Hello, Could I used the FDC2212 this way? Two channels connect to the same two plates. Now the LC result in a 6.5M oscillation, but I want to get a frequency between 300k and 1M, which value of LC do you
recommend? And I want to use fdc2212 two channels one is 6.5M and the other is between 300k and 1M, but they both connect to the same two plates. Because currently my sensor is sensitive to different frequency
field for different parameters, so I want to use it this way. Is it feasible or not? thank you for your reply.
