Good Morning,
I am using CCS V5.2.
I am getting the following errors in the cmd error with the library Flash2808_API_V302
"Flash28_API:
Flash2808_API_V302.lib(.econst) ->Error 10008-D "Cannot find file "Flash2808_API_V302.lib"
Flash2808_API_V302.lib(.text) ->Error 10008-D "Cannot find file "Flash2808_API_V302.lib"
I have also some warning "#16002-D build attribute vendor section TI missin in "
Our code was working with CCS3.3.
Hi Stephane,
it appears CCS can not find the library. This is added in the linkers file search path option as described here
http://processors.wiki.ti.com/index.php/Include_paths_and_options
It is unfortunately known that include paths and variable sometimes need adding and/or correcting when migrating versions.
I hope this helps and please keep us informed.
Lisa
Hi Lisa,
All the paths are correct. Do you have an other idea?
Best Regards.
Stephane
Please post your CCS build log file.
Also, please ensure the linker include paths have a directory path to the Flash2808_API_V302.lib file. If not, this needs to be corrected.
I am referencing the Linker, not the C compiler.
hi,
here is the log file. the linker include path have the right directory
Regards.
Stephane
**** Build of configuration Release for project conexAGabsolu **** C:\ti\ccsv5\utils\bin\gmake -k all 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conex.tcf' 'Invoking: TConf' "C:/ti/xdctools_3_23_03_53/tconf" -b -Dconfig.importPath="C:/ti/bios_5_41_13_42/packages;" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conex.tcf" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conex.tcf' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_CodeStartBranch.asm' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="DSP280x_CodeStartBranch.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_CodeStartBranch.asm" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_CodeStartBranch.asm' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_CpuTimers.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="DSP280x_CpuTimers.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_CpuTimers.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_CpuTimers.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_DBGIER.asm' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="DSP280x_DBGIER.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_DBGIER.asm" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_DBGIER.asm' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_DefaultIsr.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="DSP280x_DefaultIsr.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_DefaultIsr.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_DefaultIsr.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_GlobalVariableDefs.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="DSP280x_GlobalVariableDefs.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_GlobalVariableDefs.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_GlobalVariableDefs.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_usDelay.asm' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="DSP280x_usDelay.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_usDelay.asm" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/DSP280x_usDelay.asm' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Fctstand.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="Fctstand.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Fctstand.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Fctstand.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Gpio.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="Gpio.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Gpio.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Gpio.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/PieCtrl_BIOS.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="PieCtrl_BIOS.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/PieCtrl_BIOS.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/PieCtrl_BIOS.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp2.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="Stdgrp2.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp2.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp2.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp4.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="Stdgrp4.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp4.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp4.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp6.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="Stdgrp6.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp6.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Stdgrp6.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/SysCtrl.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="SysCtrl.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/SysCtrl.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/SysCtrl.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Uart.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="Uart.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Uart.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/Uart.c' ' ' 'Building file: conexcfg.s??' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="conexcfg.pp" "conexcfg.s??" 'Finished building: conexcfg.s??' ' ' 'Building file: conexcfg_c.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="conexcfg_c.pp" "conexcfg_c.c" 'Finished building: conexcfg_c.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/corrector.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="corrector.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/corrector.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/corrector.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/divers.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="divers.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/divers.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/divers.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/fifo.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="fifo.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/fifo.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/fifo.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/global.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="global.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/global.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/global.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/io.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="io.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/io.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/io.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/it.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="it.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/it.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/it.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/main.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="main.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/main.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/main.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/parametres.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="parametres.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/parametres.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/parametres.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/utils.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="utils.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/utils.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/utils.c' ' ' 'Building file: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/watch.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --include_path="C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../include/DSP280x_headers" --include_path="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/Release" --include_path="C:/ti/bios_5_41_13_42/packages/ti/bios/include" --include_path="C:/ti/bios_5_41_13_42/packages/ti/rtdx/include/c2000" --include_path="C:/ti/xdais_7_21_01_07/packages/ti/xdais" --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --preproc_with_compile --preproc_dependency="watch.pp" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/watch.c" 'Finished building: C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/src/watch.c' ' ' 'Building target: Distribution/conexAGabs.out' 'Invoking: C2000 Linker' "C:/ti/ccsv5/tools/compiler/c2000_6.1.0/bin/cl2000" -v28 -ml -O2 --define="LARGE_MODEL" --display_error_number --diag_wrap=off --temp_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" --obj_directory="C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../Release" -z -m"C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../../Distribution/conexAGabs.map" --warn_sections -i"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/lib" -i"C:/ti/ccsv5/tools/compiler/c2000_6.1.0/include" -i"C:/ti/bios_5_41_13_42/packages/ti/rtdx/lib/c2000" -i"C:/ti/bios_5_41_13_42/packages/ti/bios/lib" -i"C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu" -i"C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../projects" -i"C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/conexAGabsolu/../../lib" --reread_libs --display_error_number --diag_suppress=16002 --diag_wrap=off --rom_model -o "Distribution/conexAGabs.out" -l"./conexcfg.cmd" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/f2808_BIOS_flash.cmd" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/DSP280x_Headers_BIOS.cmd" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/watch.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/utils.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/parametres.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/main.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/it.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/io.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/global.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/fifo.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/divers.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/corrector.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/conexcfg_c.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/conexcfg.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/Uart.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/SysCtrl.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/Stdgrp6.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/Stdgrp4.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/Stdgrp2.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/PieCtrl_BIOS.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/Gpio.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/Fctstand.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/DSP280x_usDelay.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/DSP280x_GlobalVariableDefs.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/DSP280x_DefaultIsr.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/DSP280x_DBGIER.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/DSP280x_CpuTimers.obj" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/Release/DSP280x_CodeStartBranch.obj" -l"C:\pvcs\firmware_CCS\Mini AG Absolu conex\Firmware\Programme\Sources\projects\Flash2808_API_V302.lib" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/Flash2808_API_V302.lib" <Linking> "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/f2808_BIOS_flash.cmd", line 21: error #10008-D: cannot find file "Flash2808_API_V302.lib" "C:/pvcs/firmware_CCS/Mini AG Absolu conex/Firmware/Programme/Sources/projects/f2808_BIOS_flash.cmd", line 22: error #10008-D: cannot find file "Flash2808_API_V302.lib" error #10010: errors encountered during linking; "Distribution/conexAGabs.out" not built >> Compilation failure gmake: *** [Distribution/conexAGabs.out] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished ****
hi brandon,
here is the log file. the linker include path have the right directory.
We use an trail version of CCS5.2.
Regards.
Stephane
Thanks for the log file. This may have obfuscated what I needed to see, so let's take a slightly different approach.
What does your CCS project build settings look like?
When I have included libraries, there are specific areas in the CCS project build settings for the linker to 1) name the filename which is the library intended and 2) describe the path to find it.
