The installation of Eclipse appears to be missing something. I have uninstalled everything and re-installed the code composer application but the Eclipse that is bundled with the download fails to start. I have a 64 bit version of Eclipse Luna running on my Windows 7 machine and it works fine.
The crash log is attached:
!SESSION 2015-11-07 22:15:42.880 -----------------------------------------------
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.7.0_60
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 4 0 2015-11-07 22:16:34.345
!MESSAGE path=ccs_base/DebugServer
!ENTRY com.ti.common.core 4 0 2015-11-07 22:16:34.347
!MESSAGE debugServerDir=H:/ccsv6/ccs_base/DebugServer
!ENTRY org.eclipse.equinox.event 4 0 2015-11-07 22:16:37.085
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@1be2c27
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:210)
at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:145)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:190)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:564)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:758)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:85)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1480)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1453)
at com.ti.ccstudio.debug.ui.licensing.LicenseMonitor.addStatusBar(LicenseMonitor.java:449)
at com.ti.ccstudio.debug.ui.licensing.LicenseStatusBar.fill(LicenseStatusBar.java:52)
at com.ti.ccstudio.debug.ui.targetStatus.statusBar.CCSStatusBar.createControl(CCSStatusBar.java:39)
at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:105)
at org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(CompatibilityWorkbenchWindowControlContribution.java:90)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:271)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:107)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:50)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(ToolControlContribution.java:65)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:101)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:365)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$3.handleEvent(ToolBarManagerRenderer.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:345)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(ToolBarContributionRecord.java:73)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$10.changed(ToolBarManagerRenderer.java:510)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:110)
at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:319)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(ToolBarManagerRenderer.java:502)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(ToolBarManagerRenderer.java:471)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(ToolBarManagerRenderer.java:430)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(ToolBarManagerRenderer.java:391)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.handleEvent(PartRenderingEngine.java:289)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:341)
at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(ContributionsAnalyzer.java:369)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(TrimBarRenderer.java:194)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:166)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:531)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:687)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1074)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.IllegalArgumentException:
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:142)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:309)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:295)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getActivePerspective(ModelServiceImpl.java:815)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:670)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:645)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:359)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
... 147 more
!SESSION 2015-11-07 22:17:05.766 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 22:17:10.870
!ENTRY com.ti.common.core 4 0 2015-11-07 22:17:10.874
!SESSION 2015-11-07 22:19:18.421 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 22:19:25.549
!ENTRY com.ti.common.core 4 0 2015-11-07 22:19:25.552
!SESSION 2015-11-07 22:19:44.640 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 22:19:59.057
!ENTRY com.ti.common.core 4 0 2015-11-07 22:19:59.058
!SESSION 2015-11-07 22:29:37.615 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 22:29:56.124
!ENTRY com.ti.common.core 4 0 2015-11-07 22:29:56.128
!SESSION 2015-11-07 22:38:22.541 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 22:38:26.865
!ENTRY com.ti.common.core 4 0 2015-11-07 22:38:26.866
!SESSION 2015-11-07 23:14:56.720 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 23:15:04.880
!ENTRY com.ti.common.core 4 0 2015-11-07 23:15:04.881
!SESSION 2015-11-07 23:23:37.308 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 23:23:48.265
!ENTRY com.ti.common.core 4 0 2015-11-07 23:23:48.268
!SESSION 2015-11-07 23:27:21.647 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 23:27:30.523
!ENTRY com.ti.common.core 4 0 2015-11-07 23:27:30.524
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2015-11-07 23:27:33.299
!MESSAGE No repository found at file:/H:/ccsv6/eclipse_orig/.eclipseextension.
!SESSION 2015-11-07 23:32:48.000 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 23:32:58.843
!ENTRY com.ti.common.core 4 0 2015-11-07 23:32:58.847
!SESSION 2015-11-07 23:35:05.852 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 23:35:10.014
!ENTRY com.ti.common.core 4 0 2015-11-07 23:35:10.015
!SESSION 2015-11-07 23:43:59.257 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-07 23:44:03.233
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2015-11-07 23:44:06.289
!SESSION 2015-11-08 11:40:39.844 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2015-11-08 11:42:02.978
!ENTRY com.ti.common.core 4 0 2015-11-08 11:42:02.982
I have the solution.
I had to uninstall Code composer and the control suite.
Then I downloaded a clean copy of both and installed again.
The Code Composer Studio will now launch.
