I need a switch to multiplex UART to 4 sensors
Other Parts Discussed in Thread: CD74HC4052
I am trying to multiplex 4 sensors using UART communication to an Arduino Serial input. I only need to communicate with one serial device at a time and need to be able to select which device to communicate with. The devices are operating at a buad rate of 9600.
I was suggested to use a CD74HC4052 HIgh-Speed CMOS Differential Multiplexer/Demultiplexer. Would this chip meet my needs or should I use another one?
  • Matt,
    When selecting an appropriate signal switch for your application you need to consider 3 things : Configuration, Bandwidth, and voltage range.
    Based on your application description we can determine the answer to these questions:
    Configuration: 2 channel (1 for Tx and 1 for Rx) 1:4 mux
    Bandwidth: 9600 baud (which means you need a switch with > 15kHz)
    voltage range:  0 - 5 V ( I think this is Arduio's voltage range)
    The CD74HC4052 device is a 2 channel 1:4 mux, 165 MHz, and  +/-6 V which will meet your requirements
    Thank you,
    Adam
