When I launch Code Composer from the terminal with /opt/ti/ccsv5/eclipse/eclipse the SDK launches but in the terminal I see flxInitLoad:client has not been protected.
I have a working msp430 compiler is this a problem. Sorry I should add that I am running this on gentoo Linux.
Hi Glendon,
could you please provide a bit more information/background?
Do you have all dependancies and permissions installed? Are you looking to work the the MSP430 and CCS in Linux? This is currently only supported with the v5.2 beta, not 5.1.1.. What msp430 setup do you have? Might be good to know, even if it is not likely this is the issue.
Unfortunately we can not test every single variant, however I would like to try and help you.
What gentoo version?
Lisa
Hi Glendon,
just thought I would check whether there is any update to your enquiry or whether you could provide a bit more info should you still require assistance.
Lisa
