Hope that you are well and good.
I would like to measure inductive signal direct from steel rebar or H beam without using additional spring attached.
Is it necessary to wind the coil directly on the reinforcing steel bar diameter 19mm or H beam in order to obtain the inductive signal?
Otherwise Should a large size coil be attached?
R S YOUN
