Connection of TS3USB221E
Other Parts Discussed in Thread: TS3USB221E
Can TS3USB221ERSER use like a attached schematic?
I am concerned that datasheet is wrote different connection.
Please let me know if you have any problem.
Best regards
Manabu ItoConnection image(TS3USB221E).pptx
  • Hello Manabu,
    In terms of the peripherals attached to the TS3USB221E, I do not see an issue with the way the TS3USB221E is used. I did notice in your picture that PCA USB Host is connected to 1D+ and 1D+. This should instead be 1D+ and 1D-. This applied to the USB connector (Device) as well, where in the picture it is connected to D+ and D+. This should instead be D+ and D-.
    The corrections can be seen in this picture:
    Can you identify the part of the datasheet that has you concerned with the connections?
    Thank you,
    Jared
