" value="76.0" /> <param name="freqLimitHigh" value="81" /> </apiname_freqlimit_cfg> <apiname_rfldobypass_cfg> <param name="RFLdoByPass" value="0" /> </apiname_rfldobypass_cfg> <apiname_radarmisccontrol_cfg> <param name="PerChirpPhaseShiftEna" value="0" /> </apiname_radarmisccontrol_cfg> <apiname_calmonfreqtxpowlimit_cfg> <param name="freqLimitLowTx1" value="76.0" /> <param name="freqLimitHighTx2" value="81" /> <param name="freqLimitLowTx0" value="76.0" /> <param name="tx0PowerBackoff" value="0" /> <param name="tx1PowerBackoff" value="0" /> <param name="freqLimitHighTx0" value="81" /> <param name="tx2PowerBackoff" value="0" /> <param name="freqLimitLowTx2" value="76.0" /> <param name="freqLimitHighTx1" value="81" /> </apiname_calmonfreqtxpowlimit_cfg> <apiname_datapath_cfg> <param name="dataPathCfgPath" value="1" /> <param name="dataCfgFmt1" value="0" /> <param name="pkt0VChannelNo" value="0" /> <param name="pkt1VChannelNo" value="0" /> <param name="dataCfgFmt0" value="0" /> </apiname_datapath_cfg> <apiname_clock_cfg> <param name="dataRate" value="1" /> <param name="laneClock" value="1" /> </apiname_clock_cfg> <apiname_lvdslane_cfg> <param name="lane4En" value="0" /> <param name="lane2En" value="1" /> <param name="lane3En" value="0" /> <param name="lane1En" value="1" /> <param name="lvdsPacketEndPulse" value="0" /> <param name="lvdsCrcEn" value="0" /> <param name="laneFormat" value="0" /> <param name="lvdsMsbFirst" value="1" /> </apiname_lvdslane_cfg> <apiname_csi2lane_cfg> <param name="clockPol" value="0" /> <param name="lane1Pos" value="2" /> <param name="lane2Pos" value="4" /> <param name="lane2Pol" value="0" /> <param name="lane0Pos" value="1" /> <param name="lane0Pol" value="0" /> <param name="lane1Pol" value="0" /> <param name="lane3Pos" value="5" /> <param name="lane3Pol" value="0" /> <param name="clockPos" value="3" /> </apiname_csi2lane_cfg> <apiname_testpatterngen_cfg> <param name="testPatternRx3ICFGVal" value="0" /> <param name="testPatternPktSize" value="0" /> <param name="testPatternRx0ICFGStartOffset" value="0" /> <param name="numTestPatternPkts" value="0" /> <param name="testPatternRx1QCFGStartOffset" value="0" /> <param name="testPatternRx2QCFGVal" value="0" /> <param name="testPatternGenCtl" value="0" /> <param name="testPatternRx3QCFGStartOffset" value="0" /> <param name="testPatternRx0QCFGVal" value="0" /> <param name="testPatternRx3QCFGVal" value="0" /> <param name="testPatternRx2QCFGStartOffset" value="0" /> <param name="testPatternRx1QCFGVal" value="0" /> <param name="testPatternRx2ICFGVal" value="0" /> <param name="testPatternRx0QCFGStartOffset" value="0" /> <param name="testPatternRx1ICFGStartOffset" value="0" /> <param name="testPatternRx3ICFGStartOffset" value="0" /> <param name="testPatternGenTime" value="0" /> <param name="testPatternRx0ICFGVal" value="0" /> <param name="testPatternRx2ICFGStartOffset" value="0" /> <param name="testPatternRx1ICFGVal" value="0" /> </apiname_testpatterngen_cfg> <apiname_testsource_cfg> <param name="obj2PosY" value="327" /> <param name="obj1AntPosRx1X" value="0" /> <param name="obj2Sig" value="-95" /> <param name="obj1VelY" value="0" /> <param name="obj2VelZ" value="0" /> <param