Hi there.
Is there a shortcut to build current highlighted sourcefile in CCS?
Otherwise it would be appreciated if you'd implement it ctrl+shift+B for example.
BR; Carsten
HI Carsten,
Have you checked Window->preferences->general->keys? You can change it but build should be CTRL+B.
Lisa
Hi Lisa.
I'd like it for the current highlighted file (single one). That would improve build iterations.
BR, Carsten
Hi Carsten,
I suspect this might be something lacking in eclipse. You can right click on a file and build it, but that command does not seem to be listed in the keys section so it appears a binding is not possible.
Sorry for the inconvenience. I would post your suggestion to the eclipse community.
Lisa
Hi Carsten,
you too. Unfortunate I agree. Hopefully it is something that the community can add in.
Lisa
