Can the TMP100-Q1 SCL and SDA pins be pulled up to a voltage lower than the V+ chip supply pin? Section 9.2.1 of the datasheet mentions "The SCL, SDA, and ALERT lines can be pulled up to a supply that is equal to or higher than VS through the pullup resistors.", but not if there is a lower limit for the SCL and SDA pull up voltages.