name="obj1PosZ" value="0" /> <param name="obj1PosY" value="3" /> <param name="obj2PosZ" value="0" /> <param name="obj1BMaxZ" value="327" /> <param name="obj1BMaxX" value="327" /> <param name="obj1BMaxY" value="327" /> <param name="obj1AntPosRx4Z" value="0" /> <param name="obj1AntPosRx2Z" value="0" /> <param name="obj1AntPosRx3Z" value="0" /> <param name="obj1AntPosRx1Z" value="0" /> <param name="obj1VelX" value="0" /> <param name="obj1AntPosRx3X" value="1" /> <param name="obj1PosX" value="4" /> <param name="obj2BMaxZ" value="327" /> <param name="obj2BMaxX" value="327" /> <param name="obj2BMaxY" value="327" /> <param name="obj1BMinZ" value="-327.6" /> <param name="obj1BMinX" value="-327.6" /> <param name="obj1BMinY" value="0" /> <param name="obj1AntPosTx2X" value="0" /> <param name="obj1AntPosTx3X" value="0" /> <param name="obj1Sig" value="-2.5" /> <param name="obj1AntPosTx1X" value="0" /> <param name="obj1VelZ" value="0" /> <param name="obj2VelX" value="0" /> <param name="obj2BMinZ" value="-327" /> <param name="obj2BMinX" value="-327" /> <param name="obj2BMinY" value="0" /> <param name="obj2PosX" value="327" /> <param name="obj1AntPosTx2Z" value="0" /> <param name="obj1AntPosTx3Z" value="0" /> <param name="obj2VelY" value="0" /> <param name="obj1AntPosTx1Z" value="0" /> <param name="obj1AntPosRx4X" value="1.5" /> <param name="obj1AntPosRx2X" value="0.5" /> </apiname_testsource_cfg> <apiname_profile_cfg> <param name="rampEndTime" value="120" /> <param name="tx1PhaseShifter" value="0" /> <param name="adcStartTimeConst" value="6" /> <param name="hpfCornerFreq1" value="0" /> <param name="freqSlopeConst" value="7.483" /> <param name="rxGain" value="30" /> <param name="numAdcSamples" value="256" /> <param name="tx1OutPowerBackoffCode" value="0" /> <param name="tx2OutPowerBackoffCode" value="0" /> <param name="pprofileId" value="0" /> <param name="tx3OutPowerBackoffCode" value="0" /> <param name="hpfCornerFreq2" value="0" /> <param name="txStartTime" value="0" /> <param name="tx2PhaseShifter" value="0" /> <param name="startFreqConst" value="75.9999999761582" /> <param name="retainRxCalLUT" value="0" /> <param name="vcoSelect" value="0" /> <param name="idleTimeConst" value="100" /> <param name="forceVCOSelect" value="0" /> <param name="tx3PhaseShifter" value="0" /> <param name="digOutSampleRate" value="10000" /> <param name="rfGainTarget" value="0" /> <param name="retainTxCalLUT" value="0" /> </apiname_profile_cfg> <apiname_chirp_cfg> <param name="startFreqVar" value="0" /> <param name="adcStartTimeVar" value="0" /> <param name="cprofileId" value="0" /> <param name="tx3Enable" value="0" /> <param name="tx2Enable" value="0" /> <param name="tx1Enable" value="0" /> <param name="freqSlopeVar" value="0" /> <param name="idleTimeVar" value="0" /> <param name="chirpEndIdx" value="0" /> <param name="chirpStartIdx" value="0" /> </apiname_chirp_cfg> <apiname_frame_cfg> <param name="frameCount" value="400" /> <param name="triggerSelect" value="0" /> <param name="triggerDelay" value="0" /> <param name="testSourceEn" value="0" /> <param name="loopCount" value="128" /> <param name="fchirpStartIdx" value="0" /> <param name="periodicity" value="40" /> <param