Other Parts Discussed in Thread: MCU-PLUS-SDK-AM263X
I think this is a CCS problem rather than an SDK problem.
I'm using MCU-PLUS-SDK-AM263X, CCS 12.1 and imported the following example: C:\ti\mcu_plus_sdk_am263x_08_05_00_24\examples\drivers\ipc\ipc_notify_echo\am263x-cc\system_freertos_nortos
I can build and rebuild at will until I assign the projects to the core in the System Settings:
Rebuild results in "Nothing to be done".
Clean does nothing also.
If I remove the assignment with the 'Remove' button everything works as it should.