name="fchirpEndIdx" value="0" /> </apiname_frame_cfg> <apiname_advanceframe_cfg> <param name="numOfSubFrames" value="1" /> <param name="sb3noOfAdcSamples" value="1" /> <param name="sb4subFramePeriod" value="40" /> <param name="sb3forceProfileIdx" value="0" /> <param name="sb1numOfBrust" value="1" /> <param name="sb2numOfLoops" value="128" /> <param name="sb4numOfLoops" value="128" /> <param name="loopBackCfg" value="0" /> <param name="sb4numOfBrust" value="1" /> <param name="sb1subFramePeriod" value="40" /> <param name="numOfFrames" value="0" /> <param name="sb3numOfBrustLoops" value="1" /> <param name="sb3chirpStartIdxOffset" value="0" /> <param name="sb2chirpStartIdx" value="0" /> <param name="sb3brustPeriodicity" value="40" /> <param name="sb2numOfBrust" value="1" /> <param name="sb2noOfAdcSamples" value="1" /> <param name="sb4noOfAdcSamples" value="1" /> <param name="sb1numOfChirps" value="1" /> <param name="sb4chirpStartIdx" value="0" /> <param name="sb4brustPeriodicity" value="40" /> <param name="sb1chirpStartIdxOffset" value="0" /> <param name="sb2chirpStartIdxOffset" value="0" /> <param name="softwareTrigger" value="1" /> <param name="sb3numOfBrust" value="1" /> <param name="sb3subFramePeriod" value="40" /> <param name="sb3chirpStartIdx" value="0" /> <param name="sb4numOfBrustLoops" value="1" /> <param name="sb1numOfBrustLoops" value="1" /> <param name="sb4forceProfileIdx" value="0" /> <param name="sb1brustPeriodicity" value="40" /> <param name="sb3numOfLoops" value="128" /> <param name="sb3numOfChirps" value="1" /> <param name="sb1forceProfileIdx" value="0" /> <param name="frameTriggerDelay" value="0" /> <param name="sb2numOfChirps" value="1" /> <param name="sb1chirpStartIdx" value="0" /> <param name="sb2numOfBrustLoops" value="1" /> <param name="sb2forceProfileIdx" value="0" /> <param name="sb2subFramePeriod" value="40" /> <param name="testSourceEn" value="0" /> <param name="forceProfileEna" value="0" /> <param name="sb4chirpStartIdxOffset" value="0" /> <param name="loopBackCfgSubFrameID" value="3" /> <param name="sb1noOfAdcSamples" value="1" /> <param name="sb4numOfChirps" value="1" /> <param name="sb2brustPeriodicity" value="40" /> <param name="sb1numOfLoops" value="128" /> <param name="hardwareTrigger" value="0" /> </apiname_advanceframe_cfg> <apiname_loopbackburst_cfg> <param name="digCorrRxGainPhase" value="0" /> <param name="iflLoopBackMag" value="2" /> <param name="rfGainTarget" value="0" /> <param name="psTx1LoopBackFreq" value="0" /> <param name="tx2En" value="0" /> <param name="digitalCorrDisable" value="0" /> <param name="tx2BackOff" value="0" /> <param name="loopBackSelect" value="0" /> <param name="tx0En" value="0" /> <param name="baseProfileIndex" value="0" /> <param name="ifLoopBackFreq" value="0" /> <param name="bpmTx1On" value="0" /> <param name="bpmTx2On" value="0" /> <param name="paLoopBackFreq" value="2" /> <param name="tx1En" value="0" /> <param name="psTx0LoopBackFreq" value="0" /> <param name="freqConst" value="77" /> <param name="ps2PGAGainIndex" value="23" /> <param name="busrtIndex" value="0" /> <param name="tx1BackOff" value="0" /> <param name="ps1PGAGainIndex" value="23" /> <param name="tx0BackOff" value="0" /> <param name="rxGain" value="30" /> <param name="bpmTx2Off" value="0" /> <param name="bpmTx0Off" value="0" /> <param name="slopeConst" value="0" /> <param name="bpmTx1Off" value="0" /> <param name="bpmTx0On" value="0" /> </apiname_loopbackburst_cfg> <apiname_analogmonenable_cfg> <param name="tx2BallBreakMonEna" value="0" /> <param name="rxNoiseMonEna" value="1" /> <param name="rxIFStageMonEna" value="1" /> <param name="reservedMonEna" value="0" /> <param name="tx0BPMMonEna" value="0" /> <param name="rxIFASaturationMonEna" value="0" /> <param name="internalGPADCSignalsMonEna" value="0" /> <param name="tx0BallBreakMonEna" value="0" /> <param name="synthFreqMonEna" value="0" /> <param name="internalTX0SignalsMonEna" value="0" /> <param name="rxGainPhaseMonEna" value="1" /> <param name="internalRXSignalsMonEna" value="0" /> <param name="tx1PowerMonEna" value="0" /> <param name="rxSigImgBandMonEna" value="0" /> <param name="temperatureMonEna" value="1" /> <param name="internalTX2SignalsMonEna" value="0" /> <param name="txGainPhaseMonEna" value="0" /> <param name="internalTX1SignalsMonEna" value="0" /> <param name="tx1BPMMonEna" value="0" /> <param name="tx2BPMMonEna" value="0" /> <param name="pllControlVolMonEna" value="0" /> <param name="tx0PowerMonEna" value="0" /> <param name="externalAnalogSignalsMonEna" value="0" /> <param name="tx2PowerMonEna" value="0" /> <param name="tx1BallBreakMonEna" value="0" /> <param name="rxMixerInputPowerMonEna" value="0" /> <param name="dccClockFreqMonEna" value="0" /> <param name="internalPMCLKLOSignalsMonEna" value="0" /> </apiname_analogmonenable_cfg> <apiname_tx0ballbreak_cfg> <param name="tx0ReflCoeffMagThreshold" value="-9" /> <param name="tx0BallBreakMonReportingMode" value="0" /> </apiname_tx0ballbreak_cfg> <apiname_tx1ballbreak_cfg> <param name="tx1BallBreakMonReportingMode" value="0" /> <param name="tx1ReflCoeffMagThreshold" value="-9" /> </apiname_tx1ballbreak_cfg> <apiname_tx2ballbreak_cfg> <param name="tx2BallBreakMonReportingMode" value="0" /> <param name="tx2ReflCoeffMagThreshold" value="0" /> </apiname_tx2ballbreak_cfg> <apiname_tx0powermon_cfg> <param name="tx0PowerRF2" value="1" /> <param name="tx0PwAbsErrThreshold" value="1" /> <param name="tx0PowerReportingMode" value="0" /> <param name="tx0PwFlatnessThreshold" value="0" /> <param name="tx0PwrMonProfileIndex" value="0" /> <param name="tx0PowerRF3" value="1" /> <param name="tx0PowerRF1" value="1" /> </apiname_tx0powermon_cfg> <apiname_tx1powermon_cfg> <param name="tx1PowerReportingMode" value="0" /> <param name="tx1PwrMonProfileIndex" value="0" /> <param name="tx1PwFlatnessThreshold" value="0" /> <param name="tx1PowerRF1" value="1" /> <param name="tx1PowerRF2" value="1" /> <param name="tx1PwAbsErrThreshold" value="1" /> <param name="tx1PowerRF3" value="1" /> </apiname_tx1powermon_cfg> <apiname_tx2powermon_cfg> <param name="tx2PwAbsErrThreshold" value="1" /> <param name="tx2PwFlatnessThreshold" value="0" /> <param name="tx2PowerRF3" value="1" /> <param name="tx2PwrMonProfileIndex" value="0" /> <param name="tx2PowerRF2" value="1" /> <param name="tx2PowerReportingMode" value="0" /> <param name="tx2PowerRF1" value="1" /> </apiname_tx2powermon_cfg> <apiname_tx0bpmmon_cfg> <param name="tx0BPMPhaseMonErrorThreshold" value="0" /> <param name="tx0BPMPhaseMonReportMode" value="0" /> <param name="tx0BPMMonRx2" value="1" /> <param name="tx0BPMMonRx0" value="1" /> <param name="tx0BPMMonRx3" value="1" /> <param name="tx0BPMMonRx1" value="1" /> <param name="tx0BPMPhaseMonProfileIndex" value="0" /> <param name="tx0BPMAmplitudeMonErrorThreshold" value="0" /> </apiname_tx0bpmmon_cfg> <apiname_tx1bpmmon_cfg> <param name="tx1BPMMonRx3" value="1" /> <param name="tx1BPMMonRx1" value="1" /> <param name="tx1BPMPhaseMonProfileIndex" value="0" /> <param name="tx1BPMAmplitudeMonErrorThreshold" value="0" /> <param name="tx1BPMPhaseMonReportMode" value="0" /> <param name="tx1BPMMonRx2" value="1" /> <param name="tx1BPMMonRx0" value="1" /> <param name="tx1BPMPhaseMonErrorThreshold" value="0" /> </apiname_tx1bpmmon_cfg> <apiname_tx2bpmmon_cfg> <param name="tx2BPMPhaseMonErrorThreshold" value="0" /> <param name="tx2BPMPhaseMonReportMode" value="0" /> <param name="tx2BPMMonRx1" value="1" /> <param name="tx2BPMPhaseMonProfileIndex" value="0" /> <param name="tx2BPMMonRx3" value="1" /> <param name="tx2BPMMonRx2" value="1" /> <param name="tx2BPMMonRx0" value="1" /> <param name="tx2BPMAmplitudeMonErrorThreshold" value="0" /> </apiname_tx2bpmmon_cfg> <apiname_txgainphasemismatchmon_cfg> <param name="rf3TX2TXGainPhaseMismatchOffVal" value="0" /> <param name="txGainPhaseMismatchMonRx3" value="1" /> <param name="txGainPhaseMismatchMonRx2" value="1" /> <param name="txGainPhaseMismatchMonRx1" value="1" /> <param name="txGainPhaseMismatchMonRx0" value="1" /> <param name="rf3TX2TXPhaseMismatchOffVal" value="0" /> <param name="rf2TX2TXGainPhaseMismatchOffVal" value="0" /> <param name="rf1TX1TXGainPhaseMismatchOffVal" value="0" /> <param name="rf2TX2TXPhaseMismatchOffVal" value="0" /> <param name="txGainPhaseMismacthMonTxPhaseMismatchThreshold" value="0" /> <param name="rf1TX0TXPhaseMismatchOffVal" value="0" /> <param name="rf2TXGainPhaseMismatchMonBitMask" value="1" /> <param name="txGainPhaseMismacthMonTxGainMismatchThreshold" value="0" /> <param name="rf1TX1TXPhaseMismatchOffVal" value="0" /> <param name="rf2TX0TXGainPhaseMismatchOffVal" value="0" /> <param name="rf3TXGainPhaseMismatchMonBitMask" value="1" /> <param name="rf3TX1TXGainPhaseMismatchOffVal" value="0" /> <param name="rf3TX1TXPhaseMismatchOffVal" value="0" /> <param name="rf2TX1TXPhaseMismatchOffVal" value="0" /> <param name="rf2TX1TXGainPhaseMismatchOffVal" value="0" /> <param name="rf1TX2TXGainPhaseMismatchOffVal" value="0" /> <param name="rf3TX0TXPhaseMismatchOffVal" value="0" /> <param name="rf1TXGainPhaseMismatchMonBitMask" value="1" /> <param name="rf1TX2TXPhaseMismatchOffVal" value="0" /> <param name="rf3TX0TXGainPhaseMismatchOffVal" value="0" /> <param name="txGainPhaseMismacthMonReportingMode" value="0" /> <param name="tx1GainPhaseMismatchMon" value="0" /> <param name="tx0GainPhaseMismatchMon" value="0" /> <param name="txGainPhaseMismacthMonProfileIndex" value="0" /> <param name="tx2GainPhaseMismatchMon" value="0" /> <param name="rf2TX0TXPhaseMismatchOffVal" value="0" /> <param name="rf1TX0TXGainPhaseMismatchOffVal" value="0" /> </apiname_txgainphasemismatchmon_cfg> <apiname_analogfaultinjection_cfg> <param name="rxIFStageRx2" value="0" /> <param name="txGainInvTx2BPMVal" value="0" /> <param name="rxPhaseInvRx0" value="0" /> <param name="rxLOAmpRx2Rx3" value="0" /> <param name="txGainInvTx1BPMVal" value="0" /> <param name="rxHighNoiseRx2" value="0" /> <param name="rxHighNoiseRx1" value="0" /> <param name="txLOAmpTx2" value="0" /> <param name="ldoRxLODistFault" value="0" /> <param name="rxPhaseInvRx2" value="0" /> <param name="rxGainDropRx1" value="0" /> <param name="rxGainDropRx0" value="0" /> <param name="rxHighNoiseRx3" value="0" /> <param name="gpadcIntSigMon" value="0" /> <param name="txGainInvTxFault" value="0" /> <param name="rxGainDropRx3" value="0" /> <param name="txLOAmpTx0Tx1" value="0" /> <param name="txGainInvTx0BPMVal" value="0" /> <param name="txGainDropTx1" value="0" /> <param name="txGainDropTx0" value="0" /> <param name="rxIFStageRx1" value="0" /> <param name="txGainDropTx2" value="0" /> <param name="rxGainDropRx2" value="0" /> <param name="rxIFStageRx3" value="0" /> <param name="rxLOAmpRx0Rx1" value="0" /> <param name="synthFreqMonOffset" value="0" /> <param name="rxHighNoiseRx0" value="0" /> <param name="rxIFStageRx0" value="0" /> <param name="synthVCOOpenLoop" value="0" /> <param name="extAnaSigMon" value="0" /> <param name="rxPhaseInvRx1" value="0" /> <param name="gpadcClkFreqFault" value="0" /> <param name="rxPhaseInvRx3" value="0" /> </apiname_analogfaultinjection_cfg> <apiname_rxgainphasemon_cfg> <param name="rf3RX0RXPhaseMismatchOffVal" value="0" /> <param name="rf3RX1RXPhaseMismatchOffVal" value="0" /> <param name="rf3RX2RXGainMismatchOffVal" value="0" /> <param name="rf2RX3RXGainMismatchOffVal" value="0" /> <param name="rxGainPhaseReprotingMode" value="0" /> <param name="rf1RX3RXGainMismatchOffVal" value="0" /> <param name="rf1RX2RXPhaseMismatchOffVal" value="0" /> <param name="rf2RX1RXGainMismatchOffVal" value="0" /> <param name="rxPhaseMismatchThreshold" value="0" /> <param name="rf1RX1RXGainMismatchOffVal" value="0" /> <param name="rf2RX2RXPhaseMismatchOffVal" value="0" /> <param name="rf2RX3RXPhaseMismatchOffVal" value="0" /> <param name="rf2RX2RXGainMismatchOffVal" value="0" /> <param name="rf2RX0RXGainMismatchOffVal" value="0" /> <param name="rf2RXGainPhaseMonBitMask" value="1" /> <param name="rf1RX0RXGainMismatchOffVal" value="0" /> <param name="rf1RXGainPhaseMonBitMask" value="1" /> <param name="rxGainFlatnessErrThreshold" value="0" /> <param name="rxGainMismatchThresholds" value="0" /> <param name="rf1RX0RXPhaseMismatchOffVal" value="0" /> <param name="rf3RX2RXPhaseMismatchOffVal" value="0" /> <param name="rf1RX2RXGainMismatchOffVal" value="0" /> <param name="rf1RX1RXPhaseMismatchOffVal" value="0" /> <param name="rf3RX3RXPhaseMismatchOffVal" value="0" /> <param name="rf3RX3RXGainMismatchOffVal" value="0" /> <param name="rf2RX0RXPhaseMismatchOffVal" value="0" /> <param name="rf2RX1RXPhaseMismatchOffVal" value="0" /> <param name="rxGainPhaseMonTxSelect" value="0" /> <param name="rxGainPhaseMonProfileIndex" value="0" /> <param name="rf3RX0RXGainMismatchOffVal" value="0" /> <param name="rxGainPhaseAbsErrThreshold" value="0" /> <param name="rf3RXGainPhaseMonBitMask" value="1" /> <param name="rf1RX3RXPhaseMismatchOffVal" value="0" /> <param name="rf3RX1RXGainMismatchOffVal" value="0" /> </apiname_rxgainphasemon_cfg> <apiname_rxnoisefiguremon_cfg> <param name="rf1RXNoiseMon" value="1" /> <param name="rxNoiseFigureThreshold" value="0" /> <param name="rf3RXNoiseMon" value="1" /> <param name="rf2RXNoiseMon" value="1" /> <param name="rxNoiseFigureReportingMode" value="0" /> <param name="rxNoiseMonProfileIndex" value="0" /> </apiname_rxnoisefiguremon_cfg> <apiname_rxifstagemon_cfg> <param name="rxIFStageReportingMode" value="0" /> <param name="rxIFStageMonProfileIndex" value="0" /> <param name="rxIFStageLPFCuttoffFreqErrThreshold" value="0" /> <param name="rxIFStageHPFCuttoffFreqErrThreshold" value="0" /> <param name="rxIFStageIFAGainErrThreshold" value="0" /> </apiname_rxifstagemon_cfg> <apiname_rxsaturationdetectormon_cfg> <param name="rxSatDetectorMonSatMonNumSlice" value="63" /> <param name="rxSatDetectorSatMonSelect" value="1" /> <param name="rxSatDetectorMonSatMonRxChannelMask" value="0" /> <param name="rxSatDetectorMonPriTimeSliceDuration" value="0.800000011920929" /> <param name="rxSatDetectorMonProfileIndex" value="0" /> </apiname_rxsaturationdetectormon_cfg> <apiname_rxsignalandimagemon_cfg> <param name="sigImgMonNumSlice" value="63" /> <param name="sigImgMonPriTimeSliceNumSamples" value="8" /> <param name="sigImgMonProfileIndex" value="0" /> </apiname_rxsignalandimagemon_cfg> <apiname_rxmixerinputpowermon_cfg> <param name="rxMixerIpPowMonMinThresholds" value="0" /> <param name="rxMixerIpPowMonProfielIdnex" value="0" /> <param name="rxMixerIpPowMonMaxThresholds" value="0" /> <param name="rxMixerIpPowMonReportingMode" value="0" /> <param name="rxMixerIpPowMonTx2Ena" value="0" /> <param name="rxMixerIpPowMonTx0Ena" value="0" /> <param name="rxMixerIpPowMonTx1Ena" value="0" /> </apiname_rxmixerinputpowermon_cfg> <apiname_rxtemperaturemon_cfg> <param name="tempMonTempDiffThresh" value="0" /> <param name="tempMonDigTempThreshMin" value="0" /> <param name="tempMonDigTempThreshMax" value="0" /> <param name="tempMonAnaTempThreshMax" value="0" /> <param name="tempMonAnaTempThreshMin" value="0" /> <param name="tempMonReportingMode" value="0" /> </apiname_rxtemperaturemon_cfg> <apiname_rxsynthfreqerrormon_cfg> <param name="synthFrequencyMonStartTime" value="2.0" /> <param name="synthFrequencyMonReportingMode" value="0" /> <param name="synthFrequencyProfileIndex" value="0" /> <param name="synthFrequencyMonFreqErrorThreshold" value="4000" /> </apiname_rxsynthfreqerrormon_cfg> <apiname_rxextanalogsignalmon_cfg> <param name="extAnalogSigMonSigIPEnaAnaTest4" value="0" /> <param name="extAnalogSigMonSigThresholdMinAnaTest3" value="0" /> <param name="extAnalogSigMonSigThresholdMaxAnaTest2" value="0" /> <param name="extAnalogSigMonSigSettlingTimeAnaTest4" value="0" /> <param name="extAnalogSigMonSigBufEnaAnaTest2" value="0" /> <param name="extAnalogSigMonSigThresholdMaxAnaVSense" value="0" /> <param name="extAnalogSigMonSigThresholdMinAnaTest4" value="0" /> <param name="extAnalogSigMonSigThresholdMinAnaVSense" value="0" /> <param name="extAnalogSigMonSigSettlingTimeAnaVSense" value="0" /> <param name="extAnalogSigMonSigSettlingTimeAnaTest2" value="0" /> <param name="extAnalogSigMonSigBufEnaAnaTest3" value="0" /> <param name="extAnalogSigMonSigThresholdMaxAnaMux" value="0" /> <param name="extAnalogSigMonSigBufEnaAnaMux" value="0" /> <param name="extAnalogSigMonSigThresholdMaxAnaTest4" value="0" /> <param name="extAnalogSigMonSigThresholdMinAnaTest2" value="0" /> <param name="extAnalogSigMonSigThresholdMaxAnaTest1" value="0" /> <param name="extAnalogSigMonSigThresholdMinAnaMux" value="0" /> <param name="extAnalogSigMonReportingMode" value="0" /> <param name="extAnalogSigMonSigBufEnaAnaTest4" value="0" /> <param name="extAnalogSigMonSigSettlingTimeAnaTest3" value="0" /> <param name="extAnalogSigMonSigSettlingTimeAnaMux" value="0" /> <param name="extAnalogSigMonSigIPEnaAnaTest3" value="0" /> <param name="extAnalogSigMonSigBufEnaAnaTest1" value="0" /> <param name="extAnalogSigMonSigThresholdMaxAnaTest3" value="0" /> <param name="extAnalogSigMonSigIPEnaVSense" value="0" /> <param name="extAnalogSigMonSigIPEnaAnaMux" value="0" /> <param name="extAnalogSigMonSigIPEnaAnaTest1" value="0" /> <param name="extAnalogSigMonSigIPEnaAnaTest2" value="0" /> <param name="extAnalogSigMonSigSettlingTimeAnaTest1" value="0" /> <param name="extAnalogSigMonSigThresholdMinAnaTest1" value="0" /> </apiname_rxextanalogsignalmon_cfg> <apiname_tx0intanalogsignalmon_cfg> <param name="tx0IntAnalogSigMonReportingMode" value="0" /> <param name="tx0IntAnalogSigMonProfileIndex" value="0" /> </apiname_tx0intanalogsignalmon_cfg> <apiname_tx1intanalogsignalmon_cfg> <param name="tx1IntAnalogSigMonReportingMode" value="0" /> <param name="tx1IntAnalogSigMonProfileIndex" value="0" /> </apiname_tx1intanalogsignalmon_cfg> <apiname_tx2intanalogsignalmon_cfg> <param name="tx2IntAnalogSigMonReportingMode" value="0" /> <param name="tx2IntAnalogSigMonProfileIndex" value="0" /> </apiname_tx2intanalogsignalmon_cfg> <apiname_rxintanalogsignalmon_cfg> <param name="rxIntAnalogSigMonProfileIndex" value="0" /> <param name="rxIntAnalogSigMonReportingMode" value="0" /> </apiname_rxintanalogsignalmon_cfg> <apiname_pmclklointanalogsignalmon_cfg> <param name="pmCLKLOIntAnalogSigMonReportingMode" value="0" /> <param name="pmCLKLOIntAnalogSigMonProfileIndex" value="0" /> </apiname_pmclklointanalogsignalmon_cfg> <apiname_gpadcintanalogsignalmon_cfg> <param name="gpadcIntAnalogSigMonReportingMode" value="0" /> </apiname_gpadcintanalogsignalmon_cfg> <apiname_pllcontrolvoltagemon_cfg> <param name="pllCtlVolMonSynthVCO2VolControl" value="0" /> <param name="pllCtlVolMonReportingMode" value="0" /> <param name="pllCtlVolMonSynthVCO1VolControl" value="0" /> <param name="pllCtlVolMonAPLLVctl" value="0" /> </apiname_pllcontrolvoltagemon_cfg> <apiname_dccmon_cfg> <param name="dccMonClockPair4" value="0" /> <param name="dccMonClockPair0" value="0" /> <param name="dccMonClockPair5" value="0" /> <param name="dccMonReportingMode" value="0" /> <param name="dccMonClockPair1" value="0" /> <param name="dccMonClockPair3" value="0" /> <param name="dccMonClockPair2" value="0" /> </apiname_dccmon_cfg> </configuration>
